он очень старый уже и не поддерживается автоматическим обновлятором или в чем-то другом проблема?
root@wirenboard-AHT3VCYP:~# wb-mcu-fw-updater update-all
2024-04-18 13:30:47,116 Will probe all devices on enabled serial ports of /etc/wb-mqtt-serial.conf:
2024-04-18 13:30:47,118 Probing WB-MSW2 (port: /dev/ttyRS485-1, slaveid: 36, uart_params: 9600N2, response_timeout: 0.50)...
2024-04-18 13:30:53,605 0 upgraded, 0 skipped upgrade, 0 bootloader updates available, 0 stuck in bootloader, 0 disconnected and 0 too old for any updates.
root@wirenboard-AHT3VCYP:~# wb-mcu-fw-updater update-fw /dev/ttyRS485-1 -a36
2024-04-18 13:32:00,982 Will find serial port settings for (/dev/ttyRS485-1 : 36; response_timeout: 0.20)...
2024-04-18 13:32:01,091 Has found serial port settings: SerialSettings(baudrate=9600, parity='N', stopbits=2)
2024-04-18 13:32:04,571 Flashing fw to (/dev/ttyRS485-1 36; response_timeout: 0.20s) has failed!
2024-04-18 13:32:04,572 Possibly, device (/dev/ttyRS485-1 36) is not a WB-one!
