Здравствуйте! Почему-то два из трёх устройств на одном из портов не читаются, регистры разве что на пару секунд после ребута WB становятся чёрными, а потом опять красными. Вот конфиг:
Конфиг
"path": "/dev/ttyRS485-2",
"devices": [
"slave_id": "2",
"name": "Buhler",
"id": "buhler",
"protocol": "modbus",
"enabled": true,
"poll_interval": 1000,
"channels": [
"name": "DrawingSW",
"type": "switch",
"reg_type": "coil",
"address": "0",
"format": "s16",
"scale": 1,
"offset": 0
"name": "Drawing",
"type": "value",
"reg_type": "input",
"address": "0",
"format": "s16",
"scale": 1,
"offset": 0
"name": "Drawing_setpoint",
"type": "range",
"reg_type": "holding",
"address": "0",
"format": "s16",
"scale": 1,
"offset": 0,
"max": "100"
"name": "MasterBedroomSW",
"type": "switch",
"reg_type": "coil",
"address": "1",
"format": "s16",
"scale": 1,
"offset": 0
"name": "MasterBedroom",
"type": "value",
"address": "1",
"format": "s16",
"scale": 1,
"offset": 0
"name": "MasterBedroom_setpoint",
"type": "range",
"address": "1",
"format": "s16",
"scale": 1,
"offset": 0,
"max": "100"
"name": "BedroomGuestSW",
"type": "switch",
"reg_type": "coil",
"address": "2",
"format": "s16",
"scale": 1,
"offset": 0
"name": "BedroomGuest",
"type": "value",
"address": "2",
"format": "s16",
"scale": 1,
"offset": 0
"name": "BedroomGuest_setpoint",
"type": "range",
"address": "2",
"format": "s16",
"scale": 1,
"offset": 0,
"max": "100"
"device_max_fail_cycles": 0
"slave_id": "1",
"name": "SystemAir",
"id": "SystemAir",
"enabled": true,
"poll_interval": 2000,
"channels": [
"name": "Supply_air_sensor",
"type": "value",
"address": "213",
"format": "s16",
"channel_readonly": false
"name": "FanSpeed",
"type": "range",
"address": "100",
"max": "4",
"name": "Fan_SF_RPM",
"type": "value",
"address": "110",
"channel_readonly": true,
"name": "Fan_EF_RPM",
"type": "value",
"address": "111",
"name": "REG_HC_WH_SIGNAL",
"type": "value",
"address": "204",
"name": "REG_HC_TEMP_IN1",
"type": "temperature",
"address": "213",
"scale": 0.1,
"name": "REG_HC_TEMP_IN2",
"address": "214",
"scale": 0.1,
"name": "REG_HC_TEMP_IN3",
"address": "215",
"scale": 0.1,
"name": "REG_HC_TEMP_IN4",
"address": "216",
"scale": 0.1,
"name": "REG_HC_TEMP_IN5",
"address": "217",
"scale": 0.1,
"name": "REG_HC_TEMP_LVL",
"type": "range",
"address": "206",
"max": "5",
"name": "REG_HC_TEMP_SP",
"type": "range",
"address": "207",
"max": "40",
"name": "REG_HC_TEMP_SP_DEG",
"type": "range",
"address": "221",
"scale": 0.1,
"max": "40",
"name": "REG_PREHEATER_SETPOINT",
"type": "value",
"address": "230",
"scale": 0.1,
"max": "40",
"name": "REG_PREHEATER_P_BAND",
"type": "range",
"address": "231",
"scale": 0.1,
"max": "60",
"name": "REG_ROTOR_STATE",
"type": "text",
"address": "350",
"name": "REG_RH_SENSOR_VALUE",
"type": "rel_humidity",
"address": "380",
"name": "REG_RH_SENSOR_DATA_VALID",
"type": "value",
"address": "381",
"name": "REG_FILTER_PER",
"type": "value",
"address": "600",
"name": "REG_FILTER_DAYS",
"type": "value",
"address": "601",
"name": "REG_CLK_S",
"type": "range",
"address": "550",
"max": "59"
"name": "REG_CLK_M",
"type": "range",
"address": "551",
"max": "59"
"name": "REG_CLK_H",
"type": "range",
"address": "552",
"max": "23"
"name": "REG_CLK_D",
"type": "range",
"address": "553",
"max": "31"
