proff
08.Июнь.2020 09:40:06
61
5V_vout работат, в интерфейсе меняеться он на офф но это не влият на него, он всгда 5V выдает.
root@wirenboard-ABM5SQMJ:~# service wb-homa-gpio status
● wb-homa-gpio.service - LSB: MQTT Driver for GPIO-controlled switches
Loaded: loaded (/etc/init.d/wb-homa-gpio; generated; vendor preset: enabled)
Active: active (exited) since Mon 2020-06-08 08:29:48 UTC; 1h 12min ago
Docs: man:systemd-sysv-generator(8)
Process: 1639 ExecStart=/etc/init.d/wb-homa-gpio start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/wb-homa-gpio.service
Jun 08 08:29:18 wirenboard-ABM5SQMJ systemd[1]: Starting LSB: MQTT Driver for GPIO-controlled switches…
Jun 08 08:29:23 wirenboard-ABM5SQMJ wb-homa-gpio[1639]: Starting MQTT Driver for GPIO-controlled switches: wb-homa-gpiodeclare -A OF_GPIOCHIPS=([7]=“96” [52]=“32” [47]=“0” [41]=“64” [32]=“128” )
Jun 08 08:29:48 wirenboard-ABM5SQMJ wb-homa-gpio[1639]: .
Jun 08 08:29:48 wirenboard-ABM5SQMJ systemd[1]: Started LSB: MQTT Driver for GPIO-controlled switches.
А должен работать. Первый сервис что мы переустановили - гененрирует файлы конфигов. А этот - управляет выводами.
Пробуем
apt purge wb-homa-gpio -y
apt install wb-homa-gpio -y
потом перезагружаемся и
Должно быть
Active: active (running)
proff
08.Июнь.2020 11:14:43
64
Active: active (running) since Mon 2020-06-08 11:07:36 UTC; 6min ago
Process: 1331 ExecStart=/etc/init.d/wb-homa-gpio start (code=exited, status=0/SUCCESS)
└─3976 /usr/bin/wb-homa-gpio -c /tmp/wb-homa-gpio.do-not-edit.conf
Jun 08 11:07:05 wirenboard-ABM5SQMJ systemd[1]: Starting LSB: MQTT Driver for GPIO-controlled switches…
Jun 08 11:07:11 wirenboard-ABM5SQMJ wb-homa-gpio[1331]: Starting MQTT Driver for GPIO-controlled switches: wb-homa-gpiodeclare -A OF_GPIOCHIPS=([7]=“96” [52]=“32” [47]=“0” [41]=“64” [32]=“128” )
Jun 08 11:07:36 wirenboard-ABM5SQMJ wb-homa-gpio[1331]: .
Jun 08 11:07:36 wirenboard-ABM5SQMJ systemd[1]: Started LSB: MQTT Driver for GPIO-controlled switches.
proff:
running
Отлично. А сейчас выход управляется?
proff
08.Июнь.2020 11:20:22
66
да, заработало! отключается и включается, и на обычном V_out появилось 24 V! Большое спасибо за помощь! Неужели все это случилось из-за нехватки памяти?
В общем - да, но там целый ворох. И недоустановленные пакеты и нехватка места. Но корень - именно отсутствие свободного места. Сервис пытается записать (изменить) файл - и падает в ошибку.
Флешка USB стОит копейки, а места на ней гигабайты. Всем советую все дополнительное ставить снаружи.
Ну и рад помочь.
Пишу в эту тему, закончилось место на диске. Что знал что можно удалить - удалил, но места не хватает
root@wirenboard-AFMIIQX7:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 980M 957M 0 100% /
devtmpfs 241M 0 241M 0% /dev
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 544K 249M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/mmcblk0p6 4.7G 476M 4.0G 11% /mnt/data
tmpfs 50M 0 50M 0% /run/user/0
Начинаю смотреть что занимает место и возникают вопросы:
Можно ли удалить журналы из папки var/log/journal ?
root@wirenboard-AFMIIQX7:~# du -h -d 1 /var/log
193M /var/log/journal
236K /var/log/nginx
4.0K /var/log/watchdog
432K /var/log/mosquitto
120K /var/log/apt
194M /var/log
Можно ли удалить какие нибудь пакеты из /usr/lib. Если да, то какие и как правильно?
