Ошибки в системном журнале
Здравствуйте, посыпались ошибки в системный журнал после перезагрузки контроллера, пропали все устройства из Home Assistant. Перезапустил HA , устройства появились, но ошибки в журнале продолжили появляться, логи прилагаю.
2025-03-05T08:40:16.103Z [systemd-udevd] vethf45b6c6: Failed to get link config: No such device
2025-03-05T08:40:16.099Z [systemd-udevd] vethf45b6c6: Failed to query device driver: No such device
2025-03-05T08:40:13.228Z [ntp] unable to create socket on veth7d33009 (2104) for fe80::cc10:edff:fe75:a266%2653#123
2025-03-05T08:40:13.225Z [ntp] bind(30) AF_INET6 fe80::cc10:edff:fe75:a266%2653#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:39:10.782Z [systemd-udevd] vethdb7a27a: Failed to get link config: No such device
2025-03-05T08:39:10.777Z [systemd-udevd] vethdb7a27a: Failed to query device driver: No such device
2025-03-05T08:39:07.227Z [ntp] unable to create socket on vetha9bebe0 (2102) for fe80::dcba:efff:fe8b:4bd8%2651#123
2025-03-05T08:39:07.224Z [ntp] bind(30) AF_INET6 fe80::dcba:efff:fe8b:4bd8%2651#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:38:05.481Z [systemd-udevd] veth8597d3a: Failed to get link config: No such device
2025-03-05T08:38:05.478Z [systemd-udevd] veth8597d3a: Failed to query device driver: No such device
2025-03-05T08:38:02.228Z [ntp] unable to create socket on veth5a39b7f (2100) for fe80::9cd7:a4ff:fe0e:2f3c%2649#123
2025-03-05T08:38:02.225Z [ntp] bind(30) AF_INET6 fe80::9cd7:a4ff:fe0e:2f3c%2649#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:37:00.230Z [systemd-udevd] veth47fdb17: Failed to get link config: No such device
2025-03-05T08:37:00.224Z [systemd-udevd] veth47fdb17: Failed to query device driver: No such device
2025-03-05T08:36:57.227Z [ntp] unable to create socket on veth820da66 (2098) for fe80::3071:b7ff:fe38:47f0%2647#123
2025-03-05T08:36:57.224Z [ntp] bind(30) AF_INET6 fe80::3071:b7ff:fe38:47f0%2647#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:36:46.988Z RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
2025-03-05T08:35:54.856Z [systemd-udevd] veth8b11951: Failed to get link config: No such device
2025-03-05T08:35:54.851Z [systemd-udevd] veth8b11951: Failed to query device driver: No such device
2025-03-05T08:35:52.228Z [ntp] unable to create socket on veth4364f90 (2096) for fe80::84a3:b0ff:fe90:3d%2645#123
2025-03-05T08:35:52.225Z [ntp] bind(30) AF_INET6 fe80::84a3:b0ff:fe90:3d%2645#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:34:49.775Z [systemd-udevd] veth22f54cb: Failed to get link config: No such device
2025-03-05T08:34:49.769Z [systemd-udevd] veth22f54cb: Failed to query device driver: No such device
2025-03-05T08:33:44.505Z [systemd-udevd] veth304387a: Failed to get link config: No such device
2025-03-05T08:33:44.500Z [systemd-udevd] veth304387a: Failed to query device driver: No such device
2025-03-05T08:33:41.227Z [ntp] unable to create socket on veth9057331 (2093) for fe80::e44c:f0ff:fef3:c195%2641#123
2025-03-05T08:33:41.224Z [ntp] bind(30) AF_INET6 fe80::e44c:f0ff:fef3:c195%2641#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:32:39.322Z [systemd-udevd] veth9f45df1: Failed to get link config: No such device
2025-03-05T08:32:39.312Z [systemd-udevd] veth9f45df1: Failed to query device driver: No such device
2025-03-05T08:32:36.227Z [ntp] unable to create socket on veth64086d9 (2091) for fe80::2c5e:5ff:fe5e:507c%2639#123
