Чтение конфигурационных параметров датчика WB-MSW-ZIGBEE_v.4
Подскажите, есть ли способ узнать настройки интервала опроса изнутри wb_rules. Я попробовал установить два интервала для шума и движения и получил разные ответы.
Прошивка датчика последняя …
вызывающий скрипт:
message = {
“id”: “wb-msw-v4_zigbee”,
“endpoint”:1,
“options”: {“manufacturerCode”:26214},
“cluster”: “sprutNoise”,
“attribute”: “noise”,
“minimum_report_interval”: 120,
“maximum_report_interval”: 120,
“reportable_change”: 5
publish(‘zigbee2mqtt/bridge/request/device/configure_reporting’, JSON.stringify(message), 2, false);
message = {
“endpoint”:1,
“cluster”: “msOccupancySensing”,
“attribute”: “occupancy”,
ответы, полученные с помощью mosquitto_sub -v -t zigbee2mqtt/#
zigbee2mqtt/bridge/logging {“level”:“info”,“message”:“z2m: Configured reporting for ‘wb-msw-v4_zigbee’, ‘sprutNoise.noise’”}
zigbee2mqtt/bridge/logging {“level”:“info”,“message”:“z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/configure_reporting’, payload ‘{"data":{"attribute":"noise","cluster":"sprutNoise","endpoint":1,"id":"wb-msw-v4_zigbee","maximum_report_interval":120,"minimum_report_interval":120,"reportable_change":5},"status":"ok"}’”}
zigbee2mqtt/bridge/response/device/configure_reporting {“data”:{“attribute”:“noise”,“cluster”:“sprutNoise”,“endpoint”:1,“id”:“wb-msw-v4_zigbee”,“maximum_report_interval”:120,“minimum_report_interval”:120,“reportable_change”:5},“status”:“ok”}
zigbee2mqtt/bridge/logging {“level”:“error”,“message”:“z2m: Request ‘zigbee2mqtt/bridge/request/device/configure_reporting’ failed with error: ‘ZCL command 0xbc026efffe373447/1 msOccupancySensing.configReport([{"attribute":"occupancy","minimumReportInterval":120,"maximumReportInterval":120,"reportableChange":5}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":26214,"writeUndiv":false}) failed (Status ‘UNSUPPORTED_ATTRIBUTE’)’”}
zigbee2mqtt/bridge/logging {“level”:“info”,“message”:“z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/configure_reporting’, payload ‘{"data":{},"error":"ZCL command 0xbc026efffe373447/1 msOccupancySensing.configReport([{\"attribute\":\"occupancy\",\"minimumReportInterval\":120,\"maximumReportInterval\":120,\"reportableChange\":5}], {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":true,\"direction\":0,\"reservedBits\":0,\"manufacturerCode\":26214,\"writeUndiv\":false}) failed (Status ‘UNSUPPORTED_ATTRIBUTE’)","status":"error"}’”}
Честно говоря не очень понял корректные ли действия я выполняю из документации и примеров (см. Универсальный настенный датчик WB-MSW-ZIGBEE v.4 — Wiren Board )
Как по мне - оптимальный способ - посмотреть как это делает сам z2m
То есть подписаться на его топик (топики) и из его же интерфейса вызвать.
Для примера, кликаю на Apply:
На изображении представлен интерфейс настройки параметров для конечной точки msOccupancySensing, включая различные атрибуты и интервалы повторений. (Captioned by AI)
Но, похоже что отправляется сразу весь набор. Не уверен, есть ли возможность задавать отдельно значения.
