Wirenboard 6.7.2 проблемы после обновления прошивки
после обновления прошивки (через веб интерфейс) Wirenboard 6.7.2
Пропал доступ к устройству.
Не зайти через браузер.
информация через DedugConsole
  • Логин root, пароль wirenboard - воспринимаются некорректно.
wirenboard-AKIZE3TV login: root
Password:
Login incorrect
U-Boot SPL 2021.10-wb1.5.0-gf1b9e03284 (Apr 05 2023 - 14:31:04 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0   = 0x01150111
.p0_mpdgctrl1   = 0x0e3f0e3f
.p0_mprddlctl   = 0x3f3f3d3f
.p0_mpwrdlctl   = 0x3f3f3936
.p0_mpwldectrl0 = 0x000b000b
.p0_mpwldectrl1 = 0x000c000c
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.5.0-gf1b9e03284 (Apr 05 2023 - 14:31:04 +0000)
CPU:   Freescale i.MX6ULL rev1.0 900 MHz (running at 396 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 64C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM:  512 MiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=2
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net:   eth0: ethernet@2188000
Hit any key to stop autoboot:  0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices...
.p0_mpdgctrl0   = 0x01150112
.p0_mprddlctl   = 0x3f3f3d40
.p0_mpwrdlctl   = 0x3f3f3a36
CPU:   Commercial temperature grade (0C to 95C) at 60C
Reset cause: POR
DRAM:  512 MiB
MMC:   FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
scanning bus usb@2184200 for devices... EHCI timed out on TD - token=0x80008d80
      USB device not accepting new address (error=22)
       scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
323 bytes read in 3 ms (104.5 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
5899184 bytes read in 252 ms (22.3 MiB/s)
MMC read: dev # 1, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard670
46734 bytes read in 6 ms (7.4 MiB/s)
485 bytes read in 4 ms (118.2 KiB/s)
Applying DT overlay wb6-nogsm
225 bytes read in 4 ms (54.7 KiB/s)
Applying DT overlay wb6-nowifi
229 bytes read in 5 ms (43.9 KiB/s)
Applying DT overlay wb6-nobluetooth
509 bytes read in 5 ms (98.6 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 4 ms (81.1 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 4 ms (61.5 KiB/s)
Applying DT overlay temp-commercial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x5a03b0 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Loading Device Tree to 9ef78000, end 9ef9afff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.35-wb116 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516, GNU ld (GNU Binutils for Debian) 2.28) #1 Wed Jul 6 16:10:09 UTC 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Wiren Board rev. 6.7.0 (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait ro
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 489388K/524288K available (8192K kernel code, 714K rwdata, 2680K rodata, 1024K init, 272K bss, 18516K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x238/0x3d4 with crng_init=0
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000062] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.002821] Console: colour dummy device 80x30
[    0.002886] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.002926] pid_max: default: 32768 minimum: 301
[    0.003351] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003387] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.004975] CPU: Testing write buffer coherency: ok
[    0.006067] Setting up static identity map for 0x80100000 - 0x80100078
[    0.006941] devtmpfs: initialized
[    0.025124] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.025641] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.025688] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.027060] pinctrl core: initialized pinctrl subsystem
[    0.029098] NET: Registered protocol family 16
[    0.031444] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.033485] thermal_sys: Registered thermal governor 'step_wise'
[    0.033776] cpuidle: using governor menu
[    0.228908] vdd1p1: supplied by regulator-dummy
[    0.241388] vdd3p0: supplied by regulator-dummy
[    0.253899] cpu: supplied by regulator-dummy
[    0.266388] vddsoc: supplied by regulator-dummy
[    0.623870] No ATAGs?
