Не работает порт USB 1 на контроллере WirenBoard 7.3.3C/5
Один из десяти заказанных контроллеров не видит USB
Повторил действия в теме
Вывод lsusb
root@wirenboard-AYNSSST3:~# lsusb
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0bda:b720 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@wirenboard-AYNSSST3:~# dmesg | grep sda
Также полный вывод dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.35-wb120 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516, GNU ld (GNU Binutils for Debian) 2.28) #1 SMP Fri Sep 2 07:33:43 UTC 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Wiren Board rev. 7.3.3 (A40i)
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 16 MiB at 0x7ec00000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
[    0.000000]   HighMem  [mem 0x0000000070000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 19 pages/cpu s47884 r8192 d21748 u77824
[    0.000000] pcpu-alloc: s47884 r8192 d21748 u77824 alloc=19*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p3 rootwait ro
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1005600K/1048576K available (9216K kernel code, 1429K rwdata, 3096K rodata, 1024K init, 296K bss, 26592K reserved, 16384K cma-reserved, 245748K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 30807 entries in 61 pages
[    0.000000] ftrace: allocated 61 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x680/0x84c with crng_init=0
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000022] Switching to timer-based delay loop, resolution 41ns
[    0.000352] Console: colour dummy device 80x30
[    0.000422] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000683] pid_max: default: 32768 minimum: 301
[    0.001563] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001640] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003473] CPU: Testing write buffer coherency: ok
[    0.004011] /cpus/cpu@0 missing clock-frequency property
[    0.004073] /cpus/cpu@1 missing clock-frequency property
[    0.004130] /cpus/cpu@2 missing clock-frequency property
[    0.004193] /cpus/cpu@3 missing clock-frequency property
[    0.004215] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005323] Setting up static identity map for 0x40100000 - 0x40100060
[    0.005537] rcu: Hierarchical SRCU implementation.
[    0.007664] smp: Bringing up secondary CPUs ...
[    0.019371] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031043] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.042429] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.042652] smp: Brought up 1 node, 4 CPUs
[    0.042698] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.042714] CPU: All CPU(s) started in HYP mode.
[    0.042730] CPU: Virtualization extensions available.
[    0.043768] devtmpfs: initialized
[    0.064513] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.064871] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.064910] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.065942] pinctrl core: initialized pinctrl subsystem
[    0.069197] NET: Registered protocol family 16
[    0.073707] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.075470] thermal_sys: Registered thermal governor 'step_wise'
[    0.076064] No ATAGs?
[    0.076310] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.076331] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.159321] SCSI subsystem initialized
[    0.160188] usbcore: registered new interface driver usbfs
[    0.160344] usbcore: registered new interface driver hub
[    0.160513] usbcore: registered new device driver usb
[    0.161226] mc: Linux media interface: v0.10
[    0.161310] videodev: Linux video capture interface: v2.00
[    0.161418] pps_core: LinuxPPS API ver. 1 registered
[    0.161445] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.161512] PTP clock support registered
[    0.161954] Advanced Linux Sound Architecture Driver Initialized.
[    0.163408] clocksource: Switched to clocksource arch_sys_counter
[    1.341969] NET: Registered protocol family 2
[    1.342938] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.343003] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.343107] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.343242] TCP: Hash tables configured (established 8192 bind 8192)
[    1.343467] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.343546] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.343855] NET: Registered protocol family 1
[    1.346512] RPC: Registered named UNIX socket transport module.
[    1.346550] RPC: Registered udp transport module.
[    1.346573] RPC: Registered tcp transport module.
