Не стартует WB после ремонта
на прошлой неделе контроллер вернули из ремонта (тема для обсуждения здесь Docker не запускается - #19 от пользователя BrainRoot)
однако, конроллер все еще не загружается.
при загрузке без флешки со сбросом прошивки уходит в беконечный цикл:
U-Boot SPL 2021.10-wb1.5.0-gf1b9e03284 (Apr 05 2023 - 14:31:04 +0000)
DRAM init ok, rows:16, ncs:1, size: 1024MB
.p0_mpdgctrl0   = 0x010f0109
.p0_mpdgctrl1   = 0x0e3f0e3f
.p0_mprddlctl   = 0x3f3f3c3f
.p0_mpwrdlctl   = 0x3f3f3834
.p0_mpwldectrl0 = 0x000f000d
.p0_mpwldectrl1 = 0x00100010
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.5.0-gf1b9e03284 (Apr 05 2023 - 14:31:04 +0000)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 45C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=3
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net:   Could not get PHY for FEC0: addr 0
No ethernet found.
Hit any key to stop autoboot:  0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices... EHCI timed out on TD - token=0x80008d80
      USB device not accepting new address (error=22)
       scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
323 bytes read in 2 ms (157.2 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
6304344 bytes read in 269 ms (22.4 MiB/s)
MMC read: dev # 1, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard690
47776 bytes read in 5 ms (9.1 MiB/s)
485 bytes read in 3 ms (157.2 KiB/s)
Applying DT overlay wb6-nogsm
597 bytes read in 2 ms (291 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 3 ms (165 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 3 ms (108.4 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 3 ms (82 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x603258 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Loading Device Tree to bef78000, end bef9afff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.35-wb133 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Tue Feb 21 08:07:14 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Wiren Board rev. 6.9.0 (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0xbf000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 259840
[    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1008656K/1048576K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 23536K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000057] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002803] Console: colour dummy device 80x30
[    0.002868] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002904] pid_max: default: 32768 minimum: 301
[    0.003324] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003366] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.005103] CPU: Testing write buffer coherency: ok
[    0.006320] Setting up static identity map for 0x80100000 - 0x80100078
[    0.007318] devtmpfs: initialized
[    0.025266] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.025783] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.025828] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.027210] pinctrl core: initialized pinctrl subsystem
[    0.029215] NET: Registered protocol family 16
[    0.031514] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.033535] thermal_sys: Registered thermal governor 'step_wise'
[    0.033816] cpuidle: using governor menu
[    0.221760] vdd1p1: supplied by regulator-dummy
[    0.233899] vdd3p0: supplied by regulator-dummy
[    0.246068] cpu: supplied by regulator-dummy
[    0.258248] vddsoc: supplied by regulator-dummy
[    0.600972] No ATAGs?
[    0.601031] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.601051] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.601652] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[    0.602312] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[    0.603872] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[    0.603913] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.646516] mxs-dma 1804000.dma-apbh: initialized
[    0.651782] SCSI subsystem initialized
[    0.652274] usbcore: registered new interface driver usbfs
[    0.652404] usbcore: registered new interface driver hub
[    0.652522] usbcore: registered new device driver usb
[    0.653457] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.653587] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.654912] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[    0.655798] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.655921] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.656516] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[    0.657206] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.657331] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.657916] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[    0.659504] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.659865] i2c i2c-1: IMX I2C adapter registered
[    0.660595] mc: Linux media interface: v0.10
[    0.660709] videodev: Linux video capture interface: v2.00
[    0.660842] pps_core: LinuxPPS API ver. 1 registered
[    0.660862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.660914] PTP clock support registered
[    0.661531] Advanced Linux Sound Architecture Driver Initialized.
[    0.663766] clocksource: Switched to clocksource mxc_timer1
[    0.681407] NET: Registered protocol family 2
[    0.682706] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.682804] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.682981] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.683171] TCP: Hash tables configured (established 8192 bind 8192)
[    0.683393] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.683470] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.683971] NET: Registered protocol family 1
[    0.684890] RPC: Registered named UNIX socket transport module.
[    0.684928] RPC: Registered udp transport module.
[    0.684947] RPC: Registered tcp transport module.
