Сдвинулось!
root@wirenboard-AV6U5XZP:~# route del default
root@wirenboard-AV6U5XZP:~# route add default dev ppp0
root@wirenboard-AV6U5XZP:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 0.0.0.0 0.0.0.0 U 0 0 0 ppp0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
root@wirenboard-AV6U5XZP:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=46 time=5593 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=46 time=4580 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=46 time=3548 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=46 time=2544 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=46 time=1512 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=46 time=533 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=46 time=3033 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=46 time=2774 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=46 time=1994 ms
^C
--- 8.8.8.8 ping statistics ---
13 packets transmitted, 9 received, 30% packet loss, time 12380ms
rtt min/avg/max/mdev = 533.617/2901.814/5593.534/1453.120 ms, pipe 6
Пинги пошли.
Проверяем cloud.wirenboard.ru:
root@wirenboard-AV6U5XZP:~# ping cloud.wirenboard.ru
PING contactless.ru (194.85.80.11) 56(84) bytes of data.
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=1 ttl=52 time=5536 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=2 ttl=52 time=5434 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=3 ttl=52 time=5864 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=4 ttl=52 time=6042 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=5 ttl=52 time=6124 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=6 ttl=52 time=6364 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=7 ttl=52 time=6311 ms
64 bytes from ip80-11.campus.mipt.ru (194.85.80.11): icmp_seq=8 ttl=52 time=6569 ms
^C
--- contactless.ru ping statistics ---
14 packets transmitted, 8 received, 42% packet loss, time 13238ms
rtt min/avg/max/mdev = 5434.716/6031.063/6569.752/373.620 ms, pipe 7
Далее проверяем получение данных по запросу:
root@wirenboard-AV6U5XZP:~# mosquitto_sub -v -h contactless.ru -u wb_AV6U5XZP -P xxxxxxxxxxxxxxxx -t "/#"
/client/wb_AV6U5XZP/devices/network/controls/Ethernet 0 IP 192.168.1.35
/client/wb_AV6U5XZP/devices/network/controls/Ethernet 0 IP/meta/type text
/client/wb_AV6U5XZP/devices/network/controls/Ethernet 0 IP/meta/order 1
/client/wb_AV6U5XZP/devices/network/controls/Wi-Fi 0 IP/meta/type text
/client/wb_AV6U5XZP/devices/network/controls/Wi-Fi 0 IP/meta/order 4
/client/wb_AV6U5XZP/devices/network/controls/Ethernet 1 IP/meta/type text
/client/wb_AV6U5XZP/devices/network/controls/Ethernet 1 IP/meta/order 2
/client/wb_AV6U5XZP/devices/network/controls/Wi-Fi 1 IP/meta/type text
/client/wb_AV6U5XZP/devices/network/controls/Wi-Fi 1 IP/meta/order 5
/client/wb_AV6U5XZP/devices/network/controls/GPRS IP 10.219.43.158
/client/wb_AV6U5XZP/devices/network/controls/GPRS IP/meta/type text
/client/wb_AV6U5XZP/devices/network/controls/GPRS IP/meta/order 3
/client/wb_AV6U5XZP/devices/network/meta/name Network
/client/wb_AV6U5XZP/devices/system/controls/Current uptime 0d 0h 10m
/client/wb_AV6U5XZP/devices/system/controls/Current uptime/meta/type text
/client/wb_AV6U5XZP/devices/system/controls/Current uptime/meta/order 1
/client/wb_AV6U5XZP/devices/system/controls/DTS Version 61
/client/wb_AV6U5XZP/devices/system/controls/DTS Version/meta/type text
/client/wb_AV6U5XZP/devices/system/controls/DTS Version/meta/order 2
/client/wb_AV6U5XZP/devices/system/controls/Firmware version 201807100856
/client/wb_AV6U5XZP/devices/system/controls/Firmware version/meta/type text
/client/wb_AV6U5XZP/devices/system/controls/Firmware version/meta/order 3
/client/wb_AV6U5XZP/devices/system/controls/Reboot/meta/type pushbutton
/client/wb_AV6U5XZP/devices/system/controls/Reboot/meta/order 4
/client/wb_AV6U5XZP/devices/system/controls/Short SN AV6U5XZP
/client/wb_AV6U5XZP/devices/system/controls/Short SN/meta/type text
/client/wb_AV6U5XZP/devices/system/controls/Short SN/meta/order 5
/client/wb_AV6U5XZP/devices/system/meta/name System
/client/wb_AV6U5XZP/devices/power_status/controls/Vin 11.82
/client/wb_AV6U5XZP/devices/power_status/controls/Vin/meta/type voltage