[    1.346595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.348712] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.352099] Initialise system trusted keyrings
[    1.352505] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.366722] NFS: Registering the id_resolver key type
[    1.366980] Key type id_resolver registered
[    1.367023] Key type id_legacy registered
[    1.368106] Key type asymmetric registered
[    1.368141] Asymmetric key parser 'x509' registered
[    1.368386] bounce: pool size: 64 pages
[    1.368479] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.368506] io scheduler mq-deadline registered
[    1.368529] io scheduler kyber registered
[    1.370006] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    1.511259] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.534380] brd: module loaded
[    1.552077] loop: module loaded
[    1.561722] libphy: Fixed MDIO Bus: probed
[    1.564480] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    1.565587] libphy: sun4i_mii_bus: probed
[    1.568211] CAN device driver interface
[    1.572077] PPP generic driver version 2.4.2
[    1.572397] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.572417] ehci-platform: EHCI generic platform driver
[    1.574602] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.574692] ohci-platform: OHCI generic platform driver
[    1.576666] usbcore: registered new interface driver usb-storage
[    1.576847] usbcore: registered new interface driver usbserial_generic
[    1.576904] usbserial: USB Serial support registered for generic
[    1.580582] sun6i-rtc 1c20400.rtc: registered as rtc1
[    1.580628] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.581320] i2c /dev entries driver
[    1.592159] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.597381] ledtrig-cpu: registered to indicate activity on CPUs
[    1.598400] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[    1.598852] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    1.599442] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    1.599691] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    1.599961] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    1.600142] sun8i-ce 1c15000.crypto: Register cbc(aes)
[    1.600369] sun8i-ce 1c15000.crypto: Register ecb(aes)
[    1.600572] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
[    1.601578] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
[    1.602199] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
[    1.604988] usbcore: registered new interface driver usbhid
[    1.605013] usbhid: USB HID core driver
[    1.609689] iio-rescale a1-volt: using raw+scale source channel
[    1.610205] iio-rescale a2-volt: using raw+scale source channel
[    1.610619] iio-rescale a3-volt: using raw+scale source channel
[    1.610969] iio-rescale vin-volt: using raw+scale source channel
[    1.616698] NET: Registered protocol family 10
[    1.619324] Segment Routing with IPv6
[    1.619471] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.620517] NET: Registered protocol family 17
[    1.620555] can: controller area network core
[    1.620701] NET: Registered protocol family 29
[    1.620721] can: raw protocol
[    1.620741] can: broadcast manager protocol
[    1.620768] can: netlink gateway - max_hops=1
[    1.621077] Key type dns_resolver registered
[    1.621228] Registering SWP/SWPB emulation handler
[    1.621354] registered taskstats version 1
[    1.621419] Loading compiled-in X.509 certificates
[    1.655079] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    1.663649] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.664723] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    1.672784] printk: console [ttyS0] disabled
[    1.673165] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 52, base_baud = 1500000) is a Allwinner sun4i
[    2.629866] printk: console [ttyS0] enabled
[    2.635872] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PI regulator
[    2.642675] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
[    2.649662] sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
[    2.657078] sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18  on device 1c20800.pinctrl
[    2.667812] dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
[    2.676260] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    2.684872] libphy: sun4i_mii_bus: probed
[    2.690415] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[    2.697259] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
[    2.704275] sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
[    2.714358] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[    2.721184] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
[    2.727882] sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
[    2.735409] sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8  on device 1c20800.pinctrl
[    2.745946] sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
[    2.755412] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
[    2.762213] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
[    2.768680] sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
[    2.776053] sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0  on device 1c20800.pinctrl
[    2.786498] dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
[    2.806074] axp20x-i2c 0-0034: AXP20x variant AXP221 found
[    2.820652] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp221-pek/input/input0
[    2.843293] vcc-3v3: supplied by regulator-dummy
[    2.849286] vdd-cpu: supplied by regulator-dummy
[    2.855083] vdd-sys: supplied by regulator-dummy
[    2.860799] dcdc4: supplied by regulator-dummy
[    2.866359] vcc-dram: supplied by regulator-dummy
[    2.871286] vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
[    2.878334] vcc-gmac-phy: supplied by vcc-3v3
[    2.883894] dc5ldo: supplied by vcc-dram
[    2.888453] tv: Bringing 700000uV into 3300000-3300000uV
[    2.894497] tv: supplied by regulator-dummy
[    2.899358] aldo2: Bringing 2500000uV into 3300000-3300000uV
