Не сбрасывается на заводские
Добрый день, не могу сбросить на заводские:
Wiren Board 6.6.0 (s/n AHWCRLZP), release wb-2207 (as stable).
Лог при попытке сбросить:
U-Boot 2017.03-1.0.2-g6ee0824fba (May 27 2019 - 16:14:52 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 53C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
EEPROM #0 MAC: 54:10:ec:34:61:44
EEPROM #1 MAC: 54:10:ec:34:52:16
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices… 2 USB Device(s) found
scanning bus 1 for devices… EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
scanning usb for storage devices… 1 Storage Device(s) found
Device 0: Vendor: Generic Rev: 8.07 Prod: Flash Disk
Type: Removable Hard Disk
Capacity: 1901.0 MB = 1.8 GB (3893248 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
1 bytes read in 19 ms (0 Bytes/s)
Detected USB flash drive with update file
Filename: wb6_update_FACTORYRESET.fit
Press a FW key if you want to update firmware from this file
or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
Loading FIT header to 0x82000000 …
Loading FIT strings to 0x82000028 …
Loading FIT struct to 0x82000100 …
FAT: Misaligned buffer address (820010c8)
Skip 7928976 bytes of data
FAT: Misaligned buffer address (8200042c)
Skip 46505 bytes of data
FAT: Misaligned buffer address (82000e74)
Skip 4917 bytes of data
Skip 171809929 bytes of data
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can’t find subimage ‘ubootenv’
Extracting kernel
7945616 bytes read in 5002 ms (1.5 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x82000300
Data Size: 7928976 Bytes = 7.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 47f6419e0d5d8326c41b16761827dc3d746fec78
Verifying … sha1+
Loading part 0 … OK
Extracting DTB
Loading FIT header to 0x83000000 …
Loading FIT strings to 0x83000028 …
Loading FIT struct to 0x83000100 …
FAT: Misaligned buffer address (830010c8)
FAT: Misaligned buffer address (8300042c)
63589 bytes read in 712 ms (86.9 KiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x83000440
Data Size: 46505 Bytes = 45.4 KiB
Architecture: ARM
Hash algo: sha1
Hash value: ef9dd3fe2b348fb8eb9f150b9dc2e27d6899e823
Verifying … sha1+
Loading part 0 … OK
Kernel image @ 0x82000000 [ 0x000000 - 0x78fc90 ]
Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef48000, end 9ef565a8 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb6_initramfs (root@WB-buildserver) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #2 SMP Tue Feb 1 16:52:01 MSK 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board init (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @cfbd0000 s25932 r8192 d23220 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttymxc0,115200 bootmode=usbupdate,wb6_update_FACTORYRESET.fit
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 506760K/524288K available (5120K kernel code, 202K rwdata, 1576K rodata, 5120K init, 295K bss, 17528K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xd0000000 ( 512 MB)
[ 0.000000] modules : 0xaf000000 - 0xb0000000 ( 16 MB)
[ 0.000000] .text : 0xb0008000 - 0xb0600000 (6112 kB)
[ 0.000000] .init : 0xb0800000 - 0xb0d00000 (5120 kB)
[ 0.000000] .data : 0xb0d00000 - 0xb0d32880 ( 203 kB)
[ 0.000000] .bss : 0xb0d34000 - 0xb0d7ddb0 ( 296 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000052] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002600] Console: colour dummy device 80x30
[ 0.002641] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002674] pid_max: default: 32768 minimum: 301
[ 0.002865] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002891] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004083] CPU: Testing write buffer coherency: ok
[ 0.004579] /cpus/cpu@0 missing clock-frequency property
[ 0.004618] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004676] Setting up static identity map for 0x80100000 - 0x80100070
[ 0.007063] Brought up 1 CPUs
[ 0.007100] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.007116] CPU: All CPU(s) started in SVC mode.
