Factory reset USB flash
Received good update FIT /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit, starting update
Thu Sep  7 10:14:37 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
Description:         WirenBoard firmware update
Compatible device:   contactless,imx6ul-wirenboard61
Firmware version:    202309011013
Firmware compatible: +single-rootfs +force-repartition
Release name:        wb-2307
Release suite:       stable
Release target:      wb6/bullseye
Release repo prefix:
Time of creation:    Fri Sep  1 10:16:10 UTC 2023
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.0110086 s, 1.5 MB/s
tar: stdout: write error
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
>>> Using flags from /mnt/data/.wb-update/install_update.web.flags: --force-repartition
>>> Console logging enabled; tempfile /tmp/tmp.pMUXx7z31g, final file /mnt/data/.wb-update/wb-console.log will be written on exit
>>> Checking SHA1 hash of rootfs
>>> SHA1 hash of rootfs ok
>>> rootfs is valid, installing firmware update
>>> No factory FIT found, storing this update as factory FIT to use as bootlet
mkdir: cannot create directory ‘/tmp/tmp.4hrz5vgzHG/.wb-restore’: File exists
Thu Sep  7 10:15:59 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00465957 s, 3.5 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.oe0f6f0ilD, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.ks4B6oDH4n/.wb-restore’: File exists
Thu Sep  7 10:17:21 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00428432 s, 3.8 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.ENd2dNGdgs, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.BPrR8KgC2X/.wb-restore’: File exists
Thu Sep  7 10:18:43 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00617194 s, 2.7 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.wwYzbWR61c, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.mRoIdbmpc4/.wb-restore’: File exists
Thu Sep  7 10:20:00 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00458403 s, 3.6 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.Qp70nZIkmJ, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.l2OwBWT4ac/.wb-restore’: File exists
Thu Sep  7 10:21:23 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.0219562 s, 746 kB/s
>>> Console logging enabled; tempfile /tmp/tmp.r0FPMJIimI, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.mMzLG52Qmd/.wb-restore’: File exists
Thu Sep  7 10:22:43 UTC 2023: started update from /mnt/data/.wb-update/202309011013_wb-2307_bullseye_wb6x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00615315 s, 2.7 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.4P7b74ubPs, final file /mnt/data/.wb-update/wb-console.log will be written on exit
mkdir: cannot create directory ‘/tmp/tmp.pJCVcIGTKf/.wb-restore’: File exists
Блок питания HDR-100-24N через WB-UPS v.2 (правда у него батарея не держит, я так понял). Резервного нет. Фактически 24,12 В
Пришлите полный вывод при обновлении через флешку. По одной строке не понятно.
U-Boot SPL 2021.10-wb1.4.3-ge44f7a4224 (Oct 13 2022 - 09:52:21 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0	= 0x0112010f
.p0_mpdgctrl1	= 0x0e3f0e3f
.p0_mprddlctl	= 0x3f3f3d3d
.p0_mpwrdlctl	= 0x3f3f3836
.p0_mpwldectrl0	= 0x00080009
.p0_mpwldectrl1	= 0x000a000a
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.4.3-ge44f7a4224 (Oct 13 2022 - 09:52:21 +0000)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 64C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM:  512 MiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=3
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net:   eth0: ethernet@2188000
Hit any key to stop autoboot:  0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 2 USB Device(s) found
scanning bus usb@2184200 for devices... EHCI timed out on TD - token=0x80008d80
      USB device not accepting new address (error=22)
1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
  Device 0: Vendor: General  Rev: 5.00 Prod: UDisk
            Type: Removable Hard Disk
            Capacity: 7680.0 MB = 7.5 GB (15728640 x 512)
** No partition table - usb 0 **
Couldn't find partition usb 0:1
Can't set block device
No USB update detected, continuing boot
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
322 bytes read in 3 ms (104.5 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
6304344 bytes read in 274 ms (21.9 MiB/s)
MMC read: dev # 1, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard660
46098 bytes read in 5 ms (8.8 MiB/s)
670 bytes read in 3 ms (217.8 KiB/s)
Applying DT overlay wb6-gsm-sim800
597 bytes read in 3 ms (194.3 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 4 ms (124 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 3 ms (108.4 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 4 ms (61.5 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x603258 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Loading Device Tree to 9ef78000, end 9ef9afff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.35-wb142 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Thu Jul 20 07:59:09 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Wiren Board rev. 6.6.0 (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 489364K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18540K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000058] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002736] Console: colour dummy device 80x30
[    0.002801] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002840] pid_max: default: 32768 minimum: 301
[    0.003227] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003262] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.004945] CPU: Testing write buffer coherency: ok
[    0.006173] Setting up static identity map for 0x80100000 - 0x80100078
[    0.007037] devtmpfs: initialized
[    0.024454] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.024959] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.025007] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.026371] pinctrl core: initialized pinctrl subsystem
[    0.028375] NET: Registered protocol family 16
[    0.030583] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.032533] thermal_sys: Registered thermal governor 'step_wise'
[    0.032806] cpuidle: using governor menu
[    0.195145] vdd1p1: supplied by regulator-dummy
[    0.206173] vdd3p0: supplied by regulator-dummy
[    0.217213] cpu: supplied by regulator-dummy
[    0.228212] vddsoc: supplied by regulator-dummy
[    0.557811] No ATAGs?
