FACTORY RESET REQUESTED
This WILL destroy ALL YOUR DATA: configuration, scripts,
files in home directory!
If you are ABSOLUTELY SURE that you want to reset Wiren Board
to factory condition, hold the FW button for 4 seconds.
If you will not do it in 10 seconds, the controller will reboot
without firmware update.
If you want to perform a regular firmware update, rename
FIT file to "wbX_update.fit" without "factory-reset" suffix.
ooo....
Factory reset is confirmed!
Tue Oct 6 13:57:44 UTC 2020: started update from /usb/wb6_update_FACTORYRESET.fit
Description: WirenBoard firmware update
Compatible device: contactless,imx6ul-wirenboard61
Firmware version: 202010060602
Firmware compatible: unknown
Time of creation: Tue Oct 6 06:04:23 UTC 2020
>>> Checking SHA1 hash of install
PROGRESS: 0%
>>> SHA1 hash of install ok
>>> Wiping data partition (factory reset)
mke2fs 1.43.4 (31-Jan-2017)
ext2fs_check_if_mount: Can't check if filesystem is mounted due to missing mtab file while determining whether /dev/mmcblk0p6 is mounted.
Discarding device blocks: [ 17.313583] random: crng init done
done
Creating filesystem with 331008 4k blocks and 82896 inodes
Filesystem UUID: 954bb860-5d24-42a3-ac33-b102206a0bb5
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
>>> Extracting install script
>>> Running install script
>>> Checking SHA1 hash of rootfs
PROGRESS: 100%
>>> SHA1 hash of rootfs ok
>>> Installing firmware update
>>> Getting mmcpart from U-Boot environment
>>> Will install to /dev/mmcblk0p3
>>> Check if partition table is correct
!!! rootfs partition doesn't exist, looks like partitions table is broken. Give up.
[ 63.988177] usb 1-1: USB disconnect, device number 2
U-Boot 2017.03-1.0.1-gf543a623ed (Mar 14 2019 - 14:32:12 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 44C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
EEPROM #0 MAC: 80:1f:12:48:b5:67
EEPROM #1 MAC: 80:1f:12:48:b1:fb
Net: No ethernet found.
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
323 bytes read in 59 ms (4.9 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
5127128 bytes read in 341 ms (14.3 MiB/s)
MMC read: dev # 0, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard65
44232 bytes read in 413 ms (104.5 KiB/s)
485 bytes read in 140 ms (2.9 KiB/s)
Applying DT overlay wb6-nogsm
597 bytes read in 134 ms (3.9 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 162 ms (2.9 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 101 ms (2.9 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 115 ms (2 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x4e3bd8 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef33000, end 9ef55fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb6 (root@wbdevenv) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #2 SMP Tue Sep 1 06:27:21 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board rev. 6.5 (i.MX6UL/ULL)
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @defc8000 s25996 r8192 d23156 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait ro
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 491720K/524288K available (6144K kernel code, 312K rwdata, 2276K rodata, 1024K init, 342K bss, 16184K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
[ 0.000000] .data : 0xc0b00000 - 0xc0b4e140 ( 313 kB)
[ 0.000000] .bss : 0xc0b50000 - 0xc0ba5aec ( 343 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000055] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002552] Console: colour dummy device 80x30
[ 0.002594] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002627] pid_max: default: 32768 minimum: 301
[ 0.002899] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002924] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004404] CPU: Testing write buffer coherency: ok
[ 0.004974] /cpus/cpu@0 missing clock-frequency property
[ 0.005015] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005071] Setting up static identity map for 0x80100000 - 0x80100070
[ 0.007701] Brought up 1 CPUs
[ 0.007733] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.007750] CPU: All CPU(s) started in SVC mode.
[ 0.009208] devtmpfs: initialized
[ 0.035534] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.036312] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.036361] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.037749] pinctrl core: initialized pinctrl subsystem
[ 0.040037] NET: Registered protocol family 16
[ 0.042215] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.045088] cpuidle: using governor menu
[ 0.079214] No ATAGs?
[ 0.079268] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.079290] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.081666] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.127659] mxs-dma 1804000.dma-apbh: initialized
[ 0.132445] SCSI subsystem initialized
[ 0.133063] usbcore: registered new interface driver usbfs
[ 0.133219] usbcore: registered new interface driver hub
[ 0.133502] usbcore: registered new device driver usb
[ 0.135197] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[ 0.136130] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[ 0.137002] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[ 0.138387] i2c i2c-1: IMX I2C adapter registered
[ 0.138431] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.138776] Linux video capture interface: v2.00
[ 0.138934] pps_core: LinuxPPS API ver. 1 registered
[ 0.138953] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.139007] PTP clock support registered
[ 0.139731] Advanced Linux Sound Architecture Driver Initialized.