2025-03-05T08:32:36.224Z [ntp] bind(30) AF_INET6 fe80::2c5e:5ff:fe5e:507c%2639#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:31:34.032Z [systemd-udevd] veth90c2c3f: Failed to get link config: No such device
2025-03-05T08:31:34.028Z [systemd-udevd] veth90c2c3f: Failed to query device driver: No such device
2025-03-05T08:30:28.638Z [systemd-udevd] vetha74f932: Failed to get link config: No such device
2025-03-05T08:30:28.634Z [systemd-udevd] vetha74f932: Failed to query device driver: No such device
2025-03-05T08:29:23.582Z [systemd-udevd] vethb2c2f54: Failed to get link config: No such device
2025-03-05T08:29:23.577Z [systemd-udevd] vethb2c2f54: Failed to query device driver: No such device
2025-03-05T08:29:20.227Z [ntp] unable to create socket on veth4613c23 (2087) for fe80::1097:5cff:fe67:be06%2633#123
2025-03-05T08:29:20.224Z [ntp] bind(30) AF_INET6 fe80::1097:5cff:fe67:be06%2633#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:28:18.462Z [systemd-udevd] vethd71886d: Failed to get link config: No such device
2025-03-05T08:28:18.460Z [systemd-udevd] vethd71886d: Failed to query device driver: No such device
2025-03-05T08:28:18.326Z [systemd-udevd] vethd71886d: Failed to get link config: No such device
2025-03-05T08:28:18.321Z [systemd-udevd] vethd71886d: Failed to query device driver: No such device
2025-03-05T08:28:15.227Z [ntp] unable to create socket on veth21f1ec8 (2085) for fe80::6c9b:dcff:febb:f058%2631#123
2025-03-05T08:28:15.224Z [ntp] bind(30) AF_INET6 fe80::6c9b:dcff:febb:f058%2631#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:27:13.144Z [systemd-udevd] veth588b6e7: Failed to get link config: No such device
2025-03-05T08:27:13.138Z [systemd-udevd] veth588b6e7: Failed to query device driver: No such device
2025-03-05T08:26:46.768Z RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
2025-03-05T08:26:08.010Z [systemd-udevd] vethc9111c8: Failed to get link config: No such device
2025-03-05T08:26:08.005Z [systemd-udevd] vethc9111c8: Failed to query device driver: No such device
2025-03-05T08:25:32.940Z [wb-rules] WARNING: [rule warning] DAC: no config file
2025-03-05T08:25:32.727Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.256Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.225Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.216Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.206Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.193Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.138Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.125Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.119Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.106Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.089Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.082Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.065Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.061Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.049Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:31.042Z [wb-mqtt-db] WARNING: [conventions] converting empty value to boolean "false"
2025-03-05T08:25:01.560Z [systemd-udevd] vethb319512: Failed to get link config: No such device
2025-03-05T08:25:01.555Z [systemd-udevd] vethb319512: Failed to query device driver: No such device
2025-03-05T08:24:58.227Z [ntp] unable to create socket on vethd7ea924 (2081) for fe80::78ea:3eff:fe7f:9fe2%2625#123
