WB 5.8 запускается и через мин 5-7 зависает. Перестает работать доступ через веб и через ssh. Подключил консколь и вот что при загрузке
В консоли тоже управление пропадает. На команды не реагирует. Только ошибки выдает
[ 858.169356] INFO: task syslogd:611 blocked for more than 120 seconds.
[ 858.175890] Tainted: G C 4.9.22-wb2 #2
[ 858.181413] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 858.189344] syslogd D 0 611 1 0x00000000
[ 858.194940] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 858.202145] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 858.210033] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 858.218702] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 858.226924] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 858.234629] [] (__wait_on_bit) from [] (out_of_line_wait_on_bit+0x74/0x80)
[ 858.243403] [] (out_of_line_wait_on_bit) from [] (do_get_write_access+0x1f8/0x3d0)
[ 858.252905] [] (do_get_write_access) from [] (jbd2_journal_get_write_access+0x68/0x90)
[ 858.262711] [] (jbd2_journal_get_write_access) from [] (__ext4_journal_get_write_access+0x34/0x70)
[ 858.273550] [] (__ext4_journal_get_write_access) from [] (ext4_reserve_inode_write+0x60/0x90)
[ 858.283945] [] (ext4_reserve_inode_write) from [] (ext4_mark_inode_dirty+0x2c/0x164)
[ 858.293564] [] (ext4_mark_inode_dirty) from [] (ext4_dirty_inode+0x44/0x70)
[ 858.302414] [] (ext4_dirty_inode) from [] (__mark_inode_dirty+0x34/0x1cc)
[ 858.311125] [] (__mark_inode_dirty) from [] (generic_update_time+0x80/0x8c)
[ 858.319971] [] (generic_update_time) from [] (file_update_time+0xb4/0x10c)
[ 858.328637] [] (file_update_time) from [] (__generic_file_write_iter+0x8c/0x1f0)
[ 858.337923] [] (__generic_file_write_iter) from [] (ext4_file_write_iter+0xe0/0x374)
[ 858.347553] [] (ext4_file_write_iter) from [] (__vfs_write+0xbc/0x114)
[ 858.355955] [] (__vfs_write) from [] (vfs_write+0xa0/0x1b0)
[ 858.363401] [] (vfs_write) from [] (SyS_write+0x3c/0x90)
[ 858.370609] [] (SyS_write) from [] (ret_fast_syscall+0x0/0x38)
[ 858.378299] INFO: task wb-rules:4075 blocked for more than 120 seconds.
[ 858.385024] Tainted: G C 4.9.22-wb2 #2
[ 858.390522] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 858.398377] wb-rules D 0 4075 1 0x00000000
[ 858.404039] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 858.411234] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 858.419027] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 858.427772] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 858.436008] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 858.443715] [] (__wait_on_bit) from [] (wait_on_page_bit+0x90/0xa0)
[ 858.451856] [] (wait_on_page_bit) from [] (__filemap_fdatawait_range+0xe4/0x12c)
[ 858.461120] [] (__filemap_fdatawait_range) from [] (filemap_fdatawait_range+0x18/0x34)
[ 858.470904] [] (filemap_fdatawait_range) from [] (filemap_write_and_wait_range+0x54/0x74)
[ 858.480970] [] (filemap_write_and_wait_range) from [] (ext4_sync_file+0x84/0x2f4)
[ 858.490383] [] (ext4_sync_file) from [] (do_fsync+0x3c/0x64)
[ 858.497834] [] (do_fsync) from [] (ret_fast_syscall+0x0/0x38)
[ 858.505448] INFO: task kworker/0:2:4338 blocked for more than 120 seconds.
