Ошибки команды apt update
Не могу обновить контроллер. Сеть есть.
вывод apt update
root@wirenboard-A7UPLRBU:/etc# apt update
Get:1 Index of /debian-security bullseye-security InRelease [27.2 kB]
Get:2 Index of /debian bullseye InRelease [116 kB]
Err:1 Index of /debian-security bullseye-security InRelease
Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
Err:2 Index of /debian bullseye InRelease
Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
Get:3 Index of /debian bullseye-updates InRelease [44.1 kB]
Err:3 Index of /debian bullseye-updates InRelease
Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
Get:4 http://deb.wirenboard.com/wb7/bullseye stable InRelease [3940 B]
Err:4 http://deb.wirenboard.com/wb7/bullseye stable InRelease
Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
Get:5 Index of /debian bullseye-backports InRelease [49.0 kB]
Err:5 Index of /debian bullseye-backports InRelease
Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
Err:6 https://deb.nodesource.com/node_16.x bullseye InRelease
Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
Fetched 3940 B in 1s (6491 B/s)
Reading package lists… Done
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /debian-security bullseye-security InRelease: Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /debian bullseye InRelease: Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /debian bullseye-updates InRelease: Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.wirenboard.com/wb7/bullseye stable InRelease: Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /debian bullseye-backports InRelease: Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-updates_InRelease into data and signature failed
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-backports/InRelease Splitting up /var/lib/apt/lists/partial/deb.debian.org_debian_dists_bullseye-backports_InRelease into data and signature failed
W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease Splitting up /var/lib/apt/lists/partial/security.debian.org_debian-security_dists_bullseye-security_InRelease into data and signature failed
W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
W: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/dists/stable/InRelease Splitting up /var/lib/apt/lists/partial/deb.wirenboard.com_wb7_bullseye_dists_stable_InRelease into data and signature failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
вывод cat /etc/*-release
root@wirenboard-A7UPLRBU:/etc# cat /etc/*-release
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“Debian -- User Support”
BUG_REPORT_URL=“https://bugs.debian.org/”
RELEASE_NAME=wb-2307
SUITE=stable
TARGET=wb7/bullseye
информация при входе
Welcome to Wiren Board 7.3.4 (s/n A7UPLRBU), release wb-2307 (as stable)
Linux wirenboard-A7UPLRBU 5.10.35-wb142+wb101 #1 SMP Wed Sep 20 11:41:50 UTC 2023 armv7l GNU/Linux
System load: 2.55 1.78 1.47 Up time: 2:02
Memory usage: 17% of 1.96G Usage of /: 100% of 976M /mnt/data: 5% of 55G
А дата-время правильные на этом хосте?
да.
root@wirenboard-A7UPLRBU:~# date
Wed Dec 25 23:34:36 MSK 2024
Вот тут похожее было
Из стороннего только node-red стоит. Ставил по этой инструкции.
Вопрос обновления встал пару дней назад - купил пару zigbee устройств (aqara H2), и они некорректно подтянулись в WB. Предположил, что это из-за старой версии zigbee2mqtt (на сайте устройства в списке поддерживаемых есть). Но обновить не удалось.
Сбрасывать контроллер, по мне слишком кардинальное решение. Должен быть способ менее трудозатратный.
А место в корне проверили, достаточно?
Для диагностики проблемы, пожалуйста, пришлите архив с диагностической информацией контроллера. Подробное описание создания архива вы найдёте в документации.
Также выполните диагностику подключения к интернету:
  1. Проверьте доступ к интернету, выполнив команду:
ping google.com
и отдельно проверьте пинг до IP-адреса:
ping 8.8.8.8
  1. Если пинг отсутствует:
  • Убедитесь, что настроены корректные DNS-серверы. Рекомендуется указать публичные, например 8.8.8.8 и 1.1.1.1.
  • Попробуйте очистить кеш командой:
apt clean
Сообщите результаты проверки для дальнейшей помощи!