/client/wb_AV6U5XZP/devices/power_status/controls/Vin/meta/order 1
/client/wb_AV6U5XZP/devices/power_status/controls/working on battery 0
/client/wb_AV6U5XZP/devices/power_status/controls/working on battery/meta/type switch
/client/wb_AV6U5XZP/devices/power_status/controls/working on battery/meta/readonly 1
/client/wb_AV6U5XZP/devices/power_status/controls/working on battery/meta/order 2
/client/wb_AV6U5XZP/devices/power_status/meta/name Power status
/client/wb_AV6U5XZP/devices/wb-adc/controls/Vin 11.82
/client/wb_AV6U5XZP/devices/wb-adc/controls/5Vout 4.87
/client/wb_AV6U5XZP/devices/wb-adc/controls/A1 0.01
/client/wb_AV6U5XZP/devices/wb-adc/controls/A2 3.16
/client/wb_AV6U5XZP/devices/wb-adc/controls/A3 3.13
/client/wb_AV6U5XZP/devices/wb-adc/controls/A4 0.00
/client/wb_AV6U5XZP/devices/wb-w1/controls/28-041621a1f3ff 24.437
/client/wb_AV6U5XZP/devices/wb-w1/controls/28-041621bd3cff 24.375
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A3_OUT 0
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A4_IN 0
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A1_IN 1
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A1_OUT 1
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A2_OUT 0
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A2_IN 0
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A3_IN 1
/client/wb_AV6U5XZP/devices/wb-gpio/controls/A4_OUT 0
/client/wb_AV6U5XZP/devices/CloudSend/controls/Auto 1
/client/wb_AV6U5XZP/devices/buzzer/controls/enabled 0
/client/wb_AV6U5XZP/devices/buzzer/controls/enabled/meta/type switch
/client/wb_AV6U5XZP/devices/buzzer/controls/enabled/meta/order 1
/client/wb_AV6U5XZP/devices/buzzer/controls/frequency 3000
/client/wb_AV6U5XZP/devices/buzzer/controls/frequency/meta/type range
/client/wb_AV6U5XZP/devices/buzzer/controls/frequency/meta/order 2
/client/wb_AV6U5XZP/devices/buzzer/controls/frequency/meta/max 7000
/client/wb_AV6U5XZP/devices/buzzer/controls/volume 10
/client/wb_AV6U5XZP/devices/buzzer/controls/volume/meta/type range
/client/wb_AV6U5XZP/devices/buzzer/controls/volume/meta/order 3
/client/wb_AV6U5XZP/devices/buzzer/controls/volume/meta/max 100
/client/wb_AV6U5XZP/devices/buzzer/meta/name Buzzer
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/meta/name T-Sensor 01-02
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Internal Temperature 24.5
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Internal Temperature/meta/type temperature
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Internal Temperature/meta/order 1
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 1 24.75
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 1/meta/type temperature
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 1/meta/order 2
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 2 24.625
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 2/meta/type temperature
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 2/meta/order 3
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.852
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage/meta/type voltage
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage/meta/readonly 1
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage/meta/order 4
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Serial NO 4276306540
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Serial NO/meta/type text
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Serial NO/meta/order 5
/client/wb_AV6U5XZP/devices/wbrules/controls/Rule debugging 0
/client/wb_AV6U5XZP/devices/wbrules/controls/Rule debugging/meta/type switch
/client/wb_AV6U5XZP/devices/wbrules/controls/Rule debugging/meta/order 1
/client/wb_AV6U5XZP/devices/wbrules/meta/name Rule Engine Settings
/client/wb_AV6U5XZP/devices/alarms/meta/name Alarms
/client/wb_AV6U5XZP/devices/alarms/controls/log/meta/type text
/client/wb_AV6U5XZP/devices/alarms/controls/log/meta/readonly 1
/client/wb_AV6U5XZP/devices/alarms/controls/log/meta/order 1
/client/wb_AV6U5XZP/config/rooms/room1/uid room1
/client/wb_AV6U5XZP/config/rooms/room1/name Гостиная
/client/wb_AV6U5XZP/config/dashboards/dashboard1/name Квартира