[    0.557870] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.557890] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.558465] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[    0.559077] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[    0.560594] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[    0.560633] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.602904] mxs-dma 1804000.dma-apbh: initialized
[    0.608254] SCSI subsystem initialized
[    0.608746] usbcore: registered new interface driver usbfs
[    0.608869] usbcore: registered new interface driver hub
[    0.608980] usbcore: registered new device driver usb
[    0.609789] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.609913] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.610845] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[    0.611577] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.611704] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.612291] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[    0.612982] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.613104] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.613795] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[    0.615353] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.615700] i2c i2c-1: IMX I2C adapter registered
[    0.616440] mc: Linux media interface: v0.10
[    0.616554] videodev: Linux video capture interface: v2.00
[    0.616685] pps_core: LinuxPPS API ver. 1 registered
[    0.616707] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.616755] PTP clock support registered
[    0.617373] Advanced Linux Sound Architecture Driver Initialized.
[    0.619487] clocksource: Switched to clocksource mxc_timer1
[    0.637232] NET: Registered protocol family 2
[    0.638484] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.638581] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.638687] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.638791] TCP: Hash tables configured (established 4096 bind 4096)
[    0.638982] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.639038] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.639363] NET: Registered protocol family 1
[    0.640415] RPC: Registered named UNIX socket transport module.
[    0.640451] RPC: Registered udp transport module.
[    0.640469] RPC: Registered tcp transport module.
[    0.640487] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.641564] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.644368] Initialise system trusted keyrings
[    0.644854] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.656397] NFS: Registering the id_resolver key type
[    0.656473] Key type id_resolver registered
[    0.656492] Key type id_legacy registered
[    0.890817] Key type asymmetric registered
[    0.890857] Asymmetric key parser 'x509' registered
[    0.890979] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.891002] io scheduler mq-deadline registered
[    0.891021] io scheduler kyber registered
[    0.902852] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.902902] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.906738] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
[    1.569783] printk: console [ttymxc0] enabled
[    1.576203] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 58, base_baud = 5000000) is a IMX
[    1.586845] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 59, base_baud = 5000000) is a IMX
[    1.630437] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[    1.639794] random: fast init done
[    1.643765] random: crng init done
[    1.682007] brd: module loaded
[    1.700163] loop: module loaded
[    1.703653] at24 5-0050: supply vcc not found, using dummy regulator
[    1.715086] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.722133] at24 6-0050: supply vcc not found, using dummy regulator
[    1.733477] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.743412] libphy: Fixed MDIO Bus: probed
[    1.750462] pps pps0: new PPS source ptp0
[    1.790908] libphy: fec_enet_mii_bus: probed
[    1.796198] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[    1.920173] pps pps1: new PPS source ptp1
[    1.926837] libphy: fec_enet_mii_bus: probed
[    1.935522] fec 2188000.ethernet ethFEC1: registered PHC device 1
[    1.942630] PPP generic driver version 2.4.2
[    1.947313] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.953954] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.959723] usbcore: registered new interface driver usb-storage
[    1.965975] usbcore: registered new interface driver usbserial_generic
[    1.972639] usbserial: USB Serial support registered for generic
[    2.021556] rtc rtc0: invalid alarm value: 2023-09-01T25:06:00
[    2.027819] rtc-pcf8563 4-0051: registered as rtc0
[    2.044576] rtc-pcf8563 4-0051: setting system clock to 2023-09-07T11:36:38 UTC (1694086598)
[    2.062859] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[    2.069295] i2c /dev entries driver
[    2.076116] lm75 4-0048: supply vs not found, using dummy regulator
[    2.087714] lm75 4-0048: hwmon0: sensor 'lm75b'
[    2.207759] sdhci: Secure Digital Host Controller Interface driver
[    2.214039] sdhci: Copyright(c) Pierre Ossman
[    2.218410] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.233237] ledtrig-cpu: registered to indicate activity on CPUs
[    2.241133] usbcore: registered new interface driver usbhid
[    2.246732] usbhid: USB HID core driver
[    2.262060] Initializing XFRM netlink socket
[    2.266463] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[    2.274787] NET: Registered protocol family 10
[    2.282577] Segment Routing with IPv6
[    2.286698] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.294731] NET: Registered protocol family 17
[    2.299889] Key type dns_resolver registered
[    2.308195] registered taskstats version 1
[    2.312971] Loading compiled-in X.509 certificates
[    2.335684] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    2.347611] of_cfs_init
[    2.350416] of_cfs_init: OK
[    2.358229] ALSA device list:
[    2.361268]   No soundcards found.
[    2.364978] Waiting for root device /dev/mmcblk0p3...
