Не знаю, возможно я сделал не совсем правильно. Получил следующее (Ethernet пропал, так что проверить обмен не могу):
Debian GNU/Linux 7 wirenboard ttyAMA0
wirenboard login: root
Password:
Last login: Fri Dec 19 10:15:18 UTC 2014 on ttyAMA0
Linux wirenboard 3.13.0-imxv5-x0.1 #54 Tue Jul 29 22:28:23 MSK 2014 armv5tejl
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@wirenboard:~# cd /home
root@wirenboard:/home# dpkg -i linux-image-3.13.0-imxv5-x0.1_3.13-imxv5-x0.1+wb2 0141219072253_armel.deb
Selecting previously unselected package linux-image-3.13.0-imxv5-x0.1.
(Reading database … 19855 files and directories currently installed.)
Unpacking linux-image-3.13.0-imxv5-x0.1 (from linux-image-3.13.0-imxv5-x0.1_3.13 -imxv5-x0.1+wb20141219072253_armel.deb) …
Setting up linux-image-3.13.0-imxv5-x0.1 (3.13-imxv5-x0.1+wb20141219072253) …
root@wirenboard:/home# reboot
The system is going down for reboot NOW!ttyAMA0) (Mon Dec 22 15:23:16 2014):
INIT: Switching to runlevel: 6
INIT: Sending processes the TERM signal
[info] Using makefile-style concurrent boot in runlevel 6.
[ ok ] Stopping advanced IEEE 802.11 management: hostapd.
[ ok ] Stopping DNS forwarder and DHCP server: dnsmasq.
[info] Saving the system clock.
[info] Hardware Clock updated to Mon Dec 22 15:23:22 UTC 2014.
[ ok ] Stopping network daemon:: mosquitto.
[…] Stopping update local time using SIMCOM SIM900 integrated RTC: wb-gsm-rtc chat: Dec 22 15:23:29 OK
. ok
[ ok ] Stopping MQTT driver for WB HomA for RFM69 ISM radio: wb-homa-rcd.
Stopping httpd daemon: webfsd.
[ ok ] Asking all remaining processes to terminate…done.
[ ok ] All processes ended within 1 seconds…done.
[…] Deconfiguring network interfaces…[ 1333.120000] R8188EU: ERROR indicate disassoc
[ 1333.500000] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
done.
[ ok ] Deactivating swap…done.
[ 1335.410000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[info] Will now restart.
[ 1337.680000] reboot: Restarting system
HTLLCLC
U-Boot 2013.07-dirty (Mar 30 2014 - 00:00:56)
CPU: Freescale i.MX23 rev1.4 at 454 MHz
BOOT: SSP SD/MMC #0
DRAM: 64 MiB
MMC: MXS MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
mmc0 is current device
SD/MMC found on device 0
227 bytes read in 101 ms (2 KiB/s)
Importing environment from mmc (uEnv.txt)…
Checking if uenvcmd is set …
Running default loadzimage …
3892528 bytes read in 1244 ms (3 MiB/s)
12243 bytes read in 181 ms (65.4 KiB/s)
Booting from mmc …
Kernel image @ 0x42000000 [ 0x000000 - 0x3b6530 ]
Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 43b62000, end 43b67fd2 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.13.0-imxv5-x0.1 (boger@boger-ThinkPad-Edge-E440) (gcc version 4.7.4 20130913 (release) [ARM/embedded-4_7-branch revision 202601] (GNU Tools for ARM Embedded Processors) ) #54 Tue Jul 29 22:28:23 MSK 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine model: Wiren Board rev. 3.2 (i.MX23)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 16256
[ 0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/mmcblk0p2 r o rootfstype=ext4 rootwait fixrtc video=
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 52312K/65536K available (4774K kernel code, 291K rwdata, 1680K rodata, 276K init, 5516K bss, 13224K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0655cc0 (6456 kB)
[ 0.000000] .init : 0xc0656000 - 0xc069b1f4 ( 277 kB)
[ 0.000000] .data : 0xc069c000 - 0xc06e4ed0 ( 292 kB)