/client/wb_AV6U5XZP/config/dashboards/dashboard1/uid dashboard1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/name External Sensor 1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/value 25.3125
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/topic /devices/T-Sensor 01-02/controls/External Sensor 1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/$$hashKey object:230
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaType temperature
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaOrder 2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/uid widget1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/name Exterrnal sensor 1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/room room1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/template temperature
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget0/canEdit false
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/name External Sensor 2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/value 25.375
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/topic /devices/T-Sensor 01-02/controls/External Sensor 2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/$$hashKey object:235
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/metaType temperature
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/metaOrder 3
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/uid widget2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/name Exterrnal sensor 2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/room room1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/template temperature
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget1/canEdit false
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/name 28-041621a1f3ff
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/value 23.562
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/topic /devices/wb-w1/controls/28-041621a1f3ff
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/$$hashKey object:10
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/uid widget3
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/name ds18b20 T1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/room room1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget2/template sensor
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/name 28-041621bd3cff
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/value 23.437
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/topic /devices/wb-w1/controls/28-041621bd3cff
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/$$hashKey object:13
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/uid widget4
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/name ds18b20 T2
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/room room1
/client/wb_AV6U5XZP/config/dashboards/dashboard1/widgets/widget3/template sensor
/client/wb_AV6U5XZP/config/widgets/widget1/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/widgets/widget1/controls/slot0/topic /devices/T-Sensor 01-02/controls/External Sensor 1
/client/wb_AV6U5XZP/config/widgets/widget1/name Exterrnal sensor 1
/client/wb_AV6U5XZP/config/widgets/widget1/room room1
/client/wb_AV6U5XZP/config/widgets/widget1/template temperature
/client/wb_AV6U5XZP/config/widgets/widget1/uid widget1
/client/wb_AV6U5XZP/config/widgets/widget2/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/widgets/widget2/controls/slot0/topic /devices/T-Sensor 01-02/controls/External Sensor 2
/client/wb_AV6U5XZP/config/widgets/widget2/name Exterrnal sensor 2
/client/wb_AV6U5XZP/config/widgets/widget2/room room1
/client/wb_AV6U5XZP/config/widgets/widget2/template temperature
/client/wb_AV6U5XZP/config/widgets/widget2/uid widget2
/client/wb_AV6U5XZP/config/widgets/widget3/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/widgets/widget3/controls/slot0/topic /devices/wb-w1/controls/28-041621a1f3ff
/client/wb_AV6U5XZP/config/widgets/widget3/name ds18b20 T1
/client/wb_AV6U5XZP/config/widgets/widget3/room room1
/client/wb_AV6U5XZP/config/widgets/widget3/template sensor
/client/wb_AV6U5XZP/config/widgets/widget3/uid widget3
/client/wb_AV6U5XZP/config/widgets/widget4/controls/slot0/uid slot0
