Проблема Каналы MQTT
Добрый день, снова проблема с отображением устройств.
system/HW Revision 7.3.4
system/Release name wb-2501 stable
Проблема: после длительного отсутвия электроэнергии после загрузки началось
это устрайства отображающиеся в интерфейсе
Это устройсва подключеные по шине
все пакеты обновил, все прошивки на устройствах обновил но не помогает. кроме того в логах:
25-04-2025 13:11:55.162 [init.scope] dev-mmcblk1p1.device: Job dev-mmcblk1p1.device/start failed with result ‘timeout’.
25-04-2025 13:11:55.161 [init.scope] systemd-fsck@dev-mmcblk1p1.service: Job systemd-fsck@dev-mmcblk1p1.service/start failed with result ‘dependency’.
25-04-2025 13:11:55.161 [init.scope] Dependency failed for File System Check on /dev/mmcblk1p1.
25-04-2025 13:11:55.160 [init.scope] mnt-sdcard.mount: Job mnt-sdcard.mount/start failed with result ‘dependency’.
25-04-2025 13:11:55.159 [init.scope] Dependency failed for /mnt/sdcard.
25-04-2025 13:11:55.158 [init.scope] Timed out waiting for device /dev/mmcblk1p1.
25-04-2025 13:11:55.155 [init.scope] dev-mmcblk1p1.device: Job dev-mmcblk1p1.device/start timed out.
25-04-2025 13:11:52.958 [init.scope] mnt-sdcard.automount: Got automount request for /mnt/sdcard, triggered by 1587 (zabbix_agent2)
25-04-2025 13:11:15.877 [NetworkManager] [1745575875.8773] dhcp4 (eth0): state changed new lease, address=10.10.55.100
25-04-2025 13:10:53.161 [init.scope] dev-mmcblk1p1.device: Job dev-mmcblk1p1.device/start failed with result ‘timeout’.
25-04-2025 13:10:53.160 [init.scope] systemd-fsck@dev-mmcblk1p1.service: Job systemd-fsck@dev-mmcblk1p1.service/start failed with result ‘dependency’.
25-04-2025 13:10:53.160 [init.scope] Dependency failed for File System Check on /dev/mmcblk1p1.
25-04-2025 13:10:53.159 [init.scope] mnt-sdcard.mount: Job mnt-sdcard.mount/start failed with result ‘dependency’.
25-04-2025 13:10:53.158 [init.scope] Dependency failed for /mnt/sdcard.
25-04-2025 13:10:53.158 [init.scope] Timed out waiting for device /dev/mmcblk1p1.
25-04-2025 13:10:53.155 [init.scope] dev-mmcblk1p1.device: Job dev-mmcblk1p1.device/start timed out.
25-04-2025 13:10:50.911 [init.scope] mnt-sdcard.automount: Got automount request for /mnt/sdcard, triggered by 1588 (zabbix_agent2)
25-04-2025 13:09:52.162 [init.scope] dev-mmcblk1p1.device: Job dev-mmcblk1p1.device/start failed with result ‘timeout’.
25-04-2025 13:09:52.161 [init.scope] systemd-fsck@dev-mmcblk1p1.service: Job systemd-fsck@dev-mmcblk1p1.service/start failed with result ‘dependency’.
25-04-2025 13:09:52.159 [init.scope] Dependency failed for File System Check on /dev/mmcblk1p1.
25-04-2025 13:09:52.159 [init.scope] mnt-sdcard.mount: Job mnt-sdcard.mount/start failed with result ‘dependency’.
25-04-2025 13:09:52.158 [init.scope] Dependency failed for /mnt/sdcard.
подскадите пожалуйста куда копать.
Прошу подробнее пояснить чем происходящее поведение отличается от ожидаемого?
Если посмотреть на скриншоты - то мы увидим, что на шине подключено 17 устройств. А кот в “Устройствах” отображается всего 5. Кроме того устройства так же отсутствуют в “Каналы MQTT”
Соответственно дальше никуда не передаются ( в Home Assistant)
Хорошо, проблема ясна. Пришлите, пожалуйста, диагностический архив. Создание архива описано в документации.
diag_output_AZ2SBJHF_2025-04-25-12.52.24.zip (258,6 КБ)
Здравствуйте. Воспроизвести не удалось, разбираюсь пока что.
Здравствуйте, спасибо ждем!
Данная проблема уже решена в testing версии прошивки. Вы можете перейти на нее до тех пор, пока не выйдет новая stable. Новая stable ожидается в ближайшее время (неделя - две).
У вас есть еще какие-либо вопросы?
Добрый день. перешел на тест. Проблема ушла - устройства видны, MQTT показывает все девайсы. Спасибо - ждем Стэйбл
