Mosquitto.service: Failed
Всем привет! Подскажите, как вылечить?
service mosquitto status
● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2020-05-29 10:34:42 UTC; 1min 9s ago
Process: 6193 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
Main PID: 6193 (code=exited, status=3)
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: mosquitto.service: Failed with result ‘exit-code’.
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: mosquitto.service: Service hold-off time over, scheduling restart.
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: mosquitto.service: Start request repeated too quickly.
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
май 29 10:34:42 wirenboard-AMDBZS5J systemd[1]: mosquitto.service: Unit entered failed state.
А что делали перед этим?
Ничего необычного не делал.
ssh выбрасывает client_loop: send disconnect: Broken pipe.
залогинился в итоге
сделал
service mosquitto stop
service watchdog stop
открыл messages
May 29 11:30:52 wirenboard-AMDBZS5J user.notice serial: connection error: Connection refused (111) retry after 6400ms…
May 29 11:30:53 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:54 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:55 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:56 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:49 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:50 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:50 wirenboard-AMDBZS5J user.notice serial: connection error: Connection refused (111) retry after 12800ms…
May 29 11:30:51 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:52 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:55 wirenboard-AMDBZS5J auth.info sshd[3941]: Accepted password for root from 192.168.3.65 port 50508 ssh2
May 29 11:30:55 wirenboard-AMDBZS5J authpriv.info sshd[3941]: pam_unix(sshd:session): session opened for user root by (uid=0)
May 29 11:30:55 wirenboard-AMDBZS5J authpriv.info systemd: pam_unix(systemd-user:session): session opened for user root by (uid=0)
May 29 11:30:55 wirenboard-AMDBZS5J auth.info sshd[3972]: lastlog_openseek: Couldn’t stat /var/log/lastlog: No such file or directory
May 29 11:30:57 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:58 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:30:59 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:31:00 wirenboard-AMDBZS5J daemon.err watchdog[3841]: cannot open /var/run/mosquitto.pid (errno = 2 = ‘No such file or directory’)
May 29 11:31:01 wirenboard-AMDBZS5J daemon.notice watchdog[3841]: stopping daemon (5.15)
May 29 11:31:01 wirenboard-AMDBZS5J daemon.notice wd_keepalive[4042]: starting watchdog keepalive daemon (5.15):
May 29 11:31:01 wirenboard-AMDBZS5J daemon.info wd_keepalive[4042]: int=1 alive=/dev/watchdog1 realtime=yes
May 29 11:31:01 wirenboard-AMDBZS5J daemon.info wd_keepalive[4042]: watchdog now set to 60 seconds
May 29 11:31:01 wirenboard-AMDBZS5J daemon.info wd_keepalive[4042]: hardware watchdog identity: GPIO Watchdog
May 29 11:31:01 wirenboard-AMDBZS5J authpriv.info CRON[4045]: pam_unix(cron:session): session opened for user root by (uid=0)
May 29 11:31:01 wirenboard-AMDBZS5J cron.info CRON[4050]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
May 29 11:31:01 wirenboard-AMDBZS5J user.notice wb-daemon-watchdogs: Error: Connection refused
May 29 11:31:03 wirenboard-AMDBZS5J user.notice serial: connection error: Connection refused (111) retry after 25600ms…
May 29 11:31:04 wirenboard-AMDBZS5J user.notice wb-daemon-watchdogs: Error: Connection refused
May 29 11:31:04 wirenboard-AMDBZS5J user.notice wb-daemon-watchdogs: wb-mqtt-confed check failed, reload wb-mqtt-confed
May 29 11:31:05 wirenboard-AMDBZS5J authpriv.info CRON[4045]: pam_unix(cron:session): session closed for user root
May 29 11:31:10 wirenboard-AMDBZS5J auth.info sshd[4126]: Accepted password for root from 192.168.3.65 port 50511 ssh2
May 29 11:31:10 wirenboard-AMDBZS5J authpriv.info sshd[4126]: pam_unix(sshd:session): session opened for user root by (uid=0)
May 29 11:31:29 wirenboard-AMDBZS5J user.notice serial: connection error: Connection refused (111) retry after 30000ms…
May 29 11:31:46 wirenboard-AMDBZS5J daemon.info ntpd[2923]: Soliciting pool server 195.50.171.101
May 29 11:31:46 wirenboard-AMDBZS5J daemon.info ntpd[2923]: Soliciting pool server 213.251.53.217
May 29 11:31:47 wirenboard-AMDBZS5J daemon.info ntpd[2923]: Soliciting pool server 207.34.49.172
А что в dmesg?