[ 858.512427] Tainted: G C 4.9.22-wb2 #2
[ 858.517846] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 858.525803] kworker/0:2 D 0 4338 2 0x00000000
[ 858.531471] Workqueue: events_freezable mmc_rescan
[ 858.536350] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 858.543554] [] (schedule) from [] (__mmc_claim_host+0x8c/0x190)
[ 858.551378] [] (__mmc_claim_host) from [] (mmc_detect+0x1c/0x70)
[ 858.559251] [] (mmc_detect) from [] (mmc_rescan+0x198/0x364)
[ 858.566712] [] (mmc_rescan) from [] (process_one_work+0x1f4/0x400)
[ 858.574797] [] (process_one_work) from [] (worker_thread+0x58/0x564)
[ 858.583030] [] (worker_thread) from [] (kthread+0xbc/0xdc)
[ 858.590390] [] (kthread) from [] (ret_from_fork+0x14/0x24)
[ 981.046429] INFO: task mmcqd/0:62 blocked for more than 120 seconds.
[ 981.052882] Tainted: G C 4.9.22-wb2 #2
[ 981.058418] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.066370] mmcqd/0 D 0 62 2 0x00000000
[ 981.071967] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.079172] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.087059] [] (schedule_timeout) from [] (wait_for_common+0x98/0x154)
[ 981.095389] [] (wait_for_common) from [] (mmc_wait_for_req_done+0x84/0x10c)
[ 981.104231] [] (mmc_wait_for_req_done) from [] (mmc_wait_for_cmd+0x58/0x7c)
[ 981.113085] [] (mmc_wait_for_cmd) from [] (get_card_status+0x58/0x70)
[ 981.121414] [] (get_card_status) from [] (card_busy_detect+0x40/0x114)
[ 981.129880] [] (card_busy_detect) from [] (mmc_blk_err_check+0xcc/0x560)
[ 981.138453] [] (mmc_blk_err_check) from [] (mmc_start_req+0xec/0x434)
[ 981.146776] [] (mmc_start_req) from [] (mmc_blk_issue_rw_rq+0xa4/0xa54)
[ 981.155185] [] (mmc_blk_issue_rw_rq) from [] (mmc_blk_issue_rq+0x168/0x560)
[ 981.164016] [] (mmc_blk_issue_rq) from [] (mmc_queue_thread+0xd4/0x184)
[ 981.172502] [] (mmc_queue_thread) from [] (kthread+0xbc/0xdc)
[ 981.180125] [] (kthread) from [] (ret_from_fork+0x14/0x24)
[ 981.187450] INFO: task jbd2/mmcblk0p2-:69 blocked for more than 120 seconds.
[ 981.194522] Tainted: G C 4.9.22-wb2 #2
[ 981.200001] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.207902] jbd2/mmcblk0p2- D 0 69 2 0x00000000
[ 981.213481] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.220666] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.228526] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 981.237266] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 981.245405] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 981.253094] [] (__wait_on_bit) from [] (out_of_line_wait_on_bit+0x74/0x80)
[ 981.261835] [] (out_of_line_wait_on_bit) from [] (jbd2_journal_commit_transaction+0xc40/0x140c)
[ 981.272414] [] (jbd2_journal_commit_transaction) from [] (kjournald2+0xac/0x220)
[ 981.281680] [] (kjournald2) from [] (kthread+0xbc/0xdc)
[ 981.288758] [] (kthread) from [] (ret_from_fork+0x14/0x24)
[ 981.296021] INFO: task mosquitto:460 blocked for more than 120 seconds.
[ 981.302727] Tainted: G C 4.9.22-wb2 #2
[ 981.308199] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.316050] mosquitto D 0 460 1 0x00000000
[ 981.321696] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.328877] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.336753] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 981.345417] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 981.353629] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 981.361323] [] (__wait_on_bit) from [] (out_of_line_wait_on_bit+0x74/0x80)
[ 981.370077] [] (out_of_line_wait_on_bit) from [] (__block_write_begin_int+0x5fc/0x7b4)
[ 981.379870] [] (__block_write_begin_int) from [] (__block_write_begin+0x24/0x2c)
[ 981.389121] [] (__block_write_begin) from [] (ext4_da_write_begin+0x154/0x364)
[ 981.398207] [] (ext4_da_write_begin) from [] (generic_perform_write+0xbc/0x1b0)
[ 981.407381] [] (generic_perform_write) from [] (__generic_file_write_iter+0x100/0x1f0)
[ 981.417181] [] (__generic_file_write_iter) from [] (ext4_file_write_iter+0xe0/0x374)
[ 981.426822] [] (ext4_file_write_iter) from [] (__vfs_write+0xbc/0x114)
[ 981.435188] [] (__vfs_write) from [] (vfs_write+0xa0/0x1b0)
[ 981.442633] [] (vfs_write) from [] (SyS_write+0x3c/0x90)
[ 981.449817] [] (SyS_write) from [] (ret_fast_syscall+0x0/0x38)
[ 981.457490] INFO: task syslogd:611 blocked for more than 120 seconds.