[ 0.000000] .bss : 0xc06e4ed0 - 0xc0c48250 (5517 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] of_irq_init: children remain, but no parents
[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps ever y 21474836480000000ns
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Lock dependency validator: Copyright © 2006 Red Hat, Inc., Ingo Molnar
[ 0.000000] … MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] … MAX_LOCK_DEPTH: 48
[ 0.000000] … MAX_LOCKDEP_KEYS: 8191
[ 0.000000] … CLASSHASH_SIZE: 4096
[ 0.000000] … MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] … MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] … CHAINHASH_SIZE: 16384
[ 0.000000] memory used by lock dependency info: 3695 kB
[ 0.000000] per task-struct memory footprint: 1152 bytes
[ 0.070000] Calibrating delay loop… 226.09 BogoMIPS (lpj=1130496)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.090000] CPU: Testing write buffer coherency: ok
[ 0.100000] Setting up static identity map for 0x40489808 - 0x40489860
[ 0.110000] devtmpfs: initialized
[ 0.130000] pinctrl core: initialized pinctrl subsystem
[ 0.140000] regulator-dummy: no parameters
[ 0.140000] NET: Registered protocol family 16
[ 0.140000] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.210000] Serial: AMBA PL011 UART driver
[ 0.210000] 80070000.serial: ttyAMA0 at MMIO 0x80070000 (irq = 17, base_baud = 0) is a PL011 rev2
[ 0.400000] console [ttyAMA0] enabled
[ 0.430000] bio: create slab <bio-0> at 0
[ 0.450000] mxs-dma 80004000.dma-apbh: initialized
[ 0.470000] mxs-dma 80024000.dma-apbx: initialized
[ 0.470000] usbcore: registered new interface driver usbfs
[ 0.480000] usbcore: registered new interface driver hub
[ 0.480000] usbcore: registered new device driver usb
[ 0.490000] Advanced Linux Sound Architecture Driver Initialized.
[ 0.510000] cfg80211: Calling CRDA to update world regulatory domain
[ 0.520000] Switched to clocksource mxs_timer
[ 0.950000] NET: Registered protocol family 2
[ 0.960000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.970000] TCP bind hash table entries: 1024 (order: 3, 36864 bytes)
[ 0.980000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.990000] TCP: reno registered
[ 0.990000] UDP hash table entries: 256 (order: 2, 20480 bytes)
[ 1.000000] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[ 1.010000] NET: Registered protocol family 1
[ 1.010000] NetWinder Floating Point Emulator V0.97 (double precision)
[ 1.090000] msgmni has been set to 102
[ 1.110000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 51)
[ 1.120000] io scheduler noop registered (default)
[ 1.130000] of_dma_request_slave_channel: dma-names property of node ‘/apb@80 000000/apbx@80040000/serial@80070000’ missing or empty
[ 1.140000] uart-pl011 80070000.serial: no DMA platform data
[ 1.150000] 8006c000.serial: ttyAPP0 at MMIO 0x8006c000 (irq = 144, base_baud = 1500000) is a 8006c000.serial
[ 1.160000] mxs-auart 8006c000.serial: Found APPUART 3.0.0
[ 1.180000] mxs-spi 80034000.ssp: cs-gpios count: 5
[ 1.200000] spi spi1.3: gpio index 0, gpio_cs 3
[ 1.210000] spi spi1.4: gpio index 1, gpio_cs 91
[ 1.210000] spi spi1.5: gpio index 2, gpio_cs 51
[ 1.230000] spi spi1.6: gpio index 3, gpio_cs 35
[ 1.240000] spi spi1.7: gpio index 4, gpio_cs 38
[ 1.240000] PPP generic driver version 2.4.2
[ 1.250000] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.260000] usbcore: registered new interface driver usbserial
[ 1.260000] usbcore: registered new interface driver usbserial_generic
[ 1.270000] usbserial: USB Serial support registered for generic