[    2.374831] mmc0: new DDR MMC card at address 0001
[    2.380606] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[    2.385534] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[    2.391979] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[    2.398223] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB, chardev (245:0)
[    2.408941]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.436600] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[    2.444001] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[    2.883076] EXT4-fs (mmcblk0p3): recovery complete
[    2.890840] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    2.899077] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    2.907245] devtmpfs: mounted
[    2.917172] Freeing unused kernel memory: 1024K
[    2.922664] Run /sbin/init as init process
[    3.351514] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    3.375977] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 11 (bullseye)!
[    3.420860] systemd[1]: Set hostname to <wirenboard-AKQ2UEDD>.
[    5.021872] systemd[1]: Queued start job for default target Graphical Interface.
[    5.037464] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    5.073106] systemd[1]: Created slice system-modprobe.slice.
[  OK  ] Created slice system-modprobe.slice.
[    5.113321] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.157095] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[    5.205644] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.242083] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    5.280593] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    5.322445] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[    5.336756] systemd[1]: Reached target Local Encrypted Volumes.
[  OK  ] Reached target Local Encrypted Volumes.
[    5.380792] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.420144] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.455480] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[    5.492430] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    5.561041] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    5.571955] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.612049] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.661810] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.701419] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.744844] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    5.771635] systemd[1]: Mounting POSIX Message Queue File System...
[    5.822735] systemd[1]: Mounting /sys/kernel/config...
[    5.875986] systemd[1]: Mounting Kernel Debug File System...
[    5.920644] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    5.942375] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    6.001387] systemd[1]: Starting Load Kernel Module drm...
[    6.040561] systemd[1]: Starting Load Kernel Module fuse...
[    6.070009] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.093556] fuse: init (API version 7.32)
[    6.099135] systemd[1]: Starting File System Check on Root Device...
[    6.170801] systemd[1]: Starting Journal Service...
[    6.240730] systemd[1]: Starting Load Kernel Modules...
[    6.297382] systemd[1]: Starting Coldplug All udev Devices...
[    6.395435] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    6.467438] systemd[1]: Mounted /sys/kernel/config.
[  OK  ] Mounted /sys/kernel/config.
[    6.511624] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    6.541550] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[    6.644765] systemd[1]: modprobe@drm.service: Succeeded.
[    6.671954] systemd[1]: Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module drm.
[    6.701393] systemd[1]: modprobe@fuse.service: Succeeded.
[    6.720015] systemd[1]: Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Module fuse.
[    6.741938] systemd[1]: Finished File System Check on Root Device.
[  OK  ] Finished File System Check on Root Device.
[    6.770643] systemd[1]: Finished Load Kernel Modules.
[  OK  ] Finished Load Kernel Modules.
[    6.823093] systemd[1]: Mounting FUSE Control File System...
[    6.874745] systemd[1]: Started File System Check Daemon to report status.
[  OK  ] Started File System Check Daemon to report status.
[    6.962994] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.056120] systemd[1]: Starting Apply Kernel Variables...
[    7.104518] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted FUSE Control File System.
[    7.204364] EXT4-fs (mmcblk0p3): re-mounted. Opts: discard,errors=remount-ro
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Apply Kernel Variables.
         Starting Load/Save Random Seed...
         Starting Create System Users...
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Coldplug All udev Devices.
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Set up automount mnt-sdcard.automount.
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    9.988336] Driver for 1-wire Dallas network protocol.
[   10.083254] gpio-11 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   10.150148] gpio-108 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[  OK  ] Found device /dev/ttymxc0.
[   10.862059] fec 20b4000.ethernet eth1: renamed from ethFEC0
[   11.695314] fec 2188000.ethernet eth0: renamed from ethFEC1
[   11.713981] imx_usb 2184000.usb: No over current polarity defined
[   11.773150] ci_hdrc ci_hdrc.0: EHCI Host Controller
[   11.778101] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[   11.939617] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[   11.968187] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   11.976557] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.983819] usb usb1: Product: EHCI Host Controller
[   11.988705] usb usb1: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[   11.994737] usb usb1: SerialNumber: ci_hdrc.0
[   12.176825] hub 1-0:1.0: USB hub found
[   12.225868] hub 1-0:1.0: 1 port detected
[   12.308484] ci_hdrc ci_hdrc.1: EHCI Host Controller
[   12.381587] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[   12.475540] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[   12.529856] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   12.538148] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.545437] usb usb2: Product: EHCI Host Controller
[   12.550347] usb usb2: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[   12.556377] usb usb2: SerialNumber: ci_hdrc.1
[   12.749658] usb usb1-port1: over-current condition
[   12.769836] hub 2-0:1.0: USB hub found
[   12.829586] hub 2-0:1.0: 1 port detected
[   12.919654] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[   13.160772] usb 1-1: New USB device found, idVendor=abcd, idProduct=1234, bcdDevice= 1.00
[   13.169013] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   13.176232] usb 1-1: Product: UDisk
[   13.180708] usb 1-1: Manufacturer: General
[   13.184899] usb 1-1: SerialNumber: Љ
[   13.219606] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[   13.401556] usb-storage 1-1:1.0: USB Mass Storage device detected
[   13.470211] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[   13.478438] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   13.599194] hub 2-1:1.0: USB hub found
[   13.623275] scsi host0: usb-storage 1-1:1.0
[   13.705233] hub 2-1:1.0: 4 ports detected
[   14.079588] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[   14.240950] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[   14.249355] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   14.256743] usb 2-1.1: Product: 802.11n WLAN Adapter
[   14.261738] usb 2-1.1: Manufacturer: Realtek
[   14.266015] usb 2-1.1: SerialNumber: 00e04c000001
[   14.650731] scsi 0:0:0:0: Direct-Access     General  UDisk            5.00 PQ: 0 ANSI: 2
[   14.701328] sd 0:0:0:0: [sda] 15728640 512-byte logical blocks: (8.05 GB/7.50 GiB)
[   14.744960] sd 0:0:0:0: [sda] Write Protect is off
[   14.784446] sd 0:0:0:0: [sda] No Caching mode page found
[   14.789851] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   14.867727]  sda:
[   14.893472] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   15.639597] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   15.672277] Bluetooth: Core ver 2.22
[   15.684323] NET: Registered protocol family 31
[   15.688820] Bluetooth: HCI device and connection manager initialized
[   15.726608] Bluetooth: HCI socket layer initialized
[  OK  ] Found device [   15.745173] Bluetooth: L2CAP socket layer initialized
/dev/mmcblk0p5.
