Zigbee2mqtt
Добрый вечер!
Пытаюсь запустить zigbee2mqtt, сделал все по мануалу, но почему-то к серверу не подключается, в чем может быть проблема?
Логи журнала с ошибками
29-05-2023 22:05:26.087 [init.scope] Failed to start zigbee2mqtt.
29-05-2023 21:53:47.410 [ssh] error: beginning MaxStartups throttling
29-05-2023 21:53:44.141 [ssh] error: kex_exchange_identification: Connection closed by remote host
29-05-2023 21:47:15.337 [init.scope] Failed to start zigbee2mqtt.
29-05-2023 21:37:34.503 [wb-mqtt-metrics] Unexpected disconnection.
29-05-2023 21:35:26.197 [init.scope] Failed to start zigbee2mqtt.
29-05-2023 21:29:50.605 [watchdog] cannot set scheduler (errno = 1 = ‘Operation not permitted’)
29-05-2023 21:29:36.009 [NetworkManager] [1685384976.0065] audit: failed to open auditd socket: Protocol not supported
29-05-2023 21:29:32.732 [wb-mqtt-knx] ERROR: Mqtt connect error localhost:1883 : @ wblib/mqtt.cpp:255
29-05-2023 21:29:27.813 [wpa_supplicant] Using interface wlan0 with hwaddr c4:3c:b0:e6:b7:7e and ssid WirenBoard-ARNIKM27
29-05-2023 21:29:20.013 [bluetooth] sap-server: Operation not permitted (1)
29-05-2023 21:29:20.012 [bluetooth] profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
29-05-2023 21:29:13.262 vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
29-05-2023 21:29:13.260 dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
29-05-2023 21:29:13.259 sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0 on device 1c20800.pinctrl
29-05-2023 21:29:13.258 sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
29-05-2023 21:29:13.256 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
29-05-2023 21:29:13.255 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PA regulator
29-05-2023 21:29:13.254 sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
29-05-2023 21:29:13.253 sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8 on device 1c20800.pinctrl
29-05-2023 21:29:13.252 sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
29-05-2023 21:29:13.250 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
29-05-2023 21:29:13.249 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
29-05-2023 21:29:13.248 sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
29-05-2023 21:29:13.247 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
29-05-2023 21:29:13.246 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
29-05-2023 21:29:13.244 dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
29-05-2023 21:29:13.242 sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18 on device 1c20800.pinctrl
29-05-2023 21:29:13.241 sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
29-05-2023 21:29:13.240 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
29-05-2023 21:29:13.239 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PI regulator
29-05-2023 21:29:13.235 sun4i-usb-phy 1c13400.phy: Couldn’t request ID GPIO
29-05-2023 21:29:13.208 sun4i-usb-phy 1c13400.phy: Couldn’t request ID GPIO
29-05-2023 21:29:13.200 /cpus/cpu@3 missing clock-frequency property
29-05-2023 21:29:13.200 /cpus/cpu@2 missing clock-frequency property
29-05-2023 21:29:13.200 /cpus/cpu@1 missing clock-frequency property
29-05-2023 21:29:13.200 /cpus/cpu@0 missing clock-frequency property
29-05-2023 21:28:43.133 [netplug] caught signal 15 - exiting
29-05-2023 21:22:26.617 [init.scope] Failed to start zigbee2mqtt.
29-05-2023 21:21:25.692 [init.scope] Failed to start zigbee2mqtt.
29-05-2023 21:09:42.366 [wb-mqtt-metrics] Unexpected disconnection.