Что со свободным местом?
root@wirenboard-AMDBZS5J:~# df -ah
Файловая система Размер Использовано Дост Использовано% Cмонтировано в
/dev/root 976M 666M 244M 74% /
devtmpfs 241M 0 241M 0% /dev
sysfs 0 0 0 - /sys
proc 0 0 0 - /proc
securityfs 0 0 0 - /sys/kernel/security
tmpfs 249M 0 249M 0% /dev/shm
devpts 0 0 0 - /dev/pts
tmpfs 249M 6,8M 243M 3% /run
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
cgroup 0 0 0 - /sys/fs/cgroup/systemd
mqueue 0 0 0 - /dev/mqueue
debugfs 0 0 0 - /sys/kernel/debug
configfs 0 0 0 - /sys/kernel/config
/dev/mmcblk0p6 1,3G 491M 670M 43% /mnt/data
/dev/mmcblk0p6 1,3G 491M 670M 43% /var/log
tmpfs 50M 0 50M 0% /run/user/0
root@wirenboard-AMDBZS5J:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb6 (root@wbdevenv) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #2 SMP Sat Jan 26 11:34:05 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board rev. 6.5 (i.MX6UL/ULL)
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c0b4b100, node_mem_map deb33000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @defc8000 s25932 r8192 d23220 u57344
[ 0.000000] pcpu-alloc: s25932 r8192 d23220 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 492244K/524288K available (6144K kernel code, 302K rwdata, 2264K rodata, 1024K init, 342K bss, 15660K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0a00000 - 0xc0b00000 (1024 kB)
.data : 0xc0b00000 - 0xc0b4b9c0 ( 303 kB)
.bss : 0xc0b4d000 - 0xc0ba282c ( 343 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000052] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002512] Console: colour dummy device 80x30
[ 0.002554] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.002585] pid_max: default: 32768 minimum: 301
[ 0.002785] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002813] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004118] CPU: Testing write buffer coherency: ok
[ 0.004634] /cpus/cpu@0 missing clock-frequency property
[ 0.004674] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004732] Setting up static identity map for 0x80100000 - 0x80100070
[ 0.007133] Brought up 1 CPUs
[ 0.007164] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.007180] CPU: All CPU(s) started in SVC mode.
[ 0.008532] devtmpfs: initialized
[ 0.034928] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.035658] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.035706] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.037029] pinctrl core: initialized pinctrl subsystem
[ 0.039258] NET: Registered protocol family 16
[ 0.041315] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.044146] cpuidle: using governor menu
[ 0.078423] No ATAGs?
[ 0.078477] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.078501] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.080720] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.125568] mxs-dma 1804000.dma-apbh: initialized
[ 0.130150] SCSI subsystem initialized
[ 0.130781] usbcore: registered new interface driver usbfs
[ 0.130945] usbcore: registered new interface driver hub
[ 0.131289] usbcore: registered new device driver usb
[ 0.133033] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[ 0.133922] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[ 0.134810] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[ 0.136156] i2c i2c-1: IMX I2C adapter registered
[ 0.136198] i2c i2c-1: can’t use DMA, using PIO instead.
[ 0.136540] Linux video capture interface: v2.00
[ 0.136695] pps_core: LinuxPPS API ver. 1 registered
[ 0.136714] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.136767] PTP clock support registered
[ 0.137519] Advanced Linux Sound Architecture Driver Initialized.
[ 0.140007] clocksource: Switched to clocksource mxc_timer1
[ 0.164035] NET: Registered protocol family 2
[ 0.165260] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.165384] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.165540] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.165656] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.165712] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.166024] NET: Registered protocol family 1
[ 0.166885] RPC: Registered named UNIX socket transport module.
[ 0.166918] RPC: Registered udp transport module.
[ 0.166932] RPC: Registered tcp transport module.
