При загрузке WB 3.5 происходит такая ошибка:
HTLCmxs_power_init(): mxs_power_init
mxs_power_set_auto_restart(): mxs_power_set_auto_restart
mxs_power_set_linreg(): mxs_power_set_linreg
mxs_power_configure_power_source(): mxs_power_configure_power_source
mxs_get_batt_volt(): mxs_get_batt_volt volt=4208 mV
mxs_power_configure_power_source(): /* 5V source detected, good battery detected. */
mxs_5v_boot(): mxs_5v_boot
mxs_boot_valid_5v(): mxs_boot_valid_5v
mxs_power_enable_4p2(): mxs_power_enable_4p2
mxs_power_init_4p2_params(): mxs_power_init_4p2_params
mxs_power_init_4p2_regulator(): mxs_power_init_4p2_regulator
mxs_enable_4p2_dcdc_input(): mxs_enable_4p2_dcdc_input
mxs_power_init_dcdc_4p2_source(): mxs_power_init_dcdc_4p2_source
mxs_init_batt_bo(): mxs_init_batt_bo
mxs_switch_vddd_to_dcdc_source(): mxs_switch_vddd_to_dcdc_source
mxs_enable_output_rail_protection(): mxs_enable_output_rail_protection
mxs_power_set_vddx(): mxs_power_set_vddx
mxs_get_vddio_power_source_off(): mxs_get_vddio_power_source_off
mxs_get_vddd_power_source_off(): mxs_get_vddd_power_source_off
mxs_mem_init(): before_init_clock
mxs_mem_init_clock
mxs_mem_init(): after_init_clock
mxs_mem_init(): after_vdda_clock
mx23_mem_init(): DDR frequency is 133 MHz
mx23_mem_init(): DDR CAS latency=2.5
mx23_mem_init(): before vddmem
mx23_mem_setup_vddmem(): before VDDM current limit
mx23_mem_setup_vddmem(): VDDM current limit disabled
mx23_mem_init(): after vddmem
initialize_dram_values
mxs_mem_init(): after_mem_init
LC
U-Boot 2014.07-00012-gef75de6-dirty (Apr 25 2015 - 15:36:48)
CPU: Freescale i.MX23 rev1.4 at 454 MHz
BOOT: SSP SD/MMC #0
DRAM: 64 MiB
MMC: MXS MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
43 bytes read in 263 ms (0 Bytes/s)
Importing environment from mmc (uEnv.txt)…
Checking if uenvcmd is set …
Running default loadzimage …
3435144 bytes read in 1520 ms (2.2 MiB/s)
12846 bytes read in 408 ms (30.3 KiB/s)
Booting from mmc …
Kernel image @ 0x42000000 [ 0x000000 - 0x346a88 ]
Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 43b60000, end 43b6622d … OK
Starting kernel …
Периодически загружается, это проблема с процессорной платой?
