Здравствуйте, пытался установить Драйвер SNMP, по SSH после ввода команд apt update и
apt install wb-mqtt-snmp выдает ошибки:
Welcome to Wiren Board 7.4.3 (s/n AWKMIBUU), release wb-2401 (as stable)
Linux wirenboard-AWKMIBUU 5.10.35-wb159+wb1 #1 SMP Fri Mar 22 15:10:33 UTC 2024 armv7l GNU/Linux
System load: 0.64 0.89 0.43 Up time: 3 min
Memory usage: 17% of 997M Usage of /: 33% of 2.0G /mnt/data: 2 0% of 4.9G
Last login: Wed Apr 10 15:20:47 2024 from 10.55.223.205
root@wirenboard-AWKMIBUU:~# apt update
Err:1 https://deb.nodesource.com/node_16.x bullseye InRelease
Could not resolve 'deb.nodesource.com'
Err:2 http://debian-mirror.wirenboard.com/debian bullseye InRelease
Could not resolve 'debian-mirror.wirenboard.com'
Err:3 http://deb.wirenboard.com/wb7/bullseye stable InRelease
Could not resolve 'deb.wirenboard.com'
Err:4 http://debian-mirror.wirenboard.com/debian bullseye-updates InRelease
Err:5 http://debian-mirror.wirenboard.com/debian bullseye-backports InRelease
Err:6 http://debian-mirror.wirenboard.com/debian-security bullseye-security InRe lease
Reading package lists... Done
Building dependency tree... Done
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InR elease Could not resolve 'debian-mirror.wirenboard.com'
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-upd ates/InRelease Could not resolve 'debian-mirror.wirenboard.com'
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-bac kports/InRelease Could not resolve 'debian-mirror.wirenboard.com'
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bul lseye-security/InRelease Could not resolve 'debian-mirror.wirenboard.com'
W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Could not resolve 'deb.nodesource.com'
W: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/dists/stable/InRelease Could not resolve 'deb.wirenboard.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
root@wirenboard-AWKMIBUU:~# apt install wb-mqtt-snmp
The following additional packages will be installed:
libpci3 libsensors-config libsensors5 libsnmp-base libsnmp40 pci.ids snmp
Suggested packages:
lm-sensors snmp-mibs-downloader
The following NEW packages will be installed:
wb-mqtt-snmp
0 upgraded, 8 newly installed, 0 to remove and 4 not upgraded.
Need to get 6115 kB of archives.
After this operation, 12.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1 http://deb.wirenboard.com/wb7/bullseye stable/main armhf wb-mqtt-snmp armh f 1.2.6
Err:2 http://debian-mirror.wirenboard.com/debian bullseye/main armhf pci.ids all 0.0~2021.02.08-1
Err:3 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libpci3 arm hf 1:3.7.0-5
Err:4 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsensors- config all 1:3.6.0-7
Err:5 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsensors5 armhf 1:3.6.0-7
Ign:6 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsnmp-bas e all 5.9+dfsg-4+deb11u1
Ign:7 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsnmp40 a rmhf 5.9+dfsg-4+deb11u1
Ign:8 http://debian-mirror.wirenboard.com/debian bullseye/main armhf snmp armhf 5.9+dfsg-4+deb11u1
Err:6 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsnmp-bas e all 5.9+dfsg-4+deb11u1
Err:7 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libsnmp40 a rmhf 5.9+dfsg-4+deb11u1
Err:8 http://debian-mirror.wirenboard.com/debian bullseye/main armhf snmp armhf 5.9+dfsg-4+deb11u1
E: Failed to fetch http://debian-mirror.wirenboard.com/debian/pool/main/p/pci.id s/pci.ids_0.0%7e2021.02.08-1_all.deb Could not resolve 'debian-mirror.wirenboar d.com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian/pool/main/p/pciuti ls/libpci3_3.7.0-5_armhf.deb Could not resolve 'debian-mirror.wirenboard.com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian/pool/main/l/lm-sen sors/libsensors-config_3.6.0-7_all.deb Could not resolve 'debian-mirror.wirenbo ard.com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian/pool/main/l/lm-sen sors/libsensors5_3.6.0-7_armhf.deb Could not resolve 'debian-mirror.wirenboard. com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/upda tes/main/n/net-snmp/libsnmp-base_5.9%2bdfsg-4%2bdeb11u1_all.deb Could not resol ve 'debian-mirror.wirenboard.com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/upda tes/main/n/net-snmp/libsnmp40_5.9%2bdfsg-4%2bdeb11u1_armhf.deb Could not resolv e 'debian-mirror.wirenboard.com'
E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/upda tes/main/n/net-snmp/snmp_5.9%2bdfsg-4%2bdeb11u1_armhf.deb Could not resolve 'de bian-mirror.wirenboard.com'
E: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/pool/main/w/wb-mqtt-sn mp/wb-mqtt-snmp_1.2.6_armhf.deb Could not resolve 'deb.wirenboard.com'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