[ 1.280000] 80080000.usb supply vbus not found, using dummy regulator
[ 1.290000] ci_hdrc ci_hdrc.0: doesn’t support gadget
[ 1.300000] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.300000] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.330000] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.340000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.340000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.350000] usb usb1: Product: EHCI Host Controller
[ 1.350000] usb usb1: Manufacturer: Linux 3.13.0-imxv5-x0.1 ehci_hcd
[ 1.360000] usb usb1: SerialNumber: ci_hdrc.0
[ 1.380000] hub 1-0:1.0: USB hub found
[ 1.380000] hub 1-0:1.0: 1 port detected
[ 1.400000] mousedev: PS/2 mouse device common for all mice
[ 1.410000] stmp3xxx-rtc 8005c000.rtc: rtc core: registered 8005c000.rtc as r tc0
[ 1.420000] i2c /dev entries driver
[ 1.430000] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with hear tbeat 19s
[ 1.440000] 80010000.ssp supply vmmc not found, using dummy regulator
[ 1.490000] mxs-mmc 80010000.ssp: initialized
[ 1.500000] imx23-pinctrl 80018000.pinctrl: pin SSP1_DETECT already requested by 80018000.pinctrl; cannot claim for leds.4
[ 1.510000] imx23-pinctrl 80018000.pinctrl: pin-65 (leds.4) status -22
[ 1.510000] imx23-pinctrl 80018000.pinctrl: could not request pin 65 (SSP1_DE TECT) from group led_gpio2_1.0 on device 80018000.pinctrl
[ 1.530000] leds-gpio leds.4: Error applying setting, reverse things back
[ 1.550000] usbcore: registered new interface driver usbhid
[ 1.560000] usbhid: USB HID core driver
[ 1.570000] mmc0: host does not support reading read-only switch. assuming wr ite-enable.
[ 1.590000] mmc0: new high speed SDHC card at address b368
[ 1.610000] mmcblk0: mmc0:b368 USD 7.45 GiB
[ 1.640000] mxs-builtin-audio mxs-builtin-audio.5: mxs-builtin-codec-dai <-> 80048000.mxs-builtin-cpu-dai mapping ok
[ 1.650000] mmcblk0: p1 p2
[ 1.670000] mmcblk0: p2 size 15603712 extends beyond EOD, truncated
[ 1.690000] TCP: cubic registered
[ 1.700000] NET: Registered protocol family 10
[ 1.710000] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.720000] sit: IPv6 over IPv4 tunneling driver
[ 1.730000] NET: Registered protocol family 17
[ 1.740000] Key type dns_resolver registered
[ 1.750000] registered taskstats version 1
[ 1.760000] stmp3xxx-rtc 8005c000.rtc: setting system clock to 2014-12-22 15: 23:46 UTC (1419261826)
[ 1.790000] ALSA device list:
[ 1.800000] #0: mxs-builtin-audio
[ 1.860000] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.860000] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.880000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 1.880000] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.890000] hub 1-1:1.0: USB hub found
[ 1.910000] hub 1-1:1.0: 5 ports detected
[ 1.920000] devtmpfs: mounted
[ 1.930000] Freeing unused kernel memory: 276K (c0656000 - c069b000)
[ 2.220000] usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
[ 2.350000] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.350000] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
INIT: version 2.88 booting
[ 2.470000] usb 1-1.5: new high-speed USB device number 4 using ci_hdrc
[ 2.600000] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=8179
[ 2.610000] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 2.610000] usb 1-1.5: Product: 802.11n WLAN NIC
[ 2.620000] usb 1-1.5: Manufacturer: Realtek
[info] Using makefile-style concurrent boot in runlevel S.