2025-03-05T08:24:58.224Z [ntp] bind(30) AF_INET6 fe80::78ea:3eff:fe7f:9fe2%2625#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:23:56.369Z [systemd-udevd] vethbecac00: Failed to get link config: No such device
2025-03-05T08:23:56.366Z [systemd-udevd] vethbecac00: Failed to query device driver: No such device
2025-03-05T08:22:51.228Z [systemd-udevd] vethb8f0815: Failed to get link config: No such device
2025-03-05T08:22:51.224Z [systemd-udevd] vethb8f0815: Failed to query device driver: No such device
2025-03-05T08:22:48.228Z [ntp] unable to create socket on vethcab14a7 (2078) for fe80::38a0:19ff:fe90:75df%2621#123
2025-03-05T08:22:48.225Z [ntp] bind(30) AF_INET6 fe80::38a0:19ff:fe90:75df%2621#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:21:46.079Z [systemd-udevd] veth5d2f3e8: Failed to get link config: No such device
2025-03-05T08:21:46.076Z [systemd-udevd] veth5d2f3e8: Failed to query device driver: No such device
2025-03-05T08:21:43.227Z [ntp] unable to create socket on veth785f7ce (2076) for fe80::7826:a7ff:fe9c:f15%2619#123
2025-03-05T08:21:43.224Z [ntp] bind(30) AF_INET6 fe80::7826:a7ff:fe9c:f15%2619#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:21:41.889Z [wb-mqtt-serial] WARNING: [modbus] failed to read 2 input(s) @ 270 of device </dev/ttyRS485-1 9600 8 N 2> modbus:11: Serial protocol error: malformed response: invalid crc
2025-03-05T08:20:41.109Z [systemd-udevd] veth81c9c61: Failed to get link config: No such device
2025-03-05T08:20:41.104Z [systemd-udevd] veth81c9c61: Failed to query device driver: No such device
2025-03-05T08:20:38.227Z [ntp] unable to create socket on veth719e018 (2074) for fe80::8073:4cff:fef6:f208%2617#123
2025-03-05T08:20:38.224Z [ntp] bind(30) AF_INET6 fe80::8073:4cff:fef6:f208%2617#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:20:35.639Z [wb-mqtt-serial] WARNING: [modbus] failed to read 2 input(s) @ 270 of device </dev/ttyRS485-1 9600 8 N 2> modbus:124: Serial protocol error: malformed response: invalid crc
2025-03-05T08:19:36.051Z [systemd-udevd] vethf32bba2: Failed to get link config: No such device
2025-03-05T08:19:36.047Z [systemd-udevd] vethf32bba2: Failed to query device driver: No such device
2025-03-05T08:19:33.227Z [ntp] unable to create socket on veth963fe15 (2072) for fe80::ccb7:3ff:fe7d:a35%2615#123
2025-03-05T08:19:33.224Z [ntp] bind(30) AF_INET6 fe80::ccb7:3ff:fe7d:a35%2615#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:18:30.902Z [systemd-udevd] veth4696e56: Failed to get link config: No such device
2025-03-05T08:18:30.900Z [systemd-udevd] veth4696e56: Failed to query device driver: No such device
2025-03-05T08:18:30.740Z [systemd-udevd] veth4696e56: Failed to get link config: No such device
2025-03-05T08:18:30.735Z [systemd-udevd] veth4696e56: Failed to query device driver: No such device
2025-03-05T08:17:25.595Z [systemd-udevd] veth6b707ae: Failed to get link config: No such device
2025-03-05T08:17:25.591Z [systemd-udevd] veth6b707ae: Failed to query device driver: No such device
2025-03-05T08:16:46.768Z RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
2025-03-05T08:16:18.127Z [systemd-udevd] veth8ea1e21: Failed to get link config: No such device
2025-03-05T08:16:18.123Z [systemd-udevd] veth8ea1e21: Failed to query device driver: No such device
2025-03-05T08:15:12.977Z [systemd-udevd] veth9fac52f: Failed to get link config: No such device
2025-03-05T08:15:12.970Z [systemd-udevd] veth9fac52f: Failed to query device driver: No such device