[    0.623933] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.623960] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.624610] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[    0.625259] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[    0.626706] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[    0.626748] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.667864] mxs-dma 1804000.dma-apbh: initialized
[    0.673162] SCSI subsystem initialized
[    0.673779] usbcore: registered new interface driver usbfs
[    0.673911] usbcore: registered new interface driver hub
[    0.674025] usbcore: registered new device driver usb
[    0.674856] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.675013] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.675981] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[    0.676737] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.676869] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.677468] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[    0.678170] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.678301] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.678898] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[    0.680470] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    0.680852] i2c i2c-1: IMX I2C adapter registered
[    0.681587] mc: Linux media interface: v0.10
[    0.681703] videodev: Linux video capture interface: v2.00
[    0.681842] pps_core: LinuxPPS API ver. 1 registered
[    0.681864] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.681928] PTP clock support registered
[    0.682561] Advanced Linux Sound Architecture Driver Initialized.
[    0.684783] clocksource: Switched to clocksource mxc_timer1
[    0.702726] NET: Registered protocol family 2
[    0.703892] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.704003] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.704119] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.704226] TCP: Hash tables configured (established 4096 bind 4096)
[    0.704429] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.704485] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.704984] NET: Registered protocol family 1
[    0.705961] RPC: Registered named UNIX socket transport module.
[    0.705998] RPC: Registered udp transport module.
[    0.706019] RPC: Registered tcp transport module.
[    0.706037] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.707237] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.710147] Initialise system trusted keyrings
[    0.710599] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.722401] NFS: Registering the id_resolver key type
[    0.722482] Key type id_resolver registered
[    0.722504] Key type id_legacy registered
[    0.723422] Key type asymmetric registered
[    0.723462] Asymmetric key parser 'x509' registered
[    0.723562] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.723588] io scheduler mq-deadline registered
[    0.723609] io scheduler kyber registered
[    0.735912] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.735961] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.739914] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[    1.402720] printk: console [ttymxc0] enabled
[    1.409237] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.453073] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[    1.460512] random: fast init done
[    1.464451] random: crng init done
[    1.504077] brd: module loaded
[    1.522043] loop: module loaded
[    1.525653] at24 5-0050: supply vcc not found, using dummy regulator
[    1.537130] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.544113] at24 6-0050: supply vcc not found, using dummy regulator
[    1.555524] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.568024] libphy: Fixed MDIO Bus: probed
[    1.575211] pps pps0: new PPS source ptp0
[    1.615575] libphy: fec_enet_mii_bus: probed
[    1.620860] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[    1.745509] pps pps1: new PPS source ptp1
[    1.752104] libphy: fec_enet_mii_bus: probed
[    1.760896] fec 2188000.ethernet ethFEC1: registered PHC device 1
[    1.768008] PPP generic driver version 2.4.2
[    1.772730] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.779381] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.785151] usbcore: registered new interface driver usb-storage
[    1.791408] usbcore: registered new interface driver usbserial_generic
[    1.798127] usbserial: USB Serial support registered for generic
[    1.847206] rtc rtc0: invalid alarm value: 2023-06-12T33:79:00
[    1.853474] rtc-pcf8563 4-0051: registered as rtc0
[    1.870258] rtc-pcf8563 4-0051: setting system clock to 2023-06-08T11:32:48 UTC (1686223968)
[    1.888661] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[    1.895214] i2c /dev entries driver
[    1.902011] lm75 4-0048: supply vs not found, using dummy regulator
[    1.913630] lm75 4-0048: hwmon0: sensor 'lm75b'
[    2.033915] sdhci: Secure Digital Host Controller Interface driver
[    2.040200] sdhci: Copyright(c) Pierre Ossman
[    2.044573] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.058585] ledtrig-cpu: registered to indicate activity on CPUs
[    2.066474] usbcore: registered new interface driver usbhid
[    2.072076] usbhid: USB HID core driver
[    2.088633] NET: Registered protocol family 10
[    2.093217] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[    2.103210] Segment Routing with IPv6
[    2.107762] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.115813] NET: Registered protocol family 17
[    2.120591] Key type dns_resolver registered
[    2.129360] registered taskstats version 1
[    2.133541] Loading compiled-in X.509 certificates
[    2.154165] imx_thermal 20c8000.anatop:tempmon: Commercial CPU temperature grade - max:95C critical:90C passive:85C
[    2.165759] of_cfs_init
[    2.168478] of_cfs_init: OK
[    2.176224] ALSA device list:
[    2.179214]   No soundcards found.
