Выкорчевать knxd
Доброго дня.
При доставании очередного контроллера из коробки сразу делаю systemctl disable все-ненужные-сервисы, а вот на релизе 2110 случайно ткнулся в лог и увидел, что система упрямо пытается перезапустить knxd, фейлит и снова пытается, НЕСМОТРЯ на статус disabled.
Nov 22 19:36:52 wirenboard-ATB3WPB2 knxd[19905]: WirenboardKNX: E00000067: [22:A.ncn5120] Opening /dev/ttyKNX failed: No such file or directory
Nov 22 19:36:52 wirenboard-ATB3WPB2 systemd[1]: Started KNX Daemon.
Nov 22 19:36:52 wirenboard-ATB3WPB2 knxd[19905]: WirenboardKNX: F00000105: [19:A.ncn5120] Link down, terminating
Nov 22 19:36:52 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Main process exited, code=exited, status=1/FAILURE
Nov 22 19:36:52 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Unit entered failed state.
Nov 22 19:36:52 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Failed with result 'exit-code'.
Nov 22 19:37:01 wirenboard-ATB3WPB2 CRON[19948]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 22 19:37:01 wirenboard-ATB3WPB2 CRON[19954]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Service hold-off time over, scheduling restart.
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: Stopped KNX Daemon.
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: Starting KNX Daemon...
Nov 22 19:37:02 wirenboard-ATB3WPB2 knxd[19967]: WirenboardKNX: E00000067: [22:A.ncn5120] Opening /dev/ttyKNX failed: No such file or directory
Nov 22 19:37:02 wirenboard-ATB3WPB2 knxd[19967]: WirenboardKNX: F00000105: [19:A.ncn5120] Link down, terminating
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: Started KNX Daemon.
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Main process exited, code=exited, status=1/FAILURE
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Unit entered failed state.
Nov 22 19:37:02 wirenboard-ATB3WPB2 systemd[1]: knxd.service: Failed with result 'exit-code'.
Как корректно убрать его запуск, чтоб, например, следующий апгрейд ненароком не спятил? Я могу вымарать его ручками, но, по опыту, это может привести потом к странным глюкам.
Здравствуйте! Эта проблема известна и уже решена, исправление доступно в релизе stable wb-2110. Для получения исправлений обновите контроллер снова:
apt update && apt upgrade
