WirenBoard 7.3.3 5.10.35-wb147 нет подключения к WEB UI
WirenBoard стоит в тест стенде и включен круглосуточно. После выходных при попытке открыть страницу в браузере WIrenBoard пишет не удалось подключится (IP):18883. Доступ по SSH есть.
Перезагрузка не помогает.
Вот из консоли
root@wirenboard-A**********:~# systemctl status mosquitto.service
● mosquitto.service - Mosquitto MQTT Broker
     Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
     Active: activating (start-pre) since Mon 2024-01-22 09:23:41 UTC; 59ms ago
       Docs: man:mosquitto.conf(5)
             man:mosquitto(8)
Cntrl PID: 12682 (mkdir)
      Tasks: 1 (limit: 2354)
     Memory: 44.0K
        CPU: 7ms
     CGroup: /system.slice/mosquitto.service
             └─12687 /bin/mkdir -m 740 -p /run/mosquitto
Jan 22 09:23:41 wirenboard-A********* systemd[1]: Starting Mosquitto MQTT Broker...
Jan 22 09:23:41 wirenboard-A******* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/00default_listener.conf
Jan 22 09:23:41 wirenboard-A********* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/10listeners.conf
Jan 22 09:23:41 wirenboard-A********* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/20bridges.conf
Jan 22 09:23:41 wirenboard-A********* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/30limits.conf
Jan 22 09:23:41 wirenboard-A********* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/bridge1.conf
Jan 22 09:23:41 wirenboard-A********* mosquitto[12692]: 1705915421: Loading config file /etc/mosquitto/conf.d/bridge2.conf
root@wirenboard-AWH3C6UH:~# journalctl -xe
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:     self.sock_connect(self._broker_url.path)
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:   File "/usr/lib/python3/dist-packages/paho_socket/client.py", line 45, in sock_connect
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:     return self.reconnect()
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:   File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 1075, in reconnect
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:     sock = self._create_socket_connection()
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:   File "/usr/lib/python3/dist-packages/paho_socket/client.py", line 105, in _create_socket_connection
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]:     raise ConnectionError("Socket connection failed.") from ex
Jan 22 09:24:04 wirenboard-A********* wb-mqtt-mbgate-confgen[15319]: ConnectionError: Socket connection failed.
Jan 22 09:24:04 wirenboard-A********* systemd[1]: wb-mqtt-logs.service: Scheduled restart job, restart counter is at 344.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ Automatic restarting of the unit wb-mqtt-logs.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Jan 22 09:24:04 wirenboard-A********* systemd[1]: Stopped Wiren Board journald to MQTT gateway.
░░ Subject: A stop job for unit wb-mqtt-logs.service has finished
░░ A stop job for unit wb-mqtt-logs.service has finished.
░░ The job identifier is 342116 and the job result is done.
Jan 22 09:24:04 wirenboard-A********* systemd[1]: wb-mqtt-mbgate.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStartPre= process belonging to unit wb-mqtt-mbgate.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Jan 22 09:24:04 wirenboard-A********* systemd[1]: wb-mqtt-mbgate.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit wb-mqtt-mbgate.service has entered the 'failed' state with result 'exit-code'.
Jan 22 09:24:04 wirenboard-A********* systemd[1]: Failed to start Wiren Board MQTT to Modbus TCP gateway.
░░ Subject: A start job for unit wb-mqtt-mbgate.service has failed
░░ A start job for unit wb-mqtt-mbgate.service has finished with a failure.
░░ The job identifier is 341297 and the job result is failed.
root@wirenboard-AWH3C6UH:~# ls -lh /var/lib/mosquitto/
total 81M
-rw------- 1 mosquitto mosquitto 81M Jan 22 04:58 mosquitto.db
Конфигурация моста
address ***********:51884 #address:ports of server
notifications true
bridge_protocol_version mqttv50
notification_topic /remoteconnect/wb_7/bridge_status
remote_clientid WB7_****************
remote_username *************
remote_password **********************
round_robin false
cleansession false
start_type automatic
#clientid********************
topic /DataStream_1/# out 2 /devices /WirenBoard /GTL_001
topic /DataStream_2/# out 2 /devices /WirenBoard /GTL_002
topic /DataStream_3/# out 2 /devices /WirenBoard /GTL_003
topic /GT_MAI6_AI1/# both 2 /devices /WirenBoard /GT_MAI6_AI1
Есть какой-то другой выход кроме удаления mosquitto.db?
P.S. > Удалил mosquitto.db и все заработало. Но хотелось бы разобраться как нужно делать. Хранение сообщений нужно чтобы при отвалах связи и ее восстановлении пропущенные данные автоматом уходили на машину за мостом.
Это все тянется еще от сюда https://support.wirenboard.com/t/stoit-li-zhdat-ispravleniya-errwb73010/16438
Отключите функцию сохранения не отправленных сообщений в файл, если она у вас включена.
Если файл уже разросся, то, из известных мне, только удаление базы.
Следить за тем, чтобы файл не превышал 50 Мб. Можно создать скрипт или правило, которое будет удалять базу при превышении размера.
(233,2 КБ)
Вопрос почему именно 50? Можно более?
Можно перенести DB на SD?
Попробую еще использовать опцию mosquitto persistent_client_expiration duration для удаления постоянных сессий через заданный промежуток времени.
Смысл? Разрастается файл базы данных и mosquitto не может его прочитать.
Я видел, что от 75 Мб уже проблема.
На Гите в одной из веток пишут что и 256 мБ не предел. Но открытие долгое. У меня была если я правильно интерпретировал 81 Мб.
К сожалению, практика такова, что увеличение данной базы приводит к подобному поведению.
