root@wirenboard-ABM5SQMJ:~# cd /var/lib
root@wirenboard-ABM5SQMJ:/var/lib# sudo rm -rf iRidium\ Server/
-bash: sudo: command not found
root@wirenboard-ABM5SQMJ:/var/lib# ^C
root@wirenboard-ABM5SQMJ:/var/lib# rm -rf iRidium\ Server/
root@wirenboard-ABM5SQMJ:/var/lib# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 980M 963M 0 100% /
devtmpfs 241M 0 241M 0% /dev
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 3.7M 246M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/mmcblk0p6 1.3G 227M 934M 20% /mnt/data
tmpfs 50M 0 50M 0% /run/user/0
и так и сяк уже)
reboot
надо сделать еще
Ну и
du -h -d 1 /var
root@wirenboard-ABM5SQMJ:~# du -h -d 1 /var
16M /var/lib
4.0K /var/opt
32K /var/tmp
2.1M /var/cache
16K /var/spool
14M /var/www
16M /var/log
4.0K /var/mail
120K /var/backups
4.0K /var/local
48M /var
root@wirenboard-ABM5SQMJ:~# df -h
/dev/root 980M 580M 334M 64% /
вроде бы получилось
дальше он сам запуститься или еще что то нужно сделать? драйвер на v out
Если ошибок нет - то да, сам.
root@wirenboard-ABM5SQMJ:~# service wb-homa-gpio status
● wb-homa-gpio.service - LSB: MQTT Driver for GPIO-controlled switches
Loaded: loaded (/etc/init.d/wb-homa-gpio; generated; vendor preset: enabled)
Active: active (exited) since Thu 2020-06-04 07:08:05 UTC; 2h 39min ago
Docs: man:systemd-sysv-generator(8)
Process: 690 ExecStart=/etc/init.d/wb-homa-gpio start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/wb-homa-gpio.service
Jun 04 07:07:36 wirenboard-ABM5SQMJ systemd[1]: Starting LSB: MQTT Driver for GPIO-controlled switches…
Jun 04 07:07:41 wirenboard-ABM5SQMJ wb-homa-gpio[690]: Starting MQTT Driver for GPIO-controlled switches: wb-homa-gpiodeclare -A OF_GPIOCHIPS=([7]=“96” [52]=“32” [47]=
Jun 04 07:08:05 wirenboard-ABM5SQMJ wb-homa-gpio[690]: .
Jun 04 07:08:05 wirenboard-ABM5SQMJ systemd[1]: Started LSB: MQTT Driver for GPIO-controlled switches.
apt purge wb-hwconf-manager -y
apt install wb-hwconf-manager wb-test-suite -y
Должно перегенерировать файлы конфигов.
С потерей текущих настроек железа.
root@wirenboard-ABM5SQMJ:~# apt purge wb-hwconf-manager -y
Reading package lists… Done
Building dependency tree
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
wb-test-suite : Depends: wb-hwconf-manager (>= 1.25) but it is not going to be installed
z-way-server : Depends: libarchive13 (>= 3.0) but it is not going to be installed
Depends: sharutils but it is not going to be installed
Depends: gawk but it is not going to be installed
Depends: libavahi-compat-libdnssd-dev but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
root@wirenboard-ABM5SQMJ:~# apt install wb-hwconf-manager wb-test-suite -y
wb-test-suite is already the newest version (1.15.1).
так ни чего и не помогает вернуть в работу v out
Как и советутет apt надо сделать
И да, z-way-server это оно?
Если не используется - снести его. Он, судя по отсутствию зависимостей и недоустановлен.
root@wirenboard-ABM5SQMJ:~# apt --fix-broken install
Correcting dependencies… Done
The following additional packages will be installed:
dbus gawk libarchive13 libavahi-client-dev libavahi-client3 libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-3 libdbus-1-dev
libdpkg-perl libfile-fcntllock-perl liblocale-gettext-perl liblzo2-2 libmpfr4 libsigsegv2 pkg-config sharutils
Suggested packages:
default-dbus-session-bus | dbus-session-bus gawk-doc lrzip debian-keyring binutils patch sharutils-doc
The following NEW packages will be installed:
gawk libarchive13 libavahi-client-dev libavahi-client3 libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev libdpkg-perl
dbus libdbus-1-3
2 upgraded, 16 newly installed, 0 to remove and 15 not upgraded.