2025-03-05T08:14:07.818Z [systemd-udevd] veth6c4e47e: Failed to get link config: No such device
2025-03-05T08:14:07.812Z [systemd-udevd] veth6c4e47e: Failed to query device driver: No such device
2025-03-05T08:14:05.227Z [ntp] unable to create socket on veth937e6fd (2066) for fe80::c0a6:eeff:fe47:34a7%2605#123
2025-03-05T08:14:05.224Z [ntp] bind(30) AF_INET6 fe80::c0a6:eeff:fe47:34a7%2605#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:13:02.594Z [systemd-udevd] veth9bd8875: Failed to get link config: No such device
2025-03-05T08:13:02.590Z [systemd-udevd] veth9bd8875: Failed to query device driver: No such device
2025-03-05T08:12:59.227Z [ntp] unable to create socket on vethd2e17ab (2064) for fe80::f8bc:a2ff:fe98:5b8e%2603#123
2025-03-05T08:12:59.224Z [ntp] bind(30) AF_INET6 fe80::f8bc:a2ff:fe98:5b8e%2603#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:11:57.431Z [systemd-udevd] vethc5e27b7: Failed to get link config: No such device
2025-03-05T08:11:57.426Z [systemd-udevd] vethc5e27b7: Failed to query device driver: No such device
2025-03-05T08:11:54.230Z [ntp] unable to create socket on vethbec4012 (2062) for fe80::4c97:1aff:fed5:7f3%2601#123
2025-03-05T08:11:54.225Z [ntp] bind(30) AF_INET6 fe80::4c97:1aff:fed5:7f3%2601#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:10:51.903Z [systemd-udevd] veth3f904ef: Failed to get link config: No such device
2025-03-05T08:10:51.898Z [systemd-udevd] veth3f904ef: Failed to query device driver: No such device
2025-03-05T08:09:46.544Z [systemd-udevd] veth83ab131: Failed to get link config: No such device
2025-03-05T08:09:46.540Z [systemd-udevd] veth83ab131: Failed to query device driver: No such device
2025-03-05T08:08:41.475Z [systemd-udevd] veth99e5c80: Failed to get link config: No such device
2025-03-05T08:08:41.460Z [systemd-udevd] veth99e5c80: Failed to query device driver: No such device
2025-03-05T08:08:38.227Z [ntp] unable to create socket on vethf35879b (2058) for fe80::f02e:3dff:fee4:6f3e%2595#123
2025-03-05T08:08:38.224Z [ntp] bind(30) AF_INET6 fe80::f02e:3dff:fee4:6f3e%2595#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:07:36.287Z [systemd-udevd] veth104fb97: Failed to get link config: No such device
2025-03-05T08:07:36.282Z [systemd-udevd] veth104fb97: Failed to query device driver: No such device
2025-03-05T08:07:33.227Z [ntp] unable to create socket on vethc901415 (2056) for fe80::9836:15ff:fef1:a18%2593#123
2025-03-05T08:07:33.224Z [ntp] bind(30) AF_INET6 fe80::9836:15ff:fef1:a18%2593#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:06:46.758Z RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
2025-03-05T08:06:31.204Z [systemd-udevd] veth46ed65b: Failed to get link config: No such device
2025-03-05T08:06:31.200Z [systemd-udevd] veth46ed65b: Failed to query device driver: No such device
2025-03-05T08:06:28.229Z [ntp] unable to create socket on vethd1ea832 (2054) for fe80::809e:20ff:fe57:9933%2591#123
2025-03-05T08:06:28.225Z [ntp] bind(30) AF_INET6 fe80::809e:20ff:fe57:9933%2591#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:05:25.921Z [systemd-udevd] veth5d7be50: Failed to get link config: No such device
2025-03-05T08:05:25.916Z [systemd-udevd] veth5d7be50: Failed to query device driver: No such device
2025-03-05T08:05:25.779Z [wb-mqtt-serial] WARNING: [modbus] failed to read 1 input(s) @ 4 of device </dev/ttyRS485-1 9600 8 N 2> modbus:104: Serial protocol error: malformed response: invalid crc