[    0.684964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.686053] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.688868] Initialise system trusted keyrings
[    0.689327] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.701001] NFS: Registering the id_resolver key type
[    0.701077] Key type id_resolver registered
[    0.701096] Key type id_legacy registered
[    0.946722] Key type asymmetric registered
[    0.946762] Asymmetric key parser 'x509' registered
[    0.946883] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.946905] io scheduler mq-deadline registered
[    0.946923] io scheduler kyber registered
[    0.958811] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.958859] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.962763] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[    1.626084] printk: console [ttymxc0] enabled
[    1.632509] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.676452] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[    1.683883] random: fast init done
[    1.687834] random: crng init done
[    1.727912] brd: module loaded
[    1.746171] loop: module loaded
[    1.749685] at24 5-0050: supply vcc not found, using dummy regulator
[    1.761146] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.768177] at24 6-0050: supply vcc not found, using dummy regulator
[    1.779556] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.791996] libphy: Fixed MDIO Bus: probed
[    1.914492] pps pps0: new PPS source ptp0
[    1.920953] libphy: fec_enet_mii_bus: probed
[    1.929728] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[    2.054461] pps pps1: new PPS source ptp1
[    2.095562] libphy: fec_enet_mii_bus: probed
[    2.100859] fec 2188000.ethernet ethFEC1: registered PHC device 1
[    2.107952] PPP generic driver version 2.4.2
[    2.112640] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.119280] ehci-mxc: Freescale On-Chip EHCI Host driver
[    2.125035] usbcore: registered new interface driver usb-storage
[    2.131291] usbcore: registered new interface driver usbserial_generic
[    2.137965] usbserial: USB Serial support registered for generic
[    2.187421] rtc rtc0: invalid alarm value: 2023-06-04T40:04:00
[    2.193714] rtc-pcf8563 4-0051: registered as rtc0
[    2.210552] rtc-pcf8563 4-0051: setting system clock to 2023-06-06T06:50:39 UTC (1686034239)
[    2.229255] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[    2.235783] i2c /dev entries driver
[    2.242501] lm75 4-0048: supply vs not found, using dummy regulator
[    2.254267] lm75 4-0048: hwmon0: sensor 'lm75b'
[    2.374424] sdhci: Secure Digital Host Controller Interface driver
[    2.380634] sdhci: Copyright(c) Pierre Ossman
[    2.385054] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.399109] ledtrig-cpu: registered to indicate activity on CPUs
[    2.406935] usbcore: registered new interface driver usbhid
[    2.412534] usbhid: USB HID core driver
[    2.427895] Initializing XFRM netlink socket
[    2.432304] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[    2.440633] NET: Registered protocol family 10
[    2.448422] Segment Routing with IPv6
[    2.452582] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.460688] NET: Registered protocol family 17
[    2.465868] Key type dns_resolver registered
[    2.475055] registered taskstats version 1
[    2.479192] Loading compiled-in X.509 certificates
[    2.501346] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    2.513342] of_cfs_init
[    2.516057] of_cfs_init: OK
[    2.523957] ALSA device list:
[    2.526973]   No soundcards found.
[    2.530740] Waiting for root device /dev/mmcblk0p3...
[    2.579212] mmc0: new DDR MMC card at address 0001
[    2.586401] mmcblk0: mmc0:0001 008GB0 7.28 GiB
[    2.591966] mmcblk0boot0: mmc0:0001 008GB0 partition 1 8.00 MiB
[    2.599223] mmcblk0boot1: mmc0:0001 008GB0 partition 2 8.00 MiB
[    2.605963] mmcblk0rpmb: mmc0:0001 008GB0 partition 3 4.00 MiB, chardev (245:0)
[    2.618806]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.660975] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[    2.668383] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[    2.686331] EXT4-fs (mmcblk0p3): recovery complete
[    2.693215] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    2.701457] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    2.709765] devtmpfs: mounted
[    2.714406] Freeing unused kernel memory: 1024K
[    2.719220] Run /sbin/init as init process
[    3.128533] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    3.152597] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 11 (bullseye)!
[    3.197111] systemd[1]: Set hostname to <wirenboard-A5ZXZ7OF>.
[    4.927415] systemd[1]: Queued start job for default target Graphical Interface.
[    4.942943] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    4.991404] systemd[1]: Created slice system-modprobe.slice.
[  OK  ] Created slice system-modprobe.slice.
[    5.042021] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.091266] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[    5.139995] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.175856] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    5.216233] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    5.255112] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[    5.268842] systemd[1]: Reached target Local Encrypted Volumes.
[  OK  ] Reached target Local Encrypted Volumes.
[    5.305380] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.344490] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.379364] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[    5.415066] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    5.479625] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    5.490351] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.528232] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.576246] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.615858] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.658708] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    5.676569] systemd[1]: Mounting POSIX Message Queue File System...
[    5.730542] systemd[1]: Mounting /sys/kernel/config...
[    5.780295] systemd[1]: Mounting Kernel Debug File System...
[    5.824944] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    5.842933] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    5.901093] systemd[1]: Starting Load Kernel Module drm...
[    5.960970] systemd[1]: Starting Load Kernel Module fuse...
[    6.007848] fuse: init (API version 7.32)
[    6.030437] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.048392] systemd[1]: Starting File System Check on Root Device...
[    6.115157] systemd[1]: Starting Journal Service...
[    6.168309] systemd[1]: Starting Load Kernel Modules...
[    6.234154] systemd[1]: Starting Coldplug All udev Devices...
[    6.351510] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    6.395746] systemd[1]: Mounted /sys/kernel/config.
[  OK  ] Mounted /sys/kernel/config.
[    6.418911] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    6.477345] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[    6.582400] systemd[1]: modprobe@drm.service: Succeeded.
[    6.614236] systemd[1]: Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module drm.
[    6.656627] systemd[1]: modprobe@fuse.service: Succeeded.
[    6.674284] systemd[1]: Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Module fuse.
[    6.724062] systemd[1]: Finished File System Check on Root Device.
[  OK  ] Finished File System Check on Root Device.