[    2.905742] aldo2: supplied by regulator-dummy
[    2.912596] avcc-pll: supplied by regulator-dummy
[    2.918473] random: fast init done
[    2.922982] eldo1: supplied by regulator-dummy
[    2.929406] eldo2: supplied by regulator-dummy
[    2.935090] vcc-pe: Bringing 1200000uV into 1800000-1800000uV
[    2.942163] vcc-pe: supplied by regulator-dummy
[    2.947498] vcc-sd-alt: Bringing 700000uV into 1800000-1800000uV
[    2.954588] vcc-sd-alt: supplied by regulator-dummy
[    2.960481] dldo2: supplied by regulator-dummy
[    2.967103] dldo3: supplied by regulator-dummy
[    2.973813] dldo4: supplied by regulator-dummy
[    2.979393] rtc_ldo: supplied by regulator-dummy
[    2.985376] ldo_io0: supplied by regulator-dummy
[    2.991164] ldo_io1: supplied by regulator-dummy
[    2.996965] axp20x-adc axp22x-adc: DMA mask not set
[    3.003904] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    3.014300] axp20x-i2c 0-0034: AXP20X driver loaded
[    3.047758] rtc-pcf85063 2-0051: registered as rtc0
[    3.062097] rtc-pcf85063 2-0051: setting system clock to 2022-11-08T11:20:44 UTC (1667906444)
[    3.071929] lm75 2-0048: supply vs not found, using dummy regulator
[    3.082970] lm75 2-0048: hwmon1: sensor 'lm75b'
[    3.122897] sun4i-usb-phy 1c13400.phy: phy0 dr_mode=3
[    3.131660] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 53, base_baud = 1500000) is a Allwinner sun4i
[    3.142200] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    3.150204] libphy: sun4i_mii_bus: probed
[    3.156051] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    3.271505] mmc0: new DDR MMC card at address 0001
[    3.277171] mmcblk0: mmc0:0001 DG4008 7.28 GiB
[    3.282121] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB
[    3.288497] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB
[    3.294757] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (246:0)
[    3.297246] sun4i-emac 1c0b000.ethernet: eth0: at (ptrval), IRQ 65 MAC: 00:85:01:01:a6:a2
[    3.311541] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[    3.317977] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[    3.324338] dwmac-sun8i 1c50000.ethernet: PTP uses main clock
[    3.330495] dwmac-sun8i 1c50000.ethernet: No HW DMA feature register supported
[    3.337792] dwmac-sun8i 1c50000.ethernet: RX Checksum Offload Engine supported
[    3.345043] dwmac-sun8i 1c50000.ethernet: COE Type 2
[    3.350007] dwmac-sun8i 1c50000.ethernet: TX Checksum insertion supported
[    3.356810] dwmac-sun8i 1c50000.ethernet: Normal descriptors
[    3.362468] dwmac-sun8i 1c50000.ethernet: Chain mode enabled
[    3.368848] libphy: stmmac: probed
[    3.373259]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    3.636183] ehci-platform 1c14000.usb: EHCI Host Controller
[    3.641801] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    3.650009] ehci-platform 1c14000.usb: irq 37, io mem 0x01c14000
[    3.683407] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    3.690544] hub 1-0:1.0: USB hub found
[    3.694429] hub 1-0:1.0: 1 port detected
[    3.699629] ehci-platform 1c19000.usb: EHCI Host Controller
[    3.705268] ehci-platform 1c19000.usb: new USB bus registered, assigned bus number 2
[    3.713259] ehci-platform 1c19000.usb: irq 39, io mem 0x01c19000
[    3.743404] ehci-platform 1c19000.usb: USB 2.0 started, EHCI 1.00
[    3.750448] hub 2-0:1.0: USB hub found
[    3.754285] hub 2-0:1.0: 1 port detected
[    3.759421] ehci-platform 1c1c000.usb: EHCI Host Controller
[    3.765044] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    3.773029] ehci-platform 1c1c000.usb: irq 41, io mem 0x01c1c000
[    3.804100] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    3.811106] hub 3-0:1.0: USB hub found
[    3.814942] hub 3-0:1.0: 1 port detected
[    3.913502] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    3.920145] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 4
[    3.928128] ohci-platform 1c14400.usb: irq 38, io mem 0x01c14400
[    4.008310] hub 4-0:1.0: USB hub found
[    4.012122] hub 4-0:1.0: 1 port detected
[    4.017297] ohci-platform 1c19400.usb: Generic Platform OHCI controller
[    4.023961] ohci-platform 1c19400.usb: new USB bus registered, assigned bus number 5
[    4.031961] ohci-platform 1c19400.usb: irq 40, io mem 0x01c19400
[    4.108365] hub 5-0:1.0: USB hub found
[    4.112178] hub 5-0:1.0: 1 port detected
[    4.117358] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    4.124036] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
[    4.131831] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    4.139140] ohci-platform 1c1c400.usb: irq 42, io mem 0x01c1c400
[    4.218385] hub 6-0:1.0: USB hub found
[    4.222200] hub 6-0:1.0: 1 port detected
[    4.228373] of_cfs_init
[    4.229711] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    4.230968] of_cfs_init: OK
[    4.242761] ALSA device list:
[    4.245787]   No soundcards found.
[    4.260791] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    4.281659] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    4.289903] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    4.300725] devtmpfs: mounted
[    4.308997] Freeing unused kernel memory: 1024K
[    4.333890] Run /sbin/init as init process
[    4.337993]   with arguments:
[    4.338001]     /sbin/init
[    4.338008]   with environment:
[    4.338015]     HOME=/
[    4.338023]     TERM=linux
[    4.551298] random: systemd: uninitialized urandom read (16 bytes read)
[    4.563120] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    4.585042] systemd[1]: Detected architecture arm.
[    4.624318] systemd[1]: Set hostname to <wirenboard>.
[    4.650030] random: systemd: uninitialized urandom read (16 bytes read)
[    4.690207] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[    4.897478] systemd[1]: [/lib/systemd/system/wb-mqtt-w1.service:10] Unknown lvalue 'StartLimitIntervalSec' in section 'Service'
[    4.976066] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.013866] systemd[1]: Listening on udev Kernel Socket.