[…] Starting the hotplug events dispatcher: udevd[ 5.870000] udevd[161]: s tarting version 175
. ok
[…] Synthesizing the initial hotplug events…[ 8.490000] cn: disagrees ab out version of symbol __nlmsg_put
[ 8.490000] cn: Unknown symbol __nlmsg_put (err -22)
[ 8.550000] cn: disagrees about version of symbol __netlink_kernel_create
[ 8.550000] cn: Unknown symbol __netlink_kernel_create (err -22)
[ 8.640000] cn: disagrees about version of symbol kfree_skb
[ 8.650000] cn: Unknown symbol kfree_skb (err -22)
[ 8.720000] cn: disagrees about version of symbol netlink_broadcast
[ 8.720000] cn: Unknown symbol netlink_broadcast (err -22)
[ 8.810000] cn: disagrees about version of symbol __alloc_skb
[ 8.810000] cn: Unknown symbol __alloc_skb (err -22)
[ 8.890000] cn: disagrees about version of symbol init_net
[ 8.890000] cn: Unknown symbol init_net (err -22)
[ 8.960000] cn: disagrees about version of symbol netlink_kernel_release
[ 8.960000] cn: Unknown symbol netlink_kernel_release (err -22)
[ 9.040000] cn: disagrees about version of symbol netlink_has_listeners
[ 9.040000] cn: Unknown symbol netlink_has_listeners (err -22)
[ 9.110000] cn: disagrees about version of symbol __nlmsg_put
[ 9.110000] cn: Unknown symbol __nlmsg_put (err -22)
[ 9.210000] cn: disagrees about version of symbol __netlink_kernel_create
[ 9.210000] cn: Unknown symbol __netlink_kernel_create (err -22)
[ 9.280000] cn: disagrees about version of symbol kfree_skb
[ 9.280000] cn: Unknown symbol kfree_skb (err -22)
[ 9.410000] cn: disagrees about version of symbol netlink_broadcast
[ 9.410000] cn: Unknown symbol netlink_broadcast (err -22)
[ 9.510000] cn: disagrees about version of symbol __alloc_skb
[ 9.510000] cn: Unknown symbol __alloc_skb (err -22)
[ 9.580000] cn: disagrees about version of symbol init_net
[ 9.580000] cn: Unknown symbol init_net (err -22)
[ 9.660000] cn: disagrees about version of symbol netlink_kernel_release
[ 9.660000] cn: Unknown symbol netlink_kernel_release (err -22)
[ 9.740000] cn: disagrees about version of symbol netlink_has_listeners
[ 9.740000] cn: Unknown symbol netlink_has_listeners (err -22)
[ ok [ 11.930000] random: nonblocking pool is initialized
[ 12.640000] can_dev: disagrees about version of symbol skb_put
[ 12.640000] can_dev: Unknown symbol skb_put (err -22)
[ 12.720000] can_dev: disagrees about version of symbol unregister_netdev
[ 12.720000] can_dev: Unknown symbol unregister_netdev (err -22)
[ 12.780000] can_dev: disagrees about version of symbol rtnl_link_register
[ 12.780000] can_dev: Unknown symbol rtnl_link_register (err -22)
done.
