Bullseye wb-mqtt-mbgate.service failed
На стартует служба. После попытки запуска службы конфиг wb-mqtt-mbgate.conf пустой
11-04-2023 09:55:10.241	ValueError: invalid literal for int() with base 10: b'false'
11-04-2023 09:55:10.221	    if int(msg.payload) == 1:
11-04-2023 09:55:10.217	  File "/usr/bin/wb-mqtt-mbgate-confgen", line 254, in mqtt_on_message
11-04-2023 09:55:10.212	    self.on_message(self, self._userdata, message)
11-04-2023 09:55:10.195	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 3444, in _handle_on_message
11-04-2023 09:55:10.192	    self._handle_on_message(message)
11-04-2023 09:55:10.173	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 3216, in _handle_publish
11-04-2023 09:55:10.172	    return self._handle_publish()
11-04-2023 09:55:10.153	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 2936, in _packet_handle
11-04-2023 09:55:10.150	    rc = self._packet_handle()
11-04-2023 09:55:10.138	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 2310, in _packet_read
11-04-2023 09:55:10.137	    rc = self._packet_read()
11-04-2023 09:55:10.120	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 1572, in loop_read
11-04-2023 09:55:10.115	    rc = self.loop_read(max_packets)
11-04-2023 09:55:10.075	  File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 1181, in loop
11-04-2023 09:55:10.072	    rc = client.loop()
11-04-2023 09:55:10.069	  File "/usr/bin/wb-mqtt-mbgate-confgen", line 314, in main
11-04-2023 09:55:10.067	    main()
11-04-2023 09:55:10.065	  File "/usr/bin/wb-mqtt-mbgate-confgen", line 322, in <module>
11-04-2023 09:55:10.063	Traceback (most recent call last):
Нужно больше данных :slight_smile:
Похоже, в какой-то топик вместо ‘0’ прилетело ‘false’. Никакие рукописные сервисы в mqtt не пишут?
Попробуйте последить за выводом mosquitto_sub -v -t /devices/# | grep false
ничего такого, чего не было до обновления
/devices/YandexWeather/controls/update/meta {"order":5,"readonly":false,"title":{"en":"Update"},"type":"switch"}
/devices/nspbathroom/controls/nsp_bathroom_screenpower/meta {"type":"switch","title":{"en":"nsp_bathroom_screenpower"},"readonly":false,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_screenpower/meta/readonly false
/devices/nspbathroom/controls/nsp_bathroom_left_button/meta {"type":"switch","title":{"en":"nsp_bathroom_left_button"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_right_button/meta {"type":"switch","title":{"en":"nsp_bathroom_right_button"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b0/meta {"type":"switch","title":{"en":"nsp_bathroom_b0"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b1/meta {"type":"switch","title":{"en":"nsp_bathroom_b1"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b2/meta {"type":"switch","title":{"en":"nsp_bathroom_b2"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b3/meta {"type":"switch","title":{"en":"nsp_bathroom_b3"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b4/meta {"type":"switch","title":{"en":"nsp_bathroom_b4"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_b5/meta {"type":"switch","title":{"en":"nsp_bathroom_b5"},"readonly":true,"default":false,"order":0}
/devices/nspbathroom/controls/nsp_bathroom_screensaver/meta {"type":"switch","title":{"en":"nsp_bathroom_screensaver"},"readonly":true,"default":false,"order":0}
/devices/wbrules/controls/Rule debugging/meta {"order":1,"readonly":false,"type":"switch"}
/devices/buzzer/controls/enabled/meta {"order":1,"readonly":false,"type":"switch"}
/devices/buzzer/controls/frequency/meta {"max":7000,"order":2,"readonly":false,"type":"range"}
/devices/buzzer/controls/volume/meta {"max":100,"order":3,"readonly":false,"type":"range"}
/devices/system/controls/Reboot/meta {"order":6,"readonly":false,"type":"pushbutton"}
/devices/nspbedroom1/controls/nsp_bedroom1_screenpower/meta {"type":"switch","title":{"en":"nsp_bedroom1_screenpower"},"readonly":false,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_screenpower/meta/readonly false
/devices/nspbedroom1/controls/nsp_bedroom1_left_button/meta {"type":"switch","title":{"en":"nsp_bedroom1_left_button"},"readonly":true,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_right_button/meta {"type":"switch","title":{"en":"nsp_bedroom1_right_button"},"readonly":true,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_udp/meta {"type":"switch","title":{"en":"nsp_bedroom1_udp"},"readonly":true,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_b0/meta {"type":"switch","title":{"en":"nsp_bedroom1_b0"},"readonly":true,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_b1/meta {"type":"switch","title":{"en":"nsp_bedroom1_b1"},"readonly":true,"default":false,"order":0}
/devices/nspbedroom1/controls/nsp_bedroom1_screensaver/meta {"type":"switch","title":{"en":"nsp_bedroom1_screensaver"},"readonly":true,"default":false,"order":0}
/devices/Termostat_livingroom/controls/Mode/meta {"order":1,"readonly":false,"title":{"en":"Mode"},"type":"switch"}
/devices/Termostat_livingroom/controls/ThragetTemp/meta {"max":35,"min":15,"order":2,"readonly":false,"title":{"en":"Thraget_temp"},"type":"range"}
/devices/zigbee2mqtt/controls/Permit join/meta {"order":3,"readonly":false,"type":"switch"}
/devices/zigbee2mqtt/controls/Update devices/meta {"order":5,"readonly":false,"type":"pushbutton"}