[   15.761909] Bluetooth: SCO socket layer initialized
[   15.807461] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.864147] usbcore: registered new interface driver btusb
[   15.872414] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[   15.886246] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   15.892383] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[   15.901621] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[   15.908223] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[   15.917496] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[   15.953472] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[  OK  ] Found device /dev/mmcblk0p6.
[   16.497168] RTL871X: module init start
[   16.501032] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[   16.689676] RTL871X: rtw_ndev_init(wlan0)
         Activating swap /dev/mmcblk0p5...
[   16.706799] RTL871X: rtw_ndev_init(wlan1)
[   16.723236] usbcore: registered new interface driver rtl8723bu
[   16.729157] RTL871X: module init ret=0
[   16.753952] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
         Starting File System Check on /dev/mmcblk0p6...
         Starting Load/Save RF Kill Switch Status...
[   17.592955] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SSDsc
[   17.752574] usbcore: registered new interface driver rtl8xxxu
[  OK  ] Activated swap /dev/mmcblk0p5.
[  OK  ] Reached target Swap.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Finished Helper to synchronize boot up for ifupdown.
[  OK  ] Finished File System Check on /dev/mmcblk0p6.
         Mounting /mnt/data...
[   19.266831] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: discard
[  OK  ] Mounted /mnt/data.
         Mounting /var/log...
[  OK  ] Mounted /var/log.
[  OK  ] Reached target Local File Systems.
[  OK  ] Started ifup for eth0.
[  OK  ] Started ifup for eth1.
         Starting Flush Journal to Persistent Storage...
         Starting prepare mounts and symlinks to config files...
[   19.760587] systemd-journald[121]: Received client request to flush runtime journal.
[   19.825004] systemd-journald[121]: File /var/log/journal/c6e020b323ad4d2ebb8a1415d9658cbf/system.journal corrupted or uncleanly shut down, renaming and replacing.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished prepare mounts and symlinks to config files.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Monitor directorie… templates for wb-mqtt-serial.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on fcgiwrap Socket.
[  OK  ] Listening on KNX Daemon (socket).
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Bluetooth service...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
         Starting Remove Stale Onli…t4 Metadata Check Snapshots...
         Starting Authorization Manager...
         Starting User Login Management...
[  OK  ] Started watch config files.
         Starting Initialize Wiren Board Device Tree overlays...
[  OK  ] Started Generates wb-mqtt-… UI schema for wb-mqtt-confed.
         Starting Avahi mDNS/DNS-SD Stack...
[   25.016967] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   25.022436] Bluetooth: BNEP filters: protocol multicast
[   25.107905] Bluetooth: BNEP socket layer initialized
         Starting WPA supplicant...
[  OK  ] Started Authorization Manager.
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth.
         Starting Modem Manager...
         Starting Hostname Service...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started WPA supplicant.
[  OK  ] Started User Login Management.
[  OK  ] Started Modem Manager.
[   32.909801] SMSC LAN8710/LAN8720 2188000.ethernet-2:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-2:00, irq=POLL)
[  OK  ] Started Hostname Service.
[   35.129974] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   35.887330] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   43.522422] Micrel KSZ8081 or KSZ8091 2188000.ethernet-2:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet-2:03, irq=POLL)
[    **] (2 of 3) A start job is running for Network Manager (49s / 1min 49s)
[***   ] (1 of 3) A start job is running for…a Check Snapshots (53s / no limit)
[  OK  ] Finished Initialize Wiren Board Device Tree overlays.
         Starting Raise network interfaces...
         Starting Power on GSM modem...
         Starting KNXD Configurator for Wiren Board...
[  OK  ] Finished Raise network interfaces.
[ INFO ] Skipped Power on GSM modem.
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
         Starting Network Manager Wait Online...
         Starting dnsmasq - A light…DHCP and caching DNS server...