[    2.182915] Waiting for root device /dev/mmcblk0p2...
[    2.219256] mmc0: new DDR MMC card at address 0001
[    2.225247] mmcblk0: mmc0:0001 NCard  7.22 GiB
[    2.230246] mmcblk0boot0: mmc0:0001 NCard  partition 1 4.00 MiB
[    2.236769] mmcblk0boot1: mmc0:0001 NCard  partition 2 4.00 MiB
[    2.243149] mmcblk0rpmb: mmc0:0001 NCard  partition 3 4.00 MiB, chardev (245:0)
[    2.254145]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.282128] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.289535] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    2.385154] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    2.395136] EXT4-fs (mmcblk0p2): 1 truncate cleaned up
[    2.400332] EXT4-fs (mmcblk0p2): recovery complete
[    2.411792] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.420026] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.427748] devtmpfs: mounted
[    2.431909] Freeing unused kernel memory: 1024K
[    2.436772] Run /sbin/init as init process
[    2.769543] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.788387] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[    2.829182] systemd[1]: Set hostname to <wirenboard-AKIZE3TV>.
[    3.358952] systemd[1]: [/lib/systemd/system/wb-mqtt-w1.service:10] Unknown lvalue 'StartLimitIntervalSec' in section 'Service'
[    3.436379] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[    3.476332] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    3.505464] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.535910] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.601419] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.635443] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Created slice System Slice.
         Mounting /sys/kernel/config...
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Listening on Journal Socket.
         Starting Journal Service...
         Starting Load Kernel Modules...
         Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
         Mounting POSIX Message Queue File System...
         Mounting Debug File System...
[  OK  ] Listening on udev Control Socket.
         Starting File System Check on Root Device...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted /sys/kernel/config.
[  OK  ] Started Journal Service.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started File System Check on Root Device.
[  OK  ] Started File System Check Daemon to report status.
         Starting Remount Root and Kernel File Systems...
         Starting Create Static Device Nodes in /dev...
[    4.592818] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
         Starting Apply Kernel Variables...
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
         Starting udev Kernel Device Manager...
         Starting prepare partitions at first boot...
         Starting udev Coldplug all Devices...
         Starting Load/Save Random Seed...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started prepare partitions at first boot.
[  OK  ] Reached target Local File Systems (Pre).
[    6.356499] Driver for 1-wire Dallas network protocol.
[    6.385478] gpio-68 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[  OK  ] Started udev Coldplug all Devices.
[    6.445814] gpio-11 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[  OK  ] Found device /dev/ttymxc0.
[    6.743650] fec 20b4000.ethernet eth1: renamed from ethFEC0
[    7.048931] fec 2188000.ethernet eth0: renamed from ethFEC1
[    7.096490] imx_usb 2184000.usb: No over current polarity defined
[    7.139433] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    7.144382] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    7.284894] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    7.339038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.347384] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.354613] usb usb1: Product: EHCI Host Controller
[    7.359534] usb usb1: Manufacturer: Linux 5.10.35-wb116 ehci_hcd
[    7.365574] usb usb1: SerialNumber: ci_hdrc.0
[    7.655547] hub 1-0:1.0: USB hub found
[    7.680429] hub 1-0:1.0: 1 port detected
[    7.724898] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    7.729847] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    7.814894] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[  OK  ] Found device /dev/mmcblk0p5.
[    7.836979] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.845347] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.852577] usb usb2: Product: EHCI Host Controller
[    7.857500] usb usb2: Manufacturer: Linux 5.10.35-wb116 ehci_hcd
[    7.863512] usb usb2: SerialNumber: ci_hdrc.1
[  OK  ] Found device /dev/mmcblk0p6.
[    8.054966] usb usb1-port1: over-current condition
[    8.074420] hub 2-0:1.0: USB hub found
[    8.105006] hub 2-0:1.0: 1 port detected
         Starting File System Check on /dev/mmcblk0p6...
         Activating swap /dev/mmcblk0p5...
[    8.385325] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SS
[    8.494884] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[  OK  ] Activated swap /dev/mmcblk0p5.