1 not fully installed or removed.
Need to get 3927 kB of archives.
After this operation, 8632 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirror.yandex.ru/debian stretch/main armhf liblzo2-2 armhf 2.08-1.2+b2 [49.7 kB]
Get:2 http://security.debian.org stretch/updates/main armhf libdbus-1-3 armhf 1.10.28-0+deb9u1 [176 kB]
Ign:3 http://mirror.yandex.ru/debian stretch/main armhf libarchive13 armhf 3.2.2-2+deb9u1
Get:4 http://mirror.yandex.ru/debian stretch/main armhf sharutils armhf 1:4.15.2-2+deb9u1 [248 kB]
Get:5 http://mirror.yandex.ru/debian stretch/main armhf libmpfr4 armhf 3.1.5-1 [536 kB]
Get:6 http://security.debian.org stretch/updates/main armhf dbus armhf 1.10.28-0+deb9u1 [198 kB]
Get:7 http://mirror.yandex.ru/debian stretch/main armhf libsigsegv2 armhf 2.10-5 [28.3 kB]
Get:8 http://mirror.yandex.ru/debian stretch/main armhf gawk armhf 1:4.1.4+dfsg-1 [537 kB]
Get:9 http://security.debian.org stretch/updates/main armhf libdbus-1-dev armhf 1.10.28-0+deb9u1 [214 kB]
Err:3 http://security.debian.org stretch/updates/main armhf libarchive13 armhf 3.2.2-2+deb9u1
404 Not Found [IP: 213.180.204.183 80]
Get:10 http://mirror.yandex.ru/debian stretch/main armhf libavahi-client3 armhf 0.6.32-2 [51.9 kB]
Get:11 http://mirror.yandex.ru/debian stretch/main armhf libavahi-compat-libdnssd1 armhf 0.6.32-2 [44.0 kB]
Get:12 http://mirror.yandex.ru/debian stretch/main armhf libavahi-common-dev armhf 0.6.32-2 [64.0 kB]
Get:13 http://mirror.yandex.ru/debian stretch/main armhf libdpkg-perl all 1.18.25 [1287 kB]
Get:14 http://mirror.yandex.ru/debian stretch/main armhf pkg-config armhf 0.29-4+b1 [60.6 kB]
Get:15 http://mirror.yandex.ru/debian stretch/main armhf libavahi-client-dev armhf 0.6.32-2 [58.7 kB]
Get:16 http://mirror.yandex.ru/debian stretch/main armhf libavahi-compat-libdnssd-dev armhf 0.6.32-2 [59.9 kB]
Get:17 http://mirror.yandex.ru/debian stretch/main armhf liblocale-gettext-perl armhf 1.07-3+b1 [18.4 kB]
Get:18 http://mirror.yandex.ru/debian stretch/main armhf libfile-fcntllock-perl armhf 0.22-3+b2 [35.1 kB]
Fetched 3667 kB in 1s (2758 kB/s)
E: Failed to fetch http://security.debian.org/pool/updates/main/liba/libarchive/libarchive13_3.2.2-2+deb9u1_armhf.deb 404 Not Found [IP: 213.180.204.183 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
z-way я так понял на юсб флешке, сейчас она не подключена, ну и датчики для него не подключены, так как их у нас нет
Выполняем
apt update
потом
так вот теперь все по порядку
root@wirenboard-ABM5SQMJ:~# apt update
Ign:1 http://mirror.yandex.ru/debian stretch InRelease
Get:2 http://security.debian.org stretch/updates InRelease [94.3 kB]
Get:3 http://mirror.yandex.ru/debian stretch-updates InRelease [93.6 kB]
Get:5 http://releases.contactless.ru/stable/stretch stretch InRelease [13.6 kB]
Get:6 http://mirror.yandex.ru/debian stretch Release [118 kB]
Get:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease [91.8 kB]
Get:7 http://mirror.yandex.ru/debian stretch Release.gpg [2410 B]
Get:8 http://releases.contactless.ru/stable/stretch stretch/main all Packages [40.8 kB]
Get:9 http://releases.contactless.ru/stable/stretch stretch/main armhf Packages [95.8 kB]
Get:10 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages.diff/Index [14.5 kB]
Get:11 http://mirror.yandex.ru/debian stretch-updates/main Translation-en.diff/Index [7624 B]
Get:12 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2019-08-14-2019.27.pdiff [339 B]
Get:13 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2019-09-18-2012.01.pdiff [337 B]
Get:14 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2019-10-27-2015.53.pdiff [398 B]
Get:15 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2019-11-06-2017.59.pdiff [903 B]
Get:16 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2020-02-23-2017.41.pdiff [1530 B]
Get:17 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2020-06-04-2016.16.pdiff [1378 B]
Get:18 http://mirror.yandex.ru/debian stretch-updates/main armhf Packages 2020-06-07-1403.53.pdiff [466 B]
Get:19 http://mirror.yandex.ru/debian stretch-updates/main Translation-en 2019-11-06-2017.59.pdiff [790 B]
Get:20 http://mirror.yandex.ru/debian stretch-updates/main Translation-en 2020-02-23-2017.41.pdiff [47 B]
