Хочу чтобы логи не забивались постоянными рестартами knxd, как можно его надежно отключить?
systemctl disable knxd - не помогает, как и другие советы, найденные на форуме, только изменилось содержимое флуда в логах
27-06-2024 03:07:30.918 [init.scope] wb-mqtt-knx.service: Failed with result 'signal'.
27-06-2024 03:07:30.917 [init.scope] wb-mqtt-knx.service: Main process exited, code=killed, status=6/ABRT
27-06-2024 03:07:30.915 [mosquitto] 1719446850: Client wb-mqtt-knx closed its connection.
27-06-2024 03:07:30.911 [wb-mqtt-knx] terminate called without an active exception
27-06-2024 03:07:30.910 [wb-mqtt-knx] ERROR: Failed to open KnxServerUrl: ip:localhost:6720. Is knxd running?
27-06-2024 03:07:30.907 [wb-mqtt-knx] INFO: Connecting to knxd... URL: 'ip:localhost:6720'
~# systemctl status knxd
● knxd.service - KNX Daemon
Loaded: loaded (/lib/systemd/system/knxd.service; disabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since Wed 2024-06-26 23:35:59 UTC; 12s ago
TriggeredBy: ● knxd.socket
Process: 21271 ExecStart=/usr/bin/knxd $KNXD_OPTS (code=exited, status=1/FAILURE)
Main PID: 21271 (code=exited, status=1/FAILURE)
CPU: 45ms