[ 0.142389] clocksource: Switched to clocksource mxc_timer1
[ 0.168051] NET: Registered protocol family 2
[ 0.169330] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.169456] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.169612] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.169734] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.169790] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.170100] NET: Registered protocol family 1
[ 0.171029] RPC: Registered named UNIX socket transport module.
[ 0.171061] RPC: Registered udp transport module.
[ 0.171077] RPC: Registered tcp transport module.
[ 0.171092] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.176034] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.195595] NFS: Registering the id_resolver key type
[ 0.195668] Key type id_resolver registered
[ 0.195687] Key type id_legacy registered
[ 0.206686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.206719] io scheduler noop registered (default)
[ 0.206738] io scheduler deadline registered
[ 0.206816] io scheduler cfq registered
[ 0.213493] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.213537] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.222992] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 0.801642] console [ttymxc0] enabled
[ 0.807274] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[ 0.850625] imx_rngc 2284000.rngb: Freescale RNGC registered.
[ 0.856762] [drm] Initialized
[ 0.896844] brd: module loaded
[ 0.916451] loop: module loaded
[ 0.924690] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 0.936090] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 0.946974] libphy: Fixed MDIO Bus: probed
[ 0.953628] 20b4000.ethernet supply phy not found, using dummy regulator
[ 0.961650] pps pps0: new PPS source ptp0
[ 0.996023] libphy: fec_enet_mii_bus: probed
[ 1.001691] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.122539] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.243530] pps pps1: new PPS source ptp1
[ 1.248802] libphy: fec_enet_mii_bus: probed
[ 1.256948] fec 2188000.ethernet eth1: registered PHC device 1
[ 1.263509] PPP generic driver version 2.4.2
[ 1.268335] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.275020] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.280882] usbcore: registered new interface driver usb-storage
[ 1.287521] usbcore: registered new interface driver usbserial
[ 1.293666] usbcore: registered new interface driver usbserial_generic
[ 1.300327] usbserial: USB Serial support registered for generic
[ 1.307049] mousedev: PS/2 mouse device common for all mice
[ 1.370918] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.387144] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.396264] i2c /dev entries driver
[ 1.409765] lm75 4-0048: hwmon0: sensor 'lm75b'
[ 1.530225] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.538574] sdhci: Secure Digital Host Controller Interface driver
[ 1.544907] sdhci: Copyright(c) Pierre Ossman
[ 1.549295] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.622472] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 1.642040] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.666698] usbcore: registered new interface driver usbhid
[ 1.674457] usbhid: USB HID core driver
[ 1.700454] NET: Registered protocol family 10
[ 1.707765] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.715617] NET: Registered protocol family 17
[ 1.720275] Key type dns_resolver registered
[ 1.729688] Registering SWP/SWPB emulation handler
[ 1.736701] registered taskstats version 1
[ 1.760214] random: fast init done
[ 1.767180] mmc0: new DDR MMC card at address 0001
[ 1.774287] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 1.785278] mmcblk0: mmc0:0001 W62704 3.53 GiB
[ 1.790266] mmcblk0boot0: mmc0:0001 W62704 partition 1 2.00 MiB
[ 1.809124] rtc-pcf8563 4-0051: setting system clock to 2020-10-06 13:58:55 UTC (1601992735)
[ 1.817619] of_cfs_init
[ 1.820428] mmcblk0boot1: mmc0:0001 W62704 partition 2 2.00 MiB
[ 1.826954] mmcblk0rpmb: mmc0:0001 W62704 partition 3 512 KiB
[ 1.835967] of_cfs_init: OK
[ 1.844496] mmcblk0: p1 p2 p4 < p5 p6 >
[ 1.850807] vdd3p0: disabling
[ 1.855761] vref-3v3: disabling
[ 1.858935] usb1_vbus: disabling
[ 1.862176] ALSA device list:
[ 1.865250] No soundcards found.
[ 1.869752] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.878698] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.888285] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.895716] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.967804] EXT4-fs (mmcblk0p2): recovery complete
[ 1.973920] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.982092] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.989775] devtmpfs: mounted
[ 1.994217] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[ 2.232206] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.268388] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.288486] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[ 2.323371] systemd[1]: Set hostname to <wirenboard-ADGVBSQC>.
[ 2.957701] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 2.993160] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.023037] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.053050] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.094446] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.133576] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.173360] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice System Slice.
Mounting POSIX Message Queue File System...
Starting Create list of required st…ce nodes for the current kernel...
Mounting Debug File System...
[ OK ] Created slice system-getty.slice.
Starting Load Kernel Modules...