Ну вот и он, больной зуб, все как в приведенной ссылке.
ping google.com
PING google.com (142.250.179.78) 56(84) bytes of data.
64 bytes from par21s19-in-f14.1e100.net (142.250.179.78): icmp_seq=1 ttl=111 time=52.1 ms
64 bytes from par21s19-in-f14.1e100.net (142.250.179.78): icmp_seq=2 ttl=111 time=52.0 ms
64 bytes from par21s19-in-f14.1e100.net (142.250.179.78): icmp_seq=3 ttl=111 time=52.1 ms
64 bytes from par21s19-in-f14.1e100.net (142.250.179.78): icmp_seq=4 ttl=111 time=51.9 ms
^C
— google.com ping statistics —
5 packets transmitted, 4 received, 20% packet loss, time 4007ms
rtt min/avg/max/mdev = 51.911/52.021/52.071/0.064 ms
ping 8.8.8.8, 1.1.1.1
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=105 time=24.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=105 time=24.3 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=105 time=24.2 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=105 time=24.5 ms
^C
— 8.8.8.8 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 24.159/24.335/24.527/0.136 ms
root@wirenboard-A7UPLRBU:~# ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=58 time=15.1 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=58 time=14.8 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=58 time=15.3 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=58 time=15.0 ms
64 bytes from 1.1.1.1: icmp_seq=5 ttl=58 time=14.5 ms
^C
— 1.1.1.1 ping statistics —
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 14.470/14.934/15.340/0.287 ms
Архив с диагностической информацией:
(116,4 КБ)
Выход - сброс до заводских?
Отнюдь, просто освободите место в корневом разделе.
Сброс настроек — это крайняя мера. Как уже упоминалось ранее, попробуйте сначала освободить место на разделе. После этого система должна начать работать корректно.
  1. Перенести node_modules, этого достаточно будет?
root@wirenboard-A7UPLRBU:/usr/lib# du -sh * | sort -hr | head -3
136M arm-linux-gnueabihf
101M node_modules
  1. Чтобы не допустить ошибку, команду, для переноса не подскажите?
ln -s /mnt/data/usr/lib/node_modules /usr/lib/node_modules
Верная команда?
Наверное, посмотрите man для деталей.
P.S. как по мне, то на этом контроллере nodejs вообще лишнее, не надо воспринимать эту железку как сервер, это “желаемое за действительное”
Перенес на /mnt/data/usr/lib/ каталог: node_modules.
Освободилось 100Мб, при обновлении вышла ошибка.
Перенес на /mnt/data/usr/lib/ каталоги: gcc, python2.7, python3, python3.9.
Удалось обновиться с помощью команды apt --fix-broken install.
После обновления перезагрузил контроллер.
Теперь не работает zigbee2mqtt.
root@wirenboard-A7UPLRBU:/mnt/data/root/zigbee2mqtt# npm start
zigbee2 mqtt@1.40.2 start
node index.js
Starting Zigbee2MQTT without watchdog.
[2024-12-26 14:22:01] info: z2m: Logging to console, file (filename: log.log)
[2024-12-26 14:22:01] info: z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-12-26 14:22:01] info: z2m: Starting zigbee-herdsman (2.1.3)
[2024-12-26 14:22:06] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/ttyMOD4”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2024-12-26 14:22:06] error: z2m: Error while starting zigbee-herdsman
[2024-12-26 14:22:06] error: z2m: Failed to start zigbee
[2024-12-26 14:22:06] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-26 14:22:06] error: z2m: Exiting…
[2024-12-26 14:22:06] error: z2m: Error: Error: Input/output error setting custom baud rate of 115200
Посмотрите вот тут
Проблема оказалась в том, что отвязались модули расширения. Через графический интерфейс повторно указал модули расширения для модуля 2, и 4. (Как ни странно, для модули 1 и 3 в норме)