/devices/Flood_Kitchen/controls/battery_low false
/devices/Flood_Kitchen/controls/tamper false
/devices/Flood_Kitchen/controls/water_leak false
/devices/Flood_Under_Bath/controls/battery_low false
/devices/Flood_Under_Bath/controls/tamper false
/devices/Flood_Under_Bath/controls/water_leak false
/devices/Flood_Bathroom_Collector/controls/battery_low false
/devices/Flood_Bathroom_Collector/controls/tamper false
/devices/Flood_Bathroom_Collector/controls/water_leak false
/devices/Flood_Washing_Machine/controls/battery_low false
/devices/Flood_Washing_Machine/controls/tamper false
/devices/Flood_Washing_Machine/controls/water_leak false
/devices/Flood_Bathroom/controls/battery_low false
/devices/Flood_Bathroom/controls/tamper false
/devices/Flood_Bathroom/controls/water_leak false
/devices/Flood_Toilet/controls/water_leak false
/devices/CurtainsLivingroom/controls/running false
/devices/system__networks__d12c8d3c-1abe-4832-9b71-4ed6e3c20885/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/system__networks__0f098677-2b49-4167-a534-207567b1751b/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/system__networks__91f1c71d-2d97-4675-886f-ecbe52b8451e/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/system__networks__c3e38405-9c17-4155-ad70-664311b49066/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/system__networks__5d4297ba-c319-4c05-a153-17cb42e6e196/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/system__networks__8b9964d4-b8dd-34d3-a3ed-481840bcf8c9/controls/UpDown/meta {"order":9,"readonly":false,"title":{"en":"Up"},"type":"pushbutton"}
/devices/knx/controls/data/meta {"order":0,"readonly":false,"type":"text"}
/devices/wb-mr6c_71/controls/K1/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mr6c_71/controls/K2/meta {"order":16,"readonly":false,"type":"switch"}
/devices/wb-mr6c_71/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mr6c_71/controls/K4/meta {"order":18,"readonly":false,"type":"switch"}
/devices/wb-mr6c_71/controls/K5/meta {"order":19,"readonly":false,"type":"switch"}
/devices/wb-mr6c_71/controls/K6/meta {"order":20,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K2/meta {"order":14,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K3/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K4/meta {"order":16,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K5/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mr6c_75/controls/K6/meta {"order":18,"readonly":false,"type":"switch"}
/devices/wb-mdm3_27/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mdm3_27/controls/Channel 1/meta {"max":100.0,"order":14,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1"},"type":"range"}
/devices/wb-mdm3_27/controls/K2/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mdm3_27/controls/Channel 2/meta {"max":100.0,"order":16,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2"},"type":"range"}
/devices/wb-mdm3_27/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mdm3_27/controls/Channel 3/meta {"max":100.0,"order":18,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3"},"type":"range"}
/devices/wb-mr6c_113/controls/K1/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mr6c_113/controls/K2/meta {"order":16,"readonly":false,"type":"switch"}
/devices/wb-mr6c_113/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mr6c_113/controls/K4/meta {"order":18,"readonly":false,"type":"switch"}
/devices/wb-mr6c_113/controls/K5/meta {"order":19,"readonly":false,"type":"switch"}
/devices/wb-mr6c_113/controls/K6/meta {"order":20,"readonly":false,"type":"switch"}
/devices/wb-mdm3_108/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mdm3_108/controls/Channel 1/meta {"max":100.0,"order":14,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1"},"type":"range"}
/devices/wb-mdm3_108/controls/K2/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mdm3_108/controls/Channel 2/meta {"max":100.0,"order":16,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2"},"type":"range"}
/devices/wb-mdm3_108/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mdm3_108/controls/Channel 3/meta {"max":100.0,"order":18,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3"},"type":"range"}
/devices/wb-mdm3_97/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mdm3_97/controls/Channel 1/meta {"max":100.0,"order":14,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1"},"type":"range"}
/devices/wb-mdm3_97/controls/K2/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mdm3_97/controls/Channel 2/meta {"max":100.0,"order":16,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2"},"type":"range"}
/devices/wb-mdm3_97/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mdm3_97/controls/Channel 3/meta {"max":100.0,"order":18,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3"},"type":"range"}
/devices/wb-mdm3_92/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mdm3_92/controls/Channel 1/meta {"max":100.0,"order":14,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1"},"type":"range"}
/devices/wb-mdm3_92/controls/K2/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mdm3_92/controls/Channel 2/meta {"max":100.0,"order":16,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2"},"type":"range"}
