Установка драйвера SNMP
Добрый день хочу установить на ПЛК WirenBoard пакеты для дальнейшей возможности читать (и обрабатывать через правила JS) информации по протоколу SNMP. Нашел инструкцию. На данный момент столкнулся с трудностью при обновлении пакетов.
Установка
Сначала нужно установить пакет wb-mqtt-snmp, для этого введите в консоли команды:
apt update
apt install wb-mqtt-snmp
Reading package lists… Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libjsoncpp1 libwbmqtt libwbmqtt0 libwbmqtt1 wb-homa-ism-radio
Use ‘apt autoremove’ to remove them.
The following additional packages will be installed:
libpci3 libsensors4 libsnmp-base libsnmp30 snmp
Suggested packages:
lm-sensors snmp-mibs-downloader
The following NEW packages will be installed:
libpci3 libsensors4 libsnmp-base libsnmp30 snmp wb-mqtt-snmp
0 upgraded, 6 newly installed, 0 to remove and 1 not upgraded.
Need to get 5476 kB of archives.
After this operation, 11.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
нажимаю Y
Err:1 http://deb.wirenboard.com/wb6/stretch stable/main armhf wb-mqtt-snmp armhf 1.2.0
Could not connect to deb.wirenboard.com:80 (52.218.105.164). - connect (113: No route to host)
Err:2 Index of /debian stretch/main armhf libpci3 armhf 1:3.5.2-1
Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:14::644 80]
Err:3 Index of /debian stretch/main armhf libsensors4 armhf 1:3.4.0-4
Err:4 http://security.debian.org stretch/updates/main armhf libsnmp-base all 5.7.3+dfsg-1.7+deb9u3
Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to security.debian.org:80 (2a04:4e42:400::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:400::644 80]
Err:5 http://security.debian.org stretch/updates/main armhf libsnmp30 armhf 5.7.3+dfsg-1.7+deb9u3
Err:6 http://security.debian.org stretch/updates/main armhf snmp armhf 5.7.3+dfsg-1.7+deb9u3
E: Failed to fetch http://deb.debian.org/debian/pool/main/p/pciutils/libpci3_3.5.2-1_armhf.deb Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:14::644 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/l/lm-sensors/libsensors4_3.4.0-4_armhf.deb Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:14::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/libsnmp-base_5.7.3+dfsg-1.7+deb9u3_all.deb Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to security.debian.org:80 (2a04:4e42:400::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:400::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/libsnmp30_5.7.3+dfsg-1.7+deb9u3_armhf.deb Cannot initiate the connection to security.debian.org:80 (2a04:4e42:400::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:400::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/snmp_5.7.3+dfsg-1.7+deb9u3_armhf.deb Cannot initiate the connection to security.debian.org:80 (2a04:4e42:400::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:400::644 80]
E: Failed to fetch http://deb.wirenboard.com/wb6/stretch/pool/main/w/wb-mqtt-snmp/wb-mqtt-snmp_1.2.0_armhf.deb Could not connect to deb.wirenboard.com:80 (52.218.105.164). - connect (113: No route to host)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@wirenboard-AXIR7TYX:~# run apt-get update
-bash: run: command not found
root@wirenboard-AXIR7TYX:~# apt-get update
Ign:1 http://deb.wirenboard.com/wb6/stretch stable InRelease
Err:2 http://deb.wirenboard.com/wb6/stretch stable Release
Unable to connect to deb.wirenboard.com:http:
Ign:3 Index of /debian stretch InRelease
Ign:4 Index of /debian stretch-updates InRelease
Err:5 Index of /debian stretch Release
Err:6 Index of /debian stretch-updates Release
Ign:7 Index of /debian stretch-backports InRelease
Err:8 Index of /debian stretch-backports Release
Cannot initiate the connection to http.debian.net:80 (2001:67c:2564:a119::77). - connect (101: Network is unreachable) [IP: 2001:67c:2564:a119::77 80]
Ign:9 http://security.debian.org stretch/updates InRelease
Err:10 http://security.debian.org stretch/updates Release
E: The repository ‘http://deb.wirenboard.com/wb6/stretch stable Release’ does no longer have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository ‘Index of /debian stretch Release’ does no longer have a Release file.
E: The repository ‘Index of /debian stretch-updates Release’ does no longer have a Release file.
E: The repository ‘Index of /debian stretch-backports Release’ does no longer have a Release file.
E: The repository ‘http://security.debian.org stretch/updates Release’ does no longer have a Release file.
root@wirenboard-AXIR7TYX:~# apt install wb-mqtt-snmp
Suggested packages:
Do you want to continue? [Y/n] Y
Could not connect to deb.wirenboard.com:80 (52.218.116.140). - connect (113: No route to host)
Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to security.debian.org:80 (2a04:4e42::644). - connect (101: Network is unreachable) [IP: 2a04:4e42::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/libsnmp-base_5.7.3+dfsg-1.7+deb9u3_all.deb Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:14::644). - connect (101: Network is unreachable) Cannot initiate the connection to security.debian.org:80 (2a04:4e42::644). - connect (101: Network is unreachable) [IP: 2a04:4e42::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/libsnmp30_5.7.3+dfsg-1.7+deb9u3_armhf.deb Cannot initiate the connection to security.debian.org:80 (2a04:4e42::644). - connect (101: Network is unreachable) [IP: 2a04:4e42::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/n/net-snmp/snmp_5.7.3+dfsg-1.7+deb9u3_armhf.deb Cannot initiate the connection to security.debian.org:80 (2a04:4e42::644). - connect (101: Network is unreachable) [IP: 2a04:4e42::644 80]
E: Failed to fetch http://deb.wirenboard.com/wb6/stretch/pool/main/w/wb-mqtt-snmp/wb-mqtt-snmp_1.2.0_armhf.deb Could not connect to deb.wirenboard.com:80 (52.218.116.140). - connect (113: No route to host)
apt-get update
Ign:3 Index of /debian stretch-backports InRelease
Err:4 Index of /debian stretch-backports Release
Ign:5 Index of /debian stretch InRelease
Ign:6 Index of /debian stretch-updates InRelease
Err:7 Index of /debian stretch Release
Err:8 Index of /debian stretch-updates Release
Cannot initiate the connection to security.debian.org:80 (2a04:4e42:200::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:200::644 80]
Если я правильно понимаю, то он не может обновиться из репозитория.
Подскажите как установить Драйвер SNMP.
Из вывода понятно что нет доступа к интернету. А именно - не настроен шлюз.