[ 0.008336] devtmpfs: initialized
[ 0.034418] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.035102] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.035154] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.035328] pinctrl core: initialized pinctrl subsystem
[ 0.037375] NET: Registered protocol family 16
[ 0.037892] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.040336] cpuidle: using governor menu
[ 0.076021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.076054] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.078276] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.118522] mxs-dma 1804000.dma-apbh: initialized
[ 0.123043] SCSI subsystem initialized
[ 0.123640] usbcore: registered new interface driver usbfs
[ 0.123816] usbcore: registered new interface driver hub
[ 0.124064] usbcore: registered new device driver usb
[ 0.125655] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[ 0.126513] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[ 0.127342] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[ 0.128824] i2c i2c-1: IMX I2C adapter registered
[ 0.128867] i2c i2c-1: can’t use DMA, using PIO instead.
[ 0.129283] pps_core: LinuxPPS API ver. 1 registered
[ 0.129306] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.129367] PTP clock support registered
[ 0.131733] clocksource: Switched to clocksource mxc_timer1
[ 0.155518] NET: Registered protocol family 2
[ 0.156718] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.156842] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.156999] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.157109] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157168] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157467] NET: Registered protocol family 1
[ 0.158287] RPC: Registered named UNIX socket transport module.
[ 0.158318] RPC: Registered udp transport module.
[ 0.158335] RPC: Registered tcp transport module.
[ 0.158349] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.726828] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.741994] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.744005] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.754404] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.754439] io scheduler noop registered (default)
[ 0.759599] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.759639] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.768777] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 1.322924] console [ttymxc0] enabled
[ 1.328447] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[ 1.338743] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
[ 1.381588] imx_rngc 2284000.rngb: Freescale RNGC registered.
[ 1.416508] brd: module loaded
[ 1.435484] loop: module loaded
[ 1.443750] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.455207] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.462757] libphy: Fixed MDIO Bus: probed
[ 1.469214] 20b4000.ethernet supply phy not found, using dummy regulator
[ 1.477252] pps pps0: new PPS source ptp0
[ 1.510196] libphy: fec_enet_mii_bus: probed
[ 1.516457] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.641817] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.762750] pps pps1: new PPS source ptp1
[ 1.767830] libphy: fec_enet_mii_bus: probed
[ 1.775736] fec 2188000.ethernet eth1: registered PHC device 1
[ 1.782306] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.788874] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.794731] usbcore: registered new interface driver cdc_acm
[ 1.800427] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.808907] usbcore: registered new interface driver usb-storage
[ 1.872232] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.888375] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.897505] i2c /dev entries driver
[ 1.905701] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.913214] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_SD1_DATA1 already requested by watchdog; cannot claim for watchdog_6x
[ 1.924764] imx6ul-pinctrl 20e0000.iomuxc: pin-114 (watchdog_6x) status -22
[ 1.931818] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 114 (MX6UL_PAD_SD1_DATA1) from group wdggrp_6x on device 20e0000.iomuxc
[ 1.944234] gpio-wdt watchdog_6x: Error applying setting, reverse things back
[ 1.951424] gpio-wdt: probe of watchdog_6x failed with error -22
[ 1.959211] sdhci: Secure Digital Host Controller Interface driver
[ 1.965534] sdhci: Copyright(c) Pierre Ossman
[ 1.969918] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.041801] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.061367] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.068930] random: fast init done
[ 2.089414] usbcore: registered new interface driver usbhid
[ 2.097178] usbhid: USB HID core driver