Jul 21 18:05:24 zigbee2mqtt/bridge/devices [{"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"10":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"11":{"bindings":[],"clusters":{"input":["ssIasAce","genTime"],"output":["ssIasZone","ssIasWd"]},"configured_reportings":[],"scenes":[]},"110":{"bindings":[],"clusters":
Обрезал часть
humidity","label":"Humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":1,"description":"Indicates whether the device detected occupancy","label":"Occupancy","name":"occupancy","property":"occupancy","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"The measured occupancy value","label":"Occupancy level","name":"occupancy_level","property":"occupancy_level","type":"numeric"},{"access":1,"description":"The measured CO2 (carbon dioxide) value","label":"CO2","name":"co2","property":"co2","type":"numeric","unit":"ppm"},{"access":1,"description":"Measured VOC value","label":"VOC","name":"voc","property":"voc","type":"numeric","unit":"µg/m³"},{"access":1,"description":"The measured noise value","label":"Noise","name":"noise","property":"noise","type":"numeric","unit":"dBA"},{"access":1,"description":"Indicates whether the device detected noise","label":"Noise detected","name":"noise_detected","property":"noise_detected","type":"binary","value_off":false,"value_on":true},{"endpoint":"l1","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l1","label":"State","name":"state","property":"state_l1","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"endpoint":"l2","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l2","label":"State","name":"state","property":"state_l2","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"endpoint":"l3","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l3","label":"State","name":"state","property":"state_l3","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":7,"category":"config","description":"Time in seconds after which noise is cleared after detecting it (default: 60)","label":"Noise timeout","name":"noise_timeout","property":"noise_timeout","type":"numeric","unit":"s","value_max":2000,"value_min":0},{"access":7,"category":"config","description":"Time in seconds after which occupancy is cleared after detecting it (default: 60)","label":"Occupancy timeout","name":"occupancy_timeout","property":"occupancy_timeout","type":"numeric","unit":"s","value_max":2000,"value_min":0},{"access":2,"category":"config","description":"Self-heating compensation. The compensation value is subtracted from the measured temperature","label":"Temperature offset","name":"temperature_offset","property":"temperature_offset","type":"numeric","unit":"°C","value_max":10,"value_min":-10},{"access":7,"category":"config","description":"If the sensor is triggered by the slightest movement, reduce the sensitivity, otherwise increase it (default: 50)","label":"Occupancy sensitivity","name":"occupancy_sensitivity","property":"occupancy_sensitivity","type":"numeric","value_max":2000,"value_min":0},{"access":7,"category":"config","description":"The minimum noise level at which the detector will work (default: 50)","label":"Noise detect level","name":"noise_detect_level","property":"noise_detect_level","type":"numeric","unit":"dBA","value_max":150,"value_min":0},{"access":7,"category":"config","description":"Automatic calibration of the CO2 sensor. If ON, the CO2 sensor will automatically calibrate every 7 days. (MH-Z19B sensor)","label":"Co2 autocalibration","name":"co2_autocalibration","property":"co2_autocalibration","type":"enum","values":["OFF","ON"]},{"access":7,"category":"config","description":"Ventilate the room for 20 minutes, turn on manual calibration, and turn it off after one second. After about 5 minutes the CO2 sensor will show 400ppm. Calibration completed. (MH-Z19B sensor)","label":"Co2 manual calibration","name":"co2_manual_calibration","property":"co2_manual_calibration","type":"enum","values":["OFF","ON"]},{"access":7,"category":"config","description":"Turn on when working in conditions of high humidity (more than 70 %, RH) or condensation, if the sensor shows 0 or 100 %.","label":"Th heater","name":"th_heater","property":"th_heater","type":"enum","values":["OFF","ON"]},{"access":5,"description":"Measured illuminance","label":"Illuminance","name":"illuminance","property":"illuminance","type":"numeric","unit":"lx"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"WB-MSW-ZIGBEE v.3","options":[{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","label":"Temperature calibration","name":"temperature_calibration","property":"temperature_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Temperature precision","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","label":"Humidity calibration","name":"humidity_calibration","property":"humidity_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Humidity precision","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the co2 value (absolute offset), takes into effect on next report of device.","label":"Co2 calibration","name":"co2_calibration","property":"co2_calibration","type":"numeric"},{"access":2,"description":"Calibrates the voc value (absolute offset), takes into effect on next report of device.","label":"Voc