Настройка модуля WBE2R-R-ZIGBEE v.1
Испытываю трудности в настройкой модуля WBE2R-R-ZIGBEE v.1
Действу по инструкции, но при первом же пункте (apt update && apt install zigbee2mqtt), как я понимаю, получаю ошибку:
root@wirenboard-AUCNYTO:~# apt update && apt install zigbee2mqtt
Err:1 http://security.debian.org stretch/updates InRelease
Could not resolve ‘security.debian.org’
Err:2 Index of /debian stretch InRelease
Could not resolve ‘deb.debian.org’
Err:3 Index of /debian stretch-backports InRelease
Could not resolve ‘http.debian.net’
Err:4 Index of /debian stretch-updates InRelease
Err:5 http://deb.wirenboard.com/wb7/stretch stable InRelease
Could not resolve ‘deb.wirenboard.com’
Reading package lists… Done
Building dependency tree
1 package can be upgraded. Run ‘apt list --upgradable’ to see it.
W: Failed to fetch http://deb.debian.org/debian/dists/stretch/InRelease Could not resolve ‘deb.debian.org’
W: Failed to fetch http://deb.debian.org/debian/dists/stretch-updates/InRelease Could not resolve ‘deb.debian.org’
W: Failed to fetch http://security.debian.org/dists/stretch/updates/InRelease Could not resolve ‘security.debian.org’
W: Failed to fetch http://http.debian.net/debian/dists/stretch-backports/InRelease Could not resolve ‘http.debian.net’
W: Failed to fetch http://deb.wirenboard.com/wb7/stretch/dists/stable/InRelease Could not resolve ‘deb.wirenboard.com’
W: Some index files failed to download. They have been ignored, or old ones used instead.
The following additional packages will be installed:
libatomic1 nodejs wb-zigbee2mqtt
The following NEW packages will be installed:
libatomic1 nodejs wb-zigbee2mqtt zigbee2mqtt
0 upgraded, 4 newly installed, 0 to remove and 1 not upgraded.
Need to get 44.6 MB of archives.
After this operation, 221 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 Index of /debian stretch/main armhf libatomic1 armhf 6.3.0-18+deb9u1
Err:2 http://deb.wirenboard.com/wb7/stretch stable/main armhf nodejs armhf 12.19.0-1nodesource1
Err:3 http://deb.wirenboard.com/wb7/stretch stable/main armhf wb-zigbee2mqtt all 1.1.0
Err:4 http://deb.wirenboard.com/wb7/stretch stable/main armhf zigbee2mqtt armhf 1.25.2
Err:1 http://security.debian.org stretch/updates/main armhf libatomic1 armhf 6.3.0-18+deb9u1
E: Failed to fetch http://security.debian.org/pool/updates/main/g/gcc-6/libatomic1_6.3.0-18+deb9u1_armhf.deb Could not resolve ‘deb.debian.org’
E: Failed to fetch http://deb.wirenboard.com/wb7/stretch/pool/main/n/nodejs/nodejs_12.19.0-1nodesource1_armhf-stretch.deb Could not resolve ‘deb.wirenboard.com’
E: Failed to fetch http://deb.wirenboard.com/wb7/stretch/pool/main/w/wb-zigbee2mqtt/wb-zigbee2mqtt_1.1.0_all.deb Could not resolve ‘deb.wirenboard.com’
E: Failed to fetch http://deb.wirenboard.com/wb7/stretch/pool/main/z/zigbee2mqtt/zigbee2mqtt_1.25.2_armhf.deb Could not resolve ‘deb.wirenboard.com’
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Прошу подсказать, в чем проблема.
Модуль покупался в сборе с WB7, установленный уже в 4й порт.
Судя по описанию ошибки:
На контроллере не настроена сеть, как минимум нет валидного DNS сервера или указан неверно.
Прошу прощения за беспокойство, все разрешил