Get:21 http://mirror.yandex.ru/debian stretch-updates/main Translation-en 2020-06-07-1403.53.pdiff [368 B]
Get:22 http://security.debian.org stretch/updates/main armhf Packages [505 kB]
Get:23 http://security.debian.org stretch/updates/main Translation-en [234 kB]
Get:24 http://mirror.yandex.ru/debian stretch/main armhf Packages [6912 kB]
Get:25 http://cdn-fastly.deb.debian.org/debian stretch-backports/main armhf Packages.diff/Index [27.8 kB]
Get:26 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en.diff/Index [27.8 kB]
Get:27 http://cdn-fastly.deb.debian.org/debian stretch-backports/main armhf Packages [600 kB]
Get:28 http://mirror.yandex.ru/debian stretch/main Translation-en [5381 kB]
Get:29 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-13-0226.01.pdiff [1666 B]
Get:30 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-14-0819.39.pdiff [49 B]
Get:31 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-16-1419.01.pdiff [31 B]
Get:32 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-16-2020.50.pdiff [246 B]
Get:33 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-21-2022.31.pdiff [123 B]
Get:34 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-22-0819.19.pdiff [3177 B]
Get:35 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-22-1415.40.pdiff [921 B]
Get:36 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-23-1430.55.pdiff [1653 B]
Get:37 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-25-0819.10.pdiff [570 B]
Get:38 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-26-0220.54.pdiff [246 B]
Get:39 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-08-28-1426.17.pdiff [383 B]
Get:40 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-05-0816.52.pdiff [1127 B]
Get:41 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-13-0830.13.pdiff [465 B]
Get:42 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-16-1418.37.pdiff [499 B]
Get:43 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-20-0823.35.pdiff [3109 B]
Get:44 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-22-2014.03.pdiff [571 B]
Get:45 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-25-2025.12.pdiff [245 B]
Get:46 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-26-1413.34.pdiff [820 B]
Get:47 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-09-27-0212.46.pdiff [524 B]
Get:48 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-10-01-2011.33.pdiff [813 B]
Get:49 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-10-14-0814.16.pdiff [136 B]
Get:50 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-10-14-1416.13.pdiff [289 B]
Get:51 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-11-18-1415.12.pdiff [324 B]
Get:52 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-11-20-2014.11.pdiff [143 B]
Get:53 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-11-21-0215.37.pdiff [44 B]
Get:54 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2019-12-01-2015.11.pdiff [86 B]
Get:55 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-01-18-2019.06.pdiff [228 B]
Get:56 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-02-03-1411.12.pdiff [136 B]
Get:57 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-02-18-2020.30.pdiff [150 B]
Get:58 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-03-09-1419.12.pdiff [611 B]
Get:59 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-03-16-1416.47.pdiff [313 B]
Get:60 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-03-20-2036.50.pdiff [4658 B]
Get:61 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-03-26-1417.37.pdiff [821 B]
Get:62 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-05-19-0807.39.pdiff [269 B]
Get:63 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-05-27-1404.35.pdiff [383 B]
Get:64 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en 2020-06-04-1406.28.pdiff [3797 B]
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
E: Could not open file /var/lib/apt/lists/http.debian.net_debian_dists_stretch-backports_main_binary-armhf_Packages.diff_Index - open (2: No such file or directory)
Suggested packages:
dbus libdbus-1-3
2 upgraded, 16 newly installed, 0 to remove and 81 not upgraded.