[ 12.820000] can_dev: disagrees about version of symbol netdev_warn
[ 12.830000] can_dev: Unknown symbol netdev_warn (err -22)
[ 12.920000] can_dev: disagrees about version of symbol netdev_err
[ 12.920000] can_dev: Unknown symbol netdev_err (err -22)
[ 12.990000] can_dev: disagrees about version of symbol alloc_netdev_mqs
[ 12.990000] can_dev: Unknown symbol alloc_netdev_mqs (err -22)
[ 13.050000] can_dev: disagrees about version of symbol kfree_skb
[ 13.050000] can_dev: Unknown symbol kfree_skb (err -22)
[ 13.130000] can_dev: disagrees about version of symbol rtnl_link_unregister
[ 13.130000] can_dev: Unknown symbol rtnl_link_unregister (err -22)
[ 13.190000] can_dev: disagrees about version of symbol nla_put
[ 13.190000] can_dev: Unknown symbol nla_put (err -22)
[ 13.260000] can_dev: disagrees about version of symbol register_netdev
[ 13.260000] can_dev: Unknown symbol register_netdev (err -22)
[ 13.340000] can_dev: disagrees about version of symbol free_netdev
[ 13.340000] can_dev: Unknown symbol free_netdev (err -22)
[ 13.400000] can_dev: disagrees about version of symbol netif_rx
[ 13.410000] can_dev: Unknown symbol netif_rx (err -22)
[ 13.470000] can_dev: disagrees about version of symbol __netdev_alloc_skb
[ 13.470000] can_dev: Unknown symbol _netdev_alloc_skb (err -22)
[ 13.480000] can_dev: disagrees about version of symbol netif_carrier_off
[ 13.490000] can_dev: Unknown symbol netif_carrier_off (err -22)
[ 13.610000] can_dev: disagrees about version of symbol skb_clone
[ 13.610000] can_dev: Unknown symbol skb_clone (err -22)
[ 13.620000] can_dev: disagrees about version of symbol netif_carrier_on
[ 13.630000] can_dev: Unknown symbol netif_carrier_on (err -22)
[ 13.660000] r8188eu: module is from the staging directory, the quality is unk nown, you have been warned.
[ 13.680000] smsc95xx: disagrees about version of symbol usbnet_set_msglevel
[ 13.690000] smsc95xx: Unknown symbol usbnet_set_msglevel (err -22)
[ 13.790000] smsc95xx: disagrees about version of symbol usbnet_write_cmd
[ 13.790000] smsc95xx: Unknown symbol usbnet_write_cmd (err -22)
[…] [ 13.840000] r8188eu: disagrees about version of symbol alloc_etherdev mqs
[ 13.840000] r8188eu: Unknown symbol alloc_etherdev_mqs (err -22)
[ 13.850000] smsc95xx: disagrees about version of symbol eth_mac_addr
[ 13.860000] smsc95xx: Unknown symbol eth_mac_addr (err -22)
[ 13.900000] r8188eu: disagrees about version of symbol skb_copy_bits
[ 13.900000] r8188eu: Unknown symbol skb_copy_bits (err -22)
[ 13.910000] smsc95xx: disagrees about version of symbol usbnet_change_mtu
[ 13.910000] smsc95xx: Unknown symbol usbnet_change_mtu (err -22)
[ 13.970000] r8188eu: disagrees about version of symbol skb_put
[ 13.970000] r8188eu: Unknown symbol skb_put (err -22)
[ 13.980000] smsc95xx: disagrees about version of symbol usbnet_write_cmd_asyn c
[ 13.980000] smsc95xx: Unknown symbol usbnet_write_cmd_async (err -22)
Waiting for /dev to be fully populated…[ 14.030000] r8188eu: disagrees about version of symbol __netif_schedule
[ 14.030000] r8188eu: Unknown symbol __netif_schedule (err -22)
[ 14.040000] smsc95xx: disagrees about version of symbol eth_validate_addr
[ 14.050000] smsc95xx: Unknown symbol eth_validate_addr (err -22)
[ 14.090000] r8188eu: disagrees about version of symbol unregister_netdev