calibration","name":"voc_calibration","property":"voc_calibration","type":"numeric"},{"access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device.","label":"Illuminance calibration","name":"illuminance_calibration","property":"illuminance_calibration","type":"numeric"},{"access":2,"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"access":3,"label":"Time","name":"time","type":"numeric"},"label":"No occupancy since","name":"no_occupancy_since","property":"no_occupancy_since","type":"list"},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Expose the raw illuminance value.","label":"Illuminance raw","name":"illuminance_raw","property":"illuminance_raw","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"Wirenboard"},"disabled":false,"endpoints":{"1":{"bindings":[{"cluster":"genBasic","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msTemperatureMeasurement","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msIlluminanceMeasurement","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msRelativeHumidity","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msOccupancySensing","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msCO2","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutVoc","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutNoise","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutIrBlaster","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"genOta","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBasic","msIlluminanceMeasurement","msTemperatureMeasurement","msRelativeHumidity","msOccupancySensing","msCO2","sprutDevice","sprutVoc","sprutNoise","sprutIrBlaster"],"output":["genOnOff","genOta"]},"configured_reportings":[{"attribute":"measuredValue","cluster":"msTemperatureMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msIlluminanceMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":5},{"attribute":"measuredValue","cluster":"msRelativeHumidity","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"occupancy","cluster":"msOccupancySensing","maximum_report_interval":3600,"minimum_report_interval":0,"reportable_change":0},{"attribute":"measuredValue","cluster":"msTemperatureMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msIlluminanceMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":5},{"attribute":"measuredValue","cluster":"msRelativeHumidity","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"occupancy","cluster":"msOccupancySensing","maximum_report_interval":3600,"minimum_report_interval":0,"reportable_change":0},{"attribute":"sprutOccupancyLevel","cluster":"msOccupancySensing","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":5},{"attribute":"noise","cluster":"sprutNoise","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":5}],"scenes":[]},"2":{"bindings":[],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[],"scenes":[]},"3":{"bindings":[],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[],"scenes":[]},"4":{"bindings":[],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[],"scenes":[]}},"friendly_name":"WB-MSW_2floor","ieee_address":"0x842e14fffe8b232b","interview_completed":true,"interview_state":"SUCCESSFUL","interviewing":false,"manufacturer":"Sprut.device","model_id":"WBMSW3","network_address":10983,"power_source":"Unknown","software_build_id":"61","supported":true,"type":"Router"},{"date_code":"20201026","definition":{"description":"Wireless button","exposes":[{"access":5,"category":"diagnostic","description":"Remaining battery in %","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":5,"category":"diagnostic","description":"Reported battery voltage in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Triggered action (e.g. a button click)","label":"Action","name":"action","property":"action","type":"enum","values":["single","double","long"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"SNZB-01","options":[],"supports_ota":false,"vendor":"SONOFF"},"disabled":false,"endpoints":{"1":{"bindings":[{"cluster":"genOnOff","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"genPowerCfg","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBasic","genIdentify","genPowerCfg"],"output":["genOnOff","genIdentify"]},"configured_reportings":[{"attribute":"batteryVoltage","cluster":"genPowerCfg","maximum_report_interval":7200,"minimum_report_interval":3600,"reportable_change":0},{"attribute":"batteryPercentageRemaining","cluster":"genPowerCfg","maximum_report_interval":7200,"minimum_report_interval":3600,"reportable_change":0}],"scenes":[]}},"friendly_name":"Button2","ieee_address":"0x00124b00239703d7","interview_completed":true,"interview_state":"SUCCESSFUL","interviewing":false,"manufacturer":"eWeLink","model_id":"WB01","network_address":27001,"power_source":"Battery","supported":true,"type":"EndDevice"},{"definition":{"description":"Wall-mounted multi sensor","exposes":[{"endpoint":"l1","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l1","label":"State","name":"state","property":"state_l1","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"endpoint":"l2","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l2","label":"State","name":"state","property":"state_l2","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"endpoint":"l3","features":[{"access":7,"description":"On/off