[ OK ] Created slice system-systemd\x2dfsck.slice.
Mounting /sys/kernel/config...
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting File System Check on Root Device...
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Reached target Paths.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted /sys/kernel/config.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started File System Check on Root Device.
[ OK ] Started File System Check Daemon to report status.
Starting Remount Root and Kernel File Systems...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ 4.145901] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Load/Save Random Seed.
[ 4.496252] systemd-journald[147]: Received request to flush runtime journal from PID 1
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ 6.052824] lirc_dev: IR Remote Control driver registered, major 245
[ 6.093992] Driver for 1-wire Dallas network protocol.
[ 6.112806] lirc_pwm: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.199183] lirc_pwm lirc-rfm69: GPIO receiver on pin 77
[ 6.257844] lirc_pwm lirc-rfm69: lirc_dev: driver lirc-rfm69 registered at minor = 0
[ 6.316700] lirc_pwm lirc-rfm69: probed
[ OK ] Found device /dev/ttymxc0.
[ 6.528880] fec 20b4000.ethernet rename2: renamed from eth0
[ 6.927065] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 6.932020] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 6.944564] fec 2188000.ethernet eth0: renamed from eth1
[ 6.991177] fec 20b4000.ethernet eth1: renamed from rename2
[ 7.082563] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 7.132827] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.139642] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.146986] usb usb1: Product: EHCI Host Controller
[ 7.151877] usb usb1: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 7.157663] usb usb1: SerialNumber: ci_hdrc.0
[ 7.450766] hub 1-0:1.0: USB hub found
[ 7.468214] hub 1-0:1.0: 1 port detected
[ 7.516988] 2184200.usb supply vbus not found, using dummy regulator
[ 7.607612] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 7.687824] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ OK ] Found device /dev/mmcblk0p5.
[ 7.792545] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 7.832255] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.839212] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.846505] usb usb2: Product: EHCI Host Controller
[ 7.851393] usb usb2: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 7.857196] usb usb2: SerialNumber: ci_hdrc.1
[ OK ] Found device /dev/mmcblk0p6.
[ 8.070481] hub 2-0:1.0: USB hub found
[ 8.136375] hub 2-0:1.0: 1 port detected
[ 8.522550] usb 2-1: new high-speed USB device number 2 using ci_hdrc
Starting File System Check on /dev/mmcblk0p6...
Activating swap /dev/mmcblk0p5...
[ 8.649603] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
[ OK ] Activated swap /dev/mmcblk0p5.
[ 8.745353] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 8.752129] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ OK ] Reached target Swap.
[ 8.764967] hub 2-1:1.0: USB hub found
[ 8.774320] hub 2-1:1.0: 4 ports detected
[ OK ] Started File System Check on /dev/mmcblk0p6.
Mounting /mnt/data...
[ 8.933866] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Mounted /mnt/data.
Starting prepare mounts and symlinks to config files...
[ 9.112593] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 9.274270] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 9.281203] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.288673] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 9.293691] usb 2-1.1: Manufacturer: Realtek
[ 9.297970] usb 2-1.1: SerialNumber: 00e04c000001
[ 9.477666] Bluetooth: Core ver 2.22
[ OK ] Listening on L[ 9.505202] NET: Registered protocol family 31
oad/Save RF Kill Switch Status /d[ 9.510409] Bluetooth: HCI device and connection manager initialized
ev/rfkill Watch.
[ 9.556955] Bluetooth: HCI socket layer initialized
[ 9.575155] Bluetooth: L2CAP socket layer initialized
[ 9.591952] Bluetooth: SCO socket layer initialized
[ 9.662303] usbcore: registered new interface driver btusb
[ 9.679879] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 9.688672] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 9.698070] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 9.707386] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 9.713964] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 9.722845] Bluetooth: hci0: rom_version status=0 version=1
[ 9.728502] Bluetooth: cfg_sz 0, total size 22496
Starting Load/Save RF Kill Switch Status...
[ OK ] Started Load/Save RF Kill Switch Status.
[ 10.106099] 8723bu: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.151436] RTL871X: module init start
[ 10.155380] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 10.162419] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 10.408233] RTL871X: rtw_ndev_init(wlan0)
[ 10.423587] RTL871X: rtw_ndev_init(wlan1)
[ 10.446756] usbcore: registered new interface driver rtl8723bu
[ 10.452752] RTL871X: module init ret=0
[ OK ] Found device 802.11n_WLAN_Adapter.
[ OK ] Started ifup for wlan0.
