апну темку
/mnt/data/.HA# wget -O homeassistant-supervised.deb https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
apt install ./homeassistant-supervised.deb
Reading package listReading package listReading package lists… Done
Building dependency Building dependency Building dependency Building dependency tree… 50Building dependency tree… 50Building dependency tree… 79Building dependency tree… Done
Reading state information… 0Reading state information… 0Reading state information… Done
Note, selecting ‘homeassistant-supervised’ instead of ‘./homeassistant-supervised.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
homeassistant-supervised : Depends: os-agent but it is not installable
Depends: systemd-resolved but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
победить не смог