[    5.043941] systemd[1]: Listening on Journal Socket.
[    5.086637] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.123953] systemd[1]: Listening on udev Control Socket.
[    5.153849] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.128372] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
[    6.979227] Driver for 1-wire Dallas network protocol.
[    7.158515] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[    7.219075] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.264005] Bluetooth: Core ver 2.22
[    7.267831] NET: Registered protocol family 31
[    7.272343] Bluetooth: HCI device and connection manager initialized
[    7.278950] Bluetooth: HCI socket layer initialized
[    7.283942] Bluetooth: L2CAP socket layer initialized
[    7.283992] Bluetooth: SCO socket layer initialized
[    7.327408] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.329134] usbcore: registered new interface driver btusb
[    7.345326] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    7.345383] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[    7.354075] cfg80211: failed to load regulatory.db
[    7.369648] Bluetooth: hci0: RTL: rom_version status=0 version=1
[    7.375868] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[    7.385750] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[    7.392535] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[    7.405824] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[    7.823635] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SS
[    7.826070] RTL871X: module init start
[    7.835817] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[    7.842800] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[    8.080353] RTL871X: rtw_ndev_init(wlan0)
[    8.085849] RTL871X: rtw_ndev_init(wlan1)
[    8.091398] usbcore: registered new interface driver rtl8723bu
[    8.097411] RTL871X: module init ret=0
[    8.200758] usbcore: registered new interface driver rtl8xxxu
[    8.236658] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[    8.913737] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    9.305473] systemd-journald[124]: Received request to flush runtime journal from PID 1
[   10.152613] RTL871X: RTW_ADAPTIVITY_EN_
[   10.152641] AUTO, chplan:0x20, Regulation:3,3
[   10.161014] RTL871X: RTW_ADAPTIVITY_MODE_
[   10.161025] NORMAL
[   12.891331] RTL871X: nolinked power save enter
[   13.022276] new mount options do not match the existing superblock, will be ignored
[   13.058101] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.063615] Bluetooth: BNEP filters: protocol multicast
[   13.068955] Bluetooth: BNEP socket layer initialized
[   13.109555] dwmac-sun8i 1c50000.ethernet eth1: PHY [stmmac-1:00] driver [ICPlus IP101A/G] (irq=POLL)
[   13.130123] dwmac-sun8i 1c50000.ethernet eth1: No Safety Features support found
[   13.139900] dwmac-sun8i 1c50000.ethernet eth1: No MAC Management Counters available
[   13.147840] dwmac-sun8i 1c50000.ethernet eth1: PTP not supported by HW
[   13.188110] dwmac-sun8i 1c50000.ethernet eth1: configuring for phy/mii link mode
[   13.557787] EXT4-fs (mmcblk0p2): recovery complete
[   13.564930] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   18.833618] sun4i-emac 1c0b000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   18.841999] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   19.052508] random: crng init done
[   19.055964] random: 7 urandom warning(s) missed due to ratelimiting
[   20.272063] 1c29000.serial: ttyS4 at MMIO 0x1c29000 (irq = 130, base_baud = 1500000) is a Allwinner sun4i
[   23.022422] process '/sbin/netplugd' started with executable stack
[   24.110845] RTL871X: RTW_ADAPTIVITY_EN_
[   24.110872] AUTO, chplan:0x20, Regulation:3,3
[   24.119214] RTL871X: RTW_ADAPTIVITY_MODE_
[   24.119224] NORMAL
[   25.178003] RTL871X: nolinked power save leave
[   25.874813] RTL871X: assoc success
[   25.878844] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   34.404236] vcc-gmac-phy: disabling
[   34.410400] dc5ldo: disabling
[   34.414004] dldo4: disabling
[   34.417658] vdd-sd-power: disabling
[   34.421284] vcc-sd: disabling
Разные флешки пробовали, результата не дало.
Есть ещё способы проверить работу порта ? или тут приговор на замену контроллера ?