[    6.765078] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Finished Load Kernel Modules.
         Mounting FUSE Control File System...
[  OK  ] Started File System Check Daemon to report status.
         Starting Remount Root and Kernel File Systems...
         Starting Apply Kernel Variables...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Finished     7.222894] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
1;39mApply Kernel Variables.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Starting Load/Save Random Seed...
         Starting Create System Users...
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Set up automount mnt-sdcard.automount.
         Starting Helper to synchronize boot up for ifupdown...
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Helper to synchronize boot up for ifupdown.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    9.965697] Driver for 1-wire Dallas network protocol.
[   10.078114] gpio-68 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   10.184603] gpio-11 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[  OK  ] Found device /dev/ttymxc0.
[   10.661979] fec 20b4000.ethernet eth1: renamed from ethFEC0
[   11.338571] fec 2188000.ethernet eth0: renamed from ethFEC1
[   11.425347] imx_usb 2184000.usb: No over current polarity defined
[   11.516523] ci_hdrc ci_hdrc.0: EHCI Host Controller
[   11.521476] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[   11.653918] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[   11.706177] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   11.714532] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.721762] usb usb1: Product: EHCI Host Controller
[   11.726695] usb usb1: Manufacturer: Linux 5.10.35-wb133 ehci_hcd
[   11.732710] usb usb1: SerialNumber: ci_hdrc.0
[   12.014156] hub 1-0:1.0: USB hub found
[   12.053952] hub 1-0:1.0: 1 port detected
[   12.141107] ci_hdrc ci_hdrc.1: EHCI Host Controller
[   12.197526] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[   12.313975] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[   12.359938] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   12.368326] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.375596] usb usb2: Product: EHCI Host Controller
[   12.380483] usb usb2: Manufacturer: Linux 5.10.35-wb133 ehci_hcd
[   12.386513] usb usb2: SerialNumber: ci_hdrc.1
[   12.463957] usb usb1-port1: over-current condition
[   12.692823] hub 2-0:1.0: USB hub found
[   12.728913] hub 2-0:1.0: 1 port detected
[   13.113894] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[   13.364666] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[   13.372896] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   13.544766] hub 2-1:1.0: USB hub found
[   13.599245] hub 2-1:1.0: 4 ports detected
[   13.983929] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[   14.205630] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[   14.214081] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   14.221428] usb 2-1.1: Product: 802.11n WLAN Adapter
[   14.226438] usb 2-1.1: Manufacturer: Realtek
[   14.230715] usb 2-1.1: SerialNumber: 00e04c000001
[  OK  ] Found device /dev/mmcblk0p6.
[   14.838749] Bluetooth: Core ver 2.22
[   14.842502] NET: Registered protocol family 31
[   14.847045] Bluetooth: HCI device and connection manager initialized
[   14.887382] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.904581] Bluetooth: HCI socket layer initialized
[   14.914781] Bluetooth: L2CAP socket layer initialized
[   14.919910] Bluetooth: SCO socket layer initialized
[  OK  ] Found device /dev/mmcblk0p5.
[   15.027105] usbcore: registered new interface driver btusb
[   15.040161] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[   15.058042] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   15.064152] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[   15.074232] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[   15.080750] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[   15.090057] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[   15.129525] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.176157] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Activating swap /dev/mmcblk0p5...
         Starting File System Check on /dev/mmcblk0p6...
         Starting Load/Save RF Kill Switch Status...
[   15.724140] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SS
[   15.843954] RTL871X: module init start
[   15.847731] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[  OK  ] Activated swap /dev/mmcblk0p5.
[  OK  ] Reached target Swap.
[   15.928129] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[   16.087414] RTL871X: rtw_ndev_init(wlan0)
[   16.111646] RTL871X: rtw_ndev_init(wlan1)
[  OK  ] Finished    16.146821] usbcore: registered new interface driver rtl8723bu
1;39mFile System Check on /dev/mm[   16.153114] RTL871X: module init ret=0
cblk0p6.
         Mounting /mnt/data...
[   16.331432] usbcore: registered new interface driver rtl8xxxu
[   16.349507] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /mnt/data.
         Mounting /var/log...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Mounted /var/log.
[  OK  ] Reached target Local File Systems.
         Starting Flush Journal to Persistent Storage...
         Starting prepare mounts and symlinks to config files...
[   17.191365] systemd-journald[122]: Received client request to flush runtime journal.
[   17.215184] systemd-journald[122]: File /var/log/journal/6771c66afdf948568d038da82d613623/system.journal corrupted or uncleanly shut down, renaming and replacing.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished prepare mounts and symlinks to config files.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Monitor directorie… templates for wb-mqtt-serial.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on fcgiwrap Socket.
[  OK  ] Listening on KNX Daemon (socket).
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Bluetooth service...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
         Starting Remove Stale Onli…t4 Metadata Check Snapshots...
         Starting Authorization Manager...
         Starting User Login Management...
[  OK  ] Started watch config files.
         Starting Initialize Wiren Board Device Tree overlays...
[  OK  ] Started Generates wb-mqtt-… UI schema for wb-mqtt-confed.