Например /usr/lib/haskell-packages - пакет не на слуху, может лишнее что-то
root@wirenboard-AFMIIQXdu -h -d 1 /usr/lib/
40K /usr/lib/tcc
12K /usr/lib/pm-utils
260K /usr/lib/wb-homa-ism-radio
124K /usr/lib/tc
52K /usr/lib/wb-utils
244K /usr/lib/gnupg1
57M /usr/lib/llvm-3.7
28M /usr/lib/node_modules
8.0K /usr/lib/sysusers.d
744K /usr/lib/openssh
251M /usr/lib/haskell-packages
8.0K /usr/lib/python2.6
404K /usr/lib/mc
236K /usr/lib/systemd
126M /usr/lib/arm-linux-gnueabihf
36K /usr/lib/dbus-1.0
29M /usr/lib/gcc
4.0K /usr/lib/binfmt.d
8.0K /usr/lib/wb-mqtt-adc
8.0K /usr/lib/wb-knxd-config
20K /usr/lib/kernel
24K /usr/lib/valgrind
544K /usr/lib/apt
12K /usr/lib/avahi
4.0K /usr/lib/compat-ld
12K /usr/lib/wb-prepare
12K /usr/lib/resolvconf
8.0K /usr/lib/wb-mqtt-gpio
48K /usr/lib/binfmt-support
24M /usr/lib/python3.5
4.0K /usr/lib/sasl2
1.1M /usr/lib/python3
372K /usr/lib/sudo
36K /usr/lib/dpkg
156K /usr/lib/pppd
28K /usr/lib/knxd
12K /usr/lib/wb-mqtt-homeui
4.0K /usr/lib/modules-load.d
4.0K /usr/lib/gold-ld
52K /usr/lib/tmpfiles.d
4.5M /usr/lib/locale
24K /usr/lib/ssl
640K /usr/lib/bluetooth
27M /usr/lib/python2.7
4.0K /usr/lib/tar
4.7M /usr/lib/file
44K /usr/lib/mime
276K /usr/lib/wb-test-suite
300K /usr/lib/ldscripts
554M /usr/lib/
Нормален ли размер zigbee2mqtt ? К слову он не работает, но об этом в других ветках
root@wirenboard-AFMIIQX7:~# du -h -d 1 /mnt/data/root/
44K /mnt/data/root/.npm
24K /mnt/data/root/.local
1.4M /mnt/data/root/wb-mqtt-serial
16K /mnt/data/root/.cache
174M /mnt/data/root/zigbee2mqtt
24K /mnt/data/root/.config
4.0K /mnt/data/root/.nano
175M /mnt/data/root/
Прошу помощи!
Можно, но в /var же монтируется /dev/mmcblk0p6
Да, вполне. И лежит не в корне, /root это симлинк на /mnt/data/root
Советую смонтировать корень например в /mnt/test1
и посмотрите, чем занято.
Прошу прощения можно ли дать прямую команду и что нужно далее сделать для анализа. Мои знания в debian посредственны
mkdir /mnt/disk_tmp
mount /dev/mmcblk0p3 /mnt/disk_tmp/
тут надо монтировать именно тот же раздел что смонтирован в корень, его видно по “mount”
и можно смотреть что занято, например
du -h -d 1 /mnt/disk_tmp/
Благодарю, если повториться произведу что вы порекомендовали.
Т.к. с контроллером возникли вопросы не только связанные с местом на диске, произвел полную переустановку системы после чего место появилось.
