- Вывод команд:
root@wirenboard-ASYV6PGG:~#
root@wirenboard-ASYV6PGG:~# wb-gsm off
root@wirenboard-ASYV6PGG:~# wb-gsm on
- вывод dmesg:
[ 6.930463] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 6.986604] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.993556] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.000859] usb usb1: Product: EHCI Host Controller
[ 7.005748] usb usb1: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 7.011536] usb usb1: SerialNumber: ci_hdrc.0
[ 7.258580] hub 1-0:1.0: USB hub found
[ 7.307098] hub 1-0:1.0: 1 port detected
[ 7.392722] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 7.446450] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 7.550416] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 7.603288] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.610106] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.617477] usb usb2: Product: EHCI Host Controller
[ 7.622417] usb usb2: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
[ 7.628193] usb usb2: SerialNumber: ci_hdrc.1
[ 7.710416] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 7.921602] hub 2-0:1.0: USB hub found
[ 7.960395] usb 1-1: device descriptor read/64, error -71
[ 8.000489] hub 2-0:1.0: 1 port detected
[ 8.310418] usb 1-1: device descriptor read/64, error -71
[ 8.400468] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 8.440184] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
[ 8.601465] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 8.608223] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.623050] hub 2-1:1.0: USB hub found
[ 8.628371] hub 2-1:1.0: 4 ports detected
[ 8.840358] usb 1-1: new full-speed USB device number 4 using ci_hdrc
[ 8.961753] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 9.059436] usb 1-1: New USB device found, idVendor=0658, idProduct=0200
[ 9.066301] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 9.073507] usb 1-1: SerialNumber: 12345678-9012-3456-7890-123456789012
[ 9.108324] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 9.131951] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 9.138883] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.146347] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 9.151358] usb 2-1.1: Manufacturer: Realtek
[ 9.155638] usb 2-1.1: SerialNumber: 00e04c000001
[ 9.191084] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 9.247225] usbcore: registered new interface driver cdc_acm
[ 9.253046] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 9.377015] Bluetooth: Core ver 2.22
[ 9.392406] NET: Registered protocol family 31
[ 9.399614] Bluetooth: HCI device and connection manager initialized
[ 9.463590] Bluetooth: HCI socket layer initialized
[ 9.469130] Bluetooth: L2CAP socket layer initialized
[ 9.476386] Bluetooth: SCO socket layer initialized
[ 9.534878] usbcore: registered new interface driver btusb
[ 9.567773] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 9.576579] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 9.588194] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 9.597824] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 9.604399] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 9.616783] Bluetooth: hci0: rom_version status=0 version=1
[ 9.622610] Bluetooth: cfg_sz 0, total size 22496
[ 9.980716] 8723bu: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.026726] RTL871X: module init start
[ 10.030667] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 10.037639] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 10.262268] RTL871X: rtw_ndev_init(wlan0)
[ 10.279201] RTL871X: rtw_ndev_init(wlan1)
[ 10.295396] usbcore: registered new interface driver rtl8723bu
[ 10.301395] RTL871X: module init ret=0
[ 11.889480] RTL871X: RTW_ADAPTIVITY_EN_
[ 11.895032] AUTO, chplan:0x20, Regulation:3,3
[ 11.899403] RTL871X: RTW_ADAPTIVITY_MODE_
[ 11.903310] NORMAL
[ 11.949039] cgroup: new mount options do not match the existing superblock, will be ignored
[ 12.727726] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.733183] Bluetooth: BNEP filters: protocol multicast
[ 12.818766] Bluetooth: BNEP socket layer initialized
[ 13.855410] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 15.931622] RTL871X: nolinked power save enter
[ 19.616072] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 218, base_baud = 5000000) is a IMX
[ 24.042857] random: crng init done
[ 41.999428] RTL871X: RTW_ADAPTIVITY_EN_
[ 42.003280] AUTO, chplan:0x20, Regulation:3,3
[ 42.007654] RTL871X: RTW_ADAPTIVITY_MODE_
[ 42.011581] NORMAL
[ 44.670759] RTL871X: nolinked power save leave
[ 45.160688] SMSC LAN8710/LAN8720 2188000.ethernet:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ 45.277618] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 45.491693] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 45.701095] Micrel KSZ8081 or KSZ8091 2188000.ethernet:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet:03, irq=-1)
[ 45.856321] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 46.543632] RTL871X: assoc success
[ 46.547318] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 46.601945] RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
[ 55.986008] RTL871X: rtw_set_802_11_connect(wlan1) fw_state=0x00000008
[ 56.456161] RTL871X: start auth
[ 56.460854] RTL871X: auth success, start assoc
[ 56.476606] RTL871X: rtw_cfg80211_indicate_connect(wlan1) BSS not found !!
[ 56.483642] RTL871X: assoc success
[ 56.487665] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 56.508446] RTL871X: send eapol packet
[ 56.551456] RTL871X: send eapol packet
[ 56.555714] RTL871X: set pairwise key camid:4, addr:54:a6:19:a9:96:bc, kid:0, type:AES
[ 56.586950] RTL871X: set group key camid:5, addr:54:a6:19:a9:96:bc, kid:1, type:TKIP
[ 646.513821] RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
[ 1246.501897] RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
[ 1846.495767] RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
[ 2446.493581] RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
[ 3046.491017] RTL871X: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
[ 3381.400691] usb 2-1.2: new high-speed USB device number 4 using ci_hdrc
[ 3381.552328] usb 2-1.2: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[ 3381.563016] usb 2-1.2: New USB device found, idVendor=058b, idProduct=0041
[ 3381.569967] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3430.509098] usb 2-1.2: USB disconnect, device number 4
[ 3430.829939] usb 2-1.2: new high-speed USB device number 5 using ci_hdrc
[ 3435.959695] usb 2-1.2: device descriptor read/64, error -110
[ 3451.319537] usb 2-1.2: device descriptor read/64, error -110
[ 3451.539606] usb 2-1.2: new high-speed USB device number 6 using ci_hdrc
