Здравствуйте, не запускается zigbee2mqtt
root@wirenboard-AMERIEJQ:~# systemctl status zigbee2mqtt.service
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor prese>
Active: activating (auto-restart) (Result: exit-code) since Fri 2023-06-09 20:>
Process: 10709 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 10709 (code=exited, status=1/FAILURE)
CPU: 25.387s
Active: active (running) since Fri 2023-06-09 21:06:37 UTC; 20s ago
Main PID: 15622 (npm start)
Tasks: 23 (limit: 4790)
Memory: 66.5M
CPU: 24.884s
CGroup: /system.slice/zigbee2mqtt.service
├─15622 npm start
├─15657 sh -c – node index.js
└─15658 node index.js
Jun 09 21:06:37 wirenboard-AMERIEJQ systemd[1]: Started zigbee2mqtt.
Jun 09 21:06:40 wirenboard-AMERIEJQ npm[15622]: > zigbee2mqtt@1.30.4 start
Jun 09 21:06:40 wirenboard-AMERIEJQ npm[15622]: > node index.js
Jun 09 21:06:52 wirenboard-AMERIEJQ npm[15658]: Zigbee2MQTT:info  2023-06-09 21:06:>
Jun 09 21:06:57 wirenboard-AMERIEJQ npm[15658]: Zigbee2MQTT:error 2023-06-09 21:06:>
Active: activating (auto-restart) (Result: exit-code) since Fri 2023-06-09 21:>
Process: 15622 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 15622 (code=exited, status=1/FAILURE)
CPU: 25.200s