[ 0.166948] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.171742] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.188363] NFS: Registering the id_resolver key type
[ 0.188431] Key type id_resolver registered
[ 0.188450] Key type id_legacy registered
[ 0.198605] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.198638] io scheduler noop registered (default)
[ 0.198656] io scheduler deadline registered
[ 0.198726] io scheduler cfq registered
[ 0.205425] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.205466] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.214439] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 0.793664] console [ttymxc0] enabled
[ 0.799180] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[ 0.809471] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
[ 0.852822] imx_rngc 2284000.rngb: Freescale RNGC registered.
[ 0.858878] [drm] Initialized
[ 0.897157] brd: module loaded
[ 0.916116] loop: module loaded
[ 0.924371] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 0.935831] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 0.946684] libphy: Fixed MDIO Bus: probed
[ 0.953314] 20b4000.ethernet supply phy not found, using dummy regulator
[ 0.961367] pps pps0: new PPS source ptp0
[ 0.994039] libphy: fec_enet_mii_bus: probed
[ 0.999703] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.120093] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.241124] pps pps1: new PPS source ptp1
[ 1.246362] libphy: fec_enet_mii_bus: probed
[ 1.254352] fec 2188000.ethernet eth1: registered PHC device 1
[ 1.260900] PPP generic driver version 2.4.2
[ 1.265702] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.272387] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.278213] usbcore: registered new interface driver usb-storage
[ 1.284829] usbcore: registered new interface driver usbserial
[ 1.290970] usbcore: registered new interface driver usbserial_generic
[ 1.297624] usbserial: USB Serial support registered for generic
[ 1.304299] mousedev: PS/2 mouse device common for all mice
[ 1.368247] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.384476] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.393590] i2c /dev entries driver
[ 1.406923] lm75 4-0048: hwmon0: sensor ‘lm75b’
[ 1.528207] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.536572] sdhci: Secure Digital Host Controller Interface driver
[ 1.542906] sdhci: Copyright© Pierre Ossman
[ 1.547290] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.620082] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 1.639694] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.664278] usbcore: registered new interface driver usbhid
[ 1.672040] usbhid: USB HID core driver
[ 1.697748] NET: Registered protocol family 10
[ 1.704958] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.712786] NET: Registered protocol family 17
[ 1.717432] Key type dns_resolver registered
[ 1.726687] Registering SWP/SWPB emulation handler
[ 1.733574] registered taskstats version 1
[ 1.757967] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 1.769965] random: fast init done
[ 1.775609] mmc0: new DDR MMC card at address 0001
[ 1.781393] mmcblk0: mmc0:0001 W62704 3.53 GiB
[ 1.798543] rtc-pcf8563 4-0051: setting system clock to 2020-05-29 11:30:03 UTC (1590751803)
[ 1.807038] of_cfs_init
[ 1.809937] mmcblk0boot0: mmc0:0001 W62704 partition 1 2.00 MiB
[ 1.816314] mmcblk0boot1: mmc0:0001 W62704 partition 2 2.00 MiB
[ 1.822707] mmcblk0rpmb: mmc0:0001 W62704 partition 3 512 KiB
[ 1.829129] of_cfs_init: OK
[ 1.836874] vdd3p0: disabling
[ 1.839870] vref-3v3: disabling
[ 1.843564] usb1_vbus: disabling
[ 1.847136] usb2_vbus: disabling
[ 1.850489] ALSA device list:
[ 1.853470] No soundcards found.
[ 1.857647] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.866818] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
[ 1.875734] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
[ 1.890809] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 1.898984] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 1.909714] devtmpfs: mounted
[ 1.914255] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[ 2.132334] ip_tables: © 2000-2006 Netfilter Core Team
[ 2.162581] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.181703] systemd[1]: Detected architecture arm.
[ 2.221005] systemd[1]: Set hostname to .
[ 2.844283] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.880733] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.920576] systemd[1]: Listening on udev Kernel Socket.
[ 2.951186] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.991307] systemd[1]: Created slice User and Session Slice.
[ 3.030793] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.087686] systemd[1]: Listening on udev Control Socket.
[ 4.059281] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
[ 4.412066] systemd-journald[138]: Received request to flush runtime journal from PID 1
[ 5.811171] Driver for 1-wire Dallas network protocol.
