WB 6.8.1 не подключается к GSM
Batch No
6.8.1B/3 517
Current uptime
0d 0h 6m
DTS Version
680
HW Revision
6.8.1
Manufacturing Date
2021-09-01 14:06:57+00:00
Release name
wb-2304
Release suite
stable
Short SN
AMJ3BTOQ
перестал работать интернет через GSM.
настроено через веб, стоит галочка Подключаться автоматически. Симку проверял на телефоне, антенна подключена, светодиод на модеме мигает, порты модема видно.
Подключения нет ((
Добрый день. А покажите логи?
root@wirenboard-AMJ3BTOQ:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.35-wb133+wb101 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Mon May 29 08:54:40 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Wiren Board rev. 6.8.0 (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] On node 0 totalpages: 131072
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 489360K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18544K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000061] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002764] Console: colour dummy device 80x30
[    0.002826] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002864] pid_max: default: 32768 minimum: 301
[    0.003255] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003290] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.004990] CPU: Testing write buffer coherency: ok
[    0.006196] Setting up static identity map for 0x80100000 - 0x80100078
[    0.007076] devtmpfs: initialized
[    0.024901] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.025413] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.025461] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.026829] pinctrl core: initialized pinctrl subsystem
[    0.028823] NET: Registered protocol family 16
[    0.031045] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.032986] thermal_sys: Registered thermal governor 'step_wise'
[    0.033310] cpuidle: using governor menu
[    0.216948] vdd1p1: supplied by regulator-dummy
[    0.228696] vdd3p0: supplied by regulator-dummy
[    0.240471] cpu: supplied by regulator-dummy
[    0.252256] vddsoc: supplied by regulator-dummy
[    0.590088] No ATAGs?
[    0.590147] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.590168] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.590753] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[    0.591417] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[    0.592940] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[    0.593054] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.635479] mxs-dma 1804000.dma-apbh: initialized
[    0.640672] SCSI subsystem initialized
[    0.641166] usbcore: registered new interface driver usbfs
[    0.641282] usbcore: registered new interface driver hub
[    0.641393] usbcore: registered new device driver usb
[    0.642212] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.642338] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.643821] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[    0.644700] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.644827] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.645411] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[    0.646099] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.646218] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.646801] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[    0.648372] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.648731] i2c i2c-1: IMX I2C adapter registered
[    0.649456] mc: Linux media interface: v0.10
[    0.649567] videodev: Linux video capture interface: v2.00
[    0.649694] pps_core: LinuxPPS API ver. 1 registered
[    0.649714] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.649766] PTP clock support registered
[    0.650374] Advanced Linux Sound Architecture Driver Initialized.
[    0.652461] clocksource: Switched to clocksource mxc_timer1
[    0.670090] NET: Registered protocol family 2
[    0.671374] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.671471] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.671575] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.671677] TCP: Hash tables configured (established 4096 bind 4096)
[    0.671869] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.671924] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.672243] NET: Registered protocol family 1
[    0.673288] RPC: Registered named UNIX socket transport module.
[    0.673327] RPC: Registered udp transport module.
[    0.673345] RPC: Registered tcp transport module.
[    0.673361] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.674427] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.677241] Initialise system trusted keyrings
[    0.677704] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.689263] NFS: Registering the id_resolver key type
[    0.689342] Key type id_resolver registered
[    0.689360] Key type id_legacy registered
[    0.925863] Key type asymmetric registered
[    0.925902] Asymmetric key parser 'x509' registered
[    0.926026] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.926048] io scheduler mq-deadline registered
[    0.926067] io scheduler kyber registered
[    0.937930] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.937978] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.941854] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[    1.605399] printk: console [ttymxc0] enabled
[    1.611772] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.655641] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[    1.663065] random: fast init done
[    1.667015] random: crng init done
[    1.706938] brd: module loaded
[    1.725097] loop: module loaded
[    1.728588] at24 5-0050: supply vcc not found, using dummy regulator
[    1.740026] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.747064] at24 6-0050: supply vcc not found, using dummy regulator
[    1.758411] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.770754] libphy: Fixed MDIO Bus: probed
[    1.777893] pps pps0: new PPS source ptp0
[    1.818303] libphy: fec_enet_mii_bus: probed
[    1.823777] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[    1.943198] pps pps1: new PPS source ptp1
[    1.949761] libphy: fec_enet_mii_bus: probed
[    1.958422] fec 2188000.ethernet ethFEC1: registered PHC device 1
[    1.965518] PPP generic driver version 2.4.2
[    1.970201] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.976842] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.982602] usbcore: registered new interface driver usb-storage
[    1.988857] usbcore: registered new interface driver usbserial_generic
[    1.995519] usbserial: USB Serial support registered for generic
[    2.057179] rtc-pcf8563 4-0051: registered as rtc0
[    2.074009] rtc-pcf8563 4-0051: setting system clock to 2023-06-27T09:35:11 UTC (1687858511)
[    2.092716] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[    2.099156] i2c /dev entries driver
[    2.105982] lm75 4-0048: supply vs not found, using dummy regulator
[    2.117651] lm75 4-0048: hwmon0: sensor 'lm75b'
[    2.237852] sdhci: Secure Digital Host Controller Interface driver
[    2.244134] sdhci: Copyright(c) Pierre Ossman
[    2.248507] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.262389] ledtrig-cpu: registered to indicate activity on CPUs
[    2.270217] usbcore: registered new interface driver usbhid
[    2.275922] usbhid: USB HID core driver
[    2.291073] Initializing XFRM netlink socket
[    2.295521] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[    2.303806] NET: Registered protocol family 10
[    2.311544] Segment Routing with IPv6
[    2.315744] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.323811] NET: Registered protocol family 17
[    2.328946] Key type dns_resolver registered
[    2.337292] registered taskstats version 1
[    2.341431] Loading compiled-in X.509 certificates
[    2.365384] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    2.377269] of_cfs_init
[    2.379862] of_cfs_init: OK
[    2.387613] ALSA device list:
[    2.390734]   No soundcards found.