         Starting Access point and …rver for Wi-Fi and Ethernet...
         Starting KNX Daemon...
         Starting Mosquitto MQTT Broker...
         Starting Network Time Service...
         Starting OpenBSD Secure Shell server...
         Starting Permit User Sessions...
[  OK  ] Started Network connection…rvice for Wiren Board devices.
         Starting MQTT Driver for ADC...
         Starting MQTT Driver for GPIO-controlled switches...
[  OK  ] Started MQTT Driver for serial devices.
[  OK  ] Started Kernel 1-Wire MQTT driver for WB-HomA.
[  OK  ] Started KNX Daemon.
[  OK  ] Finished KNXD Configurator for Wiren Board.
[ INFO ] Skipped dnsmasq - A lightw…t DHCP and caching DNS server.
[ INFO ] Skipped Access point and a…server for Wi-Fi and Ethernet.
обрезал последние несколько строк из-за ограничений редактора.
На флешке нет таблицы разделов. Опишите процесс подготовки флешки. В какой ОС это делаете и какое ПО используете?
Видел. Это было выделено в моем стартовом посте.
  1. Купил новую флэшку 32ГБ, согласно статье Форматирование USB-накоптеля в FAT32 — Wiren Board отформатировал в FAT32 в Windows, скопировал прошивку, отмонтировал.
  2. Вижу эту ошибку. Пробую еще раз. Та же флэшка, тот же способ.
  3. Вижу эту ошибку. Покупаю новую флэшку, 7ГБ. Пробую тем же способом.
  4. Ваш коллега выше давал ссылку на другой тикет Не подключается к WEB UI и SSH - #14 от пользователя BrainRoot. Согласно ему, на самом контроллере отформатировал флэшку 7ГБ, скопировал туда прошивку, проверил хэш, отмонтировал, перезагрузился. После нормальной загрузки контроллера примонтировал флэшку, убедился, что файл в корне на месте и называется корректно.
Все 4 способа приводили к одной и той же ошибке
и
Довольно инетерсно…
А что возвращает
fw_printenv
На контроллере?
Ну и - выполните
apt update
apt install u-boot-wb6
u-boot-install-wb
fw_printenv
_decr_timeout=setexpr fw_timeout ${fw_timeout} - 1
_led_toggle_state=0
_usb_update_checkbutton=run _usb_update_print_msg ; run led_wait_init ; if run wait_button_up; then if run wait_button_down; then run _usb_update_start; fi; fi
_usb_update_checkfile=if load ${fw_dev} ${loadaddr} ${fw_file} 1 ; then run _usb_update_checkbutton ; elif load ${fw_dev} ${loadaddr} ${fw_reset_file} 1 ; then setenv fw_file ${fw_reset_file}; run _usb_update_checkbutton ; fi
_usb_update_print_msg=echo ; echo '##############################' ; echo '# Detected USB flash drive with update file' ; echo "# Filename: ${fw_file}" ; echo "# Press a FW key if you want to update firmware from this file" ; echo "# or wait 3 seconds to boot normally." ; echo "##############################"
_usb_update_start=run led_fw_init; echo USB update procedure start; run do_usb_update
_wait_loop=run led_wait_toggle ; sleep 0.2 ; run _decr_timeout
addoverlay=if ${fdt_load_continue} && load mmc ${mmcdev}:${mmcpart} ${fdt_overlay_addr} ${fdt_overlays_dir}/${ovl}.dtbo; then echo Applying DT overlay ${ovl};if fdt apply ${fdt_overlay_addr}; then true; else echo Failed to apply overlay ${ovl};setenv fdt_load_continue false;fi;fi
altbootcmd=if test ${mmcpart} -eq 2; then echo Switching to rootfs on partition 3;setenv mmcpart 3;else; echo Switching to rootfs on partition 2;setenv mmcpart 2;fi;setenv bootcount 0;saveenv; boot
baudrate=115200
board_name=WB
board_rev=6UL
bootcmd=run maybe_usbupdate;mmc dev ${mmcdev};if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then run bootenv; fi;echo Running default loadzimage ...;if run loadzimage; then run loadfdt; run mmcboot; fi;fi;
bootdelay=3
bootenv=echo Importing environment from ${loadaddr}...; env import -t ${loadaddr} ${filesize};echo Checking if uenvcmd is set ...;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;
bootlimit=3
bootrestore=echo Restoring minimal partition table and bootloader; setexpr RESTOREBOOT_SIZE *$bootrestore_size / 0x200 ; setexpr RESTOREBOOT_START *$bootrestore_start ; mmc write $RESTOREBOOT_START 2 $RESTOREBOOT_SIZE ; mw.l $bootrestore_flag 0 ; led red on ; echo Done! Now do a power cycle ; reset
bootrestore_flag=0x82fffffc
bootrestore_size=0x82fffff8
bootrestore_start=0x82fffff4
console=ttymxc0