Конфигурация
WB7-1G-8G-IND Контроллер для автоматизации Wiren Board 7 [ Память и исполнение: 1 Гбайт RAM, 8 Гбайт eMMC (Industrial); ]
WBC-4G v.2
WBE2R-R-ZIGBEE v.2
Ну и аналогичное с работающего контроллера с этой же флешкой
root@IQ349000:~# lsusb
Bus 001 Device 004: ID 0781:5591 SanDisk Corp. Ultra Flair
root@IQ349000:~# dmesg | grep sda
[    4.891573] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[    4.906089] sd 0:0:0:0: [sda] Write Protect is off
[    4.910976] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    4.912215] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    4.991717]  sda: sda1
[    4.998814] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  509.293337] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[  509.303626] sd 0:0:0:0: [sda] Write Protect is off
[  509.308505] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[  509.309810] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  509.363826]  sda: sda1
[  509.371045] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1196.735074] sd 0:0:0:0: [sda] 120176640 512-byte logical blocks: (61.5 GB/57.3 GiB)
[ 1196.745476] sd 0:0:0:0: [sda] Write Protect is off
[ 1196.750345] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 1196.752113] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1196.809902]  sda: sda1
[ 1196.817143] sd 0:0:0:0: [sda] Attached SCSI removable disk
root@IQ349000:~# dmesg | grep sda^C
root@IQ349000:~# ^C
[    0.000341] Console: colour dummy device 80x30
[    0.000410] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000441] pid_max: default: 32768 minimum: 301
[    0.000652] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000679] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001756] CPU: Testing write buffer coherency: ok
[    0.002195] /cpus/cpu@0 missing clock-frequency property
[    0.002240] /cpus/cpu@1 missing clock-frequency property
[    0.002285] /cpus/cpu@2 missing clock-frequency property
[    0.002333] /cpus/cpu@3 missing clock-frequency property
[    0.002352] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003321] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003524] rcu: Hierarchical SRCU implementation.
[    0.004429] smp: Bringing up secondary CPUs ...
[    0.015536] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.026797] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.037942] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.038126] smp: Brought up 1 node, 4 CPUs
[    0.038165] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.038179] CPU: All CPU(s) started in HYP mode.
[    0.038191] CPU: Virtualization extensions available.
[    0.039135] devtmpfs: initialized
[    0.051205] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.051519] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.051555] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.052550] pinctrl core: initialized pinctrl subsystem
[    0.054062] NET: Registered protocol family 16
[    0.056688] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.058028] thermal_sys: Registered thermal governor 'step_wise'
[    0.058542] No ATAGs?
[    0.058775] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.058794] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.107637] SCSI subsystem initialized
[    0.107901] usbcore: registered new interface driver usbfs
[    0.108064] usbcore: registered new interface driver hub
[    0.108146] usbcore: registered new device driver usb
[    0.108528] mc: Linux media interface: v0.10
[    0.108576] videodev: Linux video capture interface: v2.00
[    0.108642] pps_core: LinuxPPS API ver. 1 registered
[    0.108659] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.108703] PTP clock support registered
[    0.109005] Advanced Linux Sound Architecture Driver Initialized.
[    0.110157] clocksource: Switched to clocksource arch_sys_counter
[    0.795755] NET: Registered protocol family 2
[    0.796498] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.796553] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.796647] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.796770] TCP: Hash tables configured (established 8192 bind 8192)
[    0.796939] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.797012] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.797311] NET: Registered protocol family 1
[    0.798374] RPC: Registered named UNIX socket transport module.
[    0.798400] RPC: Registered udp transport module.
[    0.798414] RPC: Registered tcp transport module.
[    0.798427] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.800178] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.801805] Initialise system trusted keyrings
[    0.802103] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.810781] NFS: Registering the id_resolver key type
[    0.810847] Key type id_resolver registered
[    0.810862] Key type id_legacy registered
[    0.811476] Key type asymmetric registered
[    0.811497] Asymmetric key parser 'x509' registered
[    0.811641] bounce: pool size: 64 pages
[    0.811696] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.811714] io scheduler mq-deadline registered
[    0.811729] io scheduler kyber registered
[    0.812879] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.898794] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.913217] brd: module loaded
[    0.924278] loop: module loaded
[    0.930276] libphy: Fixed MDIO Bus: probed
[    0.931480] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    0.932139] libphy: sun4i_mii_bus: probed
[    0.934282] CAN device driver interface
[    0.936351] PPP generic driver version 2.4.2