[    2.394626] Waiting for root device /dev/mmcblk0p3...
[    2.402882] mmc0: new DDR MMC card at address 0001
[    2.408624] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.413666] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.419988] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.426312] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB, chardev (245:0)
[    2.437019]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.459921] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[    2.467331] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[    3.453922] EXT4-fs (mmcblk0p3): orphan cleanup on readonly fs
[    3.479173] EXT4-fs (mmcblk0p3): 8 orphan inodes deleted
[    3.484596] EXT4-fs (mmcblk0p3): recovery complete
[    3.514203] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    3.522445] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    3.530570] devtmpfs: mounted
[    3.540467] Freeing unused kernel memory: 1024K
[    3.545649] Run /sbin/init as init process
[    3.549759]   with arguments:
[    3.549767]     /sbin/init
[    3.549774]   with environment:
[    3.549780]     HOME=/
[    3.549787]     TERM=linux
[    3.980082] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    4.004374] systemd[1]: Detected architecture arm.
[    4.054414] systemd[1]: Set hostname to <wirenboard-AMJ3BTOQ>.
[    5.820900] systemd[1]: Queued start job for default target Graphical Interface.
[    5.836924] systemd[1]: Created slice system-getty.slice.
[    5.880139] systemd[1]: Created slice system-modprobe.slice.
[    5.916311] systemd[1]: Created slice system-openvpn.slice.
[    5.960230] systemd[1]: Created slice system-postgresql.slice.
[    6.010182] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.060170] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    6.108917] systemd[1]: Created slice User and Session Slice.
[    6.143840] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.183708] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.225037] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[    6.239075] systemd[1]: Reached target Local Encrypted Volumes.
[    6.274206] systemd[1]: Reached target Remote File Systems.
[    6.314234] systemd[1]: Reached target Slices.
[    6.347898] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.383641] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.454807] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    6.465555] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.504479] systemd[1]: Listening on Journal Socket.
[    6.545335] systemd[1]: Listening on udev Control Socket.
[    6.585970] systemd[1]: Listening on udev Kernel Socket.
[    6.627680] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    6.648448] systemd[1]: Mounting POSIX Message Queue File System...
[    6.698699] systemd[1]: Mounting /sys/kernel/config...
[    6.748887] systemd[1]: Mounting Kernel Debug File System...
[    6.793695] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    6.814270] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.870087] systemd[1]: Starting Load Kernel Module drm...
[    6.922045] systemd[1]: Starting Load Kernel Module fuse...
[    6.965770] fuse: init (API version 7.32)
[    6.980299] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.996514] systemd[1]: Starting File System Check on Root Device...
[    7.064484] systemd[1]: Starting Journal Service...
[    7.105781] systemd[1]: Starting Load Kernel Modules...
[    7.173658] systemd[1]: Starting Coldplug All udev Devices...
[    7.272197] systemd[1]: Mounted POSIX Message Queue File System.
[    7.344385] systemd[1]: Mounted /sys/kernel/config.
[    7.366225] systemd[1]: Mounted Kernel Debug File System.
[    7.395699] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.498921] systemd[1]: modprobe@drm.service: Succeeded.
[    7.522909] systemd[1]: Finished Load Kernel Module drm.
[    7.545301] systemd[1]: modprobe@fuse.service: Succeeded.
[    7.565000] systemd[1]: Finished Load Kernel Module fuse.
[    7.595940] systemd[1]: Finished File System Check on Root Device.
[    7.652878] systemd[1]: Finished Load Kernel Modules.
[    7.723107] systemd[1]: Mounting FUSE Control File System...
[    7.777658] systemd[1]: Started File System Check Daemon to report status.
[    7.856031] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.929138] systemd[1]: Starting Apply Kernel Variables...
[    8.007989] systemd[1]: Started Journal Service.
[    8.085819] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
[   10.794485] Driver for 1-wire Dallas network protocol.