[   19.892115] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.897540] Bluetooth: BNEP filters: protocol multicast
         Starting Avahi mDNS/DNS-SD Stack...
[   19.956343] Bluetooth: BNEP socket layer initialized
         Starting WPA supplicant...
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth.
[  OK  ] Started Authorization Manager.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started WPA supplicant.
         Starting Modem Manager...
         Starting Hostname Service...
[  OK  ] Started User Login Management.
[  OK  ] Started Hostname Service.
[  OK  ] Started Modem Manager.
[  OK  ] Started Network Manager.
         Starting Network Manager Wait Online...
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Started Network Manager Script Dispatcher Service.
[   28.904088] SMSC LAN8710/LAN8720 20b4000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=20b4000.ethernet-1:00, irq=POLL)
[   29.304085] SMSC LAN8710/LAN8720 20b4000.ethernet-1:01: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=20b4000.ethernet-1:01, irq=POLL)
.p0_mpdgctrl0   = 0x0110010d
.p0_mpwrdlctl   = 0x3f3f3833
.p0_mpwldectrl0 = 0x000d000d
.p0_mpwldectrl1 = 0x000e000e
CPU:   Industrial temperature grade (-40C to 105C) at 51C
Reset cause: POR
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=3
upgrade_available=0
No ethernet found.
при попытке сброса прошивки с флешки (контрольную сумму проверил) после начала пересборки вываливается в ребут опять (логи будут в следующем сообщении)
логи при попытке сброса поршивки через флешку:
Reset cause: WDOG
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=3
upgrade_available=0
Net:   eth0: ethernet@2188000
Hit any key to stop autoboot:  1
.p0_mpdgctrl0   = 0x0114010b
.p0_mpwrdlctl   = 0x3f3f3835
CPU:   Industrial temperature grade (-40C to 105C) at 49C
Reset cause: POR
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=3
upgrade_available=0
No ethernet found.
starting USB...
scanning bus usb@2184000 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
  Device 0: Vendor: SanDisk Rev: 1.00 Prod: Cruzer Blade
            Type: Removable Hard Disk
            Capacity: 29358.0 MB = 28.6 GB (60125184 x 512)
Failed to load 'wb6_update.fit'
1 bytes read in 12 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x82000100 ...
Can't find subimage 'ubootenv'
Extracting kernel
7937936 bytes read in 516 ms (14.7 MiB/s)
     Description:  Update kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x82000300
     Data Size:    7928976 Bytes = 7.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   47f6419e0d5d8326c41b16761827dc3d746fec78
## Verifying ... sha1+
   Loading part 0 ... OK
Extracting DTB
## Loading FIT header to 0x83000000 ...
## Loading FIT strings to 0x83000028 ...
## Loading FIT struct to 0x83000100 ...
55849 bytes read in 65 ms (838.9 KiB/s)
     Description:  Update DTB
     Type:         Flat Device Tree
     Data Start:   0x83000480
     Data Size:    46505 Bytes = 45.4 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   ef9dd3fe2b348fb8eb9f150b9dc2e27d6899e823
Kernel image @ 0x82000000 [ 0x000000 - 0x78fc90 ]
   Loading Device Tree to bef8c000, end bef9a5a8 ... OK
Starting kernel ...
[    0.000000] Linux version 4.9.22-wb6_initramfs (root@WB-buildserver) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #2 SMP Tue Feb 1 16:52:01 MSK 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] OF: fdt:Machine model: Wiren Board init (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 14 pages/cpu @ef7cf000 s25932 r8192 d23220 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: console=ttymxc0,115200 bootmode=usbupdate,wb6_update_FACTORYRESET.fit
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1026552K/1048576K available (5120K kernel code, 202K rwdata, 1576K rodata, 5120K init, 295K bss, 22024K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
[    0.000000]     modules : 0xaf000000 - 0xb0000000   (  16 MB)
[    0.000000]       .text : 0xb0008000 - 0xb0600000   (6112 kB)
[    0.000000]       .init : 0xb0800000 - 0xb0d00000   (5120 kB)
[    0.000000]       .data : 0xb0d00000 - 0xb0d32880   ( 203 kB)
[    0.000000]        .bss : 0xb0d34000 - 0xb0d7ddb0   ( 296 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000056] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002616] Console: colour dummy device 80x30
[    0.002658] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002692] pid_max: default: 32768 minimum: 301
[    0.002876] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002903] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.004154] CPU: Testing write buffer coherency: ok
[    0.004657] /cpus/cpu@0 missing clock-frequency property
[    0.004698] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004756] Setting up static identity map for 0x80100000 - 0x80100070
[    0.007171] Brought up 1 CPUs
[    0.007206] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.007223] CPU: All CPU(s) started in SVC mode.
[    0.008543] devtmpfs: initialized
[    0.035034] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.035722] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.035773] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.035950] pinctrl core: initialized pinctrl subsystem
[    0.038000] NET: Registered protocol family 16
[    0.038521] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.041252] cpuidle: using governor menu
[    0.077013] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.077045] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.079271] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.119834] mxs-dma 1804000.dma-apbh: initialized
[    0.124353] SCSI subsystem initialized
[    0.124970] usbcore: registered new interface driver usbfs
[    0.125131] usbcore: registered new interface driver hub
[    0.125381] usbcore: registered new device driver usb
[    0.127032] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[    0.127887] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[    0.128748] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[    0.130256] i2c i2c-1: IMX I2C adapter registered
[    0.130302] i2c i2c-1: can't use DMA, using PIO instead.
