Zigbee2mqtt не отображается в WUI
Обновился, до этого все работало в части зигби. После обновления в девайсах статус был офлайн, хотя судя по статусу см. ниже все вроде как ок.
Случайно удалил на вкладке девайсы устройство zigbeetomqtt, после перезагрузки оно у меня не появилось.
● zigbee2mqtt.service - zigbee2mqtt
   Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
   Active: active (running) since Mon 2021-08-16 10:41:27 +05; 39min ago
 Main PID: 1608 (node)
   CGroup: /system.slice/zigbee2mqtt.service
           ├─1608 npm
           ├─3408 sh -c node index.js
           └─3409 node index.js
Aug 16 11:19:20 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:19:20: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":25,"energy":0,"last_seen":1629094760287,"linkquality":44,"power":0
Aug 16 11:19:30 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:19:30: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":24,"energy":0,"last_seen":1629094770233,"linkquality":44,"power":0
Aug 16 11:19:55 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:19:55: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":23,"energy":0,"last_seen":1629094795165,"linkquality":44,"power":0
Aug 16 11:20:05 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:20:05: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":24,"energy":0,"last_seen":1629094805132,"linkquality":44,"power":0
Aug 16 11:20:19 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:20:19: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":25,"energy":0,"last_seen":1629094819071,"linkquality":44,"power":0
Aug 16 11:20:29 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:20:29: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":24,"energy":0,"last_seen":1629094829113,"linkquality":41,"power":0
Aug 16 11:20:43 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:20:43: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":23,"energy":0,"last_seen":1629094842993,"linkquality":44,"power":0
Aug 16 11:20:52 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:20:52: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":24,"energy":0,"last_seen":1629094852962,"linkquality":44,"power":0
Aug 16 11:21:03 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:21:03: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":25,"energy":0,"last_seen":1629094862990,"linkquality":44,"power":0
Aug 16 11:21:12 wirenboard-AFMIIQX7 npm[1608]: Zigbee2MQTT:info  2021-08-16 11:21:12: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":23,"energy":0,"last_seen":1629094872887,"linkquality":44,"power":0
ВОПРОСЫ:
  1. Что сделать чтобы в WUI отображалось устройство zigbee2mqtt
  2. Что делать если статус zigbee2mqtt в девайсах находится в состояние OFFLINE? (модуль указан правильно в файле configuration.yaml)
  3. Как удалить ранее привязанные устройства zigbee, но в настоящий момент не использующиеся?
Вернулся к заводским настройкам, установил по новой zigbee2mqtt 1.18.1 - в WUI он так и не появился, что делать?
Воспроизвожу.
Модуль установлен в MOD4, файл configuration.yaml поправил:
homeassistant: false
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://localhost'
serial:
  port: /dev/ttyMOD4
advanced:
  rtscts: false
  last_seen: epoch
Судя по логам сервис стартует без ошибок:
Aug 18 17:59:37 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:37: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2021-08-18.17-59-28' filename: log.txt
Aug 18 17:59:38 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:38: Starting Zigbee2MQTT version 1.18.1 (commit #unknown)
Aug 18 17:59:38 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:38: Starting zigbee-herdsman (0.13.71)
Aug 18 17:59:55 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:55: zigbee-herdsman started
Aug 18 17:59:55 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:55: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":2,"minorrel":0,"product":0,"revision":"","transportrev":2},"type":"zStack12"}'
Aug 18 17:59:55 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:55: Currently 0 devices are joined:
Aug 18 17:59:55 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:55: Zigbee: disabling joining new devices.
Aug 18 17:59:55 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:55: Connecting to MQTT server at mqtt://localhost
Aug 18 17:59:56 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:56: Connected to MQTT server
Aug 18 17:59:57 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:57: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Aug 18 17:59:57 wirenboard-AFMIIQX7 npm[1553]: e[32mZigbee2MQTT:info e[39m 2021-08-18 17:59:57: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":0,"majorrel":2,"minorrel":0,"product":0,"revision":"","transportrev":2},"type":"zStack12"},"log_level":"info","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.18.1"}'
Но во вкладке девайсов - zigbee2mqtt нет
wb-mqtt-homeui: 2.3.3
wb-zigbee2mqtt: не установлен, а нужен?
zigbee2mqtt: 1.18.1
root@wirenboard-AFMIIQX7:~# dpkg -s zigbee2mqtt
Package: zigbee2mqtt
Status: install ok installed
Priority: extra
Section: default
Installed-Size: 122924
Maintainer: <@wbdevenv>
Architecture: armhf
Version: 1.18.1
Depends: nodejs (>= 12.18.4)
Description: no description given
License: unknown
Vendor: @wbdevenv
Homepage: http://example.com/no-uri-given
Пожалуйста, команда WB дайте обратную связь что видели мой вопрос, что занимаетесь. Не оставляйте в вакууме, за ранее благодарен.
Удалось воспроизвести?
Да, так у вас zigbee2mqtt запущен? Или установлен но не работает?
Запущен, не отображается в девайсах, я не могу завести устройства новые.
Как без wui подключить устройства и проверить работу zigbee?
Так, еще раз - именно пакет wb-zigbee2mqtt стоит? Интерфейс обеспечивает именно он.
Файл /usr/share/wb-rules-system/rules/wb-zigbee2mqtt.js есть?
Данного пакета не было установлено, как писал ранее.
Установил - в девайсах zigbee2mqtt появился, как буду на объекте проверю находит ли новые устройства и отрабатывает ли корректно zigbee. Но текущий статус online что вселяет надежду.
Благодарю, вопрос считаю закрытым.