[   10.885336] gpio-68 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   10.936552] gpio-11 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   11.756035] fec 20b4000.ethernet eth1: renamed from ethFEC0
[   12.378008] fec 2188000.ethernet eth0: renamed from ethFEC1
[   12.422717] imx_usb 2184000.usb: No over current polarity defined
[   12.498899] ci_hdrc ci_hdrc.0: EHCI Host Controller
[   12.540834] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[   12.672539] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[   12.702807] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   12.711097] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.718382] usb usb1: Product: EHCI Host Controller
[   12.723305] usb usb1: Manufacturer: Linux 5.10.35-wb133+wb101 ehci_hcd
[   12.729840] usb usb1: SerialNumber: ci_hdrc.0
[   13.030221] hub 1-0:1.0: USB hub found
[   13.096768] hub 1-0:1.0: 1 port detected
[   13.179682] ci_hdrc ci_hdrc.1: EHCI Host Controller
[   13.220551] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[   13.342631] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[   13.372791] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   13.381084] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.388387] usb usb2: Product: EHCI Host Controller
[   13.393300] usb usb2: Manufacturer: Linux 5.10.35-wb133+wb101 ehci_hcd
[   13.399835] usb usb2: SerialNumber: ci_hdrc.1
[   13.522653] usb usb1-port1: over-current condition
[   13.699809] hub 2-0:1.0: USB hub found
[   13.756289] hub 2-0:1.0: 1 port detected
[   14.172623] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[   14.433292] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[   14.441521] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   14.608229] hub 2-1:1.0: USB hub found
[   14.667628] hub 2-1:1.0: 4 ports detected
[   15.042564] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[   15.203875] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[   15.212288] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   15.219687] usb 2-1.1: Product: 802.11n WLAN Adapter
[   15.224682] usb 2-1.1: Manufacturer: Realtek
[   15.228959] usb 2-1.1: SerialNumber: 00e04c000001
[   15.622771] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   15.648897] Bluetooth: Core ver 2.22
[   15.669545] NET: Registered protocol family 31
[   15.674091] Bluetooth: HCI device and connection manager initialized
[   15.702970] Bluetooth: HCI socket layer initialized
[   15.707886] Bluetooth: L2CAP socket layer initialized
[   15.726333] Bluetooth: SCO socket layer initialized
[   15.745676] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.770316] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[   15.832616] usbcore: registered new interface driver btusb
[   15.845720] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[   15.855685] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   15.861747] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[   15.872195] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[   15.878816] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[   15.888068] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[   16.360796] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SS
[   16.508757] RTL871X: module init start
[   16.512610] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[   16.701606] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[   16.764510] RTL871X: rtw_ndev_init(wlan0)
[   16.786376] RTL871X: rtw_ndev_init(wlan1)
[   16.798069] usbcore: registered new interface driver rtl8723bu
[   16.804070] RTL871X: module init ret=0
[   16.937399] usbcore: registered new interface driver rtl8xxxu
[   17.773613] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[   18.076924] systemd-journald[131]: Received client request to flush runtime journal.
[   18.130952] systemd-journald[131]: File /var/log/journal/e546d32fff574ec0b96fd3c0ff11e80f/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   20.749124] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.754586] Bluetooth: BNEP filters: protocol multicast
[   20.827708] Bluetooth: BNEP socket layer initialized
[   29.272746] SMSC LAN8710/LAN8720 2188000.ethernet-2:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-2:00, irq=POLL)
[   29.655428] Micrel KSZ8081 or KSZ8091 2188000.ethernet-2:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet-2:03, irq=POLL)
[   50.077648] RTL871X: rtw_set_802_11_connect(wlan1)  fw_state=0x00000008
[   50.207881] RTL871X: start auth
[   50.214699] RTL871X: auth success, start assoc
[   50.226090] RTL871X: rtw_cfg80211_indicate_connect(wlan1) BSS not found !!
[   50.233133] RTL871X: assoc success
[   50.269433] RTL871X: send eapol packet
[   50.306073] RTL871X: send eapol packet
[   50.339234] RTL871X: port switch - port0(wlan1), port1(wlan0)
[   50.370891] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[   50.405902] RTL871X: set pairwise key camid:4, addr:b4:b0:24:b7:9d:33, kid:0, type:AES
[   50.510626] RTL871X: set group key camid:5, addr:b4:b0:24:b7:9d:33, kid:1, type:TKIP
[   53.905423] 2018000.serial: ttymxc6 at MMIO 0x2018000 (irq = 224, base_baud = 5000000) is a IMX
[   54.055807] pps pps2: new PPS source mod4_pps.-1
[   54.060507] pps pps2: Registered IRQ 128 as PPS source
[   63.299295] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 225, base_baud = 5000000) is a IMX
[   71.465737] 2288000.serial: ttymxc7 at MMIO 0x2288000 (irq = 226, base_baud = 5000000) is a IMX
[   72.112755] gpio-19 (wbmz2_i2c_0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   72.162635] gpio-18 (wbmz2_i2c_0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   72.822445] i2c-gpio wbmz2_i2c_0: using lines 19 (SDA) and 18 (SCL)
[   85.370340] RTL871X: linked_status_chk(wlan1) disconnect or roaming
[   87.668894] RTL871X: start auth
[   87.675661] RTL871X: auth success, start assoc
[   87.685333] RTL871X: rtw_cfg80211_indicate_connect(wlan1) BSS not found !!