do_usb_update=echo Checking if ubootenv part is present; if fsfitxtract ${fw_dev} ${fw_file} ubootenv ${loadaddr}; then run bootenv; else echo Extracting kernel; fsfitxtract ${fw_dev} ${fw_file} kernel ${loadaddr}; echo Extracting DTB; fsfitxtract ${fw_dev} ${fw_file} dtb ${fdt_addr}; setenv optargs ${optargs} bootmode=usbupdate,${fw_file}; run setbootargs; bootz ${loadaddr} - ${fdt_addr}; fi;
eth1addr=54:10:ec:34:1e:be
ethaddr=54:10:ec:34:61:52
fdt_addr=0x83000000
fdt_dir=/boot/dtbs
fdt_extra_overlay_offset=0x7e0
fdt_extra_overlay_size=0x20
fdt_file=/boot/dtbs/imx6ul-wirenboard61.dtb
fdt_maxsize=0x20000
fdt_overlay_addr=0x84000000
fdt_overlays_dir=/boot/overlays
fw_dev=usb 0:1
fw_file=wb6_update.fit
fw_reset_file=wb6_update_FACTORYRESET.fit
fw_timeout="14"
ip_dyn=yes
kernel_mmcdev=0
led_fw_init=led green on; led red off;
led_nofw_init=led green off; led red on;
led_wait_init=led red on ; led green on
led_wait_toggle=if test ${_led_toggle_state} -eq 0; then led green on; led red on; else led green off; led red off; fi; setexpr _led_toggle_state ${_led_toggle_state} ^ 1
loadaddr=0x82000000
loadbootenv=load mmc ${mmcdev}:${mmcpart} ${loadaddr} /boot/uEnv.txt
loadfdt=run loadfdtandoverlays
loadfdtandoverlays=mmc read ${fdt_overlay_addr} ${fdt_extra_overlay_offset} ${fdt_extra_overlay_size};if fdt addr ${fdt_overlay_addr}; then setenv fdt_extra_overlay_addr ${fdt_overlay_addr};setexpr fdt_extra_overlay_size_bytes ${fdt_extra_overlay_size} * 0x200;setexpr fdt_overlay_addr ${fdt_overlay_addr} + ${fdt_extra_overlay_size_bytes};echo Reading overlays list from eMMC;fdt get value fdt_overlays /fragment/__overlay__ overlays;echo Reading factory fdt name from eMMC;fdt get value fdt_name_factory /fragment/__overlay__ factory-fdt;fi;run loadmainfdt;fdt addr ${fdt_addr} ${fdt_maxsize};setenv fdt_load_continue true;for ovl in ${fdt_overlays}; do run addoverlay;done;if ${fdt_load_continue} && test -n ${fdt_extra_overlay_addr}; then echo Applying extra overlay;if fdt apply ${fdt_extra_overlay_addr}; then true; else echo Failed to apply extra overlay;setenv fdt_load_continue false;fi;fi;if ${fdt_load_continue}; then true; else echo Some overlays are not applied, booting in failsafe;run loadmainfdt;fdt addr ${fdt_addr} ${fdt_maxsize};fdt set / wirenboard-boot-failsafe;fi;
loadmainfdt=if test -n ${fdt_file_override} && echo Loading fdt_file_override ${fdt_file_override} && load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file_override}; then true; else if test -n ${fdt_name_factory} && echo Loading factory fdt ${fdt_name_factory} && load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_dir}/${fdt_name_factory}.dtb;then true; else echo Loading fdt_file ${fdt_file};load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file};fi;fi;
loadzimage=load mmc ${mmcdev}:${mmcpart} ${loadaddr} /boot/zImage
maybe_usbupdate=echo Checking if there is a USB storage with update file ${fw_file}; regulator dev usb1_vbus; regulator enable; usb start; if usb storage; then run _usb_update_checkfile ; fi; run led_nofw_init ; echo No USB update detected, continuing boot
mmcargs=setenv optargs ${optargs} root=/dev/mmcblk${kernel_mmcdev}p${mmcpart} rootwait ro; run setbootargs
mmcboot=echo Booting from mmc ...; run mmcargs; bootz ${loadaddr} - ${fdt_addr}
mmcdev=1
mmcpart=3
netargs=setenv optargs ${optargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp; run setbootargs
netboot=echo Booting from net ...; run netargs; tftp zImage; if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else bootz; fi;
not_timeout=test 0x${fw_timeout} -gt 0
ramboot=echo Programming fuses ...; fuse prog -y 0 5 0x4860; fuse prog -y 0 6 0x10; echo Booting kernel from RAM ...; run setbootargs; bootz ${loadaddr} - ${fdt_addr};
read_button=gpio qi GPIO5_10
setbootargs=setenv bootargs console=${console},${baudrate} ${optargs}
videomode=video=ctfb:x:480,y:272,depth:24,pclk:108695,le:8,ri:4,up:2,lo:4,hs:41,vs:10,sync:0,vmode:0
wait_button_down=until run read_button && run not_timeout ; do run _wait_loop; done; run not_timeout
wait_button_up=while run read_button && run not_timeout ; do run _wait_loop; done; run not_timeout
bootcount=0
upgrade_available=0