[ 14.090000] r8188eu: Unknown symbol unregister_netdev (err -22)
[ 14.100000] smsc95xx: disagrees about version of symbol netdev_warn
[ 14.110000] smsc95xx: Unknown symbol netdev_warn (err -22)
[ 14.160000] r8188eu: disagrees about version of symbol skb_dequeue
[ 14.160000] r8188eu: Unknown symbol skb_dequeue (err -22)
[ 14.170000] smsc95xx: disagrees about version of symbol netdev_err
[ 14.170000] smsc95xx: Unknown symbol netdev_err (err -22)
[ 14.220000] r8188eu: disagrees about version of symbol dev_alloc_name
[ 14.220000] r8188eu: Unknown symbol dev_alloc_name (err -22)
[ 14.230000] smsc95xx: disagrees about version of symbol usbnet_get_msglevel
[ 14.240000] smsc95xx: Unknown symbol usbnet_get_msglevel (err -22)
[ 14.280000] r8188eu: disagrees about version of symbol unregister_netdevice_q ueue
[ 14.280000] r8188eu: Unknown symbol unregister_netdevice_queue (err -22)
[ 14.290000] smsc95xx: disagrees about version of symbol mii_check_media
[ 14.300000] smsc95xx: Unknown symbol mii_check_media (err -22)
[ 14.340000] r8188eu: disagrees about version of symbol wake_up_process
[ 14.340000] r8188eu: Unknown symbol wake_up_process (err -22)
[ 14.350000] smsc95xx: disagrees about version of symbol usbnet_open
[ 14.350000] smsc95xx: Unknown symbol usbnet_open (err -22)
[ 14.380000] r8188eu: disagrees about version of symbol eth_type_trans
[ 14.380000] r8188eu: Unknown symbol eth_type_trans (err -22)
[ 14.390000] smsc95xx: disagrees about version of symbol usbnet_skb_return
[ 14.400000] smsc95xx: Unknown symbol usbnet_skb_return (err -22)
[ 14.410000] r8188eu: disagrees about version of symbol netif_device_attach
[ 14.420000] r8188eu: Unknown symbol netif_device_attach (err -22)
[ 14.430000] smsc95xx: disagrees about version of symbol usbnet_tx_timeout
[ 14.430000] smsc95xx: Unknown symbol usbnet_tx_timeout (err -22)
[ 14.450000] smsc95xx: disagrees about version of symbol usbnet_read_cmd
[ 14.450000] smsc95xx: Unknown symbol usbnet_read_cmd (err -22)
[ 14.470000] r8188eu: disagrees about version of symbol skb_queue_tail
[ 14.470000] r8188eu: Unknown symbol skb_queue_tail (err -22)
[ 14.480000] smsc95xx: disagrees about version of symbol skb_copy_expand
[ 14.480000] smsc95xx: Unknown symbol skb_copy_expand (err -22)
[ 14.500000] r8188eu: disagrees about version of symbol dev_kfree_skb_any
[ 14.500000] r8188eu: Unknown symbol dev_kfree_skb_any (err -22)
[ 14.510000] smsc95xx: disagrees about version of symbol usbnet_get_settings
[ 14.520000] smsc95xx: Unknown symbol usbnet_get_settings (err -22)
[ 14.530000] r8188eu: disagrees about version of symbol init_net
[ 14.530000] r8188eu: Unknown symbol init_net (err -22)
[ 14.540000] smsc95xx: disagrees about version of symbol usbnet_write_cmd_nopm
[ 14.540000] smsc95xx: Unknown symbol usbnet_write_cmd_nopm (err -22)
[ 14.560000] r8188eu: disagrees about version of symbol skb_pull
[ 14.560000] r8188eu: Unknown symbol skb_pull (err -22)
[ 14.570000] smsc95xx: disagrees about version of symbol dev_kfree_skb_any
[ 14.570000] smsc95xx: Unknown symbol dev_kfree_skb_any (err -22)
[ 14.590000] r8188eu: disagrees about version of symbol skb_push
[ 14.590000] r8188eu: Unknown symbol skb_push (err -22)
[ 14.600000] smsc95xx: disagrees about version of symbol usbnet_get_link