[   87.692340] RTL871X: assoc success
[   87.715494] RTL871X: send eapol packet
[   87.835754] RTL871X: send eapol packet
[   87.846472] RTL871X: rtw_tkip_decrypt(wlan1) gkey installed. no_gkey_bc_cnt:2, no_gkey_mc_cnt:0
[   88.013352] RTL871X: set pairwise key camid:4, addr:b4:b0:24:b7:9d:97, kid:0, type:AES
[   88.161624] RTL871X: set group key camid:5, addr:b4:b0:24:b7:9d:97, kid:1, type:TKIP
[   91.689387] process '/usr/sbin/netplugd' started with executable stack
[   93.251521] tun: Universal TUN/TAP device driver, 1.6
[  158.859802] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  172.595809] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  187.677843] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  189.223370] usb 2-1.3: new high-speed USB device number 4 using ci_hdrc
[  189.429705] usb 2-1.3: New USB device found, idVendor=1286, idProduct=812a, bcdDevice= 0.00
[  189.438196] usb 2-1.3: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[  189.445561] usb 2-1.3: Product: WUKONG
[  189.449463] usb 2-1.3: Manufacturer: MARVELL
[  189.630934] usb 2-1.3: can't set config #1, error -71
[  189.711564] usb 2-1.3: USB disconnect, device number 4
[  196.911633] usb 2-1.3: new high-speed USB device number 5 using ci_hdrc
[  197.102281] usb 2-1.3: config 1 has an invalid interface number: 5 but max is 4
[  197.109689] usb 2-1.3: config 1 has no interface number 3
[  197.162262] usb 2-1.3: New USB device found, idVendor=1e0e, idProduct=9011, bcdDevice= 1.00
[  197.170744] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  197.178274] usb 2-1.3: Product: Mobile Composite Device Bus
[  197.184010] usb 2-1.3: Manufacturer: Marvell
[  197.188287] usb 2-1.3: SerialNumber: 200806006809080000
[  197.727466] usbcore: registered new interface driver cdc_ether
[  197.759097] usbcore: registered new interface driver option
[  197.871229] rndis_host 2-1.3:1.0 usb0: register 'rndis_host' at usb-ci_hdrc.1-1.3, RNDIS device, c6:af:30:d4:1b:be
[  197.951137] usbserial: USB Serial support registered for GSM modem (1-port)
[  198.059902] option 2-1.3:1.2: GSM modem (1-port) converter detected
[  198.081359] usbcore: registered new interface driver rndis_host
[  198.169433] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[  198.354016] option 2-1.3:1.4: GSM modem (1-port) converter detected
[  198.462919] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[  198.593723] option 2-1.3:1.5: GSM modem (1-port) converter detected
[  198.690224] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[  202.236807] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  217.453881] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  232.540811] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  247.473688] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  262.508816] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  277.020796] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  292.122820] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  307.498782] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  322.298887] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  337.220784] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  352.191983] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  367.656779] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  382.098814] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[  397.062818] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
какие еще логи нужны? и как их получить?
Логи NetworkManager, ModemManager
https://wirenboard.com/wiki/Journalctl
-- Boot 93b2f2f25277474dab7e65f2a2f90602 --
июн 27 12:35:29 wirenboard-AMJ3BTOQ systemd[1]: Starting Network Manager...
июн 27 12:35:36 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858536.6169] NetworkManager (version 1.40.0) is starting... (boot:93b2f2f2-5277-474d-ab7e-65f2a2f90602)
июн 27 12:35:36 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858536.6243] Read config: /etc/NetworkManager/NetworkManager.conf (lib: no-mac-addr-change.conf, wb.conf)
июн 27 12:35:36 wirenboard-AMJ3BTOQ systemd[1]: Started Network Manager.
июн 27 12:35:36 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858536.7388] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.0774] manager[0x1bdd850]: monitoring kernel firmware directory '/lib/firmware'.
