после обновления через флешку wb6.6.0
не могу войти в web и контроллер начал переодически сам перезагружаться
Лог прилагаю
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x01130116
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3b3e
.p0_mpwrdlctl = 0x3f3f3935
.p0_mpwldectrl0 = 0x000d000d
.p0_mpwldectrl1 = 0x000e000e
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Freescale i.MX6ULL rev1.0 900 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 57C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=3
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net: eth0: ethernet@2188000
Hit any key to stop autoboot: 0
## Info: input data size = 4285 = 0x10BD
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices... EHCI timed out on TD - token=0x80008d80
USB device not accepting new address (error=22)
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
322 bytes read in 2 ms (157.2 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
6304344 bytes read in 269 ms (22.4 MiB/s)
MMC read: dev # 1, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard660
46098 bytes read in 6 ms (7.3 MiB/s)
808 bytes read in 4 ms (197.3 KiB/s)
Applying DT overlay wb6-gsm-sim5300e
597 bytes read in 3 ms (194.3 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 4 ms (124 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 3 ms (108.4 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 3 ms (82 KiB/s)
Applying DT overlay temp-commercial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x603258 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef77000, end 9ef99fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb142 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Thu Jul 20 07:59:09 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 6.6.0 (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 489364K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18540K reserved, 16384K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000058] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002744] Console: colour dummy device 80x30
[ 0.002807] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002843] pid_max: default: 32768 minimum: 301
[ 0.003234] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003268] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.004976] CPU: Testing write buffer coherency: ok
[ 0.006210] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.007088] devtmpfs: initialized
[ 0.024534] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.025042] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025087] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.026461] pinctrl core: initialized pinctrl subsystem
[ 0.028449] NET: Registered protocol family 16
[ 0.030657] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.032577] thermal_sys: Registered thermal governor 'step_wise'
[ 0.032849] cpuidle: using governor menu
[ 0.197420] vdd1p1: supplied by regulator-dummy
[ 0.208565] vdd3p0: supplied by regulator-dummy
[ 0.219725] cpu: supplied by regulator-dummy
[ 0.230889] vddsoc: supplied by regulator-dummy
[ 0.567765] No ATAGs?
[ 0.567826] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.567846] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.568421] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[ 0.569033] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[ 0.570538] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[ 0.570578] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.612856] mxs-dma 1804000.dma-apbh: initialized
[ 0.618208] SCSI subsystem initialized
[ 0.618700] usbcore: registered new interface driver usbfs
[ 0.618826] usbcore: registered new interface driver hub
[ 0.618934] usbcore: registered new device driver usb
[ 0.619736] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.619862] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.620802] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[ 0.621556] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.621681] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.622260] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[ 0.622950] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.623075] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.623772] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[ 0.625339] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.625691] i2c i2c-1: IMX I2C adapter registered
[ 0.626436] mc: Linux media interface: v0.10
[ 0.626551] videodev: Linux video capture interface: v2.00
[ 0.626681] pps_core: LinuxPPS API ver. 1 registered
[ 0.626700] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.626752] PTP clock support registered
[ 0.627406] Advanced Linux Sound Architecture Driver Initialized.
[ 0.629505] clocksource: Switched to clocksource mxc_timer1
[ 0.647184] NET: Registered protocol family 2
[ 0.648468] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.648571] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.648676] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.648780] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.648969] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.649022] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.649338] NET: Registered protocol family 1
[ 0.650368] RPC: Registered named UNIX socket transport module.
[ 0.650406] RPC: Registered udp transport module.
[ 0.650423] RPC: Registered tcp transport module.