u-boot-install-wb
Das U-Boot installer for Wiren Board
You are about to install U-boot image '/usr/lib/u-boot/mx6ul_wirenboard6/u-boot-with-spl.imx' on '/dev/mmcblk0' (platform wb6)
Do you want to continue (y/n)?y
Writing U-boot image '/usr/lib/u-boot/mx6ul_wirenboard6/u-boot-with-spl.imx' on '/dev/mmcblk0' (options 'bs=512 seek=2')
831+1 записей получено
831+1 записей отправлено
425816 байт (426 kB, 416 KiB) скопирован, 0,628564 s, 677 kB/s
Syncing device
Пришлите вывод команд:
blkid
и
lsblk | grep sd
при вставленных флешках
blkid
/dev/mmcblk0p1: PARTUUID="f31e1617-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="8371addb-38f1-4bec-a3e7-6dd49c79032a" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f31e1617-02"
/dev/mmcblk0p3: UUID="7a6217e7-c8f0-4bc6-a5dd-58cec811dec1" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f31e1617-03"
/dev/mmcblk0p5: UUID="7cd0b6d4-b3f8-49a2-85fa-dae21de9aa37" TYPE="swap" PARTUUID="f31e1617-05"
/dev/mmcblk0p6: LABEL="data" UUID="6b523279-10f0-480a-af0d-bc10bcc779c9" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f31e1617-06"
/dev/sda: UUID="6370-0423" BLOCK_SIZE="512" TYPE="vfat"
lsblk | grep sd
sda            8:0    1  7,5G  0 disk
root@wirenboard-AKQ2UEDD:~#
Не вижу раздела на флешке. Показывает только сам диск.
Совершенно верно…
Тоже самое с другой флешкой посмотрите.
blkid
/dev/sda1: LABEL="KINGSTON" UUID="1618-C379" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02f5df23-01"
lsblk | grep sd
sda            8:0    1 28,9G  0 disk
└─sda1         8:1    1 28,9G  0 part
Попробуйте обновиться с этой флешкой и пришлите вывод консоли.
Какого типа раздел, кстати?
U-Boot SPL 2021.10-wb1.6.0-g9e72dde28f (Jul 11 2023 - 12:18:34 +0000)
.p0_mpdgctrl0	= 0x01120110
.p0_mprddlctl	= 0x3f3f3c3e
.p0_mpwrdlctl	= 0x3f3f3734
.p0_mpwldectrl0	= 0x0008000a
.p0_mpwldectrl1	= 0x000b000b
.p0_mpdgctrl0	= 0x010d010b
.p0_mprddlctl	= 0x3f3f3d3e
.p0_mpwrdlctl	= 0x3f3f3835
.p0_mpwldectrl0	= 0x00080008
.p0_mpwldectrl1	= 0x00090009
U-Boot 2021.10-wb1.6.0-g9e72dde28f (Jul 11 2023 - 12:18:34 +0000)
CPU:   Industrial temperature grade (-40C to 105C) at 45C
Reset cause: POR
DRAM:  512 MiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
bootcount=0
mmcpart=3
upgrade_available=0
## Info: input data size = 4285 = 0x10BD
eMMC found on device 1
Press FW button to enter firmware update mode
Entering firmware update mode.
## Loading FIT header to 0x82000000 ...
** File not found .wb-restore/factoryreset.fit **
Read failed: -1Extracting kernel
Read failed: -1Extracting DTB
## Loading FIT header to 0x83000000 ...
Read failed: -1zimage: Bad magic!
ERROR: Failed to enter update mode!
ERROR: /mnt/data/.wb-restore/factoryreset.fit missing or corrupt
starting USB...
scanning bus usb@2184000 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
597 bytes read in 4 ms (145.5 KiB/s)
   Loading Device Tree to 9ef77000, end 9ef99fff ... OK
Starting kernel ...
[    0.000000] Kernel command line: console=ttymxc0,115200 bootmode=update_auto root=/dev/mmcblk0p3 rootwait ro
[    0.000059] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002724] Console: colour dummy device 80x30
[    0.002785] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002822] pid_max: default: 32768 minimum: 301
[    0.003213] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003250] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.004938] CPU: Testing write buffer coherency: ok
[    0.007056] devtmpfs: initialized
[    0.024503] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.025004] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.025050] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.026425] pinctrl core: initialized pinctrl subsystem
[    0.028414] NET: Registered protocol family 16
[    0.030632] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.032578] thermal_sys: Registered thermal governor 'step_wise'
[    0.032849] cpuidle: using governor menu
[    0.195434] vdd1p1: supplied by regulator-dummy
[    0.206470] vdd3p0: supplied by regulator-dummy
[    0.217537] cpu: supplied by regulator-dummy
[    0.228586] vddsoc: supplied by regulator-dummy
[    0.558949] No ATAGs?