state of the switch","endpoint":"l3","label":"State","name":"state","property":"state_l3","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":7,"category":"config","description":"Controls green activity LED","endpoint":"indicator","label":"Activity led","name":"activity_led","property":"activity_led_indicator","type":"binary","value_off":false,"value_on":true},{"access":5,"category":"diagnostic","description":"Indicates whether the device is communicating with sensors via UART","label":"Uart connection","name":"uart_connection","property":"uart_connection","type":"binary","value_off":false,"value_on":true},{"access":5,"description":"Measured temperature value","label":"Temperature","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":7,"category":"config","description":"Self-heating compensation. The compensation value is subtracted from the measured temperature (default: 0)","label":"Temperature offset","name":"temperature_offset","property":"temperature_offset","type":"numeric","unit":"°C","value_max":10,"value_min":-10},{"access":5,"description":"Measured relative humidity","label":"Humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":7,"category":"config","description":"Turn on when working in conditions of high humidity (more than 70 %, RH) or condensation, if the sensor shows 0 or 100 %.","label":"Th heater","name":"th_heater","property":"th_heater","type":"binary","value_off":false,"value_on":true},{"access":5,"description":"Measured value","label":"CO2","name":"co2","property":"co2","type":"numeric","unit":"ppm"},{"access":5,"description":"Measured illuminance","label":"Illuminance","name":"illuminance","property":"illuminance","type":"numeric","unit":"lx"},{"access":5,"description":"Indicates whether the device detected occupancy","label":"Occupancy","name":"occupancy","property":"occupancy","type":"binary","value_off":false,"value_on":true},{"access":7,"category":"config","description":"If the sensor is triggered by the slightest movement, reduce the sensitivity, otherwise increase it (default: 50)","label":"Occupancy sensitivity","name":"occupancy_sensitivity","property":"occupancy_sensitivity","type":"numeric","value_max":2000,"value_min":0},{"access":5,"category":"diagnostic","description":"Measured occupancy level","label":"Occupancy level","name":"occupancy_level","property":"occupancy_level","type":"numeric"},{"access":7,"category":"config","description":"Time in seconds after which occupancy is cleared after detecting it (default: 60)","label":"Occupancy timeout","name":"occupancy_timeout","property":"occupancy_timeout","type":"numeric","unit":"s","value_max":2000,"value_min":0},{"access":5,"category":"diagnostic","description":"Measured noise level","label":"Noise","name":"noise","property":"noise","type":"numeric","unit":"dBA"},{"access":7,"category":"config","description":"The minimum noise level at which the detector will work (default: 50)","label":"Noise detect level","name":"noise_detect_level","property":"noise_detect_level","type":"numeric","unit":"dBA","value_max":150,"value_min":0},{"access":5,"description":"Indicates whether the device detected noise","label":"Noise detected","name":"noise_detected","property":"noise_detected","type":"binary","value_off":false,"value_on":true},{"access":7,"category":"config","description":"Time in seconds after which noise is cleared after detecting it (default: 60)","label":"Noise timeout","name":"noise_timeout","property":"noise_timeout","type":"numeric","unit":"s","value_max":2000,"value_min":0},{"access":5,"description":"Measured VOC level","label":"VOC","name":"voc","property":"voc","type":"numeric","unit":"µg/m³"},{"access":7,"category":"config","description":"UART baud rate","label":"Uart baud rate","name":"uart_baud_rate","property":"uart_baud_rate","type":"enum","values":["9600","19200","38400","57600","115200"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"WB-MSW-ZIGBEE v.4","options":[{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","label":"Temperature calibration","name":"temperature_calibration","property":"temperature_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Temperature precision","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","label":"Humidity calibration","name":"humidity_calibration","property":"humidity_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Humidity precision","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the co2 value (absolute offset), takes into effect on next report of device.","label":"Co2 calibration","name":"co2_calibration","property":"co2_calibration","type":"numeric"},{"access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device.","label":"Illuminance calibration","name":"illuminance_calibration","property":"illuminance_calibration","type":"numeric"},{"access":2,"description":"Calibrates the voc value (absolute offset), takes into effect on next report of device.","label":"Voc calibration","name":"voc_calibration","property":"voc_calibration","type":"numeric"},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Expose the raw illuminance value.","label":"Illuminance raw","name":"illuminance_raw","property":"illuminance_raw","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"access":3,"label":"Time","name":"time","type":"numeric"},"label":"No