[ 12.100980] RTL871X: RTW_ADAPTIVITY_EN_[ 12.104795] AUTO, chplan:0x20, Regulation:3,3
[ 12.109167] RTL871X: RTW_ADAPTIVITY_MODE_[ 12.113095] NORMAL
[ OK ] Started prepare mounts and symlinks to config files.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ 13.032958] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started watch config files.
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down...
Starting LSB: Kernel 1-wire MQTT driver for WB-HomA...
Starting Avahi mDNS/DNS-SD Stack...
Starting LSB: Hardware configuration with Device Tree overlays...
Starting LSB: prepare partitions & rootfs...
[ OK ] Started Node-RED graphical event wiring tool.
[ OK ] Started Regular background program processing daemon.
[ OK ] Started Cgroup management daemon.
Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
Starting LSB: Starts syslogd...
Starting Bluetooth service...
[ OK ] Started D-Bus System Message Bus.
[ 13.918409] cgroup: new mount options do not match the existing superblock, will be ignored
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Blueto[ 14.347408] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
oth service.
[ 14.355670] Bluetooth: BNEP filters: protocol multicast
[ OK ] Reached target Bluetooth.
Starting Login Service...
[ 14.392608] Bluetooth: BNEP socket layer initialized
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started Mosquitto MQTT v3.1/v3.1.1 Broker.
[ OK ] Started LSB: Kernel 1-wire MQTT driver for WB-HomA.
[ 15.045348] RTL871X: nolinked power save enter
[ OK ] Started LSB: Starts syslogd.
[ OK ] Started Login Service.
Starting LSB: Starts klogd...
Starting Hostname Service...
Starting LSB: MQTT driver for WB HomA for RFM69 ISM radio...
Starting LSB: MQTT Driver for ADC...
Starting LSB: Configuration Editor Backend...
Starting LSB: : Wiren Board MQTT to Modbus TCP gateway...
Starting LSB: Firmware update monitor...
Starting LSB: : Wiren Board database logger...
[ OK ] Started Hostname Service.
[ OK ] Started LSB: Configuration Editor Backend.
[ OK ] Started LSB: Firmware update monitor.
[ OK ] Started LSB: : Wiren Board database logger.
[ OK ] Started LSB: Starts klogd.
[ 22.872492] random: crng init done
[ 23.013270] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 217, base_baud = 5000000) is a IMX
[ OK ] Started LSB: : Wiren Board MQTT to Modbus TCP gateway.
[ OK ] Started LSB: Hardware configuration with Device Tree overlays.
Starting LSB: MQTT Driver for serial devices...
Starting LSB: MQTT Rule Engine for Wiren Board...
Starting LSB: MQTT Driver for GPIO-controlled switches...
[ OK ] Started LSB: MQTT Driver for serial devices.
[ OK ] Started LSB: MQTT Rule Engine for Wiren Board.
[ OK ] Started LSB: prepare partitions & rootfs.
Starting LSB: initscript to use GSM modem integrated RTC...
[ OK ] Started LSB: MQTT Driver for ADC.
[ OK ] Started LSB: initscript to use GSM modem integrated RTC.
Starting Raise network interfaces...
[ OK ] Started Raise network interfaces.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server...
[ OK ] Reached target Network is Online.
Starting LSB: Brings up/down network automatically...
Starting LSB: Advanced IEEE 802.11 management daemon...
Starting LSB: Start NTP daemon...
Starting A high performance web server and a reverse proxy server...
Starting dnsmasq - A lightweight DHCP and caching DNS server...
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started OpenBSD Secure Shell server.
[ 38.352809] SMSC LAN8710/LAN8720 2188000.ethernet:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ OK ] Started LSB: Start NTP daemon.
[ 38.499651] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started LSB: MQTT driver for WB HomA for RFM69 ISM radio.
Starting LSB: board-specific initscript...
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: board-specific initscript.
[ 41.181080] RTL871X: RTW_ADAPTIVITY_EN_[ 41.184896] AUTO, chplan:0x20, Regulation:3,3
[ 41.189290] RTL871X: RTW_ADAPTIVITY_MODE_[ 41.193198] NORMAL
[ 42.765651] RTL871X: nolinked power save leave
[ 43.113280] Micrel KSZ8081 or KSZ8091 2188000.ethernet:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet:03, irq=-1)
[ 43.148420] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 43.448711] RTL871X: assoc success
[ 43.452240] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started dnsmasq - A lightweight DHCP and caching DNS server.
[ OK ] Reached target Host and Network Name Lookups.
Debian GNU/Linux 9 wirenboard-ADGVBSQC ttymxc0
wirenboard-ADGVBSQC login: root
Password:
Linux wirenboard-ADGVBSQC 4.9.22-wb6 #2 SMP Tue Sep 1 06:27:21 UTC 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@wirenboard-ADGVBSQC:~#