[    0.936638] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.936657] ehci-platform: EHCI generic platform driver
[    0.937719] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.937756] ohci-platform: OHCI generic platform driver
[    0.938852] usbcore: registered new interface driver usb-storage
[    0.938972] usbcore: registered new interface driver usbserial_generic
[    0.939016] usbserial: USB Serial support registered for generic
[    0.941266] sun6i-rtc 1c20400.rtc: registered as rtc1
[    0.941290] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.941680] i2c /dev entries driver
[    0.947954] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.951037] ledtrig-cpu: registered to indicate activity on CPUs
[    0.951630] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[    0.952048] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    0.952741] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    0.952965] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    0.953167] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[    0.953327] sun8i-ce 1c15000.crypto: Register cbc(aes)
[    0.953537] sun8i-ce 1c15000.crypto: Register ecb(aes)
[    0.953733] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
[    0.953932] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
[    0.954151] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
[    0.955997] usbcore: registered new interface driver usbhid
[    0.956018] usbhid: USB HID core driver
[    0.958679] iio-rescale a1-volt: using raw+scale source channel
[    0.959103] iio-rescale a2-volt: using raw+scale source channel
[    0.959465] iio-rescale a3-volt: using raw+scale source channel
[    0.959819] iio-rescale vin-volt: using raw+scale source channel
[    0.963393] NET: Registered protocol family 10
[    0.964546] Segment Routing with IPv6
[    0.964636] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.965407] NET: Registered protocol family 17
[    0.965439] can: controller area network core
[    0.965542] NET: Registered protocol family 29
[    0.965558] can: raw protocol
[    0.965573] can: broadcast manager protocol
[    0.965594] can: netlink gateway - max_hops=1
[    0.965857] Key type dns_resolver registered
[    0.965988] Registering SWP/SWPB emulation handler
[    0.966115] registered taskstats version 1
[    0.966172] Loading compiled-in X.509 certificates
[    0.986703] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.991318] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.992147] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    0.997283] printk: console [ttyS0] disabled
[    0.997451] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 52, base_baud = 1500000) is a Allwinner sun4i
[    1.949735] printk: console [ttyS0] enabled
[    1.955016] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PI regulator
[    1.961856] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
[    1.968472] sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
[    1.975813] sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18  on device 1c20800.pinctrl
[    1.986518] dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
[    1.994931] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    2.003040] libphy: sun4i_mii_bus: probed
[    2.008107] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[    2.014940] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
[    2.021583] sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
[    2.031190] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[    2.037984] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
[    2.044642] sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
[    2.052143] sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8  on device 1c20800.pinctrl
[    2.062670] sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
[    2.071131] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
[    2.077922] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
[    2.084399] sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
[    2.091723] sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0  on device 1c20800.pinctrl
[    2.102077] dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
[    2.117100] axp20x-i2c 0-0034: AXP20x variant AXP221 found
[    2.128978] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp221-pek/input/input0
[    2.149067] vcc-3v3: supplied by regulator-dummy
[    2.154726] vdd-cpu: supplied by regulator-dummy
[    2.160305] vdd-sys: supplied by regulator-dummy
[    2.165859] dcdc4: supplied by regulator-dummy
[    2.171270] vcc-dram: supplied by regulator-dummy
[    2.176151] vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
[    2.183179] vcc-gmac-phy: supplied by vcc-3v3
[    2.188616] dc5ldo: supplied by vcc-dram
[    2.193165] tv: Bringing 700000uV into 3300000-3300000uV
[    2.199181] tv: supplied by regulator-dummy
[    2.203998] aldo2: Bringing 2500000uV into 3300000-3300000uV
[    2.210349] aldo2: supplied by regulator-dummy
[    2.216178] avcc-pll: supplied by regulator-dummy
[    2.221881] eldo1: supplied by regulator-dummy
[    2.226653] random: fast init done
[    2.230608] eldo2: supplied by regulator-dummy
[    2.235702] vcc-pe: Bringing 1200000uV into 1800000-1800000uV
[    2.242590] vcc-pe: supplied by regulator-dummy
[    2.247742] vcc-sd-alt: Bringing 700000uV into 1800000-1800000uV
[    2.254796] vcc-sd-alt: supplied by regulator-dummy
[    2.260670] dldo2: supplied by regulator-dummy
[    2.266066] dldo3: supplied by regulator-dummy
[    2.271497] dldo4: supplied by regulator-dummy
[    2.276505] rtc_ldo: supplied by regulator-dummy
[    2.282051] ldo_io0: supplied by regulator-dummy
[    2.287595] ldo_io1: supplied by regulator-dummy
