Ошибка при запуске Zigbee2mqtt
Перестал работать zigbee2mqtt. Модуль в установлен в MOD4. Какое то время работал…
Как починить, посоветуйте!
Лог при ручном запуске через команду npm start:
0 info it worked if it ends with ok
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
2 info using npm@6.14.8
3 info using node@v12.19.0
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle zigbee2mqtt@1.18.1~prestart: zigbee2mqtt@1.18.1
6 info lifecycle zigbee2mqtt@1.18.1~start: zigbee2mqtt@1.18.1
7 verbose lifecycle zigbee2mqtt@1.18.1~start: unsafe-perm in lifecycle true
8 verbose lifecycle zigbee2mqtt@1.18.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/mnt/data/root/zigbee2mqtt/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
9 verbose lifecycle zigbee2mqtt@1.18.1~start: CWD: /mnt/data/root/zigbee2mqtt
10 silly lifecycle zigbee2mqtt@1.18.1~start: Args: [ ‘-c’, ‘node index.js’ ]
11 silly lifecycle zigbee2mqtt@1.18.1~start: Returned: code: 1 signal: null
12 info lifecycle zigbee2mqtt@1.18.1~start: Failed to exec start script
13 verbose stack Error: zigbee2mqtt@1.18.1 start: node index.js
13 verbose stack Exit status 1
13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:314:20)
13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:314:20)
13 verbose stack at maybeClose (internal/child_process.js:1021:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
14 verbose pkgid zigbee2mqtt@1.18.1
15 verbose cwd /mnt/data/root/zigbee2mqtt
16 verbose Linux 5.10.35-wb105+1
17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
18 verbose node v12.19.0
19 verbose npm v6.14.8
20 error code ELIFECYCLE
21 error errno 1
22 error zigbee2mqtt@1.18.1 start: node index.js
22 error Exit status 1
23 error Failed at the zigbee2mqtt@1.18.1 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
суд по выводу в лог - до установки соединения с модулем не доходит. Точно ли остановлен сервис zigbee2mqtt на момент ручного запуска?
Вообще, если ставился из исходников - рекомендую удалить zigbee2mqtt и перключившись в testing установить из пакета так: Подключение устройств Zigbee к контроллеру Wiren Board — Wiren Board
как правильно удалить zigbee2mqtt. ?
надо ли при этом удалять Wb-zigbee2mqtt ?
Вместе с каталогом лучше всего, не забыв удалить /etc/systemd/system/zigbee2mqtt.service
Нет, не нужно.
Заработало! Все устройства zigbee на связи.
Надо ли менять версию релиза обратно на stable ?
Нет, думаю не нужно. В релизе stable более старая версия пакета zigbee2mqtt.
testing в ближайшее время станет релизом, после этого - можно.
