при вводе команды выдает
Hit:1 http://deb.debian.org/debian bullseye InRelease
Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Err:1 http://deb.debian.org/debian bullseye InRelease
Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
Err:2 http://deb.debian.org/debian bullseye-updates InRelease
Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
Err:3 http://security.debian.org/debian-security bullseye-security InRelease
Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
Err:4 http://deb.debian.org/debian bullseye-backports InRelease
Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
Get:5 http://deb.wirenboard.com/wb7/bullseye stable InRelease [3939 B]
Err:5 http://deb.wirenboard.com/wb7/bullseye stable InRelease
Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
Get:6 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Err:6 https://download.docker.com/linux/debian bullseye InRelease
Splitting up /var/lib/apt/lists/partial/download.docker.com_linux_debian_dists_bullseye_InRelease into data and signature failed
Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
Err:7 https://deb.nodesource.com/node_16.x bullseye InRelease
Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
Fetched 47.3 kB in 1s (62.6 kB/s)
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye-updates InRelease: Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://security.debian.org/debian-security bullseye-security InRelease: Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye-backports InRelease: Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.wirenboard.com/wb7/bullseye stable InRelease: Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://download.docker.com/linux/debian bullseye InRelease: Splitting up /var/lib/apt/lists/partial/download.docker.com_linux_debian_dists_bullseye_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-backports/InRelease Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
W: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/partial/download.docker.com_linux_debian_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/dists/stable/InRelease Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