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.1642] hostname: hostname: using hostnamed
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.1659] hostname: static hostname changed from (none) to "wirenboard-AMJ3BTOQ"
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.1949] dns-mgr: init: dns=default,systemd-resolved rc-manager=file
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.2910] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.3017] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.3386] manager[0x1bdd850]: rfkill: Wi-Fi hardware radio set enabled
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.3460] manager[0x1bdd850]: rfkill: WWAN hardware radio set enabled
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.5336] Loaded device plugin: NMWwanFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-device-plug>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.6414] Loaded device plugin: NMTeamFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-device-plug>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.6712] Loaded device plugin: NMWifiFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-device-plug>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.7191] Loaded device plugin: NMBluezManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-device-plu>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.7418] Loaded device plugin: NMAtmManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-device-plugi>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.7689] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.7813] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.7920] manager: Networking is enabled by state file
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.8269] settings: Loaded settings plugin: ifupdown ("/usr/lib/arm-linux-gnueabihf/NetworkManager/1.40.0/libnm-set>
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.8289] settings: Loaded settings plugin: keyfile (internal)
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.8526] ifupdown: management mode: unmanaged
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.8574] ifupdown:       interface-parser: parsing file /etc/network/interfaces
июн 27 12:35:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858537.8577] ifupdown:       interface-parser: finished parsing file /etc/network/interfaces
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.3558] dhcp: init: Using DHCP client 'internal'
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.3602] device (lo): carrier: link connected
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.3970] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.5638] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.6136] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
июн 27 12:35:38 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858538.9652] manager: (eth1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/3)
июн 27 12:35:39 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858539.0016] device (eth1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
июн 27 12:35:39 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858539.3517] manager: (sit0): new IPTunnel device (/org/freedesktop/NetworkManager/Devices/4)
июн 27 12:35:39 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858539.4220] device (wlan0): driver supports Access Point (AP) mode
июн 27 12:35:39 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858539.4750] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/5)
июн 27 12:35:39 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858539.5063] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
июн 27 12:35:43 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858543.8409] device (wlan1): driver supports Access Point (AP) mode
июн 27 12:35:43 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858543.8888] manager: (wlan1): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/6)
июн 27 12:35:43 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858543.9280] device (wlan1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
июн 27 12:35:44 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858544.4394] modem-manager: ModemManager available
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.0683] device (wlan0): supplicant interface state: internal-starting -> disconnected
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.0891] Wi-Fi P2P device controlled by interface wlan0 created
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.0919] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/7)
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.0943] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'exter>
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.2223] device (wlan1): supplicant interface state: internal-starting -> disconnected
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.2247] Wi-Fi P2P device controlled by interface wlan1 created
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.2616] manager: (p2p-dev-wlan1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.2935] device (p2p-dev-wlan1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'exter>
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.3629] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state>
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.4360] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'manag>
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.4990] device (wlan1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state>
июн 27 12:35:45 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858545.5558] device (p2p-dev-wlan1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'manag>
июн 27 12:35:49 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858549.6305] policy: auto-activating connection 'GS2' (34f7c425-bb52-400c-86d1-6b0f2ec0014d)
июн 27 12:35:49 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858549.6914] device (wlan1): Activation: starting connection 'GS2' (34f7c425-bb52-400c-86d1-6b0f2ec0014d)
июн 27 12:35:49 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858549.7275] device (wlan1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:49 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858549.7827] manager: NetworkManager state is now CONNECTING
июн 27 12:35:49 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858549.8444] device (wlan1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.4057] device (wlan1): Activation: (wifi) access point 'GS2' has security, but secrets are required.
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.4060] device (wlan1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.4305] sup-iface[2ccb0490c83a1d9a,1,wlan1]: wps: type pbc start...
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.5727] device (wlan1): supplicant interface state: disconnected -> scanning
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.5787] device (p2p-dev-wlan1): supplicant management interface state: disconnected -> scanning
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.5955] device (wlan1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6437] device (wlan1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6537] device (wlan1): Activation: (wifi) connection 'GS2' has security, and secrets exist.  No new secrets need>
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6828] Config: added 'ssid' value 'GS2'
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6865] Config: added 'scan_ssid' value '1'
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6883] Config: added 'bgscan' value 'simple:30:-70:86400'
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6900] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
июн 27 12:35:53 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858553.6902] Config: added 'psk' value '<hidden>'
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.6075] device (wlan1): supplicant interface state: scanning -> associating
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.6185] device (p2p-dev-wlan1): supplicant management interface state: scanning -> associating
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.7429] device (wlan1): supplicant interface state: associating -> associated
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.7432] device (p2p-dev-wlan1): supplicant management interface state: associating -> associated
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.7616] device (wlan1): supplicant interface state: associated -> 4way_handshake
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.7621] device (p2p-dev-wlan1): supplicant management interface state: associated -> 4way_handshake
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.8918] device (wlan1): supplicant interface state: 4way_handshake -> completed
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.8921] device (wlan1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless netw>
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.8923] device (p2p-dev-wlan1): supplicant management interface state: 4way_handshake -> completed
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.8934] device (wlan1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
июн 27 12:35:59 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858559.8973] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
июн 27 12:36:00 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858560.0401] dhcp4 (wlan1): state changed new lease, address=192.168.99.95
июн 27 12:36:00 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858560.2720] policy: set 'GS2' (wlan1) as default for IPv4 routing and DNS
июн 27 12:36:00 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858560.7086] device (wlan1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.2019] device (wlan1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.2038] device (wlan1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.2072] manager: NetworkManager state is now CONNECTED_SITE
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.2650] device (wlan1): Activation: successful, device activated.
