Аккумуляторный блок встроенный.
Контроллер простоял 3 дня в выключенном состоянии и без внешнего питания.
Видимо аккумулятор разрядился в ноль.
При включении контроллер повел себя странно:
Загрузка процессора 95-99%
Не работают правила
В веб-интерфейса в разделе Scripts таймаут
Выяснилось вот что:mosquitto_sub -v -t “/devices/wb-gpio/controls/#”
/devices/wb-gpio/controls/A1_OUT 0
/devices/wb-gpio/controls/A1_OUT/meta/order 0
/devices/wb-gpio/controls/A1_OUT/meta/type switch
/devices/wb-gpio/controls/A2_OUT 0
/devices/wb-gpio/controls/A2_OUT/meta/order 2
/devices/wb-gpio/controls/A2_OUT/meta/type switch
/devices/wb-gpio/controls/A3_OUT 0
/devices/wb-gpio/controls/A3_OUT/meta/order 4
/devices/wb-gpio/controls/A3_OUT/meta/type switch
/devices/wb-gpio/controls/A4_OUT 0
/devices/wb-gpio/controls/A4_OUT/meta/order 6
/devices/wb-gpio/controls/A4_OUT/meta/type switch
/devices/wb-gpio/controls/A1_IN 0
/devices/wb-gpio/controls/A1_IN/meta/order 8
/devices/wb-gpio/controls/A1_IN/meta/type switch
/devices/wb-gpio/controls/A1_IN/meta/readonly 1
/devices/wb-gpio/controls/A2_IN 0
/devices/wb-gpio/controls/A2_IN/meta/order 10
/devices/wb-gpio/controls/A2_IN/meta/type switch
/devices/wb-gpio/controls/A2_IN/meta/readonly 1
/devices/wb-gpio/controls/A3_IN 0
/devices/wb-gpio/controls/A3_IN/meta/order 12
/devices/wb-gpio/controls/A3_IN/meta/type switch
/devices/wb-gpio/controls/A3_IN/meta/readonly 1
/devices/wb-gpio/controls/A4_IN 0
/devices/wb-gpio/controls/A4_IN/meta/order 14
/devices/wb-gpio/controls/A4_IN/meta/type switch
/devices/wb-gpio/controls/A4_IN/meta/readonly 1
/devices/wb-gpio/controls/R1_IN 1
/devices/wb-gpio/controls/R1_IN/meta/order 16
/devices/wb-gpio/controls/R1_IN/meta/type switch
/devices/wb-gpio/controls/R1_IN/meta/readonly 1
/devices/wb-gpio/controls/BATTERY_PRESENT 1
/devices/wb-gpio/controls/BATTERY_PRESENT/meta/order 18
/devices/wb-gpio/controls/BATTERY_PRESENT/meta/type switch
/devices/wb-gpio/controls/BATTERY_PRESENT/meta/readonly 1
/devices/wb-gpio/controls/BATTERY_CHARGING 1
/devices/wb-gpio/controls/BATTERY_CHARGING/meta/order 20
/devices/wb-gpio/controls/BATTERY_CHARGING/meta/type switch
/devices/wb-gpio/controls/BATTERY_CHARGING/meta/readonly 1
/devices/wb-gpio/controls/5V_OUT 1
/devices/wb-gpio/controls/5V_OUT/meta/order 22
/devices/wb-gpio/controls/5V_OUT/meta/type switch
/devices/wb-gpio/controls/EXT1_DR1 0
/devices/wb-gpio/controls/EXT1_DR1/meta/order 24
/devices/wb-gpio/controls/EXT1_DR1/meta/type switch
/devices/wb-gpio/controls/EXT1_DR1/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR2 0
/devices/wb-gpio/controls/EXT1_DR2/meta/order 26
/devices/wb-gpio/controls/EXT1_DR2/meta/type switch
/devices/wb-gpio/controls/EXT1_DR2/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR3 0
/devices/wb-gpio/controls/EXT1_DR3/meta/order 28
/devices/wb-gpio/controls/EXT1_DR3/meta/type switch
/devices/wb-gpio/controls/EXT1_DR3/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR4 0
/devices/wb-gpio/controls/EXT1_DR4/meta/order 30
/devices/wb-gpio/controls/EXT1_DR4/meta/type switch
/devices/wb-gpio/controls/EXT1_DR4/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR5 0
/devices/wb-gpio/controls/EXT1_DR5/meta/order 32
/devices/wb-gpio/controls/EXT1_DR5/meta/type switch
/devices/wb-gpio/controls/EXT1_DR5/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR6 0
/devices/wb-gpio/controls/EXT1_DR6/meta/order 34
/devices/wb-gpio/controls/EXT1_DR6/meta/type switch
