root@wirenboard-AMJ3BTOQ:~# mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: d1c349f1972fb47045ed31fa309981bb8ab0f1a2
Hardware | manufacturer: INCORPORATED
| model: A7600E-HNVW
| firmware revision: A39C4B02A7600M7
| supported: gsm-umts
| current: gsm-umts
| equipment id: 861065040051733
System | device: /sys/devices/platform/soc/2100000.bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.3
| drivers: option, rndis_host
| plugin: simtech
| primary port: ttyUSB1
| ports: ttyUSB0 (ignored), ttyUSB1 (at), ttyUSB2 (at), usb0 (net)
Numbers | own: +375291697238
Status | unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 70% (recent)
Modes | supported: allowed: any; preferred: none
| current: allowed: any; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 861065040051733
| registration: home
| packet service state: attached
3GPP EPS | ue mode of operation: csps-1
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
root@wirenboard-AMJ3BTOQ:~# mmcli -m 0 --signal-setup=10
Successfully setup signal quality information polling
root@wirenboard-AMJ3BTOQ:~# mmcli -m 0 --signal-get
Signal | refresh rate: 10 seconds
| rssi threshold: 0 dBm
| error rate threshold: no
GSM | rssi: -71,00 dBm
LTE | rsrq: -11,00 dB
| rsrp: -101,00 dBm
Я никакие файлы не настраивал… только через веб интерфейс… какой файл вам показать?
сравните файлы в /etc/NetworkManager/system-connections
можно даже с одного контроллера на другой.
этот работает
root@wirenboard-AVABZSCH:/etc/NetworkManager/system-connections# cat ./wb-gsm-sim1.nmconnection
[connection]
id=wb-gsm-sim1
uuid=5d4297ba-c319-4c05-a153-17cb42e6e196
type=gsm
timestamp=1688481087
[gsm]
auto-config=true
sim-slot=1
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=ignore
[proxy]
root@wirenboard-AVABZSCH:/etc/NetworkManager/system-connections# cat ./wb-gsm-sim2.nmconnection
[connection]
id=wb-gsm-sim2
uuid=8b9964d4-b8dd-34d3-a3ed-481840bcf8c9
type=gsm
autoconnect=false
[gsm]
auto-config=true
sim-slot=2
[ipv4]
method=auto
[ipv6]
method=ignore
[proxy]
этот нет
root@wirenboard-AMJ3BTOQ:/etc/NetworkManager/system-connections# cat ./wb-gsm-sim1.nmconnection
[connection]
id=wb-gsm-sim1
type=gsm
timestamp=1687849612
[gsm]
auto-config=true
sim-slot=1
[ipv4]
method=auto
[ipv6]
method=ignore
[proxy]
root@wirenboard-AMJ3BTOQ:/etc/NetworkManager/system-connections# cat ./wb-gsm-sim2.nmconnection
[connection]
id=wb-gsm-sim2
type=gsm
autoconnect=false
[gsm]
auto-config=true
sim-slot=2
[ipv4]
method=auto
[ipv6]
method=ignore
[proxy]
Я вижу что APN не установлен. Сбросьте оба модема at&f и проверьте. Но и установить APN тоже нужно, можно с этого и начать на том контроллере где нет соединения.
я что-то психанул и сделал FACTORYRESET… и все равно не поднимается интернет на GSM
Хм. Ну, это все ж никак на настройки модема не влияет. Попробуйте именно модем сбросить - не возымеет результата - давайте ssh к контроллеру, посмотрю сам.
Я вижу:
июл 20 17:51:05 wirenboard-AMJ3BTOQ ModemManager[321]: <warn> [modem1] initial 3GPP registration check failed: Operation not allowed
июл 20 17:51:07 wirenboard-AMJ3BTOQ ModemManager[321]: <info> [modem1] 3GPP registration state changed (denied -> registering)
июл 20 17:51:07 wirenboard-AMJ3BTOQ ModemManager[321]: <warn> [modem1] couldn't load operator code: Couldn't match response
июл 20 17:54:01 wirenboard-AMJ3BTOQ NetworkManager[1952]: <warn> [1689864841.5953] device (ttyUSB1): Activation: failed for connection 'wb-gsm-sim1'
При этом пакетная
mmcli -m any
| model: A7600E-HNVW
| supported: gsm-umts
| current: gsm-umts
System | device: wbc
| plugin: simtech
| state: registered
| power state: on
| access tech: hspa
| signal quality: 45% (recent)
| registration: home
| packet service state: detached
| slot 2: none
Такое впечатление что оператор не позволяет подключиться. Проверте пожалуйста карту другого оператора…
я тут перезагружал борд и заметил, что иногда после ребута ppp поднимается, но похоже редко… сейчас не поднялся… глянете?
Вообще нестабильно работает. Именно сам модем.
Давайте мы бесплатно поменяем вам оборудование. Курьер привезёт новое:
- ссылку на эту тему,