[ 14.600000] smsc95xx: Unknown symbol usbnet_get_link (err -22)
[ 14.620000] r8188eu: disagrees about version of symbol wireless_send_event
[ 14.620000] r8188eu: Unknown symbol wireless_send_event (err -22)
[ 14.630000] smsc95xx: disagrees about version of symbol skb_pull
[ 14.640000] smsc95xx: Unknown symbol skb_pull (err -22)
[ 14.650000] r8188eu: disagrees about version of symbol register_netdev
[ 14.650000] r8188eu: Unknown symbol register_netdev (err -22)
[ 14.660000] smsc95xx: disagrees about version of symbol usbnet_suspend
[ 14.660000] smsc95xx: Unknown symbol usbnet_suspend (err -22)
[ 14.680000] r8188eu: disagrees about version of symbol free_netdev
[ 14.680000] r8188eu: Unknown symbol free_netdev (err -22)
[ 14.690000] smsc95xx: disagrees about version of symbol usbnet_start_xmit
[ 14.690000] smsc95xx: Unknown symbol usbnet_start_xmit (err -22)
[ 14.710000] r8188eu: disagrees about version of symbol skb_queue_purge
[ 14.710000] r8188eu: Unknown symbol skb_queue_purge (err -22)
[ 14.720000] smsc95xx: disagrees about version of symbol usbnet_read_cmd_nopm
[ 14.730000] smsc95xx: Unknown symbol usbnet_read_cmd_nopm (err -22)
[ 14.760000] r8188eu: disagrees about version of symbol __pskb_pull_tail
[ 14.760000] r8188eu: Unknown symbol __pskb_pull_tail (err -22)
[ 14.770000] smsc95xx: disagrees about version of symbol skb_push
[ 14.770000] smsc95xx: Unknown symbol skb_push (err -22)
[ 14.780000] r8188eu: disagrees about version of symbol netif_rx
[ 14.790000] r8188eu: Unknown symbol netif_rx (err -22)
[ 14.800000] smsc95xx: disagrees about version of symbol usbnet_get_drvinfo
[ 14.810000] smsc95xx: Unknown symbol usbnet_get_drvinfo (err -22)
[ 14.820000] r8188eu: disagrees about version of symbol __netdev_alloc_skb
[ 14.820000] r8188eu: Unknown symbol __netdev_alloc_skb (err -22)
[ 14.830000] smsc95xx: disagrees about version of symbol usbnet_get_endpoints
[ 14.840000] smsc95xx: Unknown symbol usbnet_get_endpoints (err -22)
[ 14.850000] r8188eu: disagrees about version of symbol skb_trim
[ 14.850000] r8188eu: Unknown symbol skb_trim (err -22)
[ 14.860000] smsc95xx: disagrees about version of symbol mii_nway_restart
[ 14.860000] smsc95xx: Unknown symbol mii_nway_restart (err -22)
[ 14.880000] r8188eu: disagrees about version of symbol netif_carrier_off
[ 14.880000] r8188eu: Unknown symbol netif_carrier_off (err -22)
[ 14.890000] smsc95xx: disagrees about version of symbol usbnet_nway_reset
[ 14.900000] smsc95xx: Unknown symbol usbnet_nway_reset (err -22)
[ 14.910000] r8188eu: disagrees about version of symbol skb_copy
[ 14.910000] r8188eu: Unknown symbol skb_copy (err -22)
[ 14.920000] smsc95xx: disagrees about version of symbol skb_trim
[ 14.920000] smsc95xx: Unknown symbol skb_trim (err -22)
[ 14.940000] r8188eu: disagrees about version of symbol skb_clone
[ 14.940000] r8188eu: Unknown symbol skb_clone (err -22)
[ 14.950000] smsc95xx: disagrees about version of symbol usbnet_stop
[ 14.950000] smsc95xx: Unknown symbol usbnet_stop (err -22)
[ 14.970000] r8188eu: disagrees about version of symbol dev_get_by_name
[ 14.970000] r8188eu: Unknown symbol dev_get_by_name (err -22)
[ 14.980000] smsc95xx: disagrees about version of symbol usbnet_defer_kevent
[ 14.990000] smsc95xx: Unknown symbol usbnet_defer_kevent (err -22)