2025-03-05T08:05:25.584Z [wb-mqtt-serial] WARNING: [modbus] failed to read 1 input(s) @ 4 of device </dev/ttyRS485-1 9600 8 N 2> modbus:151: Serial protocol error: malformed response: invalid crc
2025-03-05T08:05:23.227Z [ntp] unable to create socket on veth708773f (2052) for fe80::500b:8cff:feb2:23b%2589#123
2025-03-05T08:05:23.225Z [ntp] bind(30) AF_INET6 fe80::500b:8cff:feb2:23b%2589#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:04:20.735Z [systemd-udevd] vethfd4f108: Failed to get link config: No such device
2025-03-05T08:04:20.705Z [systemd-udevd] vethfd4f108: Failed to query device driver: No such device
2025-03-05T08:03:15.511Z [systemd-udevd] veth2a223bb: Failed to get link config: No such device
2025-03-05T08:03:15.506Z [systemd-udevd] veth2a223bb: Failed to query device driver: No such device
2025-03-05T08:03:12.227Z [ntp] unable to create socket on veth13959f3 (2049) for fe80::8ae:5ff:fece:49fa%2585#123
2025-03-05T08:03:12.225Z [ntp] bind(30) AF_INET6 fe80::8ae:5ff:fece:49fa%2585#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:02:10.402Z [systemd-udevd] vetha63862c: Failed to get link config: No such device
2025-03-05T08:02:10.398Z [systemd-udevd] vetha63862c: Failed to query device driver: No such device
2025-03-05T08:01:05.242Z [systemd-udevd] veth71ff012: Failed to get link config: No such device
2025-03-05T08:01:05.237Z [systemd-udevd] veth71ff012: Failed to query device driver: No such device
2025-03-05T08:01:05.097Z [systemd-udevd] veth71ff012: Failed to get link config: No such device
2025-03-05T08:01:05.092Z [systemd-udevd] veth71ff012: Failed to query device driver: No such device
2025-03-05T08:01:02.228Z [ntp] unable to create socket on vethd405045 (2046) for fe80::5c0e:f3ff:fed0:c9d7%2581#123
2025-03-05T08:01:02.225Z [ntp] bind(30) AF_INET6 fe80::5c0e:f3ff:fed0:c9d7%2581#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T08:00:00.134Z [systemd-udevd] vethe89db87: Failed to get link config: No such device
2025-03-05T08:00:00.132Z [systemd-udevd] vethe89db87: Failed to query device driver: No such device
2025-03-05T08:00:00.040Z [systemd-udevd] vethe89db87: Failed to get link config: No such device
2025-03-05T07:59:57.229Z [ntp] unable to create socket on vethed26f03 (2044) for fe80::c4fd:2cff:fefc:2554%2579#123
2025-03-05T07:59:57.225Z [ntp] bind(30) AF_INET6 fe80::c4fd:2cff:fefc:2554%2579#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:58:55.068Z [systemd-udevd] vethcdba8e9: Failed to get link config: No such device
2025-03-05T07:58:55.067Z [systemd-udevd] vethcdba8e9: Failed to query device driver: No such device
2025-03-05T07:58:54.930Z [systemd-udevd] vethcdba8e9: Failed to get link config: No such device
2025-03-05T07:58:54.925Z [systemd-udevd] vethcdba8e9: Failed to query device driver: No such device
2025-03-05T07:58:52.227Z [ntp] unable to create socket on vethb54541c (2042) for fe80::8840:cbff:fe90:8071%2577#123
2025-03-05T07:58:52.225Z [ntp] bind(30) AF_INET6 fe80::8840:cbff:fe90:8071%2577#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:57:49.555Z [systemd-udevd] veth827387f: Failed to get link config: No such device
2025-03-05T07:57:49.548Z [systemd-udevd] veth827387f: Failed to query device driver: No such device
2025-03-05T07:57:46.227Z [ntp] unable to create socket on veth1e1b691 (2040) for fe80::987b:e1ff:fe52:f91f%2575#123
2025-03-05T07:57:46.224Z [ntp] bind(30) AF_INET6 fe80::987b:e1ff:fe52:f91f%2575#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:56:46.758Z RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