/devices/wb-gpio/controls/EXT1_DR6/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR7 0
/devices/wb-gpio/controls/EXT1_DR7/meta/order 36
/devices/wb-gpio/controls/EXT1_DR7/meta/type switch
/devices/wb-gpio/controls/EXT1_DR7/meta/readonly 1
/devices/wb-gpio/controls/EXT1_DR8 0
/devices/wb-gpio/controls/EXT1_DR8/meta/order 38
/devices/wb-gpio/controls/EXT1_DR8/meta/type switch
/devices/wb-gpio/controls/EXT1_DR8/meta/readonly 1
/devices/wb-gpio/controls/EXT2_R3A1 0
/devices/wb-gpio/controls/EXT2_R3A1/meta/order 40
/devices/wb-gpio/controls/EXT2_R3A1/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A2 0
/devices/wb-gpio/controls/EXT2_R3A2/meta/order 42
/devices/wb-gpio/controls/EXT2_R3A2/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A3 0
/devices/wb-gpio/controls/EXT2_R3A3/meta/order 44
/devices/wb-gpio/controls/EXT2_R3A3/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A4 0
/devices/wb-gpio/controls/EXT2_R3A4/meta/order 46
/devices/wb-gpio/controls/EXT2_R3A4/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A5 0
/devices/wb-gpio/controls/EXT2_R3A5/meta/order 48
/devices/wb-gpio/controls/EXT2_R3A5/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A6 0
/devices/wb-gpio/controls/EXT2_R3A6/meta/order 50
/devices/wb-gpio/controls/EXT2_R3A6/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A7 0
/devices/wb-gpio/controls/EXT2_R3A7/meta/order 52
/devices/wb-gpio/controls/EXT2_R3A7/meta/type switch
/devices/wb-gpio/controls/EXT2_R3A8 0
/devices/wb-gpio/controls/EXT2_R3A8/meta/order 54
/devices/wb-gpio/controls/EXT2_R3A8/meta/type switch
/devices/wb-gpio/controls/EXT3_DR1 0
/devices/wb-gpio/controls/EXT3_DR1/meta/order 56
/devices/wb-gpio/controls/EXT3_DR1/meta/type switch
/devices/wb-gpio/controls/EXT3_DR1/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR2 0
/devices/wb-gpio/controls/EXT3_DR2/meta/order 58
/devices/wb-gpio/controls/EXT3_DR2/meta/type switch
/devices/wb-gpio/controls/EXT3_DR2/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR3 0
/devices/wb-gpio/controls/EXT3_DR3/meta/order 60
/devices/wb-gpio/controls/EXT3_DR3/meta/type switch
/devices/wb-gpio/controls/EXT3_DR3/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR4 0
/devices/wb-gpio/controls/EXT3_DR4/meta/order 62
/devices/wb-gpio/controls/EXT3_DR4/meta/type switch
/devices/wb-gpio/controls/EXT3_DR4/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR5 0
/devices/wb-gpio/controls/EXT3_DR5/meta/order 64
/devices/wb-gpio/controls/EXT3_DR5/meta/type switch
/devices/wb-gpio/controls/EXT3_DR5/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR6 0
/devices/wb-gpio/controls/EXT3_DR6/meta/order 66
/devices/wb-gpio/controls/EXT3_DR6/meta/type switch
/devices/wb-gpio/controls/EXT3_DR6/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR7 0
/devices/wb-gpio/controls/EXT3_DR7/meta/order 68
/devices/wb-gpio/controls/EXT3_DR7/meta/type switch
/devices/wb-gpio/controls/EXT3_DR7/meta/readonly 1
/devices/wb-gpio/controls/EXT3_DR8 0
/devices/wb-gpio/controls/EXT3_DR8/meta/order 70
/devices/wb-gpio/controls/EXT3_DR8/meta/type switch
/devices/wb-gpio/controls/EXT3_DR8/meta/readonly 1
/devices/wb-gpio/controls/BATTERY_CHARGING 0
/devices/wb-gpio/controls/BATTERY_CHARGING 1root@wirenboard:~#
(сообщения “/devices/wb-gpio/controls/BATTERY_CHARGING 1” сыпались несколько раз в секунду.)
Перезапуск служб (wb-rules, wb-home-gpio) не помог.
Минут через 15-20 все пришло в норму.
Но такое поведение напрягает.