Need to get 261 kB/3928 kB of archives.
Get:1 http://mirror.yandex.ru/debian stretch/main armhf libarchive13 armhf 3.2.2-2+deb9u2 [261 kB]
Fetched 261 kB in 0s (445 kB/s)
Selecting previously unselected package liblzo2-2:armhf.
(Reading database … 33325 files and directories currently installed.)
Preparing to unpack …/liblzo2-2_2.08-1.2+b2_armhf.deb …
Unpacking liblzo2-2:armhf (2.08-1.2+b2) …
Selecting previously unselected package libarchive13:armhf.
Preparing to unpack …/libarchive13_3.2.2-2+deb9u2_armhf.deb …
Unpacking libarchive13:armhf (3.2.2-2+deb9u2) …
Selecting previously unselected package sharutils.
Preparing to unpack …/sharutils_1%3a4.15.2-2+deb9u1_armhf.deb …
Unpacking sharutils (1:4.15.2-2+deb9u1) …
Selecting previously unselected package libmpfr4:armhf.
Preparing to unpack …/libmpfr4_3.1.5-1_armhf.deb …
Unpacking libmpfr4:armhf (3.1.5-1) …
Selecting previously unselected package libsigsegv2:armhf.
Preparing to unpack …/libsigsegv2_2.10-5_armhf.deb …
Unpacking libsigsegv2:armhf (2.10-5) …
Setting up libmpfr4:armhf (3.1.5-1) …
Setting up libsigsegv2:armhf (2.10-5) …
Selecting previously unselected package gawk.
(Reading database … 33408 files and directories currently installed.)
Preparing to unpack …/00-gawk_1%3a4.1.4+dfsg-1_armhf.deb …
Unpacking gawk (1:4.1.4+dfsg-1) …
Preparing to unpack …/01-libdbus-1-3_1.10.28-0+deb9u1_armhf.deb …
Unpacking libdbus-1-3:armhf (1.10.28-0+deb9u1) over (1.10.26-0+deb9u1) …
Preparing to unpack …/02-dbus_1.10.28-0+deb9u1_armhf.deb …
Unpacking dbus (1.10.28-0+deb9u1) over (1.10.26-0+deb9u1) …
Selecting previously unselected package libavahi-client3:armhf.
Preparing to unpack …/03-libavahi-client3_0.6.32-2_armhf.deb …
Unpacking libavahi-client3:armhf (0.6.32-2) …
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
Preparing to unpack …/04-libavahi-compat-libdnssd1_0.6.32-2_armhf.deb …
Unpacking libavahi-compat-libdnssd1:armhf (0.6.32-2) …
Selecting previously unselected package libavahi-common-dev:armhf.
Preparing to unpack …/05-libavahi-common-dev_0.6.32-2_armhf.deb …
Unpacking libavahi-common-dev:armhf (0.6.32-2) …
Selecting previously unselected package libdpkg-perl.
Preparing to unpack …/06-libdpkg-perl_1.18.25_all.deb …
Unpacking libdpkg-perl (1.18.25) …
Selecting previously unselected package pkg-config.
Preparing to unpack …/07-pkg-config_0.29-4+b1_armhf.deb …
Unpacking pkg-config (0.29-4+b1) …
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack …/08-libdbus-1-dev_1.10.28-0+deb9u1_armhf.deb …
Unpacking libdbus-1-dev:armhf (1.10.28-0+deb9u1) …
Selecting previously unselected package libavahi-client-dev:armhf.
