Использую WirenBoard 7. Пытаюсь обновить пакеты: apt update
Консоль выдает вот это:
Err:1 http://security.debian.org / debian-security bullseye-security InRelease
Could not resolve 'security.debian.org'
Err:2 https://deb.no desource.com/ nod e_16.x bullseye InRelease
Could not resolve 'deb.nodesource.com'
Err:3 http://deb.wirenboard.com/wb7/bullseye stable InRelease
Could not resolve 'deb.wirenboard.com'
Err:4 http://deb.debian.org/debian jessie InRelease
Could not resolve 'deb.debian.org'
Err:5 http://deb.debian.org/debian bullseye InRelease
Err:6 http://deb.debian.org/debian bullseye-updates InRelease
Err:7 http://deb.debian.org/debian bullseye-backports InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
W: Failed to fetch http://deb.debian.org/debian/dists/jessie/InRelease Could no t resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-backports/InRelea se Could not resolve 'deb.debian.org'
W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-sec urity/InRelease Could not resolve 'security.debian.org'
W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Could not resolve 'deb.nodesource.com'
W: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/dists/stable/InRelease Could not resolve 'deb.wirenboard.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Прошивка актуальная: release wb-2304 (as stable)
Судя по выводу - у вас не настроена сеть, а именно разрешение имен. Совсем не специфично именно для контроллера, поэтому провербте и настройте верный dns-сервер.
Подключился, при попытке обновить пакеты выдает вот это:
Ign:1 http://deb.debian.org/debian jessie InRelease
Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
Hit:3 http://deb.debian.org/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
Err:6 http://deb.debian.org/debian jessie Release
404 Not Found [IP: 146.75.118.132 80]
Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
E: The repository 'http://deb.debian.org/debian jessie Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/debian-upstream.list:5
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/debian-upstream.list:5
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/debian-upstream.list:5
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:4 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Packages (contrib/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Packages (contrib/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Translations (contrib/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Packages (non-free/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Packages (non-free/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
W: Target Translations (non-free/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream.list:5 and /etc/apt/sources.list.d/wirenboard.list:7
При попытке установить зигби выдает вот это:
root@wirenboard-ABIYNCEC:~# apt install zigbee2mqtt
Reading package lists… Done
E: Unable to locate package zigbee2mqtt
Толку от вас как от козла молока. 0 помощи абсолютно. Сам разобрался в итоге.
Поделитесь с сообществом что в итоге было, может кто-нибудь в будущем столкнётся с проблемой и сразу сможет посмотреть решение.
Думаю Wb debian stretch. apt update - #2 от пользователя BrainRoot
Вы задаете вопросы,ответы на которые прямо в консоль пишутся. И да - работа контроллера с пакетами происходит точно так же как на настольком компьютере, совершенно нет разницы.