[ 0.650441] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.651539] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.654345] Initialise system trusted keyrings
[ 0.654799] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.666346] NFS: Registering the id_resolver key type
[ 0.666436] Key type id_resolver registered
[ 0.666455] Key type id_legacy registered
[ 0.904975] Key type asymmetric registered
[ 0.905014] Asymmetric key parser 'x509' registered
[ 0.905141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.905165] io scheduler mq-deadline registered
[ 0.905184] io scheduler kyber registered
[ 0.917029] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.917078] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.921013] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
[ 1.584019] printk: console [ttymxc0] enabled
[ 1.590525] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 58, base_baud = 5000000) is a IMX
[ 1.601110] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 59, base_baud = 5000000) is a IMX
[ 1.644773] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[ 1.652203] random: fast init done
[ 1.656154] random: crng init done
[ 1.696033] brd: module loaded
[ 1.714153] loop: module loaded
[ 1.717649] at24 5-0050: supply vcc not found, using dummy regulator
[ 1.729126] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.736155] at24 6-0050: supply vcc not found, using dummy regulator
[ 1.747504] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.757448] libphy: Fixed MDIO Bus: probed
[ 1.764477] pps pps0: new PPS source ptp0
[ 1.804768] libphy: fec_enet_mii_bus: probed
[ 1.810270] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[ 1.930210] pps pps1: new PPS source ptp1
[ 1.936812] libphy: fec_enet_mii_bus: probed
[ 1.945527] fec 2188000.ethernet ethFEC1: registered PHC device 1
[ 1.952638] PPP generic driver version 2.4.2
[ 1.957314] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.963952] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.969731] usbcore: registered new interface driver usb-storage
[ 1.975989] usbcore: registered new interface driver usbserial_generic
[ 1.982651] usbserial: USB Serial support registered for generic
[ 2.043671] rtc-pcf8563 4-0051: registered as rtc0
[ 2.060396] rtc-pcf8563 4-0051: setting system clock to 2023-08-10T19:34:32 UTC (1691696072)
[ 2.078672] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 2.085200] i2c /dev entries driver
[ 2.092016] lm75 4-0048: supply vs not found, using dummy regulator
[ 2.103620] lm75 4-0048: hwmon0: sensor 'lm75b'
[ 2.223619] sdhci: Secure Digital Host Controller Interface driver
[ 2.229901] sdhci: Copyright(c) Pierre Ossman
[ 2.234273] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.249018] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.256879] usbcore: registered new interface driver usbhid
[ 2.262580] usbhid: USB HID core driver
[ 2.277678] Initializing XFRM netlink socket
[ 2.282129] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[ 2.290917] NET: Registered protocol family 10
[ 2.298020] Segment Routing with IPv6
[ 2.302154] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.310238] NET: Registered protocol family 17
[ 2.315347] Key type dns_resolver registered
[ 2.323820] registered taskstats version 1
[ 2.327957] Loading compiled-in X.509 certificates
[ 2.349249] imx_thermal 20c8000.anatop:tempmon: Commercial CPU temperature grade - max:95C critical:90C passive:85C
[ 2.360949] of_cfs_init
[ 2.363633] of_cfs_init: OK
[ 2.371401] ALSA device list:
[ 2.374451] No soundcards found.
[ 2.378194] Waiting for root device /dev/mmcblk0p3...
[ 2.430851] mmc0: new DDR MMC card at address 0001
[ 2.437946] mmcblk0: mmc0:0001 NCard 7.22 GiB
[ 2.443774] mmcblk0boot0: mmc0:0001 NCard partition 1 4.00 MiB
[ 2.450821] mmcblk0boot1: mmc0:0001 NCard partition 2 4.00 MiB
[ 2.457499] mmcblk0rpmb: mmc0:0001 NCard partition 3 4.00 MiB, chardev (245:0)
[ 2.469971] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.507231] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.515804] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 2.523770] devtmpfs: mounted
[ 2.530180] Freeing unused kernel memory: 1024K
[ 2.535993] Run /sbin/init as init process
[ 2.941023] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.966372] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 11 (bullseye)!
[ 3.010833] systemd[1]: Set hostname to <wirenboard-AYJOBSNL>.
[ 4.515591] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.530658] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.574213] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 4.612353] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.657008] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ 4.702416] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.741992] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 4.780726] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 4.822795] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 4.837036] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 4.880555] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.920107] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.952874] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 4.992374] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.056072] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 5.066654] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.101549] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.153291] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.193200] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.231842] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.250923] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.303358] systemd[1]: Mounting /sys/kernel/config...
[ 5.355505] systemd[1]: Mounting Kernel Debug File System...
[ 5.400591] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 5.422043] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 5.476386] systemd[1]: Starting Load Kernel Module drm...
[ 5.526217] systemd[1]: Starting Load Kernel Module fuse...
[ 5.573416] fuse: init (API version 7.32)
[ 5.594778] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.610609] systemd[1]: Starting File System Check on Root Device...
[ 5.652800] systemd[1]: Starting Journal Service...
[ 5.712722] systemd[1]: Starting Load Kernel Modules...
[ 5.764252] systemd[1]: Starting Coldplug All udev Devices...
[ 5.857960] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File Sy[ 5.915998] systemd[1]: Mounted /sys/kernel/config.
stem.
[ OK ] Mounted /sys/kernel/config.
[ 5.960957] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 5.991474] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ OK ] Finished Create list of st… nodes for the current kernel.
[ 6.095317] systemd[1]: modprobe@drm.service: Succeeded.
[ 6.120002] systemd[1]: Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module drm.
[ 6.142586] systemd[1]: modprobe@fuse.service: Succeeded.
[ 6.160060] systemd[1]: Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Module fuse.
[ 6.192867] systemd[1]: Finished File System Check on Root Device.
[ OK ] Finished File System Check on Root Device.
