Вот что выдает команда проверки статуса.
Я так понимаю, что проблема в файле конфигурации?
В чем именно?
/etc/wb-mqtt-serial.conf
“debug”: true,
“ports”: [
“path”: “/dev/ttyRS485-1”,
“port_type”: “serial”,
“devices”: [
“slave_id”: 26,
“device_type”: “WB-MDM3”
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“poll_interval”: 10,
“enabled”: true
“path”: “/dev/ttyRS485-2”,
“devices”: [
“slave_id”: 26,
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“enabled”: true
“path”: “/dev/ttyMOD1”,
“devices”: [],
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“enabled”: false
“path”: “/dev/ttyMOD2”,
“devices”: [],
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“enabled”: false
“path”: “/dev/ttyMOD3”,
“devices”: [],
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“enabled”: false
