wb-mcu-fw-updater update-all
2023-06-25 20:30:05,666 Will probe all devices on enabled serial ports of /etc/wb-mqtt-serial.conf:
2023-06-25 20:30:05,671 Unhandled exception!
File "/usr/bin/wb-mcu-fw-updater", line 517, in <module>
args.func(args)
File "/usr/bin/wb-mcu-fw-updater", line 208, in update_all
update_monitor._update_all(
File "/usr/lib/python3/dist-packages/wb_mcu_fw_updater/update_monitor.py", line 637, in _update_all
probing_result = probe_all_devices(
File "/usr/lib/python3/dist-packages/wb_mcu_fw_updater/update_monitor.py", line 567, in probe_all_devices
for port, port_params in get_devices_on_driver(driver_config_fname).items():
File "/usr/lib/python3/dist-packages/wb_mcu_fw_updater/update_monitor.py", line 256, in get_devices_on_driver
uart_params_of_port = [int(port["baud_rate"]), port["parity"], int(port["stop_bits"])]
KeyError: 'parity'
wb-mcu-fw-updater update-fw /dev/ttyRS485-2 -a140
2023-06-25 20:31:10,490 Will find serial port settings for (/dev/ttyRS485-2 : 140; response_timeout: 0.20)...
2023-06-25 20:31:10,597 Has found serial port settings: {'baudrate': 9600, 'parity': 'N', 'stopbits': 2}
2023-06-25 20:31:13,710 fw (mrwl3G 140 on /dev/ttyRS485-2):
2023-06-25 20:31:13,711 Update skipped: 1.19.2 -> 1.19.2 (mrwl3G 140 /dev/ttyRS485-2)
2023-06-25 20:31:13,712 Done
https://fw-releases.wirenboard.com/fw/by-signature/mrwl3G/main/latest.txt : 1.20.0
wb-mcu-fw-updater update-fw /dev/ttyRS485-2 -a169
2023-06-25 20:37:43,210 Will find serial port settings for (/dev/ttyRS485-2 : 169; response_timeout: 0.20)...
2023-06-25 20:37:43,316 Has found serial port settings: {'baudrate': 9600, 'parity': 'N', 'stopbits': 2}
2023-06-25 20:37:46,382 fw (mr6cpG 169 on /dev/ttyRS485-2):
2023-06-25 20:37:46,383 Update skipped: 1.19.2 -> 1.19.2 (mr6cpG 169 /dev/ttyRS485-2)
2023-06-25 20:37:46,385 Done
https://fw-releases.wirenboard.com/fw/by-signature/mr6cpG/main/latest.txt : 1.20.0
У меня RS-485 работает на 115200, надо ли переводить на 9600? Так и так не получилось…
Спасибо.