Preparing to unpack …/09-libavahi-client-dev_0.6.32-2_armhf.deb …
Unpacking libavahi-client-dev:armhf (0.6.32-2) …
Selecting previously unselected package libavahi-compat-libdnssd-dev:armhf.
Preparing to unpack …/10-libavahi-compat-libdnssd-dev_0.6.32-2_armhf.deb …
Unpacking libavahi-compat-libdnssd-dev:armhf (0.6.32-2) …
Selecting previously unselected package liblocale-gettext-perl.
Preparing to unpack …/11-liblocale-gettext-perl_1.07-3+b1_armhf.deb …
Unpacking liblocale-gettext-perl (1.07-3+b1) …
Selecting previously unselected package libfile-fcntllock-perl.
Preparing to unpack …/12-libfile-fcntllock-perl_0.22-3+b2_armhf.deb …
Unpacking libfile-fcntllock-perl (0.22-3+b2) …
Setting up libavahi-common-dev:armhf (0.6.32-2) …
Setting up sharutils (1:4.15.2-2+deb9u1) …
Setting up libdpkg-perl (1.18.25) …
Setting up gawk (1:4.1.4+dfsg-1) …
Setting up libfile-fcntllock-perl (0.22-3+b2) …
Setting up pkg-config (0.29-4+b1) …
Processing triggers for libc-bin (2.24-11+deb9u4) …
Processing triggers for systemd (232-25+deb9u11) …
Setting up liblocale-gettext-perl (1.07-3+b1) …
Setting up libdbus-1-3:armhf (1.10.28-0+deb9u1) …
Setting up liblzo2-2:armhf (2.08-1.2+b2) …
Setting up libdbus-1-dev:armhf (1.10.28-0+deb9u1) …
Setting up libarchive13:armhf (3.2.2-2+deb9u2) …
Setting up libavahi-client3:armhf (0.6.32-2) …
Setting up dbus (1.10.28-0+deb9u1) …
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up libavahi-client-dev:armhf (0.6.32-2) …
Setting up libavahi-compat-libdnssd1:armhf (0.6.32-2) …
Setting up libavahi-compat-libdnssd-dev:armhf (0.6.32-2) …
Setting up z-way-server (2.3.8) …
Configuration file ‘/etc/init.d/z-way-server’
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** z-way-server (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/init.d/z-way-server …
Configuration file ‘/opt/z-way-server/config/Defaults.xml’
*** Defaults.xml (Y/I/N/O/D/Z) [default=N] ? n
sed: can’t read /boot/cmdline.txt: No such file or directory
Usage: ./z-cfg-update
Starting z-way-server: done.
The following packages were automatically installed and are no longer required:
python-cffi-backend python-chardet python-crypto python-cryptography python-enum34 python-gsmmodem-new python-gspread python-httplib2 python-idna python-ipaddress
python-oauth2client python-openssl python-pkg-resources python-pyasn1 python-pyasn1-modules python-requests python-rsa python-setuptools python-uritemplate
python-urllib3
Use ‘apt autoremove’ to remove them.
The following packages will be REMOVED:
wb-hwconf-manager* wb-test-suite*
0 upgraded, 0 newly installed, 2 to remove and 79 not upgraded.
After this operation, 435 kB disk space will be freed.
(Reading database … 33866 files and directories currently installed.)
Removing wb-test-suite (1.15.1) …
Removing wb-hwconf-manager (1.27.0) …
(Reading database … 33674 files and directories currently installed.)
Purging configuration files for wb-hwconf-manager (1.27.0) …
root@wirenboard-ABM5SQMJ:~# apt install wb-whconf-manager wb-test-suite -y
E: Unable to locate package wb-whconf-manager
wb-hwconf-manager
ошибка в букве.
Полностью:
Выбираем первый (верхний) вариант.
Нам нужно заменить конфиги.
сделано. теперь во вкладке Hardware Modules Configuration не ругаеться на конфиг.
но питание так и не дает
Надо б перезапустить контроллер.
так и сделал
Так. А выход 5V_OUT - работает? То есть включается-выключается через вебинтерфейс?
И сейчас
что возвращает?
Потому как может что не доисправляли.