2025-03-05T07:56:44.456Z [systemd-udevd] veth26fd27c: Failed to get link config: No such device
2025-03-05T07:56:44.451Z [systemd-udevd] veth26fd27c: Failed to query device driver: No such device
2025-03-05T07:56:41.227Z [ntp] unable to create socket on veth41ff677 (2038) for fe80::cc95:cfff:fec5:4942%2573#123
2025-03-05T07:56:41.224Z [ntp] bind(30) AF_INET6 fe80::cc95:cfff:fec5:4942%2573#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:55:39.226Z [systemd-udevd] vethea0fc27: Failed to get link config: No such device
2025-03-05T07:55:39.222Z [systemd-udevd] vethea0fc27: Failed to query device driver: No such device
2025-03-05T07:54:33.968Z [systemd-udevd] veth53fb386: Failed to get link config: No such device
2025-03-05T07:54:33.964Z [systemd-udevd] veth53fb386: Failed to query device driver: No such device
2025-03-05T07:53:28.787Z [systemd-udevd] veth88ac08d: Failed to get link config: No such device
2025-03-05T07:53:28.783Z [systemd-udevd] veth88ac08d: Failed to query device driver: No such device
2025-03-05T07:52:23.616Z [systemd-udevd] veth2c03053: Failed to get link config: No such device
2025-03-05T07:52:23.596Z [systemd-udevd] veth2c03053: Failed to query device driver: No such device
2025-03-05T07:52:20.227Z [ntp] unable to create socket on veth362f217 (2033) for fe80::84bf:a5ff:fe24:33a1%2565#123
2025-03-05T07:52:20.225Z [ntp] bind(30) AF_INET6 fe80::84bf:a5ff:fe24:33a1%2565#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:51:18.394Z [systemd-udevd] vetheb3d1c6: Failed to get link config: No such device
2025-03-05T07:51:18.389Z [systemd-udevd] vetheb3d1c6: Failed to query device driver: No such device
2025-03-05T07:50:13.159Z [systemd-udevd] vetha171055: Failed to get link config: No such device
2025-03-05T07:50:13.151Z [systemd-udevd] vetha171055: Failed to query device driver: No such device
2025-03-05T07:50:10.228Z [ntp] unable to create socket on veth5af1d5e (2030) for fe80::2c50:a4ff:fe19:75dd%2561#123
2025-03-05T07:50:10.225Z [ntp] bind(30) AF_INET6 fe80::2c50:a4ff:fe19:75dd%2561#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:49:08.034Z [systemd-udevd] vethd93de9c: Failed to get link config: No such device
2025-03-05T07:49:08.030Z [systemd-udevd] vethd93de9c: Failed to query device driver: No such device
2025-03-05T07:48:02.775Z [systemd-udevd] vethf4eae9a: Failed to get link config: No such device
2025-03-05T07:48:02.764Z [systemd-udevd] vethf4eae9a: Failed to query device driver: No such device
2025-03-05T07:46:57.621Z [systemd-udevd] veth2e89e39: Failed to get link config: No such device
2025-03-05T07:46:57.620Z [systemd-udevd] veth2e89e39: Failed to query device driver: No such device
2025-03-05T07:46:57.509Z [systemd-udevd] veth2e89e39: Failed to get link config: No such device
2025-03-05T07:46:54.229Z [ntp] unable to create socket on vethc785562 (2026) for fe80::90a6:32ff:fe34:e6ce%2555#123
2025-03-05T07:46:54.225Z [ntp] bind(30) AF_INET6 fe80::90a6:32ff:fe34:e6ce%2555#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:46:46.748Z RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
2025-03-05T07:45:52.176Z [systemd-udevd] vethb9f4d39: Failed to get link config: No such device
2025-03-05T07:45:52.171Z [systemd-udevd] vethb9f4d39: Failed to query device driver: No such device
2025-03-05T07:45:49.227Z [ntp] unable to create socket on veth5ced19d (2024) for fe80::500f:9dff:fe97:dcac%2553#123
2025-03-05T07:45:49.224Z [ntp] bind(30) AF_INET6 fe80::500f:9dff:fe97:dcac%2553#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:44:47.141Z [systemd-udevd] vethb86b335: Failed to get link config: No such device
2025-03-05T07:44:47.136Z [systemd-udevd] vethb86b335: Failed to query device driver: No such device
2025-03-05T07:44:44.228Z [ntp] unable to create socket on vethf4a7e75 (2022) for fe80::2888:dff:fe1b:970a%2551#123
2025-03-05T07:44:44.225Z [ntp] bind(30) AF_INET6 fe80::2888:dff:fe1b:970a%2551#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:43:41.988Z [systemd-udevd] veth4fb403e: Failed to get link config: No such device
2025-03-05T07:43:41.983Z [systemd-udevd] veth4fb403e: Failed to query device driver: No such device
2025-03-05T07:42:36.651Z [systemd-udevd] vetha855867: Failed to get link config: No such device
2025-03-05T07:42:36.648Z [systemd-udevd] vetha855867: Failed to query device driver: No such device
2025-03-05T07:41:31.492Z [systemd-udevd] vethdc97600: Failed to get link config: No such device
2025-03-05T07:41:31.486Z [systemd-udevd] vethdc97600: Failed to query device driver: No such device
2025-03-05T07:41:28.227Z [ntp] unable to create socket on veth216e32e (2018) for fe80::e4ad:faff:fe61:17b3%2545#123
2025-03-05T07:41:28.224Z [ntp] bind(30) AF_INET6 fe80::e4ad:faff:fe61:17b3%2545#123 flags 0x11 failed: Cannot assign requested address
2025-03-05T07:40:26.312Z [systemd-udevd] veth782add4: Failed to get link config: No such device
2025-03-05T07:40:26.306Z [systemd-udevd] veth782add4: Failed to query device driver: No such device
2025-03-05T07:40:23.228Z [ntp] unable to create socket on vethaf3b9a3 (2016) for fe80::9899:fbff:feb8:5588%2543#123
2025-03-05T07:40:23.224Z [ntp] bind(30) AF_INET6 fe80::9899:fbff:feb8:5588%2543#123 flags 0x11 failed: Cannot assign requested address
Добрый день
Сделал фактори ресет только что, и обновил прошивку через веб морду. Сделал диагностический архив и логи системного журнала. Система пуста полностью, но идут ошибки, что не так?
(117,9 КБ)
log_20250306T150118.log (9,7 КБ)
Попробуйте отключить все периферийные устройства от контроллера и сообщите результат.
Из устройств только модбас устройства, из физически нужно отключить? Всю шину? Я уже уехал от клиента
Да, это необходимо, чтобы исключить влияние внешних факторов.
Попробую завтра
Кстати на этом же контроллере я 3 часа пытался расширить корневой раздел, через веб морду, и через консоль, ничего не получилось. Создал тему на портале.
Добрый день! Ждем от вас обратной связи.
Здравствуйте, на тот объект пока попасть не могу. Сейчас собрал еще один щит, сделал обновление, поставил докер, в системном журнале тоже присутствуют ошибки, логи и журнал прилагаю
(500,5 КБ)
log_20250310T175528.log (20,3 КБ)
Прошу прощения за долгий ответ.
Уточните пожалуйста установку docker делали по нашей инструкции? Контроллер перед этим был с заводскими настройками?
Здравствуйте, да установку docker делал по инструкции, предварительно делал сброс до заводских настроек через factoryreset
Не так давно сталкивались с проблемой разворачивания docker. Разработчики сделали исправление.
Попробуйте выполнить обновление:
apt update && apt upgrade
Если не поможет, то выведите результаты команд:
docker -v
systemctl status docker.service
Добрый день! Вам удалось выполнить обновление?
Здравствуйте, установил клиенту другой контроллер этот забрал себе на исправление, докер не ставил, так как не могу расширить корневой раздел