[    0.130717] pps_core: LinuxPPS API ver. 1 registered
[    0.130742] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130798] PTP clock support registered
[    0.133210] clocksource: Switched to clocksource mxc_timer1
[    0.157442] NET: Registered protocol family 2
[    0.158650] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.158855] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.159149] TCP: Hash tables configured (established 8192 bind 8192)
[    0.159291] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.159375] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.159716] NET: Registered protocol family 1
[    0.160567] RPC: Registered named UNIX socket transport module.
[    0.160600] RPC: Registered udp transport module.
[    0.160616] RPC: Registered tcp transport module.
[    0.160629] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.734351] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[    0.749332] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.751400] ntfs: driver 2.1.32 [Flags: R/W].
[    0.761851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.761888] io scheduler noop registered (default)
[    0.767443] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.767485] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.776701] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[    1.331378] console [ttymxc0] enabled
[    1.336980] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[    1.347292] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
[    1.390105] imx_rngc 2284000.rngb: Freescale RNGC registered.
[    1.425328] brd: module loaded
[    1.444391] loop: module loaded
[    1.452403] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.464015] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.471548] libphy: Fixed MDIO Bus: probed
[    1.478096] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.486135] pps pps0: new PPS source ptp0
[    1.519423] libphy: fec_enet_mii_bus: probed
[    1.525700] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.653311] 2188000.ethernet supply phy not found, using dummy regulator
[    1.774264] pps pps1: new PPS source ptp1
[    1.779332] libphy: fec_enet_mii_bus: probed
[    1.786458] fec 2188000.ethernet eth1: registered PHC device 1
[    1.792874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.799578] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.805399] usbcore: registered new interface driver cdc_acm
[    1.811096] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.819464] usbcore: registered new interface driver usb-storage
[    1.870266] rtc rtc0: invalid alarm value: 2023-7-4 40:4:0
[    1.876405] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[    1.892421] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[    1.901652] i2c /dev entries driver
[    1.909888] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[    1.917414] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_SD1_DATA1 already requested by watchdog; cannot claim for watchdog_6x
[    1.928967] imx6ul-pinctrl 20e0000.iomuxc: pin-114 (watchdog_6x) status -22
[    1.936025] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 114 (MX6UL_PAD_SD1_DATA1) from group wdggrp_6x  on device 20e0000.iomuxc
[    1.948444] gpio-wdt watchdog_6x: Error applying setting, reverse things back
[    1.955675] gpio-wdt: probe of watchdog_6x failed with error -22
[    1.963543] sdhci: Secure Digital Host Controller Interface driver
[    1.969769] sdhci: Copyright(c) Pierre Ossman
[    1.974223] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.043281] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    2.062894] ledtrig-cpu: registered to indicate activity on CPUs
[    2.072898] random: fast init done
[    2.091023] usbcore: registered new interface driver usbhid
[    2.098789] usbhid: USB HID core driver
[    2.113092] NET: Registered protocol family 17
[    2.124107] Registering SWP/SWPB emulation handler
[    2.131171] registered taskstats version 1
[    2.148328] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    2.172806] rtc-pcf8563 4-0051: setting system clock to 2023-06-06 06:58:17 UTC (1686034697)
[    2.181299] of_cfs_init
[    2.183946] of_cfs_init: OK
[    2.198040] vdd3p0: disabling
[    2.201065] vref-3v3: disabling
[    2.206412] usb1_vbus: disabling
[    2.213366] mmc0: new DDR MMC card at address 0001
[    2.224878] Freeing unused kernel memory: 5120K (b0800000 - b0d00000)
[    2.236600] mmcblk0: mmc0:0001 008GB0 7.28 GiB
[    2.253436] mmcblk0boot0: mmc0:0001 008GB0 partition 1 8.00 MiB
[    2.268137] mmcblk0boot1: mmc0:0001 008GB0 partition 2 8.00 MiB
[    2.281478] mmcblk0rpmb: mmc0:0001 008GB0 partition 3 4.00 MiB
mount: mounting none on /dev/pts failed: No such file or directory[    2.294713]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
Boot mode: usbupdate,wb6_update_FACTORYRESET.fit
Board is WB6, loading ci_hdrc_imx module
[    2.548818] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    2.554051] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    2.583268] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    2.588967] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.595829] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.603059] usb usb1: Product: EHCI Host Controller
[    2.607994] usb usb1: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[    2.614658] usb usb1: SerialNumber: ci_hdrc.0
[    2.620496] hub 1-0:1.0: USB hub found
[    2.624498] hub 1-0:1.0: 1 port detected
[    2.629992] 2184200.usb supply vbus not found, using dummy regulator