[ 981.463956] Tainted: G C 4.9.22-wb2 #2
[ 981.469435] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.477349] syslogd D 0 611 1 0x00000000
[ 981.482927] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.490121] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.497983] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 981.506723] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 981.514860] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 981.522551] [] (__wait_on_bit) from [] (out_of_line_wait_on_bit+0x74/0x80)
[ 981.531310] [] (out_of_line_wait_on_bit) from [] (do_get_write_access+0x1f8/0x3d0)
[ 981.540759] [] (do_get_write_access) from [] (jbd2_journal_get_write_access+0x68/0x90)
[ 981.550546] [] (jbd2_journal_get_write_access) from [] (__ext4_journal_get_write_access+0x34/0x70)
[ 981.561369] [] (__ext4_journal_get_write_access) from [] (ext4_reserve_inode_write+0x60/0x90)
[ 981.571750] [] (ext4_reserve_inode_write) from [] (ext4_mark_inode_dirty+0x2c/0x164)
[ 981.581350] [] (ext4_mark_inode_dirty) from [] (ext4_dirty_inode+0x44/0x70)
[ 981.590203] [] (ext4_dirty_inode) from [] (__mark_inode_dirty+0x34/0x1cc)
[ 981.598854] [] (__mark_inode_dirty) from [] (generic_update_time+0x80/0x8c)
[ 981.607683] [] (generic_update_time) from [] (file_update_time+0xb4/0x10c)
[ 981.616423] [] (file_update_time) from [] (__generic_file_write_iter+0x8c/0x1f0)
[ 981.625619] [] (__generic_file_write_iter) from [] (ext4_file_write_iter+0xe0/0x374)
[ 981.635232] [] (ext4_file_write_iter) from [] (__vfs_write+0xbc/0x114)
[ 981.643622] [] (__vfs_write) from [] (vfs_write+0xa0/0x1b0)
[ 981.651061] [] (vfs_write) from [] (SyS_write+0x3c/0x90)
[ 981.658221] [] (SyS_write) from [] (ret_fast_syscall+0x0/0x38)
[ 981.665834] INFO: task kworker/u2:2:1622 blocked for more than 120 seconds.