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.3458] manager: NetworkManager state is now CONNECTED_GLOBAL
июн 27 12:36:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858561.4089] manager: startup complete
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.2471] device (wlan1): supplicant interface state: completed -> 4way_handshake
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.2474] device (p2p-dev-wlan1): supplicant management interface state: completed -> 4way_handshake
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3912] device (wlan1): supplicant interface state: 4way_handshake -> completed
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3917] device (wlan1): ip:dhcp4: restarting
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3920] dhcp4 (wlan1): canceled DHCP transaction
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3922] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3923] dhcp4 (wlan1): state changed no lease
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3927] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.3934] device (p2p-dev-wlan1): supplicant management interface state: 4way_handshake -> completed
июн 27 12:36:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858597.5781] dhcp4 (wlan1): state changed new lease, address=192.168.99.95
июн 27 12:36:43 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858603.1514] manager: (tun0): new Tun device (/org/freedesktop/NetworkManager/Devices/9)
июн 27 12:36:46 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858606.2195] device (tun0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'ext>
июн 27 12:36:46 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858606.5180] device (tun0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: '>
июн 27 12:36:46 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858606.8165] device (tun0): Activation: starting connection 'tun0' (dd7ea330-2473-4fcf-90be-9d3e8aeac243)
июн 27 12:36:47 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858607.3365] device (tun0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
июн 27 12:36:47 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858607.4587] device (tun0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
июн 27 12:36:47 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858607.6331] device (tun0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
июн 27 12:36:47 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858607.7712] device (tun0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
июн 27 12:36:48 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858608.3408] device (tun0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
июн 27 12:36:48 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858608.3432] device (tun0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
июн 27 12:36:48 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858608.6311] device (tun0): Activation: successful, device activated.
июн 27 12:37:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <error> [1687858621.9134] audit: failed to open auditd socket: Протокол не поддерживается
июн 27 12:37:01 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858621.9137] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:37:05 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858625.4098] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:37:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858630.2408] audit: op="device-reapply" interface="wlan1" ifindex=6 args="ipv4.route-metric" pid=1474 uid=0 result="su>
июн 27 12:37:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858630.2848] dhcp4 (wlan1): canceled DHCP transaction
июн 27 12:37:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858630.3553] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
июн 27 12:37:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858630.3665] dhcp4 (wlan1): state changed no lease
июн 27 12:37:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858630.4854] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
июн 27 12:37:11 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858631.6925] dhcp4 (wlan1): state changed new lease, address=192.168.99.95
июн 27 12:37:11 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858631.7944] policy: set 'GS2' (wlan1) as default for IPv4 routing and DNS
июн 27 12:38:09 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858689.2850] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:38:10 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858690.3324] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:38:25 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858705.6793] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/10)
июн 27 12:39:12 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858752.5098] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:39:13 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858753.3739] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:39:26 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858766.6655] audit: op="connection-activate" uuid="5d4297ba-c319-4c05-a153-17cb42e6e196" name="wb-gsm-sim1" result="fa>
июн 27 12:39:27 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858767.7128] audit: op="connection-activate" uuid="5d4297ba-c319-4c05-a153-17cb42e6e196" name="wb-gsm-sim1" result="fa>
июн 27 12:39:28 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858768.1169] audit: op="connection-activate" uuid="5d4297ba-c319-4c05-a153-17cb42e6e196" name="wb-gsm-sim1" result="fa>
июн 27 12:39:28 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858768.4967] audit: op="connection-activate" uuid="5d4297ba-c319-4c05-a153-17cb42e6e196" name="wb-gsm-sim1" result="fa>
июн 27 12:39:28 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858768.8009] audit: op="connection-activate" uuid="5d4297ba-c319-4c05-a153-17cb42e6e196" name="wb-gsm-sim1" result="fa>
июн 27 12:39:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858777.6191] audit: op="connection-activate" uuid="8b9964d4-b8dd-34d3-a3ed-481840bcf8c9" name="wb-gsm-sim2" result="fa>
июн 27 12:39:37 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858777.7034] modem-manager: ModemManager no longer available
июн 27 12:39:42 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858782.3544] modem-manager: ModemManager now available
июн 27 12:40:16 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858816.0345] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:40:16 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858816.9828] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:41:19 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858879.4032] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:41:20 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858880.4861] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:42:21 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858941.5461] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:42:22 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687858942.1857] audit: op="connection-activate" uuid="c3e38405-9c17-4155-ad70-664311b49066" name="wb-eth1" pid=1474 uid=0>
июн 27 12:43:23 wirenboard-AMJ3BTOQ NetworkManager[457]: <info>  [1687859003.5209] audit: op="connection-activate" uuid="91f1c71d-2d97-4675-886f-ecbe52b8451e" name="wb-eth0" pid=1474 uid=0>
июн 27 12:35:34 wirenboard-AMJ3BTOQ systemd[1]: Started Modem Manager.