[    2.640701] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.645798] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    2.673302] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.679087] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.685966] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.693252] usb usb2: Product: EHCI Host Controller
[    2.698149] usb usb2: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[    2.704843] usb usb2: SerialNumber: ci_hdrc.1
[    2.710629] hub 2-0:1.0: USB hub found
[    2.714633] hub 2-0:1.0: 1 port detected
[    3.073376] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[    3.264180] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[    3.271006] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.278443] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    3.288087] hub 2-1:1.0: USB hub found
[    3.292195] hub 2-1:1.0: 4 ports detected
[    3.485153] usb 1-1: New USB device found, idVendor=0781, idProduct=5567
[    3.491981] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.499349] usb 1-1: Product: Cruzer Blade
[    3.503590] usb 1-1: Manufacturer: SanDisk
[    3.507736] usb 1-1: SerialNumber: 04008506090722145745
[    3.516125] usb-storage 1-1:1.0: USB Mass Storage device detected
[    3.524513] scsi host0: usb-storage 1-1:1.0
[    3.623390] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[    3.775761] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[    3.782770] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.790304] usb 2-1.1: Product: 802.11n WLAN Adapter
[    3.795407] usb 2-1.1: Manufacturer: Realtek
[    3.799730] usb 2-1.1: SerialNumber: 00e04c000001
Load modules for USB to work
Starting USB update
Waiting for USB to settle (0/10)
[    4.565872] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
[    4.578447] sd 0:0:0:0: [sda] 60125184 512-byte logical blocks: (30.8 GB/28.7 GiB)
[    4.590408] sd 0:0:0:0: [sda] Write Protect is off
[    4.597149] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    4.628131]  sda: sda1
[    4.638730] sd 0:0:0:0: [sda] Attached SCSI removable disk
umount: can't umount /usb: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda
mount: mounting /dev/sda on /usb failed: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda1
[    5.147120] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
BusyBox v1.22.1 (Debian 1:1.22.0-19+deb9u2) built-in shell (ash)
Enter 'help' for a list of built-in commands.
                          FACTORY RESET REQUESTED
           This WILL destroy ALL YOUR DATA: configuration, scripts,
                           files in home directory!
         If you are ABSOLUTELY SURE that you want to reset Wiren Board
             to factory condition, hold the FW button for 4 seconds.
        If you will not do it in 10 seconds, the controller will reboot
                        without firmware update.
           If you want to perform a regular firmware update, rename
         FIT file to "wbX_update.fit" without "factory-reset" suffix.
ooo....
Factory reset is confirmed!
Tue Jun  6 06:58:33 UTC 2023: started update from /usb/wb6_update_FACTORYRESET.fit
Description:         WirenBoard firmware update
Compatible device:   contactless,imx6ul-wirenboard670
Firmware version:    202304211143
Firmware compatible: unknown
Release name:        wb-2304
Release suite:       stable
Release target:      wb6/bullseye
Release repo prefix:
Time of creation:    Fri Apr 21 11:46:11 UTC 2023
>>> Checking SHA1 hash of install
PROGRESS: 0%
>>> SHA1 hash of install ok
>>> Wiping data partition (factory reset)
mke2fs 1.43.4 (31-Jan-2017)
ext2fs_check_if_mount: Can't check if filesystem is mounted due to missing mtab file while determining whether /dev/mmcblk0p6 is mounted.
Discarding device blocks: [   19.751427] random: crng init done
done
Creating filesystem with 1314048 4k blocks and 328656 inodes
Filesystem UUID: 872c2326-591c-4fd0-aca6-cf4fdd28ce58
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
>>> Extracting install script
>>> Running install script
>>> Checking SHA1 hash of rootfs
PROGRESS: 29%[ ▒        ▒▒▒▒▒▒͉1-1: USB disco
.p0_mprddlctl   = 0x3f3f3c40
.p0_mpwldectrl0 = 0x000f000f
CPU:   Industrial temperature grade (-40C to 105C) at 53C
Reset cause: POR
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=3
upgrade_available=0
глобально, после ремонта стал доступен процесс подтверждения сброса (когда нужно зажать кнопку на 4 секунды). но все равно вылетает в процессе
Псоле ремонта (сброса factory reset) по сути контроллер проверялся.
От чего питаете контроллер? Что к нему (сейчас) подключено?
Весьма похоже на перезапуск под нагрузкой. Попробуйте сменить блок питания на другой.
БП - HDR 60-24
его нужно поменять для первого запуска или на постоянной основе? щит скоммутирован под использование этого блока для контроллера и всех реле. что-то не так с ним? до инцидента все работало в такой же конфигурации.
Тем не менее - попробуйте запистать контроллер отдругого, для проверки.
подключил контроллер к альтернативному блоку питания (12В) с отключенными соединениями RS-485. загрузка прошла. но контроллер постоянно уходит в ребут:
[  OK  ] Started KNX Daemon.
[ INFO ] Skipped dnsmasq - A lightw…t DHCP and caching DNS server.
[ INFO ] Skipped Access point and a…server for Wi-Fi and Ethernet.
[FAILED] Failed to start OpenBSD Secure Shell server.
See 'systemctl status ssh.service' for details.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Reached target Network is Online.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started Getty on tty1.
