Добрый день. Подскажите пути решения.
Первый раз работаю WB 7,4. Понемногу мучаю контроллер.
Сначала Zigbee2mqtt конвертер стал переходить в offline режим при введении строки:
systemctl restart zigbee2mqtt после конфигурации
Сейчас после конфигурирования Zigbee2mqtt конвертер ни версию ни состояния не отображает. Только разрешение на сопряжение доступно.
Сброс к заводским настройкам результата не дал.
-- Journal begins at Thu 2024-10-31 03:25:00 UTC, ends at Thu 2024-10-31 04:50:39 UTC. --
Oct 31 03:47:08 wirenboard-AU3VMI6Q systemd[1]: Started zigbee2mqtt.
Oct 31 03:47:14 wirenboard-AU3VMI6Q npm[16253]: > zigbee2mqtt@1.40.1 start
Oct 31 03:47:14 wirenboard-AU3VMI6Q npm[16253]: > node index.js
Oct 31 03:47:16 wirenboard-AU3VMI6Q npm[16349]: Starting Zigbee2MQTT without watchdog.
Oct 31 03:47:30 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:30] info: z2m: Logging to console, file (filename: log.log)
Oct 31 03:47:30 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:30] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
Oct 31 03:47:30 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:30] info: z2m: Starting zigbee-herdsman (0.57.3)
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts":false,"autoOpen":false}
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] error: z2m: Error while starting zigbee-herdsman
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] error: z2m: Failed to start zigbee
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] error: z2m: Exiting...
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16349]: [2024-10-31 03:47:34] error: z2m: Error: Error: Input/output error setting custom baud rate of 115200
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16253]: npm notice
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16253]: npm notice New major version of npm available! 9.8.0 -> 10.9.0
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16253]: npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.9.0>
Oct 31 03:47:34 wirenboard-AU3VMI6Q npm[16253]: npm notice Run `npm install -g npm@10.9.0` to update!
Oct 31 03:47:34 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
Oct 31 03:47:34 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Oct 31 03:47:34 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 34.857s CPU time.
Oct 31 03:49:04 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart counter is at 1.
Oct 31 03:49:04 wirenboard-AU3VMI6Q systemd[1]: Stopped zigbee2mqtt.
Oct 31 03:49:04 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 34.857s CPU time.
Oct 31 03:49:04 wirenboard-AU3VMI6Q systemd[1]: Started zigbee2mqtt.
Oct 31 03:49:08 wirenboard-AU3VMI6Q npm[17235]: > zigbee2mqtt@1.40.1 start
Oct 31 03:49:08 wirenboard-AU3VMI6Q npm[17235]: > node index.js
Oct 31 03:49:10 wirenboard-AU3VMI6Q npm[17331]: Starting Zigbee2MQTT without watchdog.
Oct 31 03:49:23 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:23] info: z2m: Logging to console, file (filename: log.log)
Oct 31 03:49:23 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:23] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
Oct 31 03:49:23 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:23] info: z2m: Starting zigbee-herdsman (0.57.3)
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts":false,"autoOpen":false}
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] error: z2m: Error while starting zigbee-herdsman
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] error: z2m: Failed to start zigbee
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] error: z2m: Exiting...
Oct 31 03:49:27 wirenboard-AU3VMI6Q npm[17331]: [2024-10-31 03:49:27] error: z2m: Error: Error: Input/output error setting custom baud rate of 115200
Oct 31 03:49:28 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
Oct 31 03:49:28 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Oct 31 03:49:28 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 29.325s CPU time.
Oct 31 03:50:58 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart counter is at 2.
Oct 31 03:50:58 wirenboard-AU3VMI6Q systemd[1]: Stopped zigbee2mqtt.
Oct 31 03:50:58 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 29.325s CPU time.
Oct 31 03:50:58 wirenboard-AU3VMI6Q systemd[1]: Started zigbee2mqtt.
Oct 31 03:51:01 wirenboard-AU3VMI6Q npm[18197]: > zigbee2mqtt@1.40.1 start
Oct 31 03:51:01 wirenboard-AU3VMI6Q npm[18197]: > node index.js
Oct 31 03:51:03 wirenboard-AU3VMI6Q npm[18252]: Starting Zigbee2MQTT without watchdog.
Oct 31 03:51:17 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:17] info: z2m: Logging to console, file (filename: log.log)
Oct 31 03:51:17 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:17] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
Oct 31 03:51:17 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:17] info: z2m: Starting zigbee-herdsman (0.57.3)
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts":false,"autoOpen":false}
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] error: z2m: Error while starting zigbee-herdsman
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] error: z2m: Failed to start zigbee
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] error: z2m: Exiting...
Oct 31 03:51:21 wirenboard-AU3VMI6Q npm[18252]: [2024-10-31 03:51:21] error: z2m: Error: Error: Input/output error setting custom baud rate of 115200
Oct 31 03:51:21 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
Oct 31 03:51:21 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Oct 31 03:51:21 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 29.342s CPU time.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart counter is at 3.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: Stopped zigbee2mqtt.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Consumed 29.342s CPU time.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Start request repeated too quickly.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Oct 31 03:52:51 wirenboard-AU3VMI6Q systemd[1]: Failed to start zigbee2mqtt.
root@wirenboard-AU3VMI6Q:~#
Очень похоже у вас не настроен сам модуль.
Для настройки и устранения проблем с Zigbee2MQTT на Wiren Board, рекомендую ознакомиться с официальной документацией.
Вижу, что есть проблема с настройкой, а точнее с дублирующимся ключом в YAML-файле конфигурации zigbee2mqtt. Сообщение YAMLException: duplicated mapping key (29:1) указывает на то, что один и тот же ключ используется более одного раза.
