Не удается настроить модем на WB6
3 года не получается настроить модем по документации и привести его хоть в какое-то рабочее состояние
WB-2307
WB6
WBC-4g v1.6b
root@wirenboard-ASMOH3BD:~# DEBUG=true wb-gsm on
DEBUG: main: Called from pid 4215 (bash)
DEBUG: guess_of_node: Got of_gsm_node: /soc/bus@2100000/usb@2184200/usb-hub@1/wbc-modem@2
DEBUG: gsm_check_present: Modem is enabled in DT (/soc/bus@2100000/usb@2184200/usb-hub@1/wbc-modem@2)
DEBUG: is_driven_by_mm: Modem is NOT driven by ModemManager
DEBUG: ensure_on: switching on GSM modem using POWER FET
DEBUG: toggle: toggle GSM modem state using PWRKEY
DEBUG: ensure_on: Waiting for modem to start
DEBUG: init_usb_connection: Will wait up to 30s untill usb port becomes available
Turning OFF modem's POWER FET
DEBUG: of_get_prop_gpio: /soc/bus@2100000/usb@2184200/usb-hub@1/wbc-modem@2 power-gpios
DEBUG: of_get_prop_gpio: gpio 33 4 0
DEBUG: of_gpio_to_num: Unpacked gpio 128:4:0 -> 128+4
Force exit: no usb device after 30s
 1: /usr/lib/wb-utils/wb-gsm-common.sh:609 init_usb_connection(...)
 2: /usr/bin/wb-gsm:28 ensure_on(...)
Error in /usr/lib/wb-utils/wb-gsm-common.sh:84. 'kill -s TERM $WB_GSM_PID' exited with status 0
Call tree:
 1: /usr/lib/wb-utils/wb-gsm-common.sh:1 force_exit_handler(...)
 2: /usr/lib/wb-utils/wb-gsm-common.sh:80 do_exit(...)
 3: /usr/lib/wb-utils/wb-gsm-common.sh:247 force_exit(...)
 4: /usr/lib/wb-utils/wb-gsm-common.sh:609 init_usb_connection(...)
 5: /usr/bin/wb-gsm:28 ensure_on(...)
Exiting with status 1
июл 10 13:49:20 wirenboard-ASMOH3BD systemd[1]: ModemManager.service: Succeeded.
июл 10 13:49:20 wirenboard-ASMOH3BD systemd[1]: Stopped Modem Manager.
июл 10 13:49:20 wirenboard-ASMOH3BD systemd[1]: ModemManager.service: Consumed 11.232s CPU time.
июл 10 13:56:05 wirenboard-ASMOH3BD systemd[1]: Starting Modem Manager...
июл 10 13:56:06 wirenboard-ASMOH3BD ModemManager[18721]: <info>  ModemManager (version 1.20.0) starting in system bus...
июл 10 13:56:06 wirenboard-ASMOH3BD systemd[1]: Started Modem Manager.
июл 10 13:56:18 wirenboard-ASMOH3BD ModemManager[18721]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.2': not supported by any plugin
июл 10 13:56:29 wirenboard-ASMOH3BD ModemManager[18721]: <info>  [device wbc] creating modem with plugin 'simtech' and '4' ports
июл 10 13:56:29 wirenboard-ASMOH3BD ModemManager[18721]: <warn>  [plugin/simtech] could not grab port ttyUSB3: Cannot add port 'tty/ttyUSB3', unhandled port type
июл 10 13:56:29 wirenboard-ASMOH3BD ModemManager[18721]: <warn>  [plugin/simtech] could not grab port ttyUSB2: Cannot add port 'tty/ttyUSB2', unhandled port type
июл 10 13:56:29 wirenboard-ASMOH3BD ModemManager[18721]: <warn>  [base-manager] couldn't create modem for device 'wbc': Failed to find primary AT port
ModemManager - не работает с модемами на контроллерах WB6.
Рекомендую использовать legacy способ.
Попытался настроить через ppp
/dev/ttyUSB2
115200
#disable hardware flow control
nocrtscts
# Assumes that your IP address is allocated dynamically by the ISP.
noipdefault
# Try to get the name server addresses from the ISP.
usepeerdns
# Use this connection as the default route.
defaultroute
# Makes pppd "dial again" when the connection is lost.
persist
# Do not ask the remote to authenticate.
noauth
persist
# no limit on failed connections
maxfail 0
lcp-echo-interval 10
lcp-echo-failure 3
holdoff 10
init "/usr/bin/wb-gsm restart_if_broken"
# Логин и пароль для Yota не нужны (вроде как)
#user ""
#password ""
connect "/usr/sbin/chat -v -f /etc/chatscripts/yota"
ABORT "BUSY"
ABORT "NO ANSWER"
ABORT "NO CARRIER"
ABORT "ERROR"
TIMEOUT 5
"" ATZ
OK AT+CGDCONT=1,"IP","internet.yota"
OK ATD*99#
CONNECT
После ifup ppp0 интерфейс не появляется, файл с логами пустой /var/log/messages (совсем пустой)
Настройка 4G модема для Tele2 и Yota - Особые запросы - Wiren Board Support
этот мануал не годится?
файлы конфигов
yota (141 байт) в /etc/chatscripts/
yota (621 байт) в /etc/ppp/peers/
Попробуйте
A Yota поддерживает, кстати, регистрацию в 2G или 3G?
Для начала целесообразно проверить, запросив у модема
AT+CBAND=?
Ну и сам статус регистрации:
AT+CREG?
Если регистрация есть - то технологию с помощью
AT+COPS?
Вот тут похожее рассматривалось: Проблема с 4g модулем - #16 от пользователя Aleksey_Dubynin
Проблема решена или еще актуальна?
