Всем привет.
На WB6 обновил все до последних версий, после запуска
wb-hwconf-helper config-apply
в конфиге
/var/lib/wb-mqtt-gpio/conf.d/system.conf
ничего не появляется и в консоли ошибки:
[info] Adding wb6-extio1:wbio-do-ssr-8.
[info] Initializing wb6-extio1:wbio-do-ssr-8.
:12.4-17: Warning (reg_format): /fragment/overlay/extio1_wbio_do_ssr_8@20:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
: Warning (pci_device_reg): Failed prerequisite ‘reg_format’
: Warning (pci_device_bus_num): Failed prerequisite ‘reg_format’
: Warning (simple_bus_reg): Failed prerequisite ‘reg_format’
: Warning (i2c_bus_reg): Failed prerequisite ‘reg_format’
: Warning (spi_bus_reg): Failed prerequisite ‘reg_format’
:8.27-19.5: Warning (avoid_default_addr_size): /fragment/overlay/extio1_wbio_do_ssr_8@20: Relying on default #address-cells value
:8.27-19.5: Warning (avoid_default_addr_size): /fragment/overlay/extio1_wbio_do_ssr_8@20: Relying on default #size-cells value
: Warning (avoid_unnecessary_addr_size): Failed prerequisite ‘avoid_default_addr_size’
: Warning (unique_unit_address): Failed prerequisite ‘avoid_default_addr_size’
…[info] Running hook service_restart_delete_retained wb-homa-gpio /devices/wb-gpio/#.
warning: no messages for this topic
Куда копать?