/devices/wb-mdm3_92/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mdm3_92/controls/Channel 3/meta {"max":100.0,"order":18,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3"},"type":"range"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 1 (B)/meta {"order":1,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1 (B)"},"type":"switch"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 1 (B) Brightness/meta {"max":100.0,"min":0.0,"order":2,"readonly":false,"title":{"ru":"\u042f\u0440\u043a\u043e\u0441\u0442\u044c \u043a\u0430\u043d\u0430\u043b\u0430 1 (B)"},"type":"range"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 2 (R)/meta {"order":3,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2 (R)"},"type":"switch"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 2 (R) Brightness/meta {"max":100.0,"min":0.0,"order":4,"readonly":false,"title":{"ru":"\u042f\u0440\u043a\u043e\u0441\u0442\u044c \u043a\u0430\u043d\u0430\u043b\u0430 2 (R)"},"type":"range"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 3 (G)/meta {"order":5,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3 (G)"},"type":"switch"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 3 (G) Brightness/meta {"max":100.0,"min":0.0,"order":6,"readonly":false,"title":{"ru":"\u042f\u0440\u043a\u043e\u0441\u0442\u044c \u043a\u0430\u043d\u0430\u043b\u0430 3 (G)"},"type":"range"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 4 (W)/meta {"order":7,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 4 (W)"},"type":"switch"}
/devices/wb-mrgbw-d-fw3_182/controls/Channel 4 (W) Brightness/meta {"max":100.0,"min":0.0,"order":8,"readonly":false,"title":{"ru":"\u042f\u0440\u043a\u043e\u0441\u0442\u044c \u043a\u0430\u043d\u0430\u043b\u0430 4 (W)"},"type":"range"}
/devices/wb-mdm3_216/controls/K1/meta {"order":13,"readonly":false,"type":"switch"}
/devices/wb-mdm3_216/controls/Channel 1/meta {"max":100.0,"order":14,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 1"},"type":"range"}
/devices/wb-mdm3_216/controls/K2/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mdm3_216/controls/Channel 2/meta {"max":100.0,"order":16,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 2"},"type":"range"}
/devices/wb-mdm3_216/controls/K3/meta {"order":17,"readonly":false,"type":"switch"}
/devices/wb-mdm3_216/controls/Channel 3/meta {"max":100.0,"order":18,"readonly":false,"title":{"ru":"\u041a\u0430\u043d\u0430\u043b 3"},"type":"range"}
/devices/wb-msw-v3_140/controls/Buzzer/meta {"order":9,"readonly":false,"title":{"ru":"\u0417\u0443\u043c\u043c\u0435\u0440"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Red LED/meta {"order":10,"readonly":false,"title":{"ru":"\u041a\u0440\u0430\u0441\u043d\u044b\u0439 \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Green LED/meta {"order":11,"readonly":false,"title":{"ru":"\u0417\u0435\u043b\u0435\u043d\u044b\u0439 \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434"},"type":"switch"}
/devices/wb-msw-v3_140/controls/LED Period (s)/meta {"max":10.0,"order":12,"readonly":false,"title":{"ru":"\u041f\u0435\u0440\u0438\u043e\u0434 \u0432\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u044f \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434\u043e\u0432 (\u0441)"},"type":"range"}
/devices/wb-msw-v3_140/controls/LED Glow Duration (ms)/meta {"max":50.0,"order":13,"readonly":false,"title":{"ru":"\u0414\u043b\u0438\u0442\u0435\u043b\u044c\u043d\u043e\u0441\u0442\u044c \u0432\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u044f \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434\u043e\u0432 (\u043c\u0441)"},"type":"range"}
/devices/wb-msw-v3_140/controls/Learn to RAM/meta {"order":14,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 RAM"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Play from RAM/meta {"order":15,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 RAM"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Learn to ROM1/meta {"order":16,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM1"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM2/meta {"order":17,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM2"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM3/meta {"order":18,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM3"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM4/meta {"order":19,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM4"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM5/meta {"order":20,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM5"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM6/meta {"order":21,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM6"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Learn to ROM7/meta {"order":22,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM7"},"type":"switch"}
/devices/wb-msw-v3_140/controls/Play from ROM1/meta {"order":23,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM1"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM2/meta {"order":24,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM2"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM3/meta {"order":25,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM3"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM4/meta {"order":26,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM4"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM5/meta {"order":27,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM5"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM6/meta {"order":28,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM6"},"type":"pushbutton"}
