Столкнулкнулся с проблемой: не определяются устройства подключенные к контроллеру WB7 через порт USB 1 (флешка, звуковая карта)
Контроллер WB hw:7.2.1c, прошивку обновлял через apt только сегодня.
Ниже вывод lsusb при физически подключенном устройстве:
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0bda:b720 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
вывод dmesg | grep usb:
[ 0.164816] usbcore: registered new interface driver usbfs
[ 0.164927] usbcore: registered new interface driver hub
[ 0.165058] usbcore: registered new device driver usb
[ 1.432926] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 1.685618] usbcore: registered new interface driver usb-storage
[ 1.685745] usbcore: registered new interface driver usbserial_generic
[ 1.685790] usbserial: USB Serial support registered for generic
[ 1.716340] usbcore: registered new interface driver usbhid
[ 1.716369] usbhid: USB HID core driver
[ 1.767802] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 3.383860] sun4i-usb-phy 1c13400.phy: phy0 dr_mode=3
[ 3.880292] ehci-platform 1c14000.usb: EHCI Host Controller
[ 3.885903] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[ 3.894071] ehci-platform 1c14000.usb: irq 37, io mem 0x01c14000
[ 3.927749] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[ 3.943925] ehci-platform 1c19000.usb: EHCI Host Controller
[ 3.949561] ehci-platform 1c19000.usb: new USB bus registered, assigned bus number 2
[ 3.957561] ehci-platform 1c19000.usb: irq 39, io mem 0x01c19000
[ 3.987748] ehci-platform 1c19000.usb: USB 2.0 started, EHCI 1.00
[ 4.003719] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 4.009350] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[ 4.017320] ehci-platform 1c1c000.usb: irq 41, io mem 0x01c1c000
[ 4.048155] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 4.157839] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[ 4.164476] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 4
[ 4.172446] ohci-platform 1c14400.usb: irq 38, io mem 0x01c14400
[ 4.261701] ohci-platform 1c19400.usb: Generic Platform OHCI controller
[ 4.268361] ohci-platform 1c19400.usb: new USB bus registered, assigned bus number 5
[ 4.276374] ohci-platform 1c19400.usb: irq 40, io mem 0x01c19400
[ 4.361613] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 4.368292] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
[ 4.376089] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 4.383372] ohci-platform 1c1c400.usb: irq 42, io mem 0x01c1c400
[ 7.504366] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[ 7.773874] usbcore: registered new interface driver btusb
[ 8.439214] usbcore: registered new interface driver rtl8723bu
[ 8.536743] usbcore: registered new interface driver rtl8xxxu
На контроллере WB6 такой проблемы нет. Та же самая звуковая карта подключается к USB, определяется и прекрасно работает.
В чем может быть проблема?