29-05-2023 20:59:45.077 [watchdog] cannot set scheduler (errno = 1 = ‘Operation not permitted’)
29-05-2023 20:59:32.389 [NetworkManager] [1685383172.3889] audit: failed to open auditd socket: Protocol not supported
29-05-2023 20:59:29.772 [wb-mqtt-knx] ERROR: Mqtt connect error localhost:1883 : @ wblib/mqtt.cpp:255
29-05-2023 20:59:25.060 [wpa_supplicant] Using interface wlan0 with hwaddr c4:3c:b0:e6:b7:7e and ssid WirenBoard-ARNIKM27
29-05-2023 20:59:17.002 [bluetooth] sap-server: Operation not permitted (1)
29-05-2023 20:59:17.001 [bluetooth] profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
29-05-2023 20:59:10.184 vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
29-05-2023 20:59:10.182 dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
29-05-2023 20:59:10.181 sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0 on device 1c20800.pinctrl
29-05-2023 20:59:10.179 sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
29-05-2023 20:59:10.178 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
29-05-2023 20:59:10.177 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PA regulator
29-05-2023 20:59:10.176 sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
29-05-2023 20:59:10.175 sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8 on device 1c20800.pinctrl
29-05-2023 20:59:10.173 sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
29-05-2023 20:59:10.172 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
29-05-2023 20:59:10.171 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
29-05-2023 20:59:10.170 sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
29-05-2023 20:59:10.169 sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
29-05-2023 20:59:10.167 sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
конфиг zigbee2mqtt
homeassistant: false
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://localhost
serial:
port: /dev/ttyMOD4
advanced:
rtscts: false
last_seen: epoch
pan_id: 23938
network_key:
- 162
- 143
- 146
- 137
- 156
- 73
- 99
- 26
Вывод лога npm start:
zigbee2mqtt@1.30.4 start
node index.js
Zigbee2MQTT:info 2023-05-29 22:50:37: Logging to console and directory: ‘/mnt/data/root/zigbee2mqtt/data/log/2023-05-29.22-50-37’ filename: log.txtZigbee2MQTT:info 2023-05-29 22:50:37: Starting Zigbee2MQTT version 1.30.4 (commit #b2dd21e1)
Zigbee2MQTT:info 2023-05-29 22:50:37: Starting zigbee-herdsman (0.14.111)Zigbee2MQTT:error 2023-05-29 22:50:42: Configuration is not consistent with adapter state/backup!
Zigbee2MQTT:error 2023-05-29 22:50:42: - PAN ID: configured=23938, adapter=8616
Zigbee2MQTT:error 2023-05-29 22:50:42: - Extended PAN ID: configured=00124b00256cc28c, adapter=00124b00256cc28c
Zigbee2MQTT:error 2023-05-29 22:50:42: - Network Key: configured=a28f92899c49631a9d3846837294598b, adapter=d54a6383017b45855c6d3f7ad727f65f
Zigbee2MQTT:error 2023-05-29 22:50:42: - Channel List: configured=11, adapter=11
Zigbee2MQTT:error 2023-05-29 22:50:42: Please update configuration to prevent further issues.
Zigbee2MQTT:error 2023-05-29 22:50:42: If you wish to re-commission your network, please remove coordinator backup at /mnt/data/root/zigbee2mqtt/data/coordinator_backup.json.
Zigbee2MQTT:error 2023-05-29 22:50:42: Re-commissioning your network will
require re-pairing of all devices!
Zigbee2MQTT:error 2023-05-29 22:50:42: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-05-29 22:50:42: Failed to start zigbee
Zigbee2MQTT:error 2023-05-29 22:50:42: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutionsZigbee2MQTT:error 2023-05-29 22:50:42: Exiting…
Zigbee2MQTT:error 2023-05-29 22:50:43: Error: startup failed - configuration-adapter mismatch - see logs above for more information
Мой контроллер WB7, версия ПО 202305220208_testing_bullseye_wb7x, модуль Zigbee Модуль расширения [WBE2R-R-ZIGBEE v.2 + антенна]
Вопрос решил сам, посмотрев свой же лог )
Проблема была в резервной копии /mnt/data/root/zigbee2mqtt/data/coordinator_backup.json удалив ее все запустилось !