/devices/wb-msw-v3_140/controls/Play from ROM7/meta {"order":29,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM7"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Buzzer/meta {"order":9,"readonly":false,"title":{"ru":"\u0417\u0443\u043c\u043c\u0435\u0440"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Red LED/meta {"order":10,"readonly":false,"title":{"ru":"\u041a\u0440\u0430\u0441\u043d\u044b\u0439 \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Green LED/meta {"order":11,"readonly":false,"title":{"ru":"\u0417\u0435\u043b\u0435\u043d\u044b\u0439 \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434"},"type":"switch"}
/devices/wb-msw-v3_107/controls/LED Period (s)/meta {"max":10.0,"order":12,"readonly":false,"title":{"ru":"\u041f\u0435\u0440\u0438\u043e\u0434 \u0432\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u044f \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434\u043e\u0432 (\u0441)"},"type":"range"}
/devices/wb-msw-v3_107/controls/LED Glow Duration (ms)/meta {"max":50.0,"order":13,"readonly":false,"title":{"ru":"\u0414\u043b\u0438\u0442\u0435\u043b\u044c\u043d\u043e\u0441\u0442\u044c \u0432\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u044f \u0441\u0432\u0435\u0442\u043e\u0434\u0438\u043e\u0434\u043e\u0432 (\u043c\u0441)"},"type":"range"}
/devices/wb-msw-v3_107/controls/Learn to RAM/meta {"order":14,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 RAM"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Play from RAM/meta {"order":15,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 RAM"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Learn to ROM1/meta {"order":16,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM1"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM2/meta {"order":17,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM2"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM3/meta {"order":18,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM3"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM4/meta {"order":19,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM4"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM5/meta {"order":20,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM5"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM6/meta {"order":21,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM6"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Learn to ROM7/meta {"order":22,"readonly":false,"title":{"ru":"\u0417\u0430\u043f\u0438\u0441\u0430\u0442\u044c \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0432 ROM7"},"type":"switch"}
/devices/wb-msw-v3_107/controls/Play from ROM1/meta {"order":23,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM1"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM2/meta {"order":24,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM2"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM3/meta {"order":25,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM3"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM4/meta {"order":26,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM4"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM5/meta {"order":27,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM5"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM6/meta {"order":28,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM6"},"type":"pushbutton"}
/devices/wb-msw-v3_107/controls/Play from ROM7/meta {"order":29,"readonly":false,"title":{"ru":"\u0412\u043e\u0441\u043f\u0440\u043e\u0438\u0437\u0432\u0435\u0441\u0442\u0438 \u043a\u043e\u043c\u0430\u043d\u0434\u0443 \u0438\u0437 ROM7"},"type":"pushbutton"}
/devices/wb-mwac_53/controls/K1/meta {"order":15,"readonly":false,"type":"switch"}
/devices/wb-mwac_53/controls/K2/meta {"order":16,"readonly":false,"type":"switch"}
/devices/wb-mwac_53/controls/Alarm/meta {"order":17,"readonly":false,"title":{"ru":"\u0410\u0432\u0430\u0440\u0438\u044f"},"type":"switch"}
/devices/wb-gpio/controls/A1_OUT/meta {"order":1,"readonly":false,"type":"switch"}
/devices/wb-gpio/controls/A2_OUT/meta {"order":2,"readonly":false,"type":"switch"}
/devices/wb-gpio/controls/A3_OUT/meta {"order":3,"readonly":false,"type":"switch"}
/devices/wb-gpio/controls/A4_OUT/meta {"order":4,"readonly":false,"type":"switch"}
/devices/wb-gpio/controls/V_OUT/meta {"order":9,"readonly":false,"type":"switch"}
/devices/wb-gpio/controls/5V_OUT/meta {"order":11,"readonly":false,"type":"switch"}
вижу false в zigbee устройствах, но эти топики генерит служба wb-zigbee2mqtt
Видимо вот эти два топика:
Если используете esphome2wb, уместно его обновить - в новой версии поправлено.
это какие-то старые топики. Можно как-то грохнуть базу топиков, чтоб они заново собирались?
Наверное проще всего будет записать в них пустую строку.
Грохнуть всё под корень можно так: mqtt-delete-retained /#
Да это были хвосты от esphome2wb, его уже не использую.
Удалил эти топики через mqtt explorer, сервис поднялся.
Спасибо!