[ 5.821119] lirc_dev: IR Remote Control driver registered, major 245
[ 5.877373] lirc_pwm: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.991528] lirc_pwm lirc-rfm69: GPIO receiver on pin 77
[ 6.040305] lirc_pwm lirc-rfm69: lirc_dev: driver lirc-rfm69 registered at minor = 0
[ 6.048075] lirc_pwm lirc-rfm69: probed
[ 6.315427] fec 20b4000.ethernet rename2: renamed from eth0
[ 6.764264] fec 2188000.ethernet eth0: renamed from eth1
[ 6.780128] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 6.822629] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 6.851003] fec 20b4000.ethernet eth1: renamed from rename2
[ 6.930152] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 6.935948] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.942851] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.950123] usb usb1: Product: EHCI Host Controller
[ 6.955009] usb usb1: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 6.960795] usb usb1: SerialNumber: ci_hdrc.0
[ 7.226156] hub 1-0:1.0: USB hub found
[ 7.280286] hub 1-0:1.0: 1 port detected
[ 7.362914] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 7.367864] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 7.530489] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 7.539449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.546404] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.553687] usb usb2: Product: EHCI Host Controller
[ 7.558573] usb usb2: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 7.564357] usb usb2: SerialNumber: ci_hdrc.1
[ 7.810475] hub 2-0:1.0: USB hub found
[ 7.874156] hub 2-0:1.0: 1 port detected
[ 8.270204] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 8.478344] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
[ 8.501155] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 8.507956] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.566620] hub 2-1:1.0: USB hub found
[ 8.578729] hub 2-1:1.0: 4 ports detected
[ 8.744839] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 8.910251] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 9.071888] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 9.078824] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.086287] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 9.091299] usb 2-1.1: Manufacturer: Realtek
[ 9.095577] usb 2-1.1: SerialNumber: 00e04c000001
[ 9.256892] Bluetooth: Core ver 2.22
[ 9.318093] NET: Registered protocol family 31
[ 9.324143] Bluetooth: HCI device and connection manager initialized
[ 9.366785] Bluetooth: HCI socket layer initialized
[ 9.388873] Bluetooth: L2CAP socket layer initialized
[ 9.402833] Bluetooth: SCO socket layer initialized
[ 9.482208] usbcore: registered new interface driver btusb
[ 9.497451] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 9.506247] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 9.521996] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 9.531312] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 9.537853] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 9.550404] Bluetooth: hci0: rom_version status=0 version=1
[ 9.556110] Bluetooth: cfg_sz 0, total size 22496
[ 9.909745] 8723bu: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.948590] RTL871X: module init start
[ 9.952487] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 9.959457] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 10.202153] RTL871X: rtw_ndev_init(wlan0)
[ 10.219870] RTL871X: rtw_ndev_init(wlan1)
[ 10.235494] usbcore: registered new interface driver rtl8723bu
[ 10.241505] RTL871X: module init ret=0
[ 11.363796] cgroup: new mount options do not match the existing superblock, will be ignored
[ 11.804237] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.809579] Bluetooth: BNEP filters: protocol multicast
[ 11.830991] Bluetooth: BNEP socket layer initialized
[ 16.761382] ad5064 1-0031: Failed to get supply ‘vref’: -19
[ 21.611269] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 226, base_baud = 5000000) is a IMX
[ 27.221156] random: crng init done
[ 37.250425] SMSC LAN8710/LAN8720 2188000.ethernet:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ 37.460691] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 40.822849] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 41.296738] RTL871X: RTW_ADAPTIVITY_EN_
[ 41.300555] AUTO, chplan:0x20, Regulation:3,3
[ 41.304930] RTL871X: RTW_ADAPTIVITY_MODE_
[ 41.308796] NORMAL
[ 44.110872] Micrel KSZ8081 or KSZ8091 2188000.ethernet:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet:03, irq=-1)
[ 44.204222] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 44.270561] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 44.278374] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 44.548661] RTL871X: assoc success
[ 44.552330] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
А если просто запустить
что говорит?
root@wirenboard-AMDBZS5J:~# /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
Error: Unknown configuration variable " >#".
Error found at /etc/mosquitto/mosquitto.conf:1.
Error: Unable to open configuration file.
Кажется, кошка своими лапками походила по конфигу и понавставляла случайно пробелов и > :slight_smile:
Спасибо!
Да не за что. :slight_smile: Сам такой же - сделаю ошибку и потом ищу причину.