         Starting LSB: Brings up/down network automatically...
         Starting A high performanc… and a reverse proxy server...
[  OK  ] Started Serial Getty on ttymxc0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Stopped OpenBSD Secure Shell server.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started Wiren Board MQTT KNX bridge.
[   63.364544] process '/usr/sbin/netplugd' started with executable stack
[  OK  ] Started Mosquitto MQTT Broker.
[  OK  ] Started Wiren Board modbus devices manager.
[  OK  ] Started one-click diagnost… generating archive with data.
[  OK  ] Started Wiren Board configuration editor backend.
[  OK  ] Started Wiren Board database logger.
[  OK  ] Started Wiren Board journald to MQTT gateway.
         Starting Wiren Board MQTT to Modbus TCP gateway...
[  OK  ] Started metrics sender..
         Starting Wiren Board MQTT to OPC UA gateway...
[  OK  ] Started MQTT Rule engine for Wiren Board.
[  OK  ] Started Wiren Board firmware update service.
Debian GNU/Linux 11 wirenboard-A5ZXZ7OF ttymxc0
wirenboard-A5ZXZ7OF login: root
Password:
cat: /var/lib/wirenboard/short_sn.conf: No such file or directory
          _                _                         _
__      _(_)_ __ ___ _ __ | |__   ___   __ _ _ __ __| |
\ \ /\ / / | '__/ _ \ '_ \| '_ \ / _ \ / _` | '__/ _` |
 \ V  V /| | | |  __/ | | | |_) | (_) | (_| | | | (_| |
  \_/\_/ |_|_|  \___|_| |_|_.__/ \___/ \__,_|_|  \__,_|
Welcome to Wiren Board 6.9.1 (s/n ), release wb-2304 (as stable)
Linux wirenboard-A5ZXZ7OF 5.10.35-wb133 #1 Tue Feb 21 08:07:14 UTC 2023 armv7l GNU/Linux
System load:   12.46 3.86 1.35  Up time:       1 min
Memory usage:  14% of 0.98G     Usage of /:    64% of 976M      /mnt/data:     1% of 4.9G
Last login: Wed Jun  7 09:17:20 UTC 2023 on ttymxc0
root@wirenboard-A5ZXZ7OF:~#
root@wirenboard-A5ZXZ7OF:~# top
top - 09:20:46 up 2 min,  1 user,  load average: 9.50, 3.86, 1.42
Tasks: 102 total,   1 running, 101 sleeping,   0 stopped,   0 zombie
%Cpu(s): 88.9 us, 11.1 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   1002.0 total,    675.4 free,    153.1 used,    173.5 buff/cache
MiB Swap:    256.0 total,    256.0 free,      0.0 used.    834.5 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 2005 root      20   0  855084  72704  11552 S  68.2   7.1   0:05.56 wb-mqtt-c+
 2057 root      20   0  910864  20804  11204 S   6.6   2.0   0:05.21 wb-rules
  434 root      20   0   53716  12624  10352 S   4.3   1.2   0:04.98 NetworkMa+
  263 message+  20   0    6412   3336   2576 S   2.6   0.3   0:03.90 dbus-daem+
 3447 root      20   0    9268   2664   2180 R   1.0   0.3   0:00.15 top
 2285 root      20   0   60184   5408   4728 S   0.7   0.5   0:00.24 wb-mqtt-o+
 3245 root      20   0   59824   5156   4548 S   0.7   0.5   0:00.24 wb-mqtt-a+
    3 root      20   0       0      0      0 I   0.3   0.0   0:00.24 kworker/0+
    8 root      20   0       0      0      0 S   0.3   0.0   0:00.80 ksoftirqd+
   96 root       0 -20       0      0      0 I   0.3   0.0   0:00.42 kworker/0+
  122 root      20   0   26860  11088  10320 S   0.3   1.1   0:03.02 systemd-j+
 1442 root      20   0       0      0      0 I   0.3   0.0   0:00.05 kworker/u+
 1691 root      20   0   79568   8492   6000 S   0.3   0.8   0:02.07 wb-mqtt-s+
 1900 mosquit+  20   0   10520   5892   4748 S   0.3   0.6   0:00.60 mosquitto
 2010 root      20   0   60700   6044   5164 S   0.3   0.6   0:00.69 main
 3361 root      20   0   59952   6248   5552 S   0.3   0.6   0:00.15 wb-mqtt-g+
    1 root      20   0   31128   7304   5488 S   0.0   0.7   0:07.40 systemd
root@wirenboard-A5ZXZ7OF:~# [  146.011044] systemd-journald[122]: Received SIGTERM from PID 3366 (watchdog).
[  147.373739] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[  147.397745] systemd[1]: Detected architecture arm.
[  151.383120] EXT4-fs (mmcblk0p3): re-mounted. Opts:
[  17▒
.p0_mpdgctrl0   = 0x0113010d
.p0_mpwrdlctl   = 0x3f3f3733
CPU:   Industrial temperature grade (-40C to 105C) at 57C
Reset cause: POR
DRAM:  1 GiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=3
upgrade_available=0
No ethernet found.
starting USB...