[    2.293027] axp20x-adc axp22x-adc: DMA mask not set
[    2.299748] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    2.309184] axp20x-i2c 0-0034: AXP20X driver loaded
[    2.339548] rtc-pcf85063 2-0051: registered as rtc0
[    2.353845] rtc-pcf85063 2-0051: setting system clock to 2022-11-08T11:05:07 UTC (1667905507)
[    2.362956] lm75 2-0048: supply vs not found, using dummy regulator
[    2.373679] lm75 2-0048: hwmon1: sensor 'lm75b'
[    2.405477] sun4i-usb-phy 1c13400.phy: phy0 dr_mode=3
[    2.414188] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 53, base_baud = 1500000) is a Allwinner sun4i
[    2.424675] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[    2.432713] libphy: sun4i_mii_bus: probed
[    2.439426] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    2.555665] mmc0: new DDR MMC card at address 0001
[    2.561359] mmcblk0: mmc0:0001 DG4008 7.28 GiB
[    2.566277] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB
[    2.572686] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB
[    2.573985] sun4i-emac 1c0b000.ethernet: eth0: at (ptrval), IRQ 65 MAC: 00:85:01:01:06:30
[    2.578916] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (246:0)
[    2.587892] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[    2.600597] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[    2.607004] dwmac-sun8i 1c50000.ethernet: PTP uses main clock
[    2.613144] dwmac-sun8i 1c50000.ethernet: No HW DMA feature register supported
[    2.620427] dwmac-sun8i 1c50000.ethernet: RX Checksum Offload Engine supported
[    2.627666] dwmac-sun8i 1c50000.ethernet: COE Type 2
[    2.632659] dwmac-sun8i 1c50000.ethernet: TX Checksum insertion supported
[    2.639445] dwmac-sun8i 1c50000.ethernet: Normal descriptors
[    2.645118] dwmac-sun8i 1c50000.ethernet: Chain mode enabled
[    2.651498] libphy: stmmac: probed
[    2.656433]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.912775] ehci-platform 1c14000.usb: EHCI Host Controller
[    2.918392] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    2.926597] ehci-platform 1c14000.usb: irq 37, io mem 0x01c14000
[    2.960159] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    2.967327] hub 1-0:1.0: USB hub found
[    2.971203] hub 1-0:1.0: 1 port detected
[    2.976421] ehci-platform 1c19000.usb: EHCI Host Controller
[    2.982054] ehci-platform 1c19000.usb: new USB bus registered, assigned bus number 2
[    2.990054] ehci-platform 1c19000.usb: irq 39, io mem 0x01c19000
[    3.020159] ehci-platform 1c19000.usb: USB 2.0 started, EHCI 1.00
[    3.027224] hub 2-0:1.0: USB hub found
[    3.031065] hub 2-0:1.0: 1 port detected
[    3.036217] ehci-platform 1c1c000.usb: EHCI Host Controller
[    3.041848] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    3.049819] ehci-platform 1c1c000.usb: irq 41, io mem 0x01c1c000
[    3.080694] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    3.087694] hub 3-0:1.0: USB hub found
[    3.091528] hub 3-0:1.0: 1 port detected
[    3.190249] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    3.196892] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 4
[    3.204867] ohci-platform 1c14400.usb: irq 38, io mem 0x01c14400
[    3.285081] hub 4-0:1.0: USB hub found
[    3.288899] hub 4-0:1.0: 1 port detected
[    3.294111] ohci-platform 1c19400.usb: Generic Platform OHCI controller
[    3.300776] ohci-platform 1c19400.usb: new USB bus registered, assigned bus number 5
[    3.308729] ohci-platform 1c19400.usb: irq 40, io mem 0x01c19400
[    3.385135] hub 5-0:1.0: USB hub found
[    3.388949] hub 5-0:1.0: 1 port detected
[    3.394195] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    3.400876] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
[    3.408732] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    3.416056] ohci-platform 1c1c400.usb: irq 42, io mem 0x01c1c400
[    3.495115] hub 6-0:1.0: USB hub found
[    3.498932] hub 6-0:1.0: 1 port detected
[    3.505131] of_cfs_init
[    3.506506] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.507729] of_cfs_init: OK
[    3.519535] ALSA device list:
[    3.522574]   No soundcards found.
[    3.537528] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    3.559467] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    3.567718] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    3.578427] devtmpfs: mounted
[    3.586793] Freeing unused kernel memory: 1024K
[    3.610204] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    3.617782] Run /sbin/init as init process
[    3.621929]   with arguments:
[    3.621938]     /sbin/init
[    3.621945]   with environment:
[    3.621952]     HOME=/
[    3.621960]     TERM=linux
[    3.812554] usb-storage 1-1:1.0: USB Mass Storage device detected
[    3.819686] scsi host0: usb-storage 1-1:1.0
[    3.824369] systemd[1]: RTC configured in localtime, applying delta of 0 minutes to system time.
[    3.871061] random: systemd: uninitialized urandom read (16 bytes read)
[    3.882787] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    3.905858] systemd[1]: Detected architecture arm.
[    3.941049] systemd[1]: Set hostname to <IQ349000>.
[    3.971709] random: systemd: uninitialized urandom read (16 bytes read)
[    3.984204] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[    4.240940] systemd[1]: Configuration file /lib/systemd/system/lsyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    4.270747] systemd[1]: [/lib/systemd/system/wb-mqtt-w1.service:10] Unknown lvalue 'StartLimitIntervalSec' in section 'Service'
[    4.338852] systemd[1]: Listening on Journal Socket.
[    4.371283] systemd[1]: Created slice User and Session Slice.
[    4.400573] systemd[1]: Listening on Syslog Socket.
[    4.444822] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.480684] systemd[1]: Listening on udev Control Socket.
[    4.881478] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra USB 3.0    1.00 PQ: 0 ANSI: 6
[    5.467841] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
[    6.409423] Driver for 1-wire Dallas network protocol.
[    6.569302] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[    6.686411] Bluetooth: Core ver 2.22
[    6.690419] NET: Registered protocol family 31
[    6.694959] Bluetooth: HCI device and connection manager initialized
[    6.698167] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.701485] Bluetooth: HCI socket layer initialized
[    6.714316] Bluetooth: L2CAP socket layer initialized
[    6.714393] Bluetooth: SCO socket layer initialized
[    6.765692] usbcore: registered new interface driver btusb
[    6.796394] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[    6.806416] Bluetooth: hci0: RTL: rom_version status=0 version=1
[    6.812605] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[    6.821884] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[    6.828421] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[    6.831755] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.837774] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[    6.848863] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    6.858523] cfg80211: failed to load regulatory.db
[    7.345430] RTL871X: module init start
[    7.349214] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[    7.356299] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[    7.380406] Adding 262140k swap on /dev/mmcblk0p5.  Priority:-2 extents:1 across:262140k SS
[    7.539590] RTL871X: rtw_ndev_init(wlan0)
[    7.548575] RTL871X: rtw_ndev_init(wlan1)
[    7.557600] usbcore: registered new interface driver rtl8723bu
[    7.563576] RTL871X: module init ret=0
[    7.652402] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[    7.664115] usbcore: registered new interface driver rtl8xxxu
[    8.359970] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    8.858847] systemd-journald[120]: Received request to flush runtime journal from PID 1
[    9.621683] RTL871X: RTW_ADAPTIVITY_EN_
[    9.621714] AUTO, chplan:0x20, Regulation:3,3
[    9.629961] RTL871X: RTW_ADAPTIVITY_MODE_
[    9.629976] NORMAL
[   11.209110] new mount options do not match the existing superblock, will be ignored
[   11.438949] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   11.444708] Bluetooth: BNEP filters: protocol multicast
[   11.450128] Bluetooth: BNEP socket layer initialized
[   12.402791] RTL871X: nolinked power save enter
[   12.634600] random: crng init done
[   12.640320] random: 7 urandom warning(s) missed due to ratelimiting
[   13.535962] process '/sbin/netplugd' started with executable stack
[   14.101775] dwmac-sun8i 1c50000.ethernet eth1: PHY [stmmac-1:00] driver [ICPlus IP101A/G] (irq=POLL)
[   14.111241] sun4i-emac 1c0b000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   14.126106] dwmac-sun8i 1c50000.ethernet eth1: No Safety Features support found
[   14.133601] dwmac-sun8i 1c50000.ethernet eth1: No MAC Management Counters available
[   14.141372] dwmac-sun8i 1c50000.ethernet eth1: PTP not supported by HW
[   14.170405] dwmac-sun8i 1c50000.ethernet eth1: configuring for phy/mii link mode
[   14.184324] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   21.746493] 1c29c00.serial: ttyS7 at MMIO 0x1c29c00 (irq = 130, base_baud = 1500000) is a Allwinner sun4i
[   22.587986] 1c29000.serial: ttyS4 at MMIO 0x1c29000 (irq = 131, base_baud = 1500000) is a Allwinner sun4i
[   33.760297] vcc-gmac-phy: disabling
[   33.764185] dc5ldo: disabling
[   33.767627] dldo4: disabling
[   33.771162] vdd-sd-power: disabling
[   33.774676] vcc-sd: disabling
[  505.254172] usb 1-1: USB disconnect, device number 2
[  508.011484] usb 1-1: new high-speed USB device number 3 using ehci-platform
[  508.226123] usb-storage 1-1:1.0: USB Mass Storage device detected
[  508.233030] scsi host0: usb-storage 1-1:1.0
[  509.282813] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra USB 3.0    1.00 PQ: 0 ANSI: 6
[  528.744378] usb 1-1: USB disconnect, device number 3
[ 1195.463029] usb 1-1: new high-speed USB device number 4 using ehci-platform
[ 1195.665567] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 1195.673223] scsi host0: usb-storage 1-1:1.0
[ 1196.724146] scsi 0:0:0:0: Direct-Access      USB      SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
Диагностика грамотная, все сделано верно.
Скорее всего проблема аппаратная, сожалею что столкнулись с такой ситуацией.
WB7 1G - 1 шт
WBC-4G v.2 - 1 шт
WBE2R-R-ZIGBEE v.2 - 1 шт
  1. ссылку на эту тему,
  2. серийный номер контроллера,
