WB пришел с WBE2R-R-ZIGBEE. Установлен в MOD3.
root@wirenboard-AVNAZUEJ:/mnt/data/root/zigbee2mqtt#  ls -al /dev/ttyMOD3
lrwxrwxrwx 1 root root 7 Apr 16 02:34 /dev/ttyMOD3 → ttymxc6
service zigbee2mqtt status
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2021-04-17 19:43:32 MSK; 29min ago
Process: 17158 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 17158 (code=exited, status=1/FAILURE)Apr 17 19:42:02 wirenboard-AVNAZUEJ systemd[1]: zigbee2mqtt.service: Failed with result ‘exit-code’.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: zigbee2mqtt.service: Service hold-off time over, scheduling restart.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: Stopped zigbee2mqtt.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: zigbee2mqtt.service: Start request repeated too quickly.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: Failed to start zigbee2mqtt.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: zigbee2mqtt.service: Unit entered failed state.
Apr 17 19:43:32 wirenboard-AVNAZUEJ systemd[1]: zigbee2mqtt.service: Failed with result ‘exit-code’.
/mnt/data/root/zigbee2mqtt/data/configuration.yaml
homeassistant: false
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: ‘mqtt://localhost’
serial:
port: /dev/ttyMOD3
advanced:
rtscts: false
last_seen: epoch
Куда копать?