[ 981.672888] Tainted: G C 4.9.22-wb2 #2
[ 981.678369] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.686287] kworker/u2:2 D 0 1622 2 0x00000000
[ 981.691840] Workqueue: writeback wb_workfn (flush-179:0)
[ 981.697318] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.704419] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.712299] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 981.721046] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 981.729245] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 981.736945] [] (__wait_on_bit) from [] (out_of_line_wait_on_bit+0x74/0x80)
[ 981.745622] [] (out_of_line_wait_on_bit) from [] (do_get_write_access+0x1f8/0x3d0)
[ 981.755072] [] (do_get_write_access) from [] (jbd2_journal_get_write_access+0x68/0x90)
[ 981.764888] [] (jbd2_journal_get_write_access) from [] (__ext4_journal_get_write_access+0x34/0x70)
[ 981.775726] [] (__ext4_journal_get_write_access) from [] (ext4_mb_mark_diskspace_used+0x64/0x374)
[ 981.786467] [] (ext4_mb_mark_diskspace_used) from [] (ext4_mb_new_blocks+0x290/0x86c)
[ 981.796086] [] (ext4_mb_new_blocks) from [] (ext4_ext_map_blocks+0x904/0x1004)
[ 981.805164] [] (ext4_ext_map_blocks) from [] (ext4_map_blocks+0x164/0x5d0)
[ 981.813899] [] (ext4_map_blocks) from [] (mpage_map_and_submit_extent+0xa8/0x6f0)
[ 981.823243] [] (mpage_map_and_submit_extent) from [] (ext4_writepages+0x4b8/0x608)
[ 981.832687] [] (ext4_writepages) from [] (__writeback_single_inode+0x28/0x178)
[ 981.841780] [] (__writeback_single_inode) from [] (writeback_sb_inodes+0x174/0x368)
[ 981.851304] [] (writeback_sb_inodes) from [] (__writeback_inodes_wb+0x74/0xb0)
[ 981.860388] [] (__writeback_inodes_wb) from [] (wb_writeback+0x180/0x190)
[ 981.869017] [] (wb_writeback) from [] (wb_workfn+0x1d8/0x340)
[ 981.876634] [] (wb_workfn) from [] (process_one_work+0x1f4/0x400)
[ 981.884520] [] (process_one_work) from [] (worker_thread+0x58/0x564)
[ 981.892741] [] (worker_thread) from [] (kthread+0xbc/0xdc)
[ 981.900095] [] (kthread) from [] (ret_from_fork+0x14/0x24)
[ 981.907436] INFO: task wb-rules:4075 blocked for more than 120 seconds.
[ 981.914072] Tainted: G C 4.9.22-wb2 #2
[ 981.919556] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 981.927470] wb-rules D 0 4075 1 0x00000000
[ 981.933047] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 981.940233] [] (schedule) from [] (schedule_timeout+0x220/0x31c)
[ 981.948091] [] (schedule_timeout) from [] (io_schedule_timeout+0xb4/0x138)
[ 981.956831] [] (io_schedule_timeout) from [] (bit_wait_io+0x10/0x58)
[ 981.964970] [] (bit_wait_io) from [] (__wait_on_bit+0x84/0xbc)
[ 981.972661] [] (__wait_on_bit) from [] (wait_on_page_bit+0x90/0xa0)
[ 981.980788] [] (wait_on_page_bit) from [] (__filemap_fdatawait_range+0xe4/0x12c)
[ 981.990041] [] (__filemap_fdatawait_range) from [] (filemap_fdatawait_range+0x18/0x34)
[ 981.999819] [] (filemap_fdatawait_range) from [] (filemap_write_and_wait_range+0x54/0x74)
[ 982.009871] [] (filemap_write_and_wait_range) from [] (ext4_sync_file+0x84/0x2f4)
[ 982.019210] [] (ext4_sync_file) from [] (do_fsync+0x3c/0x64)
[ 982.026741] [] (do_fsync) from [] (ret_fast_syscall+0x0/0x38)
[ 982.034266] INFO: task kworker/0:2:4338 blocked for more than 120 seconds.
[ 982.041234] Tainted: G C 4.9.22-wb2 #2
[ 982.046706] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 982.054555] kworker/0:2 D 0 4338 2 0x00000000
[ 982.060188] Workqueue: events_freezable mmc_rescan
[ 982.065051] [] (__schedule) from [] (schedule+0x48/0xa0)
[ 982.072236] [] (schedule) from [] (__mmc_claim_host+0x8c/0x190)
[ 982.080029] [] (__mmc_claim_host) from [] (mmc_detect+0x1c/0x70)
[ 982.087890] [] (mmc_detect) from [] (mmc_rescan+0x198/0x364)
[ 982.095345] [] (mmc_rescan) from [] (process_one_work+0x1f4/0x400)
[ 982.103390] [] (process_one_work) from [] (worker_thread+0x58/0x564)
[ 982.111610] [] (worker_thread) from [] (kthread+0xbc/0xdc)
[ 982.118948] [] (kthread) from [] (ret_from_fork+0x14/0x24)
Обновления через веб прошивки не проходят.
Что делать?