[    0.559010] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.559029] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.559599] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[    0.560215] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[    0.561709] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[    0.561746] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.604254] mxs-dma 1804000.dma-apbh: initialized
[    0.609474] SCSI subsystem initialized
[    0.609980] usbcore: registered new interface driver usbfs
[    0.610104] usbcore: registered new interface driver hub
[    0.610210] usbcore: registered new device driver usb
[    0.611019] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.611148] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.612080] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[    0.612812] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.612939] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.613615] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[    0.614321] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.614447] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.615052] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[    0.616603] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.616952] i2c i2c-1: IMX I2C adapter registered
[    0.617686] mc: Linux media interface: v0.10
[    0.617799] videodev: Linux video capture interface: v2.00
[    0.617927] pps_core: LinuxPPS API ver. 1 registered
[    0.617946] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.617997] PTP clock support registered
[    0.618608] Advanced Linux Sound Architecture Driver Initialized.
[    0.620725] clocksource: Switched to clocksource mxc_timer1
[    0.638401] NET: Registered protocol family 2
[    0.639650] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.639752] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.639857] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.639961] TCP: Hash tables configured (established 4096 bind 4096)
[    0.640151] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.640205] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.640531] NET: Registered protocol family 1
[    0.641581] RPC: Registered named UNIX socket transport module.
[    0.641621] RPC: Registered udp transport module.
[    0.641640] RPC: Registered tcp transport module.
[    0.641654] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.642731] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.645538] Initialise system trusted keyrings
[    0.646014] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.657552] NFS: Registering the id_resolver key type
[    0.657636] Key type id_resolver registered
[    0.657655] Key type id_legacy registered
[    0.896761] Key type asymmetric registered
[    0.896804] Asymmetric key parser 'x509' registered
[    0.896927] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.896949] io scheduler mq-deadline registered
[    0.896967] io scheduler kyber registered
[    0.908734] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.908784] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.912722] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
[    1.577566] printk: console [ttymxc0] enabled
[    1.584055] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 58, base_baud = 5000000) is a IMX
[    1.594651] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 59, base_baud = 5000000) is a IMX
[    1.638295] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[    1.645725] random: fast init done
[    1.649676] random: crng init done
[    1.689666] brd: module loaded
[    1.707834] loop: module loaded
[    1.711413] at24 5-0050: supply vcc not found, using dummy regulator
[    1.722850] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.729833] at24 6-0050: supply vcc not found, using dummy regulator
[    1.741250] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.751209] libphy: Fixed MDIO Bus: probed
[    1.758158] pps pps0: new PPS source ptp0
[    1.798363] libphy: fec_enet_mii_bus: probed
[    1.803878] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[    1.931427] pps pps1: new PPS source ptp1
[    1.938005] libphy: fec_enet_mii_bus: probed
[    1.946715] fec 2188000.ethernet ethFEC1: registered PHC device 1
[    1.953830] PPP generic driver version 2.4.2
[    1.958516] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.965159] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.970929] usbcore: registered new interface driver usb-storage
[    1.977179] usbcore: registered new interface driver usbserial_generic
[    1.983835] usbserial: USB Serial support registered for generic
[    2.032709] rtc rtc0: invalid alarm value: 2023-09-01T25:06:00
[    2.038972] rtc-pcf8563 4-0051: registered as rtc0
[    2.055715] rtc-pcf8563 4-0051: setting system clock to 2023-09-07T13:23:01 UTC (1694092981)
[    2.073976] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[    2.080415] i2c /dev entries driver
[    2.087234] lm75 4-0048: supply vs not found, using dummy regulator
[    2.098843] lm75 4-0048: hwmon0: sensor 'lm75b'
[    2.218912] sdhci: Secure Digital Host Controller Interface driver
[    2.225192] sdhci: Copyright(c) Pierre Ossman
[    2.229562] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.244371] ledtrig-cpu: registered to indicate activity on CPUs
[    2.252245] usbcore: registered new interface driver usbhid
[    2.257847] usbhid: USB HID core driver
[    2.273134] Initializing XFRM netlink socket
[    2.277540] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[    2.285865] NET: Registered protocol family 10
[    2.293640] Segment Routing with IPv6
[    2.297773] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.305806] NET: Registered protocol family 17
[    2.310983] Key type dns_resolver registered
[    2.319298] registered taskstats version 1
[    2.324079] Loading compiled-in X.509 certificates
[    2.346757] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    2.358668] of_cfs_init
[    2.361464] of_cfs_init: OK
[    2.369290] ALSA device list:
[    2.372335]   No soundcards found.
[    2.376043] Waiting for root device /dev/mmcblk0p3...
[    2.386033] mmc0: new DDR MMC card at address 0001
[    2.391802] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[    2.396732] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[    2.403178] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[    2.409426] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB, chardev (245:0)
[    2.420144]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.447979] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[    2.455382] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[    2.650876] EXT4-fs (mmcblk0p3): recovery complete
[    2.660791] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    2.669022] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    2.677683] devtmpfs: mounted
[    2.682373] Freeing unused kernel memory: 1024K
[    2.687186] Run /sbin/init as init process
[    3.112592] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    3.137041] systemd[1]: Detected architecture arm.
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 60538879 60538816 28.9G c W95 FAT32 (LBA)
Предположу. Такое ощущение, что вы рано нажали кнопку FW. Нажмите в данный момент.