"name": "REG_CLK_MNTH",
"type": "range",
"address": "554",
"max": "12"
"name": "REG_CLK_Y",
"type": "range",
"address": "555",
"max": "2030"
"name": "Filter Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12800",
"name": "Fan Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12801",
"name": "Rotor Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12803",
"name": "Frost Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12804",
"name": "PCU-PB Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12805",
"name": "Temperature sensor Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12806",
"name": "Emergency Thermostat Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12807",
"name": "Damper Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12808",
"name": "Low SS Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12809",
"name": "Defrost Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12810",
"name": "RH Sensor Alarm",
"type": "switch",
"reg_type": "coil",
"address": "12811",
"slave_id": "201",
"name": "RTM-2000",
"id": "RTM2000",
"enabled": true,
"channels": [
"name": "OsadCh1",
"type": "value",
"address": "90",
"scale": 1,
"name": "WaterCh1",
"type": "value",
"address": "0x5C",
"scale": 1,
"name": "TST01_3",
"address": "0x08",
"format": "s16",
"scale": 1,
"name": "TST01_3_10",
"type": "value",
"address": "0x09",
"format": "s16",
"name": "TST01_3_mult",
"type": "value",
"address": "0x0A",
"format": "s16",
"scale": 1,
"name": "TST01_3_check",
"type": "value",
"address": "0x0B",
"scale": 1,
"name": "Relay0State",
"type": "switch",
"address": "176",
"scale": 1,
"readonly": true
"name": "Relay1State",
"type": "switch",
"address": "177",
"scale": 1,
"readonly": true
"name": "Relay2State",
"type": "switch",
"address": "178",
"scale": 1,
"readonly": true
"name": "Relay3State",
"type": "switch",
"address": "179",
"scale": 1,
"readonly": true
"name": "Relay4State",
"type": "switch",
"address": "180",
"scale": 1,
"readonly": true
"name": "Relay5State",
"type": "switch",
"address": "181",
"scale": 1,
"readonly": true
"name": "Addres_Teploskat_Air_Min",
"type": "value",
"reg_type": "holding_multi",
"address": "0x012F",
"format": "s16",
"scale": 1,
"name": "Addres_Teploskat_Air_Max",
"type": "value",
"address": "0x0130",
"scale": 1,
"name": "Addres_Teploskat_Time_Delay_Ch1",
"type": "value",
"address": "0x0137",
"scale": 1,
"channel_readonly": false,
"max": "180"
"name": "Manual_Auto_Teploskat",
"type": "switch",
"address": "0x153",
"scale": 1,
"max": "1"
"name": "Manual_Auto_Relay_1",
"type": "switch",
"address": "0x014F",
"scale": 1,
"max": "1"
"name": "Manual_Control_Relay_1",
"type": "switch",
"address": "0xAC",
"scale": 1,
"max": "1"
"name": "TST01_4",
"address": "0x0C",
"format": "s16",
"scale": 0.1,
"name": "TST01_4_10",
"type": "value",
"address": "0x0D",
"format": "s16",
"name": "TST01_4_mult",
"type": "value",
"address": "0x0E",
"format": "s16",
"scale": 1,
"name": "TST01_4_check",
"type": "value",
"address": "0x0F",
"scale": 1,
"device_max_fail_cycles": 1000
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 1,
"poll_interval": 2001,
"enabled": true
Вот часть логов: WB Logs - Pastebin.com
Интересуют девайсы с номерами modbus 1 и 201, это ПВУ SystemAir и РТМ-2000 соответственно.
З.Ы. Работать перестало довольно внезапно