323 bytes read in 3 ms (104.5 KiB/s)
6304344 bytes read in 270 ms (22.3 MiB/s)
Starting kernel ...
Причина очевидна - не запускается sshd. Рекомендую сразу после входа остановить watchdog для того чтобы избежать перезапуска и установить причину. Возможно - фатально неверные настройки сети.
удалось отключить wd
логи статуса sshd:
root@wirenboard-A5ZXZ7OF:~# systemctl status ssh
● ssh.service - OpenBSD Secure Shell server
     Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: preset: enabled)
     Active: failed (Result: exit-code) since Thu 2023-06-08 07:02:52 UTC; 2min 35s ago
       Docs: man:sshd(8)
             man:sshd_config(5)
    Process: 3187 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=1/FAILURE)
        CPU: 61ms
emd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
emd[1]: ssh.service: Failed with result 'exit-code'.
emd[1]: Failed to start OpenBSD Secure Shell server.
emd[1]: ssh.service: Scheduled restart job, restart counter is at 19.
emd[1]: Stopped OpenBSD Secure Shell server.
emd[1]: ssh.service: Start request repeated too quickly.
конфиги ssh:
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile     %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
но, насколько я понимаю, они же должны были сброситься на дефолтное состояние при сбросе до заводских настроек. как воскресить систему?
А файл разве имеет отличия от дефолтного?
Посмотрите почему не запускается sshd. Причин может быть много, основная - отсутствие сетевых интерфейсов или их совсем некорректная настройка.
Я ничего не менял после сброса до заводских настроек. Но в рамках проверки старта от альтернативного бп сейчас пробую вообще без подключения к сети запускать. Имеет ли это значение?
Как понять, что не так и как это исправить?
Что выводит
ssh-keygen -A
Ну и посмотрите/покажите лог sshd.
И результат его запуска вручную.
после настроек вроде получилось:
root@wirenboard-A5ZXZ7OF:~# ssh-keygen -A
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
root@wirenboard-A5ZXZ7OF:~# systemctl start ssh
     Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: e>
     Active: active (running) since Thu 2023-06-08 11:18:20 UTC; 7s ago
       Docs: man:sshd(8)
             man:sshd_config(5)
    Process: 3805 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS)
   Main PID: 3806 (sshd)
      Tasks: 1 (limit: 2364)
     Memory: 732.0K
        CPU: 244ms
     CGroup: /system.slice/ssh.service
             └─3806 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3805]: /etc/ssh/sshd_config line 30: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3805]: /etc/ssh/sshd_config line 37: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: /etc/ssh/sshd_config line 15: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: /etc/ssh/sshd_config line 18: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: /etc/ssh/sshd_config line 19: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: /etc/ssh/sshd_config line 30: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: /etc/ssh/sshd_config line 37: D>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: Server listening on 0.0.0.0 por>
Jun 08 11:18:20 wirenboard-A5ZXZ7OF sshd[3806]: Server listening on :: port 22.
Jun 08 11:18:20 wirenboard-A5ZXZ7OF systemd[1]: Started OpenBSD Secure Shell se>
 ESC[C
ver
/ssh.service; enabled; vendor preset: enabled)
[3805]: /etc/ssh/sshd_config line 30: Deprecated option RSAAuthentication
[3805]: /etc/ssh/sshd_config line 37: Deprecated option RhostsRSAAuthentication
[3806]: /etc/ssh/sshd_config line 15: Deprecated option UsePrivilegeSeparation
[3806]: /etc/ssh/sshd_config line 18: Deprecated option KeyRegenerationInterval
[3806]: /etc/ssh/sshd_config line 19: Deprecated option ServerKeyBits
[3806]: /etc/ssh/sshd_config line 30: Deprecated option RSAAuthentication
[3806]: /etc/ssh/sshd_config line 37: Deprecated option RhostsRSAAuthentication
[3806]: Server listening on 0.0.0.0 port 22.
emd[1]: Started OpenBSD Secure Shell server.
 ESC[D
       Docs: man:sshd(8)
             man:sshd_config(5)
     Memory: 732.0K
        CPU: 244ms
после этого перезапустил. загрузка прошла удачно. подключил к родному БП, проверил. потом подключил шину и сеть. тоже ок.
но осталась ошибка при загрузке:
нужно ли что-то с этим делать?
пробую подключить устройства, пока неудачно. но продолжаю разбираться.
Это выглядит очень странно, единственное моё предположение: из-за плохого блока питания контроллер был в циклическом ребуте и не смог выполнить действия, которые выполняются при первой загрузке после factory reset.
Попробуйте пожалуйста сделать заново factory reset с другим блоком питания. Вывод из debug usb от начала и до конца выложите пожалуйста здесь.
Но ведь первый запуск после factory reset был в вашей лаборатории. удалось восстановить видимость устройств по обоим последовательным портам. есть предчувствие, что, возможно, все заработало (хотя пока даже дышать на него страшно).
и есть ли какие-либо идеи, почему проблема вообще возникла?
Ну, логов от этого первого запуска у вас не осталось, подробного описания проблемы - тоже. Так что моё предположение остаётся в силе.
