DiVAN1
April 13, 2025, 10:40am
1
контроллер 8.5.1 + модем WBC2-4G
journalctl -u ModemManager -f
– Journal begins at Sun 2025-03-09 22:23:30 +05. –
Apr 13 15:35:19 wirenboard-ABPIFBTD ModemManager[368]: [modem0/sim0] couldn’t load list of emergency numbers: Failed to parse CRSM query result ‘+CRSM: 105,129’
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] state changed (unknown → disabled)
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] state changed (disabled → enabling)
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect started…
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect state (4/10): wait to get fully enabled
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] power state updated: on
Apr 13 15:35:20 wirenboard-ABPIFBTD ModemManager[368]: [modem0] 3GPP registration state changed (unknown → idle)
Apr 13 15:35:23 wirenboard-ABPIFBTD ModemManager[368]: [modem0] state changed (enabling → enabled)
Apr 13 15:35:23 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect state (5/10): wait after enabled
Apr 13 15:35:23 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect state (6/10): register
Apr 13 15:35:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] port ttyUSB1 timed out 2 consecutive times
Apr 13 15:35:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect started…
Apr 13 15:35:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect state (6/10): register
Apr 13 15:37:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] port ttyUSB1 timed out 3 consecutive times
Apr 13 15:37:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect started…
Apr 13 15:37:50 wirenboard-ABPIFBTD ModemManager[368]: [modem0] simple connect state (6/10): register
Apr 13 15:38:00 wirenboard-ABPIFBTD ModemManager[368]: [modem0] port ttyUSB1 timed out 4 consecutive times
Apr 13 15:38:10 wirenboard-ABPIFBTD ModemManager[368]: [modem0] port ttyUSB1 timed out 5 consecutive times
Вот тут есть пример подключения: Настройка 4G-модема в контроллере Wiren Board на Debian Bullseye — Wiren Board
Очевидно что не поднимается пакетный режим.
Советую попробовать с другой sim картой.
С этим разобрались, по новым правилам, с 1 апреля 2025 надо активировать корпоративную СИМку через Госуслуги.
Сейчас не отправляются СМС.
root@wirenboard:~# mmcli -m any
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 0e87eca665c67488ac97556ba96fd727965fd863
Hardware | manufacturer: INCORPORATED
| model: A7602E-H
| firmware revision: A50C4B08A7600M7
| supported: gsm-umts
| current: gsm-umts
| equipment id: *******
System | device: wbc
| drivers: option
| plugin: simtech
| primary port: ttyUSB1
| ports: ttyUSB0 (ignored), ttyUSB1 (at), ttyUSB2 (at),
| ttyUSB3 (ignored)
Status | unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 77% (recent)
Modes | supported: allowed: any; preferred: none
| current: allowed: any; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: ******
| operator id: 25002
| operator name: MegaFon
| registration: home
| packet service state: attached
3GPP EPS | ue mode of operation: csps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/0
root@wirenboard:~# mmcli -m wbc --messaging-create-sms=“text=‘Test’,number=‘+7xxxxxxxxxx’”
Successfully created new SMS: /org/freedesktop/ModemManager1/SMS/16
root@wirenboard:~# mmcli -m wbc -s 16 --send
error: couldn’t send the SMS: ‘GDBus.Error:org.freedesktop.ModemManager1.Error.Message.InvalidTextParameter: Invalid text mode parameter’
В скрипте отправка через Notify.sendSMS(phone, message) выдает ту же ошибку.
Пришлите, пожалуйста, архив с диагностической информацией контроллера. Создание архива описано в документации .
Ну и - перед отправкой SMS попробуйте выполнить
echo 'AT+CSCS="GSM"' >/dev/ttyUSB1
для диагностики.
Предварительно обновите пожалуйста прошивку модема, актуальная - B11
Благодарю! Прошивка до В11 помогла.