[ 6.212953] systemd[1]: Finished Load Kernel Modules.
[ OK ] Finished Load Kernel Modules.
[ 6.282837] systemd[1]: Mounting FUSE Control File System...
[ 6.340339] systemd[1]: Started File System Check Daemon to report status.
[ OK ] Started File System Check Daemon to report status.
[ 6.415970] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.505713] systemd[1]: Starting Apply Kernel Variables...
[ 6.574685] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ 6.620007] EXT4-fs (mmcblk0p3): re-mounted. Opts: discard,errors=remount-ro
[ OK ] Mounted FUSE Control File System.
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Finished Apply Kernel Variables.
Starting Load/Save Random Seed...
Starting Create System Users...
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Set up automount mnt-sdcard.automount.
Starting Helper to synchronize boot up for ifupdown...
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ 9.189157] Driver for 1-wire Dallas network protocol.
[ 9.230088] gpio-11 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 9.310774] gpio-108 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 9.775198] fec 20b4000.ethernet eth1: renamed from ethFEC0
[ OK ] Found device /dev/ttymxc0.
[ 10.693555] imx_usb 2184000.usb: No over current polarity defined
[ 10.743085] fec 2188000.ethernet eth0: renamed from ethFEC1
[ 10.812397] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 10.817346] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 10.979655] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 11.029809] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 11.038098] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.045375] usb usb1: Product: EHCI Host Controller
[ 11.050284] usb usb1: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[ 11.056313] usb usb1: SerialNumber: ci_hdrc.0
[ 11.386626] hub 1-0:1.0: USB hub found
[ 11.436352] hub 1-0:1.0: 1 port detected
[ 11.504611] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 11.559670] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 11.689655] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 11.729731] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 11.738019] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.745305] usb usb2: Product: EHCI Host Controller
[ 11.750207] usb usb2: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[ 11.756219] usb usb2: SerialNumber: ci_hdrc.1
[ 11.819677] usb usb1-port1: over-current condition
[ 12.000358] hub 2-0:1.0: USB hub found
[ 12.045142] hub 2-0:1.0: 1 port detected
[ 12.469640] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 12.720292] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 12.728517] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 12.867154] hub 2-1:1.0: USB hub found
[ 12.919625] hub 2-1:1.0: 4 ports detected
[ 13.279610] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 13.451026] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[ 13.459417] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 13.466796] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 13.471790] usb 2-1.1: Manufacturer: Realtek
[ 13.476082] usb 2-1.1: SerialNumber: 00e04c000001
[ OK ] Found device /dev/mmcblk0p5.
[ OK ] Found device /dev/mmcblk0p6.
[ 13.953830] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.965390] Bluetooth: Core ver 2.22
[ 13.975424] NET: Registered protocol family 31
[ 13.979946] Bluetooth: HCI device and connection manager initialized
[ 14.012989] Bluetooth: HCI socket layer initialized
[ 14.030867] Bluetooth: L2CAP socket layer initialized
[ 14.046169] Bluetooth: SCO socket layer initialized
[ 14.131573] usbcore: registered new interface driver btusb
[ 14.141559] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.151715] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 14.162982] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 14.169059] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 14.177815] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 14.184416] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 14.193703] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 14.219923] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Activating swap /dev/mmcblk0p5...
Starting File System Check on /dev/mmcblk0p6...
Starting Load/Save RF Kill Switch Status...
[ 15.018875] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 15.040640] Adding 262140k swap on /dev/mmcblk0p5. Priority:-2 extents:1 across:262140k SSDsc
[ 15.168475] RTL871X: module init start
[ 15.172293] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ OK ] Activated swap /dev/mmcblk0p5.
[ OK ] Finished File System Check on /dev/mmcblk0p6.
[ OK ] Reached target Swap.
Mounting /mnt/data...
[ 15.405606] RTL871X: rtw_ndev_init(wlan0)
[ 15.426811] RTL871X: rtw_ndev_init(wlan1)
[ 15.444321] usbcore: registered new interface driver rtl8723bu
[ 15.450257] RTL871X: module init ret=0
[ 15.584049] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: discard
[ 15.594327] usbcore: registered new interface driver rtl8xxxu
[ OK ] Mounted /mnt/data.
Mounting /var/log...
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Mounted /var/log.
[ OK ] Finished Helper to synchronize boot up for ifupdown.
[ OK ] Reached target Local File Systems.
[ OK ] Started ifup for eth1.
Starting Flush Journal to Persistent Storage...
Starting prepare mounts and symlinks to config files...
[ 16.555737] systemd-journald[121]: Received client request to flush runtime journal.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished prepare mounts and symlinks to config files.
Starting Create Volatile Files and Directories...
