Помогите настроить интернет через Yota
Помогите пожалуйста настроить выход в интернет через сим-карту “Yota” (WB 6.5).
Все настроил по данной инструкции, интерфейс ppp0 появился вместе с ip адресом. Однако интернет так и не появился - пинга нет с ошибкой destination port unreachable.
Вывод ifconfig и ping:
root-wirenboard-AMIGTYJM{~}:ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.20.22.73  netmask 255.255.0.0  broadcast 10.20.255.255
        inet6 fde8:284d:a1f8:0:821f:12ff:fe49:1194  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::821f:12ff:fe49:1194  prefixlen 64  scopeid 0x20<link>
        ether 80:1f:12:49:11:94  txqueuelen 1000  (Ethernet)
        RX packets 91900  bytes 8188493 (7.8 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 164  bytes 25467 (24.8 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 80:1f:12:48:d3:a7  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 52327  bytes 3676464 (3.5 MiB)
        TX packets 52327  bytes 3676464 (3.5 MiB)
ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.164.118.199  netmask 255.255.255.255  destination 10.164.118.199
        ppp  txqueuelen 3  (Point-to-Point Protocol)
        RX packets 84  bytes 8815 (8.6 KiB)
        TX packets 138  bytes 10395 (10.1 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.42.1  netmask 255.255.255.0  broadcast 192.168.42.255
        inet6 fe80::4a46:c1ff:fef7:5602  prefixlen 64  scopeid 0x20<link>
        ether 48:46:c1:f7:56:02  txqueuelen 1000  (Ethernet)
        RX packets 25  bytes 0 (0.0 B)
        TX packets 1  bytes 96 (96.0 B)
root-wirenboard-AMIGTYJM{~}:ping -I ppp0 1.1.1.1
PING 1.1.1.1 (1.1.1.1) from 10.164.118.199 ppp0: 56(84) bytes of data.
From 1.1.1.1 icmp_seq=1 Destination Port Unreachable
From 1.1.1.1 icmp_seq=2 Destination Port Unreachable
From 1.1.1.1 icmp_seq=3 Destination Port Unreachable
From 1.1.1.1 icmp_seq=4 Destination Port Unreachable
From 1.1.1.1 icmp_seq=5 Destination Port Unreachable
From 1.1.1.1 icmp_seq=6 Destination Port Unreachable
^C
--- 1.1.1.1 ping statistics ---
6 packets transmitted, 0 received, +6 errors, 100% packet loss, time 5006ms
Действия по настройки интернета: Создал файл /etc/ppp/peers/yota:
/dev/ttyACM0
115200
#disable hardware flow control
nocrtscts
# Assumes that your IP address is allocated dynamically by the ISP.
noipdefault
# Try to get the name server addresses from the ISP.
usepeerdns
# Use this connection as the default route.
defaultroute
# Makes pppd "dial again" when the connection is lost.
persist
# Do not ask the remote to authenticate.
noauth
persist
# no limit on failed connections
maxfail 0
lcp-echo-interval 10
lcp-echo-failure 3
holdoff 10
init "/usr/bin/wb-gsm restart_if_broken"
# Логин и пароль для Yota не нужны (вроде как)
#user ""
#password ""
connect "/usr/sbin/chat -v -f /etc/chatscripts/yota"
Так же создал скрипт /etc/chatscripts/yota:
ABORT "BUSY"
ABORT "NO ANSWER"
ABORT "NO CARRIER"
ABORT "ERROR"
TIMEOUT 5
"" ATZ
OK AT+CGDCONT=1,"IP","internet.yota"
OK ATD*99#
CONNECT
Внес изменение в файл /etc/network/interfaces
auto ppp0
iface ppp0 inet ppp
# select provider: megafon, mts or beeline below
  provider yota
  #Рестартуем модем, если он завис
  pre-up wb-gsm restart_if_broken
  #Затем ждем, пока он загрузится и найдет сеть.
  pre-up sleep 10
Вроде бы всё хорошо. А интернет на симке точно есть? Лучше вставить в телефон и проверить.
У Yota два вида симок, симка которая для телефона не будет давать доступа в инернет, если ее вставить в WB. Сам с этим столкнулся. Пока не знаю как подхачить, что бы оператор думал, что симка в телефон вставлена.
Смс нормально отправляются.
IMEI модема надо менять, оператор на это ориентируется.
