Пытаюсь подключить к контроллеру WB WB-MIO-E с боковым модулем WBIO-DO-R1G-16, подключил по такой схеме:
На самом WB-MIO-E стоят такие настройки:
Сам WB-MIO-E доступен в сети контроллера
В настройках драйвера на TCP 10.43.0.7 указал Modbus адрес 24:1
Но боковой модуль почему-то не доступен. в логах это:
Логи
| 02-07-2025 20:38:56.069 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:50.555 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:45.045 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:39.553 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:34.039 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:28.526 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:23.424 | RTW: WARN cfg80211_rtw_scan (wlan1) : scan abort!! BusyTraffic |
| 02-07-2025 20:38:23.013 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:17.509 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:11.993 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:06.481 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:38:00.968 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:55.453 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:49.941 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:44.428 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:38.915 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:33.402 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:27.888 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:22.375 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:16.862 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:11.349 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:05.834 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:37:00.320 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:54.808 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:49.295 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:43.781 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:38.268 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:32.755 [wb-mqtt-serial] | WARNING: <10.43.0.7:23>: closed due to repetitive errors |
| 02-07-2025 20:36:27.854 [wb-mqtt-serial] | WARNING: [serial device] device <10.43.0.7:23> modbus_io:24:1 is disconnected |
| 02-07-2025 20:36:27.296 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 134) |
| 02-07-2025 20:36:27.296 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 132) |
| 02-07-2025 20:36:27.296 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 130) |
| 02-07-2025 20:36:27.285 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 126) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 125) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 124) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 117) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 110) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 103) |
| 02-07-2025 20:36:27.284 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 96) |
| 02-07-2025 20:36:27.280 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 89) |
| 02-07-2025 20:36:27.280 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 82) |
| 02-07-2025 20:36:27.280 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 75) |
| 02-07-2025 20:36:27.280 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 68) |
| 02-07-2025 20:36:27.280 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 61) |
| 02-07-2025 20:36:27.278 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 54) |
| 02-07-2025 20:36:27.276 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 47) |
| 02-07-2025 20:36:27.274 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 40) |
| 02-07-2025 20:36:27.274 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 33) |
| 02-07-2025 20:36:27.274 [wb-mqtt-serial] | INFO: [mqtt] subscription succeeded (message id 26) |
Куда копать?