/client/wb_AV6U5XZP/config/widgets/widget4/controls/slot0/topic /devices/wb-w1/controls/28-041621bd3cff
/client/wb_AV6U5XZP/config/widgets/widget4/name ds18b20 T2
/client/wb_AV6U5XZP/config/widgets/widget4/room room1
/client/wb_AV6U5XZP/config/widgets/widget4/template sensor
/client/wb_AV6U5XZP/config/widgets/widget4/uid widget4
/client/wb_AV6U5XZP/config/default_dashboard/uid dashboard1
/client/wb_AV6U5XZP/rpc/v1/db_logger/history/get_channels 1
/client/wb_AV6U5XZP/rpc/v1/db_logger/history/get_values 1
/client/wb_AV6U5XZP/rpc/v1/wbrules/Editor/List 1
/client/wb_AV6U5XZP/rpc/v1/wbrules/Editor/Load 1
/client/wb_AV6U5XZP/rpc/v1/wbrules/Editor/Remove 1
/client/wb_AV6U5XZP/rpc/v1/wbrules/Editor/Save 1
/client/wb_AV6U5XZP/rpc/v1/confed/Editor/List 1
/client/wb_AV6U5XZP/rpc/v1/confed/Editor/Load 1
/client/wb_AV6U5XZP/rpc/v1/confed/Editor/Save 1
/client/wb_AV6U5XZP/rpc/v1/confed/Editor/Load/contactless-PQpt3PE6T8/reply {"id":5,"result":{"configPath":"/etc/wb-mqtt-setpoints.conf","content":{"highHysteresis":0.5,"lowHysteresis":0.5,"rooms":[{"roomName":"Приемка 1","setPointDay":26,"setPointNight":15},{"roomName":"Приемка 2","setPointDay":26,"setPointNight":16},{"roomName":"Санузел","setPointDay":26,"setPointNight":15}],"startDay":"08:00","startNight":"20:00"},"schema":{"$schema":"http://json-schema.org/draft-04/schema#","configFile":{"path":"/etc/wb-mqtt-setpoints.conf","service":"wb-rules"},"definitions":{"room":{"format":"grid","headerTemplate":"{{i1}} : \"{{self.roomName}}\"","properties":{"roomName":{"default":"Помещение","description":"Наименование помещения","title":"Наименование","type":"string"},"setPointDay":{"default":25,"description":"Уставка температуры в помещении днём","title":"Температура дневная","type":"number"},"setPointNight":{"default":18,"description":"Уставка температуры в помещении ночью","title":"Температура ночная","type":"number"}},"required":["roomName","setPointDay","setPointNight"],"type":"object"}},"description":"Настройки для установки температуры в помещениях","format":"grid","properties":{"highHysteresis":{"description":"Верхний предел","maximum":2,"minimum":0.1,"propertyOrder":2,"title":"Гистерезис","type":"number"},"lowHysteresis":{"description":"Нижний предел","maximum":2,"minimum":0.1,"propertyOrder":1,"title":"Гистерезис","type":"number"},"rooms":{"items":{"$ref":"#/definitions/room"},"propertyOrder":3,"title":"ПОМЕЩЕНИЯ","type":"array"},"startDay":{"default":"08:00","description":"В формате 00:00","pattern":"^[0-9][0-9]:[0-9][0-9]$","propertyOrder":4,"title":"Начало рабочего дня","type":"string"},"startNight":{"default":"21:00","description":"В формате 00:00","pattern":"^[0-9][0-9]:[0-9][0-9]$","propertyOrder":5,"title":"Конец рабочего дня","type":"string"}},"title":"Установки температуры","type":"object"}}}
/client/wb_AV6U5XZP/devices/power_status/controls/Vin 11.83
/client/wb_AV6U5XZP/devices/power_status/controls/Vin 11.84
/client/wb_AV6U5XZP/devices/wb-adc/controls/A3 3.15
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.737
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 2 24.9375
/client/wb_AV6U5XZP/devices/wb-adc/controls/A4 0.01
/client/wb_AV6U5XZP/devices/wb-adc/controls/Vin 11.72
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.738
/client/wb_AV6U5XZP/devices/wb-adc/controls/5Vout 4.89
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.736
/client/wb_AV6U5XZP/devices/wb-adc/controls/A2 3.17
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.733
/client/wb_AV6U5XZP/devices/wb-adc/controls/Vin 11.71
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.739
/client/wb_AV6U5XZP/devices/wb-adc/controls/A3 3.16
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.74
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.742
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/External Sensor 2 24.875
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.743
/client/wb_AV6U5XZP/devices/wb-adc/controls/A3 3.14
/client/wb_AV6U5XZP/devices/T-Sensor 01-02/controls/Input Voltage 11.741
На получение ответа ушло примерно 2-3 минуты.
Затем на странице Settings ввел UserId и Password как в bridge.conf и все заработало!