июн 27 12:35:38 wirenboard-AMJ3BTOQ ModemManager[327]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/2000000.bus/20b4000.ethernet': not supported by a>
июн 27 12:35:38 wirenboard-AMJ3BTOQ ModemManager[327]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.1'>
июн 27 12:35:38 wirenboard-AMJ3BTOQ ModemManager[327]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/2100000.bus/2188000.ethernet': not supported by a>
июн 27 12:38:30 wirenboard-AMJ3BTOQ ModemManager[327]: <info>  [device /sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.3] creating modem with plugin 'simtech' and >
июн 27 12:38:30 wirenboard-AMJ3BTOQ ModemManager[327]: <info>  [base-manager] modem for device '/sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.3' successfully cre>
июн 27 12:38:41 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 2 consecutive times
июн 27 12:38:47 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 3 consecutive times
июн 27 12:38:47 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] Failed to find usable modem character set, let it to UNKNOWN
июн 27 12:38:53 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 4 consecutive times
июн 27 12:38:53 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load manufacturer: Sending command failed: 'Resource temporarily unavailable'
июн 27 12:38:58 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 5 consecutive times
июн 27 12:38:58 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load model: Sending command failed: 'Resource temporarily unavailable'
июн 27 12:39:05 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 6 consecutive times
июн 27 12:39:05 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load revision: Sending command failed: 'Resource temporarily unavailable'
июн 27 12:39:10 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 7 consecutive times
июн 27 12:39:10 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load equipment identifier: Sending command failed: 'Resource temporarily unavailable'
июн 27 12:39:17 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 8 consecutive times
июн 27 12:39:17 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load device identifier: Unable to generate a device identifier
июн 27 12:39:22 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] port ttyUSB1 timed out 9 consecutive times
июн 27 12:39:27 wirenboard-AMJ3BTOQ ModemManager[327]: <error> [modem0] port ttyUSB1 timed out 10 consecutive times, marking modem as invalid
июн 27 12:39:27 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load supported modes: Couldn't retrieve supported modes
июн 27 12:39:32 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load supported IP families: AT command was cancelled
июн 27 12:39:32 wirenboard-AMJ3BTOQ ModemManager[327]: <warn>  [modem0] couldn't load power state: No AT port available to run command
июн 27 12:39:32 wirenboard-AMJ3BTOQ ModemManager[327]: <error> mm_port_peek_kernel_device: assertion 'MM_IS_PORT (self)' failed
июн 27 12:39:37 wirenboard-AMJ3BTOQ systemd[1]: ModemManager.service: Main process exited, code=killed, status=11/SEGV
июн 27 12:39:37 wirenboard-AMJ3BTOQ systemd[1]: ModemManager.service: Failed with result 'signal'.
июн 27 12:39:37 wirenboard-AMJ3BTOQ systemd[1]: ModemManager.service: Consumed 9.330s CPU time.
июн 27 12:39:37 wirenboard-AMJ3BTOQ systemd[1]: ModemManager.service: Scheduled restart job, restart counter is at 1.
июн 27 12:39:37 wirenboard-AMJ3BTOQ systemd[1]: Stopped Modem Manager.
июн 27 12:39:38 wirenboard-AMJ3BTOQ systemd[1]: Starting Modem Manager...
июн 27 12:39:38 wirenboard-AMJ3BTOQ systemd[1]: ModemManager.service: Found left-over process 6863 (detect_legacy_m) in control group while starting unit. Ignoring.
июн 27 12:39:38 wirenboard-AMJ3BTOQ systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
июн 27 12:39:39 wirenboard-AMJ3BTOQ ModemManager[6866]: <info>  ModemManager (version 1.20.0) starting in system bus...
июн 27 12:39:40 wirenboard-AMJ3BTOQ systemd[1]: Started Modem Manager.
июн 27 12:40:04 wirenboard-AMJ3BTOQ ModemManager[6866]: <info>  [device /sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.3] creating modem with plugin 'simtech' and>
июн 27 12:40:04 wirenboard-AMJ3BTOQ ModemManager[6866]: <warn>  [plugin/simtech] could not grab port ttyUSB2: Cannot add port 'tty/ttyUSB2', unhandled port type
июн 27 12:40:04 wirenboard-AMJ3BTOQ ModemManager[6866]: <warn>  [plugin/simtech] could not grab port ttyUSB1: Cannot add port 'tty/ttyUSB1', unhandled port type
июн 27 12:40:04 wirenboard-AMJ3BTOQ ModemManager[6866]: <warn>  [base-manager] couldn't create modem for device '/sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.3'>
А точно ли модем сконфигурирован в wb-hardware.conf?