[ 15.000000] r8188eu: disagrees about version of symbol netif_carrier_on
[ 15.000000] r8188eu: Unknown symbol netif_carrier_on (err -22)
[ 15.010000] smsc95xx: disagrees about version of symbol generic_mii_ioctl
[ 15.020000] smsc95xx: Unknown symbol generic_mii_ioctl (err -22)
[ 15.030000] r8188eu: disagrees about version of symbol find_vpid
[ 15.030000] r8188eu: Unknown symbol find_vpid (err -22)
[ 15.040000] smsc95xx: disagrees about version of symbol skb_clone
[ 15.040000] smsc95xx: Unknown symbol skb_clone (err -22)
[ 15.050000] r8188eu: disagrees about version of symbol register_netdevice
[ 15.060000] r8188eu: Unknown symbol register_netdevice (err -22)
[ 15.070000] smsc95xx: disagrees about version of symbol usbnet_disconnect
[ 15.080000] smsc95xx: Unknown symbol usbnet_disconnect (err -22)
[ 15.090000] smsc95xx: disagrees about version of symbol usbnet_set_settings
[ 15.100000] smsc95xx: Unknown symbol usbnet_set_settings (err -22)
[ 15.120000] smsc95xx: disagrees about version of symbol usbnet_probe
[ 15.130000] smsc95xx: Unknown symbol usbnet_probe (err -22)
[ 15.130000] smsc95xx: disagrees about version of symbol usbnet_resume
[ 15.140000] smsc95xx: Unknown symbol usbnet_resume (err -22)
[ 15.150000] smsc95xx: disagrees about version of symbol mii_ethtool_gset
[ 15.150000] smsc95xx: Unknown symbol mii_ethtool_gset (err -22)
[ 15.160000] smsc95xx: disagrees about version of symbol netdev_info
[ 15.170000] smsc95xx: Unknown symbol netdev_info (err -22)
done.
[ ok ] Activating swap…done.
[ 20.510000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[…] Checking root file system…fsck from util-linux 2.20.1
rootfs: clean, 24713/491520 files, 169717/1948416 blocks
done.
[ 21.520000] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ ok ] Cleaning up temporary files… /tmp.
[info] Loading kernel module sc16is7x2.
[ ok ] Activating lvm and md swap…done.
[…] Checking file systems…fsck from util-linux 2.20.1
done.
[ ok ] Mounting local filesystems…done.
[ ok ] Activating swapfile swap…done.
[ ok ] Setting kernel variables …done.
[…] Configuring network interfaces…SIOCSIFHWADDR: No such device
Cannot find device “eth0”
Failed to bring up eth0.
done.
[info] Setting console screen modes and fonts.
setterm: cannot (un)set powersave mode: Inappropriate ioctl for device
INIT: Entering runlevel: 2
[info] Using makefile-style concurrent boot in runlevel 2.
[…] Starting advanced IEEE 802.11 management: hostapdioctl(SIOCGIFINDEX): No such device
failed!
[ ok ] Starting DNS forwarder and DHCP server: dnsmasq.
[ ok ] Starting network daemon:: mosquitto.
[ ok ] Starting NTP server: ntpd.
Warning: Could not probe for any interfaces
[ ok ] Starting OpenBSD Secure Shell server: sshd.
[ ok ] Starting update local time using SIMCOM SIM900 integrated RTC: wb-gsm-rtc. date looks good, do nothing.
[ ok ] Starting MQTT driver for WB HomA for RFM69 ISM radio: wb-homa-rcd.
Starting httpd daemon: webfsd.
Password:
Last login: Mon Dec 22 15:21:59 UTC 2014 on ttyAMA0
root@wirenboard:~# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:176 errors:0 dropped:0 overruns:0 frame:0
TX packets:176 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:27335 (26.6 KiB) TX bytes:27335 (26.6 KiB)
root@wirenboard:~#
Как правильно установить ядро?