[ 2.111463] NET: Registered protocol family 17
[ 2.122453] Registering SWP/SWPB emulation handler
[ 2.129509] registered taskstats version 1
[ 2.146493] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 2.169659] rtc-pcf8563 4-0051: setting system clock to 2023-01-12 13:54:08 UTC (1673531648)
[ 2.178150] of_cfs_init
[ 2.180801] of_cfs_init: OK
[ 2.189696] vdd3p0: disabling
[ 2.194869] vref-3v3: disabling
[ 2.200116] usb1_vbus: disabling
[ 2.212078] Freeing unused kernel memory: 5120K (b0800000 - b0d00000)
[ 2.227734] mmc0: new DDR MMC card at address 0001
[ 2.247720] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 2.262058] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
mount: mounting none on /dev/pts [ 2.272063] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
failed: No such file or directory
[ 2.292316] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB
[ 2.303046] mmcblk0: p1 p2 p3 p4 < p5 p6 >
Boot mode: usbupdate,wb6_update_FACTORYRESET.fit
Board is WB6, loading ci_hdrc_imx module
[ 2.541434] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.546685] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.581809] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.587479] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.594335] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.601568] usb usb1: Product: EHCI Host Controller
[ 2.606501] usb usb1: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.613160] usb usb1: SerialNumber: ci_hdrc.0
[ 2.619000] hub 1-0:1.0: USB hub found
[ 2.622998] hub 1-0:1.0: 1 port detected
[ 2.628517] 2184200.usb supply vbus not found, using dummy regulator
[ 2.639195] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.644290] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.671825] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.677595] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.684473] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.691759] usb usb2: Product: EHCI Host Controller
[ 2.696653] usb usb2: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.703341] usb usb2: SerialNumber: ci_hdrc.1
[ 2.709090] hub 2-0:1.0: USB hub found
[ 2.713098] hub 2-0:1.0: 1 port detected
[ 2.981874] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 3.071868] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 3.262669] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 3.269494] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.279803] hub 2-1:1.0: USB hub found
[ 3.284142] hub 2-1:1.0: 4 ports detected
[ 3.295381] usb 1-1: New USB device found, idVendor=058f, idProduct=6387
[ 3.302379] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.309568] usb 1-1: Product: Mass Storage
[ 3.313838] usb 1-1: Manufacturer: Generic
[ 3.317983] usb 1-1: SerialNumber: 95BE5E58
[ 3.325661] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 3.332486] scsi host0: usb-storage 1-1:1.0
[ 3.611874] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 3.764505] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 3.771514] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.779111] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 3.784228] usb 2-1.1: Manufacturer: Realtek
[ 3.788547] usb 2-1.1: SerialNumber: 00e04c000001
Load modules for USB to work
Starting USB update
Waiting for USB to settle (0/10)
[ 4.407643] scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 4.422184] sd 0:0:0:0: [sda] 3893248 512-byte logical blocks: (1.99 GB/1.86 GiB)
[ 4.432358] sd 0:0:0:0: [sda] Write Protect is off
[ 4.438702] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.490553] sda: sda1 sda2
[ 4.499269] sd 0:0:0:0: [sda] Attached SCSI removable disk
umount: can’t umount /usb: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda
mount: mounting /dev/sda on /usb failed: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda1
Looking for wb6_update_FACTORYRESET.fit on /dev/sda2
mount: mounting /dev/sda2 on /usb failed: Invalid argument
BusyBox v1.22.1 (Debian 1:1.22.0-19+deb9u2) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
Добрый день. Попробуйте использовать другую флешку. Образ для восстановления корректный используется, под ваш контроллер?
Флешку видит, и читает ( на другом контроллере все прошло). Образ брал 2 разных и тестинг и стабильный (202210201426_stable_webupd_wb6x). Результат одинаковый
Попробуйте все же сменить накопитель, Wiren Board 6: обновлениe с USB-флешки и удалениe данных со сбросом к заводским настройкам — Wiren Board
Спасибо, действительно то ли образ другой то ли флешка другая. Но помогло что то одно.
Хотя поторопился… вылетело - SHA1 of rootfs doesn’t match
После записи нового файла контроллер перестал видеть эту флешку.
Подобная тема обсуждалась, скорее всего нужно или еще раз отформатировать накопитель, или заменить.
