Прошу помощи с классификацией ошибок, важно/неважно, и нужно ли их исправить?
У меня WB6.9
- Ошибка V_OUT_OK - Висит в
/devices/wb-gpio/controls/V_OUT_OK/meta/error r
Запись в журнале:
Feb 21 11:27:16 wirenboard-A4VEY6PY wb-mqtt-gpio[4913]: ERROR: [gpio chip driver] Failed to release GPIO line 2:8 (V_OUT_OK)
Feb 21 11:27:16 wirenboard-A4VEY6PY wb-mqtt-gpio[4913]: ERROR: [gpio chip driver] Skipping GPIO line 2:8 (V_OUT_OK)
Feb 21 11:27:16 wirenboard-A4VEY6PY wb-mqtt-gpio[4913]: WARNING: [gpio chip driver] GPIO_GET_LINEEVENT_IOCTL failed: Device or resource busy at GPIO line 2:8 (V_OUT_OK)
Feb 21 11:27:16 wirenboard-A4VEY6PY wb-mqtt-gpio[4913]: ERROR: [gpio chip driver] GPIO_GET_LINEHANDLE_IOCTL failed: Device or resource busy
Feb 21 11:27:16 wirenboard-A4VEY6PY wb-mqtt-gpio[4913]: ERROR: [gpio chip driver] Failed to init polling GPIO line 2:8 (V_OUT_OK). Treating as initially disconnected
- usb usb1-port1: over-current condition, когда в контроллер ничего не вставлено.
Запись в журнале:
Feb 21 14:25:12 wirenboard kernel: usb usb1-port1: over-current condition
> hubpower 1:1 status
Port 1 status: 0108 Power-On Overcurrent
- regulatory.db is malformed, что идет в пакете wireless-regdb (сам пакет уже 2024 года есть)
Запись в журнале:
Feb 21 14:25:15 wirenboard kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
root@wirenboard-A4VEY6PY:~# apt show wireless-regdb
Package: wireless-regdb
Version: 2022.04.08-2~deb11u1
Priority: optional
Section: net
Maintainer: Debian kernel team <debian-kernel@lists.debian.org>
Installed-Size: 45.1 kB
Suggests: crda
Homepage: https://wireless.wiki.kernel.org/en/developers/regulatory/wireless-regdb
Tag: admin::hardware, role::app-data
Download-Size: 15.1 kB
APT-Manual-Installed: no
APT-Sources: http://debian-mirror.wirenboard.com/debian bullseye/main armhf Packages
Description: wireless regulatory database for Linux
This package provides a machine-readable database of legal
regulations on radio emissions that affect use of wireless networking.
The Linux kernel and drivers use this to maintain compliance with
those regulations.
(142,7 КБ)
Помогите пожалуйста с вопросами 1 и 2, хотя бы.
Куда смотреть? Что проверить?
А какой версии контроллер? Ну и какой релиз ПО стоит?
судя по наличию v_out_ОК - WB6?
предполагаю что ПО неактуально, обновите.
Версия контроллера - 6.9B/1G2 593
Релиз - testing, apt update && apt upgrade регулярно.
2:8 это 64+8 = 72.
Таблице gpio соответствует.
Но драйвер не экспортирует его. То есть - чем-то занят, стоит ли какой-то дополнительный софт?
При перезапуске wb-mqtt-gpio у меня:
Feb 29 15:57:37 wirenboard-AQUDWN46 systemd[1]: Starting MQTT Driver for GPIO-controlled switches...
Feb 29 15:57:38 wirenboard-AQUDWN46 generate-system-config.sh[9524]: /var/run/wb_env.cache: line 2: OF_GPIOCHIPS: cannot convert indexed to associative array
Feb 29 15:57:44 wirenboard-AQUDWN46 systemd[1]: Started MQTT Driver for GPIO-controlled switches.
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio] Kernel uses monotonic clock for interrupt timestamps
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] Default host and port detected, checking if UNIX socket exists on /var/run/mosquitto/mosquitto.sock
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] UNIX socket exists, using it for connection
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] connection estabilished with code "0" <success>
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 1)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 2)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 2:15 (A1_OUT)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 2:16 (A2_OUT)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 2:17 (A3_OUT)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 2:18 (A4_OUT)
Feb 29 15:57:44 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 2:9 (V_OUT)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 14)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio chip driver] Initialized output GPIO line 0:27 (5V_OUT)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 21)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [gpio driver] Started
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 28)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 35)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 66)
Feb 29 15:57:45 wirenboard-AQUDWN46 wb-mqtt-gpio[10112]: INFO: [mqtt] subscription succeeded (message id 79)