occupancy since","name":"no_occupancy_since","property":"no_occupancy_since","type":"list"}],"supports_ota":true,"vendor":"Wirenboard"},"disabled":false,"endpoints":{"1":{"bindings":[{"cluster":"genBinaryOutput","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msTemperatureMeasurement","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msRelativeHumidity","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msCO2","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msIlluminanceMeasurement","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"msOccupancySensing","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutNoise","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutVoc","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"sprutIrBlaster","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBasic","genBinaryOutput","msIlluminanceMeasurement","msTemperatureMeasurement","msRelativeHumidity","msOccupancySensing","msCO2","sprutDevice","sprutVoc","sprutNoise","sprutIrBlaster"],"output":["genOnOff","genOta"]},"configured_reportings":[{"attribute":"presentValue","cluster":"genBinaryOutput","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"measuredValue","cluster":"msTemperatureMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msRelativeHumidity","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msCO2","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":0.00005},{"attribute":"measuredValue","cluster":"msIlluminanceMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":5},{"attribute":"occupancy","cluster":"msOccupancySensing","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":0},{"attribute":"presentValue","cluster":"genBinaryOutput","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"measuredValue","cluster":"msTemperatureMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msRelativeHumidity","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":100},{"attribute":"measuredValue","cluster":"msCO2","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":0.00005},{"attribute":"sprutOccupancyLevel","cluster":"msOccupancySensing","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":5},{"attribute":"noise","cluster":"sprutNoise","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":5},{"attribute":"voc","cluster":"sprutVoc","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":10},{"attribute":"measuredValue","cluster":"msIlluminanceMeasurement","maximum_report_interval":3600,"minimum_report_interval":10,"reportable_change":5},{"attribute":"occupancy","cluster":"msOccupancySensing","maximum_report_interval":60,"minimum_report_interval":10,"reportable_change":0}],"scenes":[]},"2":{"bindings":[{"cluster":"genOnOff","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]},"3":{"bindings":[{"cluster":"genOnOff","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]},"4":{"bindings":[{"cluster":"genOnOff","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genOnOff"],"output":[]},"configured_reportings":[{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]},"5":{"bindings":[{"cluster":"genBinaryOutput","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBinaryOutput"],"output":[]},"configured_reportings":[{"attribute":"presentValue","cluster":"genBinaryOutput","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1},{"attribute":"presentValue","cluster":"genBinaryOutput","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]}},"friendly_name":"Parent_bedroom","ieee_address":"0x04cd15fffea0ae63","interview_completed":true,"interview_state":"SUCCESSFUL","interviewing":false,"manufacturer":"Sprut.device","model_id":"WBMSW4","network_address":15146,"power_source":"Mains (single phase)","software_build_id":"65","supported":true,"type":"Router"},{"date_code":"","definition":{"description":"Temperature & humidity sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Measured temperature value","label":"Temperature","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Measured relative humidity","label":"Humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},[{"attribute":"onOff","cluster":"genOnOff","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]},"5":{"bindings":[{"cluster":"genBinaryOutput","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBinaryOutput"],"output":[]},"configured_reportings":[{"attribute":"presentValue","cluster":"genBinaryOutput","maximum_report_interval":65000,"minimum_report_interval":0,"reportable_change":1}],"scenes":[]}},"friendly_name":"0x04cd15fffe8fb656","ieee_address":"0x04cd15fffe8fb656","interview_completed":true,"interview_state":"SUCCESSFUL","interviewing":false,"manufacturer":"Sprut.device","model_id":"WBMSW4","network_address":25619,"power_source":"Mains (single phase)","software_build_id":"65","supported":true,"type":"Router"}]
По крайней мере через dev console таких параметров нет
Спрошу у коллег, может быть кто-то делал.
Пока нет. Попробую на выходных скорректировать параметры вручную. Но конечно из wbrules было бы интереснее…
давайте пока закроем. явных проблем нет, может кого-то тоже заинтересует конфигурация датчика MSW по ZigBee из wb-rules, тогда подключусь :slight_smile:
