Вот что-то нехорошее наблюдаю в логах.
Обновления пакетов сделал 30 минут назад. Так что они сегодняшние.
Dec 18 12:45:12 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-serial.service: Main process exited, code=killed, status=4/ILL
Dec 18 12:45:12 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-serial.service: Failed with result 'signal'.
Dec 18 12:45:12 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-serial.service: Consumed 27.559s CPU time.
Dec 18 12:45:13 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-serial.service: Scheduled restart job, restart counter is at 12.
Dec 18 12:45:13 wirenboard-AN4RTE7N systemd[1]: Stopped MQTT Driver for serial devices.
Dec 18 12:45:13 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-serial.service: Consumed 27.559s CPU time.
Dec 18 12:45:13 wirenboard-AN4RTE7N systemd[1]: Started MQTT Driver for serial devices.
Dec 18 12:45:15 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] Default host and port detected, checking if UNIX socket exists on /var/run/mosquitto/mosquitto.sock
Dec 18 12:45:15 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] UNIX socket exists, using it for connection
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] connection estabilished with code "0" <success>
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 1)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 2)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 14)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 21)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 28)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 29)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 30)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 94)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 95)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 108)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 115)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 122)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 129)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 136)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 143)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 150)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 151)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 164)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 219)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 226)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 233)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 240)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 247)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 254)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 261)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 268)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 275)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 282)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 289)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 296)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 339)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 346)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 353)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 360)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 367)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 374)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 411)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 412)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 416)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [mqtt] subscription succeeded (message id 418)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Continuous read enabled [slave_id is 1]
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Baud rate: setup register <modbus:1:holding: 110> <-- 1152 (0x480)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Maximum value: setup register <modbus:1:holding: 5130> <-- 10000 (0x2710)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Minimum value: setup register <modbus:1:holding: 5128> <-- -10000 (0xd8f0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 5120> <-- 5376 (0x1500)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Maximum value: setup register <modbus:1:holding: 9226> <-- 10000 (0x2710)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Minimum value: setup register <modbus:1:holding: 9224> <-- -10000 (0xd8f0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 9216> <-- 5376 (0x1500)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 13313> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 13312> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 17409> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 17408> <-- 1 (0x1)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 21505> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 21504> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 25601> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Mode: setup register <modbus:1:holding: 25600> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [serial device] device modbus:1 is connected
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: WARNING: [modbus] Continuous read is not enabled [slave_id is 11]
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Baud rate: setup register <modbus:11:holding: 110> <-- 1152 (0x480)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: Outputs State After Power On: setup register <modbus:11:holding: 6> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [modbus] Init: disable legacy input mode control: setup register <modbus:11:holding: 5> <-- 0 (0x0)
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [serial device] device modbus:11 is connected
Dec 18 12:45:16 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [serial device] device modbus:12 is connected
Dec 18 12:45:17 wirenboard-AN4RTE7N wb-mqtt-serial[5144]: INFO: [serial device] device modbus:13 is connected
Dec 18 12:45:55 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:45:57 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:45:59 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:46:34 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:46:36 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:46:38 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:47:37 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:47:39 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:47:41 wirenboard-AN4RTE7N kernel: i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Dec 18 12:47:48 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-db.service: Main process exited, code=killed, status=4/ILL
Dec 18 12:47:48 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-db.service: Failed with result 'signal'.
Dec 18 12:47:48 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-db.service: Consumed 4.578s CPU time.
Dec 18 12:47:49 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-db.service: Scheduled restart job, restart counter is at 18.
Dec 18 12:47:49 wirenboard-AN4RTE7N systemd[1]: Stopped Wiren Board database logger.
Dec 18 12:47:49 wirenboard-AN4RTE7N systemd[1]: wb-mqtt-db.service: Consumed 4.578s CPU time.
Dec 18 12:47:49 wirenboard-AN4RTE7N systemd[1]: Started Wiren Board database logger.
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: MQTT broker localhost:1883
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: Config file /etc/wb-mqtt-db.conf
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] Default host and port detected, checking if UNIX socket exists on /var/run/mosquitto/mosquitto.sock
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] UNIX socket exists, using it for connection
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [sqlite] Creating tables if necessary
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [sqlite] Create indices if necessary
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [sqlite] Analyzing data table
Dec 18 12:47:49 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [sqlite] DB initialization is done
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: DB logger started, go to main loop
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] connection estabilished with code "0" <success>
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] subscription succeeded (message id 1)
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] subscription succeeded (message id 2)
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] subscription succeeded (message id 5)
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] subscription succeeded (message id 6)
Dec 18 12:47:50 wirenboard-AN4RTE7N wb-mqtt-db[6388]: INFO: [mqtt] subscription succeeded (message id 7)