[  OK  ] Reached target Swap.
[    8.725683] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    8.733924] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    8.751613] hub 2-1:1.0: USB hub found
[    8.757768] hub 2-1:1.0: 4 ports detected
[  OK  ] Started File System Check on /dev/mmcblk0p6.
         Mounting /mnt/data...
[    9.247563] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /mnt/data.
         Mounting /var/log...
[  OK  ] Mounted /var/log.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Reached target Local File Systems.
         Starting prepare mounts and symlinks to config files...
[    9.536451] systemd-journald[98]: Received request to flush runtime journal from PID 1
[    9.570157] systemd-journald[98]: File /var/log/journal/e086f4cd4bfd2cb73f47e64863515954/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    9.704892] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[  OK  ] Started Flush Journal to Persistent Storage.
[    9.932834] usb 1-1: New USB device found, idVendor=8564, idProduct=1000, bcdDevice= 1.00
[    9.941116] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    9.948310] usb 1-1: Product: Mass Storage Device
[    9.953020] usb 1-1: Manufacturer: JetFlash
[    9.957226] usb 1-1: SerialNumber: R9EMMLAN
[    9.997980] usb-storage 1-1:1.0: USB Mass Storage device detected
[   10.022612] scsi host0: usb-storage 1-1:1.0
[  OK  ] Started prepare mounts and symlinks to config files.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Reached target System Time Synchronized.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on KNX Daemon (socket).
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Timers.
[  OK  ] Started Monitor directories with device templates for wb-mqtt-serial.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Basic System.
[   11.047800] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 16GB   8.07 PQ: 0 ANSI: 4
[   11.075268] sd 0:0:0:0: [sda] 31358976 512-byte logical blocks: (16.1 GB/15.0 GiB)
         Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
[   11.109293] sd 0:0:0:0: [sda] Write Protect is off
         Starting System Logging Service...
[   11.148206] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
         Starting Restore local date from Wiren Board GSM RTC...
[   11.209470]  sda: sda1
[  OK  ] Started watch config files.
[   11.251854] sd 0:0:0:0: [sda] Attached SCSI removable disk
         Starting Initialize Wiren Board Device Tree overlays...
         Starting Restore /etc/resolv.conf i…fore the ppp link was shut down...
[  OK  ] Started D-Bus System Message Bus.
         Starting Login Service...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started Cgroup management daemon.
         Starting initialize filesystems at first boot...
[  OK  ] Started Generates wb-mqtt-serial UI schema for wb-mqtt-confed.
[   12.096573] new mount options do not match the existing superblock, will be ignored
[  OK  ] Started System Logging Service.
[FAILED] Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
See 'systemctl status mosquitto.service' for details.
[DEPEND] Dependency failed for MQTT Rule engine for Wiren Board.
[  OK  ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[  OK  ] Started Login Service.
[  OK  ] Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
[  OK  ] Started initialize filesystems at first boot.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting Wiren Board MQTT to OPC UA gateway...
[  OK  ] Started Wiren Board firmware update service.
         Starting Wiren Board MQTT to Modbus TCP gateway...
[  OK  ] Started Wiren Board configuration editor backend.
[FAILED] Failed to start Wiren Board MQTT to OPC UA gateway.
See 'systemctl status wb-mqtt-opcua.service' for details.
[  OK  ] Stopped Wiren Board MQTT to OPC UA gateway.
[FAILED] Failed to start Wiren Board MQTT to Modbus TCP gateway.
See 'systemctl status wb-mqtt-mbgate.service' for details.
[  OK  ] Stopped Wiren Board MQTT to Modbus TCP gateway.
[  OK  ] Started Restore local date from Wiren Board GSM RTC.
[   25.635674] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 224, base_baud = 5000000) is a IMX
[  OK  ] Stopped Wiren Board configuration editor backend.
[  OK  ] Started Initialize Wiren Board Device Tree overlays.
         Starting KNXD Configurator for Wiren Board...
         Starting Raise network interfaces...
[  OK  ] Started one-click diagnostic data c…ard, generating archive with data.
[  OK  ] Started metrics sender..