root@wirenboard-AMJ3BTOQ:/etc# cat ./wb-hardware.conf
  "slots": [
      "id": "wb67-mod1",
      "name": "Internal slot 1",
      "compatible": [
        "wbe2",
        "wbe3-reduced"
      "module": "",
      "options": {}
      "id": "wb67-mod2",
      "name": "Internal slot 2",
      "compatible": [
        "wbe2",
        "wbe3-reduced"
      "module": "",
      "options": {}
      "id": "wb67-mod3",
      "name": "Internal slot 3",
      "compatible": [
        "wbe2",
        "wbe3-reduced"
      "module": "",
      "options": {}
      "id": "wb67-mod4",
      "name": "Internal slot 4",
      "compatible": [
        "wbe3",
        "wbe3-reduced"
      "module": "wbe3-r-gps",
      "options": {}
      "id": "wb6-extio1",
      "name": "External I/O module 1",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio2",
      "name": "External I/O module 2",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio3",
      "name": "External I/O module 3",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio4",
      "name": "External I/O module 4",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio5",
      "name": "External I/O module 5",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio6",
      "name": "External I/O module 6",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio7",
      "name": "External I/O module 7",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb6-extio8",
      "name": "External I/O module 8",
      "compatible": [
        "wb5-extio"
      "module": "",
      "options": {}
      "id": "wb67-rs485-1",
      "name": "RS485-1 interface config",
      "compatible": [
        "wb67-rs485"
      "module": "wb67-can-rs485",
      "options": {
        "mode": "enabled",
        "terminatorsMode": "enabled"
      "id": "wb67-rs485-2",
      "name": "RS485-2/CAN interface config",
      "compatible": [
        "wb67-rs485",
        "wb67-can"
      "options": {
        "mode": "enabled",
      "id": "wb67-wbc",
      "name": "Modem slot",
      "compatible": [
        "wbc"
      "module": "wbc-4g",
      "options": {}
      "id": "wb67-w1",
      "name": "W1 terminal mode",
      "compatible": [
        "wb6-wx"
      "module": "wb6-wx-1wire",
      "options": {}
      "id": "wb67-w2",
      "name": "W2 terminal mode",
      "compatible": [
        "wb6-wx"
      "options": {}
      "id": "wb67-wbmz3",
      "name": "Backup power supply",
      "compatible": [
        "wb67-wbmz3-power"
      "module": "wbmz3-battery",
      "options": {
        "resetButon": "enabled"
приложен диагностический архив, доступен только сотрудникам поддержки (94,9 КБ)
Интересно… Такое впечатление что порт модема чем-то занят.
Выполните
fuser -a /dev/ttyUSB*
Ну или дайте доступ к контроллеру по ssh, посмотрю.
root@wirenboard-AMJ3BTOQ:/opt/sensor-client/logs# fuser -a /dev/ttyUSB*
/dev/ttyUSB0:
/dev/ttyUSB1:          327
/dev/ttyUSB2:
root@wirenboard-AMJ3BTOQ:/opt/sensor-client/logs# ps aux | grep 327
root       130  0.0  0.7  43272  3752 ?        Ss   июн27   0:31 /lib/systemd/systemd-journald
root       279 30.9 51.4 323112 260608 ?       Sl   июн27 327:49 /usr/bin/java -Duser.timezone=Europe/Minsk -jar sensor-client-IQ_TERM-2.0.jar
root       327  0.0  0.8  54224  4332 ?        Ssl  июн27   0:20 /usr/sbin/ModemManager
root     25672  0.0  0.3   6860  1620 pts/1    S+   13:09   0:00 grep 327
Так, все верно.
А что за прочесс java?
Нет ли вероятности что в процессе запуска кто-то захватывает порт? Попробуйте перезапустить NetworkManager и ModemManager?
java это наше приложение… оно не трогает порты GSM. на всякий случай убрал его из автостарта и ребутнул борд. ничего не изменилось
root@wirenboard-AMJ3BTOQ:~# fuser -a /dev/ttyUSB*
/dev/ttyUSB0:
/dev/ttyUSB1:        17691
/dev/ttyUSB2:
root@wirenboard-AMJ3BTOQ:~# ps aux | grep 17691
root     17691  6.0  1.9  54136  9824 ?        Ssl  15:12   0:01 /usr/sbin/ModemManager
root     18346  0.0  0.3   6860  1712 pts/0    S+   15:12   0:00 grep 17691
Еще раз лог или диагностический архив покажите.
В привденном самое интересное обрезано.
приложен диагностический архив, доступен только сотрудникам поддержки (113,2 КБ)
ModemManager.log (10,0 КБ)
NetworkManager.log (47,7 КБ)
июн 28 15:12:56 wirenboard-AMJ3BTOQ ModemManager[17691]: <info>  [modem0] state changed (enabled -> registered)
июн 28 18:07:33 wirenboard-AMJ3BTOQ ModemManager[17691]: <info>  [modem0] network request to deactivate context (cid 1)
Регистрируется в сети но соединения нет.
Из логов явных ошибок в конфигурации не вижу. Проверьте все ж на другой карте.
поменял симки с соседним бордом… сосед поднял интернет, этот борд - нет
Проверьте все ж настройки - то есть вот буквально файлы с конфигурацией соединения. Ну и посмотрите GSM отказ в регистрации в сети
Какой статус регистрации и уровня (AT+CSQ или ```mmcli -m 0 --signal-setup=10; mmcli -m 0 --signal-get") возвращает сам модем?