[ OK ] Finished Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started Monitor directorie… templates for wb-mqtt-serial.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on fcgiwrap Socket.
[ OK ] Listening on KNX Daemon (socket).
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Bluetooth service...
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager...
Starting Remove Stale Onli…t4 Metadata Check Snapshots...
Starting Authorization Manager...
Starting User Login Management...
[ OK ] Started watch config files.
Starting Initialize Wiren Board Device Tree overlays...
[ OK ] Started Generates wb-mqtt-… UI schema for wb-mqtt-confed.
[ 20.544821] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.550224] Bluetooth: BNEP filters: protocol multicast
Starting Avahi mDNS/DNS-SD Stack...
Starting WPA su[ 20.693598] Bluetooth: BNEP socket layer initialized
pplicant...
[ OK ] Started Bluetooth service.
[ OK ] Started Authorization Manager.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Bluetooth.
Starting Modem Manager...
Starting Hostname Service...
[ OK ] Started User Login Management.
[ OK ] Started Modem Manager.
[ OK ] Started Hostname Service.
[ 28.492440] Micrel KSZ8081 or KSZ8091 2188000.ethernet-2:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet-2:03, irq=POLL)
[ 42.798412] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 224, base_baud = 5000000) is a IMX
[ OK ] Finished Initialize Wiren Board Device Tree overlays.
Starting Raise network interfaces...
Starting Power on GSM modem...
Starting KNXD Configurator for Wiren Board...
[ 47.029622] usb 2-1.2: new high-speed USB device number 4 using ci_hdrc
[ 47.211332] usb 2-1.2: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[ 47.275599] usb 2-1.2: New USB device found, idVendor=058b, idProduct=0041, bcdDevice= 0.00
[ 47.284040] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 47.629567] usbcore: registered new interface driver cdc_acm
[ 47.635253] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[*** ] (4 of 5) A start job is running for Network Manager (43s / 1min 45s)
[** ] (4 of 5) A start job is running for Network Manager (44s / 1min 45s)
[ 48.869666] usb 2-1.2: new high-speed USB device number 5 using ci_hdrc
[ 49.073964] usb 2-1.2: New USB device found, idVendor=8087, idProduct=07ed, bcdDevice= 1.00
[ 49.082415] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber[* ] (5 of 5) A start job is running for…etwork interfaces (44s / 5min 41s)
[** ] (5 of 5) A start job is running for…etwork interfaces (45s / 5min 41s)
[ 49.969834] SMSC LAN8710/LAN8720 2188000.ethernet-2:00: attached PHY driver [[ INFO ] Skipped Power on GSM modem.
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ 52.089941] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 52.097923] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ **] (2 of 3) A start job is running for Network Manager (49s / 1min 45s)
[ 54.459631] usb 2-1.2: new high-speed USB device number 6 using ci_hdrc
[ 54.622418] usb 2-1.2: New USB device found, idVendor=1e0e, idProduct=0020, bcdDevice=17.30
[ 54.630902] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 54.638272] usb 2-1.2: Product: SIMCOM_PRODUCT
[ 54.642785] usb 2-1.2: Manufacturer: SIMCOM_VENDOR
[ *] (2 of 3) A start job is running for Network Manager (50s / 1min 45s)
[ 54.745488] cdc_acm 2-1.2:1.0: ttyACM0: USB ACM device
[ 54.769913] cdc_acm 2-1.2:1.2: ttyACM1: USB ACM device
[ 54.796949] cdc_acm 2-1.2:1.4: ttyACM2: USB ACM device
[ 54.823466] cdc_acm 2-1.2:1.6: ttyACM3: USB ACM device
[ 54.846162] cdc_acm 2-1.2:1.8: ttyACM4: USB ACM device
[ 54.873807] cdc_acm 2-1.2:1.10: ttyACM5: USB ACM device
[ OK ] Finished Raise network interfaces.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Network Manager Wait Online...
Starting dnsmasq - A light…DHCP and caching DNS server...
Starting Access point and …rver for Wi-Fi and Ethernet...
Starting KNX Daemon...
Starting Mosquitto MQTT Broker...
Starting Network Time Service...
Starting OpenBSD Secure Shell server...
Starting Permit User Sessions...
[ OK ] Started Network connection…rvice for Wiren Board devices.
Starting MQTT Driver for ADC...
Starting MQTT Driver for GPIO-controlled switches...
[ OK ] Started MQTT Driver for serial devices.
[ OK ] Started Kernel 1-Wire MQTT driver for WB-HomA.
[ OK ] Started KNX Daemon.
[ OK ] Finished KNXD Configurator for Wiren Board.
[ OK ] Started Network Time Service.
[FAILED] Failed to start OpenBSD Secure Shell server.