[  OK  ] Started Raise network interfaces.
[  OK  ] Reached target Network.
         Starting MQTT Driver for ADC...
[  OK  ] Started MQTT Driver for serial devices.
         Starting A high performance web server and a reverse proxy server...
         Starting KNX Daemon...
         Starting Permit User Sessions...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started Wiren Board journald to MQTT gateway.
[  OK  ] Started Kernel 1-Wire MQTT driver for WB-HomA.
         Starting dnsmasq - A lightweight DHCP and caching DNS server...
[  OK  ] Started Wiren Board database logger.
         Starting MQTT Driver for GPIO-controlled switches...
[  OK  ] Started KNX Daemon.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttymxc0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Reached target Network is Online.
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting LSB: Brings up/down network automatically...
         Starting LSB: Start NTP daemon...
[  OK  ] Started Wiren Board MQTT KNX bridge.
[  OK  ] Started OpenBSD Secure Shell server.
[   35.515578] process '/sbin/netplugd' started with executable stack
[   36.015097] SMSC LAN8710/LAN8720 2188000.ethernet-2:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-2:00, irq=POLL)
[   36.267510] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   36.537667] Micrel KSZ8081 or KSZ8091 2188000.ethernet-2:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet-2:03, irq=POLL)
[   36.779991] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   36.910005] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   37.079285] cfg80211: failed to load regulatory.db
Debian GNU/Linux 9 wirenboard-AKIZE3TV ttymxc0
wirenboard-AKIZE3TV login: [   38.325236] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   38.439920] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Заметил странное поведение WB
Login incorrect
Login timed▒[  OK  ] Stopped Serial Getty on ttymxc0.
[  OK  ] Stopped one-click diagnostic data c…ard, generating archive with data.
[  OK  ] Stopped Wiren Board MQTT KNX bridge.
[  OK  ] Stopped Wiren Board journald to MQTT gateway.
[  OK  ] Stopped Wiren Board database logger.
[  OK  ] Stopped KNX Daemon.
Какой релиз установлен, какой загружался? А зачем, кстати, именно “через веб-интерфейс”?
В каком состоянии интерфейсы контроллера? Чем назначается их адреса?
Какой релиз был установлен - ответить не смогу 2022.хх
Загружался - 202210201437_stable_webupd_wb67.fit
В каком состоянии интерфейсы - визуально работают, ip address от Wi-fi маршрутизатора получить не могут.
Так покажите состояния интерфейсов, логи?
подскажите как мне это сделать?
Я не могу попасть на устройство через DebugConsole (моё первое сообщение) и не могу попасть через браузер (нет IP адреса). По другому я не умею…
Какая кодировка (кодовая страница) на компьютере с которого подключаетесь?
Включите отображение введенных символов для того чтобы точно быть уверенным что нет ошибки.
Видимо я не умею объяснять.
При подлючении через port DebugConsole, я вижу происходящие события, они отображаются корректно.
Логи в первом сообщении.
При вводе пароля WB мне отвечает что мой логин с паролем не подходят.
root
wirenboard
P.s. - данный метод подключения использовался и ранее, проблема возникла после обновления прошивки.
У меня одно предположение - то что пароль был изменен. Но все ж проверьте, правильно ли вводите. Ну и, можно Wiren Board 6 и 7: Восстановление пароля пользователя root — Wiren Board
Перестала работать кнопка FW (не отрабатывает нажатие). До обновления всё было хорошо, физических повреждений нет.
Пароль сбросил на стандартный wirenboard - так и не понял почему он поменялся.
Подскажите как обновить прошивку с полным сбросом через USB накопитель если я не могу нажать клавишу FW, но могу приостановить загрузку и попасть в меню для сброса пароля?
Или альтернативные варианты.
На данный момент могу подключиться только через USB port DebugConsole
добрый день!
Пожалуйста подключите Debug Console и выполните полный сброс через USB строго следуя инструцкии. Если что-то пойдёт не так, то выложите сюда полный вывод из Debug Console с момента первой подачи питания на устройство: обычно по выводу можно понять, в чём дело.
